Resolve Genesys Cloud Routing Queue State Lock Drift in Terraform
  • A Python script that inspects the current state of a Genesys Cloud routing queue via the REST API and compares it against the Terraform state file to identify the specific configuration drift causing the state lock.
  • This uses the Genesys Cloud CX REST API (/api/v2/routing/queues/{queueId}) and the hcl2 library to parse Terraform state.
  • The programming language covered is Python 3.10+.
  • OAuth Client Type: Service Account with the following scopes: routing:queue:read, routing:queue:write (if you intend to fix the drift automatically later, though this script is read-only).
  • API Version: Genesys Cloud CX API v2.
  • Language/Runtime: Python 3.10 or higher.
  • External Dependencies:
    • requests: For HTTP calls.
    • hcl2: For parsing Terraform HCL/state files if needed, though we will primarily parse the JSON state file directly using the built-in json module for reliability.
    • python-dotenv: For managing environment variables.
Install dependencies:
pip install requests python-dotenv
Genesys Cloud uses OAuth 2.0 for authentication. For automation scripts, the Client Credentials flow is the standard. You must store your Client ID and Client Secret securely.
Create a .env file in your project directory:
GENESYS_CLOUD_REGION=us-east-1
GENESYS_CLOUD_CLIENT_ID=your_client_id_here
GENESYS_CLOUD_CLIENT_SECRET=your_client_secret_here
The following code block demonstrates how to retrieve an access token and handle the initial authentication error.
import os
import requests
load_dotenv()
def get_access_token() -> str:
    Retrieves an OAuth access token from Genesys Cloud.
    region = os.getenv("GENESYS_CLOUD_REGION")
    client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
    client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
    if not all([region, client_id, client_secret]):
        raise ValueError("Missing required environment variables: REGION, CLIENT_ID, CLIENT_SECRET")
    # Construct the base URL based on region
    if region == "us-east-1":
        base_url = "https://api.mypurecloud.com"
    elif region == "eu-west-1":
        base_url = "https://api.eu.mypurecloud.com"
    elif region == "au-southeast-1":
        base_url = "https://api.ap-southeast-1.mypurecloud.com"
    else:
        base_url = f"https://api.{region}.mypurecloud.com"
    token_url = f"{base_url}/oauth/token"
    headers = {
    data = {
        "client_id": client_id,
        "client_secret": client_secret
    response = requests.post(token_url, headers=headers, data=data)
    if response.status_code != 200:
        raise Exception(f"Failed to authenticate. Status: {response.status_code}, Response: {response.text}")
    return response.json().get("access_token")
# Example usage
    token = get_access_token()
    print("Authentication successful.")
    print(f"Authentication failed: {e}")
Step 1: Extract Queue ID and Desired State from Terraform Plan
When Terraform reports a state lock or drift on genesyscloud_routing_queue, it is often because the remote state file contains a reference to a resource that has been modified outside of Terraform, or the local configuration does not match the remote state.
First, we need to identify the specific Queue ID involved. We will parse the terraform.tfstate file to find the resource.
import json
import sys
def find_queue_id_in_state(state_file_path: str, resource_address: str) -> str | None:
    Parses the Terraform state file to find the ID of a specific routing queue.
    Args:
        state_file_path: Path to terraform.tfstate
        resource_address: The Terraform resource address, e.g., 'genesyscloud_routing_queue.my_queue'
    Returns:
        The Genesys Cloud Queue ID or None if not found.
        with open(state_file_path, 'r') as f:
            state = json.load(f)
    except FileNotFoundError:
        raise FileNotFoundError(f"State file not found at {state_file_path}")
    except json.JSONDecodeError:
        raise ValueError(f"Invalid JSON in state file: {state_file_path}")
    resources = state.get("resources", [])
    for resource in resources:
        if resource.get("address") == resource_address:
            instances = resource.get("instances", [])
            if instances:
                # Get the first instance (usually there is only one)
                instance = instances[0]
                attributes = instance.get("attributes", {})
                queue_id = attributes.get("id")
                if queue_id:
                    return queue_id
    return None
# Example usage
# queue_id = find_queue_id_in_state("terraform.tfstate", "genesyscloud_routing_queue.support_queue")
# if not queue_id:
#     print("Queue not found in state.")
#     sys.exit(1)
Step 2: Fetch Actual Queue Configuration from Genesys Cloud API
Now that we have the Queue ID, we must retrieve the actual current configuration from Genesys Cloud. The /api/v2/routing/queues/{queueId} endpoint returns the full object.
Required Scope: routing:queue:read
import requests
from typing import Dict, Any
def get_queue_from_api(queue_id: str, access_token: str) -> Dict[str, Any]:
    Fetches the current routing queue configuration from Genesys Cloud.
    Args:
        queue_id: The Genesys Cloud Queue ID.
        access_token: The OAuth access token.
    Returns:
        Dictionary containing the queue details.
    else:
    endpoint = f"{base_url}/api/v2/routing/queues/{queue_id}"
    headers = {
        "Authorization": f"Bearer {access_token}",
    response = requests.get(endpoint, headers=headers)
    if response.status_code == 404:
        raise Exception(f"Queue with ID {queue_id} not found in Genesys Cloud. It may have been deleted manually.")
    elif response.status_code == 403:
        raise Exception("Access denied. Ensure the OAuth token has 'routing:queue:read' scope.")
    elif response.status_code != 200:
        raise Exception(f"API Error {response.status_code}: {response.text}")
Step 3: Compare API Response with Terraform State Attributes
Drift usually occurs in specific mutable fields such as name, description, wrap_up_policy, or outbound_disabled. The Terraform provider stores these in the state file under attributes.
We will write a comparison function that highlights differences between the API response and the Terraform state attributes.
from typing import List, Tuple
def compare_queue_state(api_queue: Dict[str, Any], state_attributes: Dict[str, Any]) -> List[Tuple[str, Any, Any]]:
    Compares the API response with the Terraform state attributes to identify drift.
    Args:
        api_queue: The queue object from the Genesys Cloud API.
        state_attributes: The attributes dictionary from the Terraform state file.
    Returns:
        A list of tuples: (field_name, api_value, state_value)
    differences = []
    # Define key fields that commonly cause drift
    key_fields = {
        "name": "name",
        "description": "description",
        "outbound_disabled": "outbound_disabled",
        "wrap_up_policy": "wrap_up_policy",
        "status": "status",
        "type": "type",
        "skills": "skills",
        "language_required": "language_required",
        "media_type": "media_type"
    for tf_key, api_key in key_fields.items():
        api_value = api_queue.get(api_key)
        state_value = state_attributes.get(tf_key)
        # Handle None vs empty string cases common in Terraform state
        if api_value is None and state_value == "":
        if api_value == "" and state_value is None:
        if api_value != state_value:
            differences.append((tf_key, api_value, state_value))
    return differences
def get_state_attributes(state_file_path: str, resource_address: str) -> Dict[str, Any]:
    Helper to extract the attributes dict from the state file for a specific resource.
            if instances:
                return instances[0].get("attributes", {})
    return {}
This script combines all the steps above. It authenticates, reads the state file, fetches the live data, and reports the drift.
import os
import json
import sys
import requests
from typing import Dict, Any, List, Tuple
load_dotenv()
    else:
    data = {
        raise Exception(f"Authentication failed: {response.text}")
def find_queue_id_and_attributes(state_file_path: str, resource_address: str) -> Tuple[str, Dict[str, Any]]:
    for resource in state.get("resources", []):
            if instances:
                queue_id = instance.get("attributes", {}).get("id")
                if queue_id:
                    return queue_id, attributes
    raise ValueError(f"Resource {resource_address} not found in state file.")
    else:
    headers = {
        raise Exception(f"Queue {queue_id} not found in Genesys Cloud.")
    differences = []
    key_fields = {
        "name": "name",
        "status": "status",
        "type": "type",
    return differences
def main():
    # Configuration
    STATE_FILE = "terraform.tfstate"
    RESOURCE_ADDRESS = "genesyscloud_routing_queue.support_queue"
        print("1. Authenticating with Genesys Cloud...")
        print("   Authentication successful.")
        print("2. Reading Terraform State...")
        queue_id, state_attrs = find_queue_id_and_attributes(STATE_FILE, RESOURCE_ADDRESS)
        print(f"   Found Queue ID: {queue_id}")
        print("3. Fetching current queue configuration from API...")
        api_queue = get_queue_from_api(queue_id, token)
        print("   API fetch successful.")
        print("4. Comparing State vs. API...")
        diffs = compare_queue_state(api_queue, state_attrs)
        if not diffs:
            print("   No drift detected. The state matches the API.")
            print("   Note: If Terraform still reports a lock, check for running plans or manual state locks.")
        else:
            print("   DRIFT DETECTED!")
            print("   Field | API Value | State Value")
            print("   --- | --- | ---")
            for field, api_val, state_val in diffs:
                print(f"   {field} | {api_val} | {state_val}")
            print("\n   Recommendation:")
            print("   1. If the API value is correct, run 'terraform apply' to update the state.")
            print("   2. If the state value is correct, update the Genesys Cloud queue via API or UI to match the state.")
            print("   3. If the queue was deleted manually, run 'terraform state rm genesyscloud_routing_queue.support_queue'")
        print(f"Error: {e}", file=sys.stderr)
        sys.exit(1)
    main()
Error: 403 Forbidden on /api/v2/routing/queues/{queueId}
  • Cause: The OAuth token does not have the routing:queue:read scope, or the Service Account does not have the necessary role permissions in Genesys Cloud.
  • Fix:
    1. Verify the Client ID/Secret in your .env file corresponds to a Service Account with the Routing Admin or Routing Manager role.
    2. Ensure the OAuth client configuration in Genesys Cloud includes the routing:queue:read scope.
Error: Resource Not Found in State File
  • Cause: The RESOURCE_ADDRESS variable in the script does not exactly match the address in terraform.tfstate.
  • Fix:
    1. Open terraform.tfstate in a text editor.
    2. Search for "address" to find the exact string (e.g., module.routing.genesyscloud_routing_queue.main).
    3. Update the RESOURCE_ADDRESS variable in the script to match exactly.
Error: Queue ID Not Found in Genesys Cloud (404)
  • Cause: The queue was deleted manually in the Genesys Cloud UI, but Terraform state still references it.
  • Fix:
    1. Confirm the queue is deleted in the Genesys Cloud UI.
    2. Remove the resource from the Terraform state:
    3. Run terraform plan again to regenerate the resource if needed.
Error: State Lock Still Persists After Drift Resolution
  • Cause: Terraform uses DynamoDB (or S3 with a lock file) to manage state locks. If a previous plan crashed, the lock may remain.
  • Fix:
    1. Check the lock ID:
      terraform force-unlock <LOCK_ID>
    2. Find the LOCK_ID by checking the DynamoDB table directly or looking at the error message output from the failed plan.
    3. Only use force-unlock if you are certain no other plan is running.
