Resolve Genesys Cloud Routing Queue State Lock and Drift in Terraform
  • A Python script that identifies orphaned Genesys Cloud API state locks and clears them to resolve Terraform plan drift.
  • A Terraform configuration pattern that prevents future state lock conflicts on genesyscloud_routing_queue resources.
  • The tutorial covers Python for API interaction and HCL for Terraform configuration.
  • OAuth Client: Genesys Cloud Service Account (Client Credentials Grant).
  • Required Scopes: admin:queue:read, admin:queue:write, platform:user:read.
  • Terraform Provider: genesyscloud provider version 1.100.0 or later.
  • Language/Runtime: Python 3.9+ with requests library.
  • External Dependencies: pip install requests python-dotenv.
Genesys Cloud API authentication uses OAuth 2.0 Client Credentials flow. You must obtain an access token before making any API calls. The token is valid for one hour.
Create a .env file in your project root:
GENESYS_CLOUD_REGION=us-east-1
GENESYS_CLOUD_CLIENT_ID=your-client-id
GENESYS_CLOUD_CLIENT_SECRET=your-client-secret
The following Python code retrieves the token. This logic is reused in the debugging script.
import requests
import os
load_dotenv()
def get_access_token() -> str:
    Retrieves a Genesys Cloud OAuth2 access token using Client Credentials flow.
    region = os.getenv("GENESYS_CLOUD_REGION", "us-east-1")
    client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
    client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
        raise ValueError("Missing GENESYS_CLOUD_CLIENT_ID or GENESYS_CLOUD_CLIENT_SECRET")
    # Construct the correct login URL based on region
    if region == "us-east-1" or region == "us-east-2":
        login_url = "https://login.us.genesyscloud.com/oauth/token"
    elif region == "eu-west-1":
        login_url = "https://login.eu.genesyscloud.com/oauth/token"
    elif region == "ap-southeast-2":
        login_url = "https://login.ap.genesyscloud.com/oauth/token"
    else:
        raise ValueError(f"Unsupported region: {region}")
    headers = {
    data = {
        "client_id": client_id,
        "client_secret": client_secret
    response = requests.post(login_url, headers=headers, data=data)
    if response.status_code != 200:
        raise Exception(f"Authentication failed: {response.status_code} - {response.text}")
    token_data = response.json()
    return token_data["access_token"]
Step 1: Identify the Drift Source
When terraform plan shows drift on genesyscloud_routing_queue accompanied by a state lock error, the issue is rarely a simple configuration mismatch. It is usually one of two scenarios:
  1. Stale State Lock: A previous Terraform process crashed, leaving a lock file in the remote backend (S3, Azure Blob, etc.). The API call to update the queue fails because the resource is locked at the platform level or the Terraform state file is locked.
  2. API-Driven Orphaned Data: The queue exists in Genesys Cloud but was modified outside of Terraform (via API or UI), causing the Terraform state to diverge. The ā€œlockā€ error might be a secondary symptom of a 409 Conflict returned by the Genesys API when Terraform tries to reconcile the state.
First, verify if the resource exists in Genesys Cloud and check its current state. We will use the Genesys Cloud API to fetch the queue details by name.
Endpoint: GET /api/v2/routing/queues
Scope: admin:queue:read
def get_queue_by_name(token: str, queue_name: str) -> dict | None:
    Searches for a routing queue by name in Genesys Cloud.
        base_url = "https://api.us.genesyscloud.com"
        base_url = "https://api.eu.genesyscloud.com"
        base_url = "https://api.ap.genesyscloud.com"
    else:
    headers = {
    # Genesys Cloud queues are paginated. We fetch the first page.
    # For production, implement pagination loop.
    params = {
        "name": queue_name,
        "pageSize": 25
    response = requests.get(
        f"{base_url}/api/v2/routing/queues",
        headers=headers,
        params=params
        raise Exception("Invalid or expired token")
    if response.status_code == 403:
        raise Exception("Insufficient permissions. Check scopes.")
        raise Exception(f"API Error: {response.status_code} - {response.text}")
    entities = data.get("entities", [])
    for queue in entities:
        if queue["name"] == queue_name:
            return queue
    return None
Step 2: Detect and Clear State Locks
If the queue exists in Genesys Cloud but Terraform reports a lock issue, you must determine if the lock is in the Terraform backend or if the Genesys Cloud resource is in a transitional state.
Terraform state locks are managed by the backend (e.g., AWS S3 with DynamoDB). You cannot clear an S3 state lock via the Genesys Cloud API. You must clear it via the backend provider CLI.
However, if the error is 409 Conflict from the Genesys API during terraform apply, it often means the resource is being modified by another process. Genesys Cloud does not have a public ā€œunlock resourceā€ API endpoint for queues. The lock is internal to the write operation.
To resolve drift caused by external modifications, you must force Terraform to accept the remote state as the source of truth. This is done using terraform refresh or by importing the resource.
First, let us write a script to compare the Terraform state (if available locally) with the live API state. Since we cannot easily parse .tfstate in Python without complex JSON parsing, we will focus on the API side: ensuring the queue is in a stable state.
Critical Check: Verify if the queue is associated with active conversations. You cannot delete or heavily modify a queue with active conversations.
Endpoint: GET /api/v2/analytics/conversations/details/query
Scope: analytics:conversation:read
def check_active_conversations(token: str, queue_id: str) -> bool:
    Checks if there are any active conversations in the queue.
    Returns True if conversations are active, False otherwise.
    else:
    headers = {
    # Query for active conversations in the last 5 minutes
    body = {
        "size": 1,  # We only need to know if count > 0
        "query": f'routing.queue.id == "{queue_id}" AND status == "active"',
        "intervalStart": "2023-01-01T00:00:00Z",  # Placeholder, analytics requires valid intervals
        "intervalEnd": "2099-01-01T00:00:00Z"
    # Note: Analytics API requires valid time intervals.
    # For a quick check, we can use the Routing API to check waiters.
    # Better approach: Check Routing Queue Waiters
    waiter_response = requests.get(
        f"{base_url}/api/v2/routing/queues/{queue_id}/waiters",
        headers=headers
    if waiter_response.status_code == 200:
        waiters = waiter_response.json().get("entities", [])
        if len(waiters) > 0:
            return True
    return False
Step 3: Resolve Drift via Import or State Replacement
If the queue exists in Genesys Cloud but Terraform believes it does not (or has different attributes), and you cannot apply due to lock errors, you must reconcile the state.
Scenario A: Terraform State Lock (Backend Issue)
If the error is Error acquiring the state lock, this is not a Genesys API issue. It is an infrastructure issue.
  1. Verify no other terraform apply is running.
  2. Run terraform force-unlock <LOCK_ID> in the CLI.
  3. The Lock ID is found in the error message.
Scenario B: API 409 Conflict / Data Drift
If the error is from the Genesys API (409), the resource is locked by an ongoing write.
  1. Wait 1-2 minutes.
  2. Re-run terraform plan.
Scenario C: State Mismatch (Drift)
If the queue configuration in Genesys Cloud differs from main.tf, and you want to keep the Genesys Cloud configuration:
  1. Run terraform refresh.
  2. If that fails, remove the resource from state and re-import it.
# Remove the resource from Terraform state
terraform state rm genesyscloud_routing_queue.my_queue
# Re-import the resource using the ID found via the API
terraform import genesyscloud_routing_queue.my_queue <queue_id>
To automate the retrieval of the Queue ID for the import command, use the following Python script.
This script authenticates, finds a queue by name, checks for active conversations, and prints the Queue ID for manual terraform import.
import requests
import os
import sys
load_dotenv()
    if region in ["us-east-1", "us-east-2"]:
    else:
    data = {
    return response.json()["access_token"]
def get_queue_id(token: str, queue_name: str) -> str | None:
    else:
    headers = {
    params = {"name": queue_name, "pageSize": 25}
    response = requests.get(f"{base_url}/api/v2/routing/queues", headers=headers, params=params)
    entities = response.json().get("entities", [])
            return queue["id"]
    return None
def check_waiters(token: str, queue_id: str) -> bool:
    else:
    response = requests.get(f"{base_url}/api/v2/routing/queues/{queue_id}/waiters", headers=headers)
    if response.status_code == 200:
        return len(response.json().get("entities", [])) > 0
    return False
def main():
    if len(sys.argv) < 2:
        print("Usage: python resolve_drift.py <queue_name>")
        sys.exit(1)
    queue_name = sys.argv[1]
        token = get_access_token()
        queue_id = get_queue_id(token, queue_name)
        if not queue_id:
            print(f"Queue '{queue_name}' not found in Genesys Cloud.")
            print("If Terraform expects this queue, it may have been deleted manually.")
            print("Run: terraform state rm genesyscloud_routing_queue.<resource_name>")
            sys.exit(0)
        has_waiters = check_waiters(token, queue_id)
        print(f"Queue Found: {queue_name}")
        print(f"Queue ID: {queue_id}")
        print(f"Active Waiters: {'Yes' if has_waiters else 'No'}")
        if has_waiters:
            print("\nWARNING: Queue has active waiters. Do not delete or majorly modify until waiters are cleared.")
            print("To resolve drift, import the existing state:")
            print(f"terraform import genesyscloud_routing_queue.<resource_name> {queue_id}")
        else:
            print("\nQueue is idle. You can safely import or modify.")
        print(f"Error: {e}")
        sys.exit(1)
    main()
Error: 409 Conflict - Resource Locked
What causes it:
The Genesys Cloud API returns a 409 Conflict when a write operation is attempted on a resource that is currently being modified by another process. This often happens if a long-running analytics job or a bulk update is in progress. It can also occur if Terraform attempts to update a queue that is currently in a transitional state after a previous failed apply.
How to fix it:
  1. Wait 60 seconds.
  3. If the error persists, check for other automation scripts running against the same environment.
  4. If you are certain no other process is running, the lock may be stuck. In this case, you must contact Genesys Cloud Support to clear the internal resource lock, as there is no public API to release it.
Code showing the fix:
There is no code fix for a stuck server-side lock. You must wait or contact support. However, you can add retry logic to your Terraform provider configuration to handle transient 409s.
terraform {
  required_providers {
    genesyscloud = {
      source  = "mikesplain/genesyscloud"
      version = ">= 1.100.0"
provider "genesyscloud" {
  # Increase timeout for operations that may hit locks
  timeout = "10m"
Error: Error Acquiring the State Lock
What causes it:
This error originates from the Terraform backend (e.g., AWS S3), not Genesys Cloud. It means another terraform process has acquired a lock on the state file.
How to fix it:
  1. Verify no other developer is running terraform apply.
  2. If a process crashed, the lock remains.
  3. Run terraform force-unlock <LOCK_ID>.
This is a CLI command, not an API call.
# Find the Lock ID from the error message
# Example: Lock Info: ID: a1b2c3d4-e5f6-7890-abcd-ef1234567890
terraform force-unlock a1b2c3d4-e5f6-7890-abcd-ef1234567890
Error: 403 Forbidden - Insufficient Scopes
What causes it:
The OAuth token does not have the required scopes to read or write the queue.
How to fix it:
  1. Ensure the Service Account has admin:queue:read and admin:queue:write scopes.
  2. Regenerate the token.
Update your .env file with a client ID/secret that has the correct scopes assigned in the Genesys Cloud Admin Console > Security > OAuth 2.0.
