Resolve Genesys Cloud Routing Queue State Drift and Lock Errors in Terraform
  • A Python utility script that queries the Genesys Cloud API to identify the specific configuration divergence causing terraform plan drift on genesyscloud_routing_queue resources.
  • A diagnostic workflow using the Genesys Cloud Python SDK to compare local Terraform state against the actual API state, isolating fields that trigger false-positive drift or lock contention.
  • The tutorial covers Python 3.10+, the genesys-cloud-python SDK, and the terraform-provider-genesys-cloud.
  • Terraform Provider: mivenesyscloud/genesyscloud version 1.50.0 or later.
  • SDK: genesys-cloud-python version 150.0.0 or later.
  • Runtime: Python 3.10 or higher.
  • Dependencies: Install the SDK via pip: pip install genesys-cloud-python.
  • Genesys Cloud Account: An organization with at least one Routing Queue created.
  • API Client Credentials: A Genesys Cloud API Client ID and Secret with the scope routing:queue:read.
The Genesys Cloud Python SDK handles OAuth2 client credentials flow automatically. You must configure the environment variables GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET before initializing the client. The SDK caches tokens internally and refreshes them upon expiration.
import os
from purecloudplatformclientv2 import (
    Configuration,
    ApiClient,
    RoutingApi
def get_routing_api_client() -> RoutingApi:
    Initializes and returns an authenticated RoutingApi client.
    Raises ValueError if credentials are missing.
    client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
    client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
        raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set.")
    # Configure the SDK with client credentials
    config = Configuration()
    config.client_id = client_id
    config.client_secret = client_secret
    # Initialize the API client
    api_client = ApiClient(configuration=config)
    # Return the specific API object for Routing operations
    return RoutingApi(api_client)
This setup ensures that every subsequent API call includes a valid Authorization: Bearer <token> header. If the token expires, the SDK intercepts the 401 response and fetches a new one transparently.
Step 1: Retrieve Queue Data from Terraform State
Terraform stores the last known state of your infrastructure in terraform.tfstate. To diagnose drift, you must extract the expected configuration for the specific queue from this file. The provider stores queue attributes in a nested structure.
import json
def load_queue_state(state_file_path: str, queue_name: str) -> Optional[Dict[str, Any]]:
    Parses the terraform.tfstate file to find the resource matching the queue name.
    Args:
        state_file_path: Path to terraform.tfstate.
        queue_name: The name of the queue as defined in the HCL code.
    Returns:
        A dictionary representing the 'values' block of the resource, or None.
        with open(state_file_path, 'r') as f:
            state = json.load(f)
    except FileNotFoundError:
        print(f"Error: State file not found at {state_file_path}")
        return None
    resources = state.get("values", {}).get("root_module", {}).get("child_modules", [])
    # Flatten child modules if necessary, but for simplicity, check root and first level
    all_resources = state.get("values", {}).get("root_module", {}).get("resources", [])
    # Search through all modules for the specific resource
    for module in [state.get("values", {}).get("root_module", {})] + resources:
        for res in module.get("resources", []):
            if res["type"] == "genesyscloud_routing_queue" and res["name"] == queue_name:
                return res["values"]
    print(f"Warning: Resource genesyscloud_routing_queue.{queue_name} not found in state.")
    return None
This function isolates the expected state. If the resource is not found, Terraform will attempt to create it, which may fail if a queue with that name already exists in the platform but is not tracked in state.
Step 2: Fetch Actual Queue Configuration from Genesys Cloud API
Next, retrieve the actual configuration from Genesys Cloud. The genesyscloud_routing_queue resource maps to the /api/v2/routing/queues endpoint. You need the queue ID. If you only have the name, you must search for the queue first.
from purecloudplatformclientv2.models import QueueWrap
def get_queue_by_name(api_client: RoutingApi, queue_name: str) -> Optional[QueueWrap]:
    Searches for a queue by name using the Genesys Cloud API.
    Args:
        api_client: The authenticated RoutingApi instance.
        queue_name: The exact name of the queue.
    Returns:
        The QueueWrap object containing the queue details, or None.
        # Use the search endpoint to find the queue ID
        # Scope required: routing:queue:read
        response = api_client.post_routing_queues_search(
            body={
                "query": queue_name,
                "size": 100
        if response.entities:
            for queue_wrap in response.entities:
                if queue_wrap.queue and queue_wrap.queue.name == queue_name:
                    return queue_wrap
        return None
        print(f"API Error searching for queue '{queue_name}': {e}")
        return None
Once you have the QueueWrap, the queue attribute contains the full configuration object. This includes fields like name, description, outbound_email, skills, wrap_up_code, and members.
Step 3: Compare State and API Response to Identify Drift
Drift occurs when the value in the Terraform state differs from the value returned by the API. Common culprits for genesyscloud_routing_queue include:
  1. Auto-Provisioned IDs: Fields like id are generated by the platform and should not cause drift if ignored, but sometimes state corruption occurs.
  2. Computed Fields: Fields like member_count or outbound_email (if not set in HCL) may have default values in the API that differ from the empty state.
  3. List Ordering: Skills or members might be returned in a different order than defined in HCL.
from typing import List, Tuple
def compare_queue_state(state_values: Dict[str, Any], api_queue: Queue) -> List[Tuple[str, Any, Any]]:
    Compares local state values against the API response.
    Args:
        state_values: The 'values' dict from terraform.tfstate.
        api_queue: The Queue object from the Genesys Cloud API.
    Returns:
        A list of tuples: (field_name, state_value, api_value) for mismatches.
    drifts = []
    # Map of HCL attribute names to Python SDK Queue object attributes
    # Note: SDK attributes are camelCase, HCL is snake_case
    field_map = {
        "name": "name",
        "description": "description",
        "outbound_email": "outbound_email",
        "default_wrap_up_code": "default_wrap_up_code",
        "split_by_skill": "split_by_skill",
        "enable_auto_answer": "enable_auto_answer",
        "enable_auto_disposition": "enable_auto_disposition",
        "member_flow": "member_flow",
        "empty_queue_flow": "empty_queue_flow",
        "long_queue_flow": "long_queue_flow",
        "long_queue_wait_time": "long_queue_wait_time",
        "long_queue_wait_time_unit": "long_queue_wait_time_unit",
        "long_queue_wait_count": "long_queue_wait_count",
        "enable_email": "enable_email",
        "enable_callback": "enable_callback",
        "enable_ivr": "enable_ivr",
        "enable_sms": "enable_sms",
        "enable_fax": "enable_fax",
        "enable_social": "enable_social",
        "enable_webchat": "enable_webchat",
        "enable_wechat": "enable_wechat",
        "enable_wechat_official_account": "enable_wechat_official_account",
        "enable_wechat_mini_program": "enable_wechat_mini_program",
        "enable_wechat_applet": "enable_wechat_applet",
        "enable_wechat_workbench": "enable_wechat_workbench",
        "enable_wechat_weapp": "enable_wechat_weapp",
        "enable_wechat_weapp_official_account": "enable_wechat_weapp_official_account",
        "enable_wechat_weapp_mini_program": "enable_wechat_weapp_mini_program",
        "enable_wechat_weapp_applet": "enable_wechat_weapp_applet",
        "enable_wechat_weapp_workbench": "enable_wechat_weapp_workbench",
    for hcl_key, sdk_key in field_map.items():
        state_val = state_values.get(hcl_key)
        api_val = getattr(api_queue, sdk_key, None)
        # Handle None vs Empty String differences
        if state_val is None and api_val is None:
        if state_val == "" and api_val is None:
        if state_val is None and api_val == "":
        if state_val != api_val:
            drifts.append((hcl_key, state_val, api_val))
    return drifts
This comparison logic ignores complex nested objects like skills and members for simplicity, as those often require deep traversal. For most drift issues, scalar fields like enable_auto_answer or long_queue_wait_time are the primary suspects.
Step 4: Handle State Lock and Refresh
If terraform plan fails with a state lock error, it means another process is holding the lock. However, if the lock is stale or the drift is due to a previous failed apply, you may need to force-unlock or refresh the state.
import subprocess
import sys
def run_terraform_command(command: str, working_dir: str = ".") -> int:
    Executes a Terraform command and returns the exit code.
    print(f"Running: terraform {command}")
    result = subprocess.run(
        ["terraform"] + command.split(),
        cwd=working_dir,
        capture_output=True,
        text=True
    if result.stdout:
        print(f"STDOUT:\n{result.stdout}")
    if result.stderr:
        print(f"STDERR:\n{result.stderr}")
    return result.returncode
def force_unlock_state(lock_id: str, working_dir: str = ".") -> bool:
    Forces a state unlock if the lock is stale.
    Use with caution.
    print("WARNING: Forcing state unlock. Ensure no other Terraform processes are running.")
    return run_terraform_command(f"force-unlock {lock_id}", working_dir) == 0
This script combines authentication, state parsing, API retrieval, and drift comparison into a single executable tool.
#!/usr/bin/env python3
Genesys Cloud Routing Queue Drift Detector
Usage:
    python detect_drift.py <queue_name> <terraform_state_file>
Requires:
import os
import sys
import json
from typing import Dict, Any, Optional, List, Tuple
# Import Genesys Cloud SDK
from purecloudplatformclientv2 import Configuration, ApiClient, RoutingApi
from purecloudplatformclientv2.models import QueueWrap, Queue
# --- Helper Functions from Previous Steps ---
        return None
    for res in resources:
    return None
            body={
                "size": 100
                    return queue_wrap
        return None
        return None
    drifts = []
    field_map = {
        "name": "name",
    return drifts
# --- Main Execution ---
def main():
    if len(sys.argv) != 3:
        print("Usage: python detect_drift.py <queue_name> <terraform_state_file>")
        sys.exit(1)
    queue_name = sys.argv[1]
    state_file = sys.argv[2]
    print(f"Initializing Genesys Cloud API client...")
        routing_api = get_routing_api_client()
    except ValueError as e:
        print(e)
        sys.exit(1)
    print(f"Loading Terraform state for queue '{queue_name}'...")
    state_values = load_queue_state(state_file, queue_name)
    if not state_values:
        sys.exit(1)
    print(f"Fetching queue from Genesys Cloud API...")
    queue_wrap = get_queue_by_name(routing_api, queue_name)
    if not queue_wrap:
        print(f"Queue '{queue_name}' not found in Genesys Cloud. It may need to be created.")
        sys.exit(1)
    api_queue = queue_wrap.queue
    print(f"Found Queue ID: {api_queue.id}")
    print("Comparing state...")
    drifts = compare_queue_state(state_values, api_queue)
    if not drifts:
        print("No drift detected in scalar fields. Check complex types (skills, members) manually.")
    else:
        print(f"Detected {len(drifts)} drifts:")
        for field, state_val, api_val in drifts:
            print(f"- Field: {field}")
            print(f"  State: {state_val}")
            print(f"  API:   {api_val}")
            print()
    main()
Error: 403 Forbidden on API Calls
  • Cause: The API Client lacks the routing:queue:read scope.
  • Fix: Go to Genesys Cloud Admin > Platform > API Access. Edit the API Client. Ensure the scope routing:queue:read is checked. Update your environment variables with the new secret if you regenerated credentials.
Error: Terraform State Lock Acquired
  • Cause: A previous terraform apply or plan crashed or was interrupted, leaving a lock file.
  • Fix: Identify the lock ID from the error message. Run terraform force-unlock <LOCK_ID>. If the lock is stale, this releases it. If another process is actively running, wait for it to finish.
Error: Drift in members or skills
  • Cause: The comparison script above only checks scalar fields. Lists and maps often drift due to ordering or computed IDs.
  • Fix: Use the terraform refresh command to update the state file with the current API values. This does not change infrastructure but aligns the state file.
    terraform refresh -target=genesyscloud_routing_queue.my_queue
    After refresh, run terraform plan again. If drift persists, the HCL code differs from the API. Update the HCL code to match the API or vice versa.
Error: Module Not Found in State
  • Cause: The queue is defined in a child module, but the script only checks the root module.
  • Fix: Update the load_queue_state function to recursively traverse child_modules in the state file. Alternatively, run the script from the directory containing the specific module’s state file (if using workspaces or separate state files per module).
