Resolve Genesys Cloud Routing Queue State Drift and Lock Contention with Terraform
- This tutorial demonstrates how to identify, debug, and resolve state drift and state lock issues specifically related to the
genesyscloud_routing_queueresource in the Genesys Cloud Terraform Provider. - This solution uses the MyPureCloud (Genesys Cloud) Terraform Provider v1.30+ and the Genesys Cloud REST API for verification.
- The implementation covers Python scripts for API verification, Terraform state manipulation commands, and HCL configuration patterns to prevent recurrence.
- Genesys Cloud Environment: An active Genesys Cloud organization with an authorized user account.
- OAuth Credentials: A Service Account with the following scopes:
routing:queue:readrouting:queue:writerouting:queue:member:readrouting:queue:member:write
- Terraform: Version 1.5+ installed.
- MyPureCloud Provider: Version 1.30.0 or later.
- Python: Version 3.9+ with
requestsandpython-dotenvinstalled. - API Access: Ability to make direct REST calls to Genesys Cloud for debugging.
To debug state drift and lock issues, you often need to bypass Terraform and query the API directly to see what Genesys Cloud actually stores versus what Terraform thinks it stores.
First, configure your environment variables. Create a .env file:
GENESYS_CLIENT_ID=your_client_id
GENESYS_CLIENT_SECRET=your_client_secret
GENESYS_REGION=us-east-1
Next, use this Python script to obtain an access token. This token is required for the debugging steps later in this tutorial.
import os
import requests
def get_genesys_token():
load_dotenv()
region = os.getenv("GENESYS_REGION", "us-east-1")
# Determine the auth domain based on region
if region == "us-east-1" or region == "us-east-2":
auth_url = "https://login.mypurecloud.com/oauth/token"
elif region == "eu-west-1":
auth_url = "https://login.europe.mypurecloud.com/oauth/token"
else:
headers = {
data = {
"client_id": client_id,
"client_secret": client_secret,
"scope": "routing:queue:read routing:queue:write routing:queue:member:read routing:queue:member:write"
response = requests.post(auth_url, headers=headers, data=data)
if response.status_code != 200:
raise Exception(f"Failed to obtain token: {response.text}")
return response.json()["access_token"]
token = get_genesys_token()
print(f"Access Token: {token[:20]}...")
Step 1: Identify the State Lock and Drift Source
State locks in Terraform occur when a previous operation did not complete cleanly, or when multiple processes attempt to modify the state simultaneously. Drift occurs when the actual resource in Genesys Cloud differs from the state file.
First, check for an active state lock.
# Check the status of the state lock
terraform force-unlock <LOCK_ID>
If you do not know the LOCK_ID, run:
terraform state pull
Look for the serial and lineage fields. If the lock is held by a stale process, you must force unlock it. However, force unlocking does not fix drift. It only allows you to proceed with planning.
To identify drift, run:
terraform plan -detailed-exitcode
If the exit code is 2, drift exists. If the error message mentions genesyscloud_routing_queue, the drift is likely in the queue configuration or its members.
Step 2: Verify Actual Queue State via API
Terraform may report drift because it cannot read the current state due to a transient error, or because the API response differs from the stored state. Use the API to fetch the actual queue configuration.
import os
import json
import requests
def fetch_queue_details(queue_id: str, token: str, region: str):
base_url = "https://api.europe.mypurecloud.com"
else:
base_url = "https://api.mypurecloud.com"
endpoint = f"{base_url}/api/v2/routing/queues/{queue_id}"
headers = {
response = requests.get(endpoint, headers=headers)
if response.status_code == 404:
raise Exception(f"Queue {queue_id} not found. It may have been deleted outside Terraform.")
elif response.status_code != 200:
raise Exception(f"API Error: {response.status_code} - {response.text}")
def fetch_queue_members(queue_id: str, token: str, region: str):
else:
endpoint = f"{base_url}/api/v2/routing/queues/{queue_id}/members"
headers = {
raise Exception(f"Failed to fetch members: {response.text}")
load_dotenv()
queue_id = "your_queue_id_here" # Replace with actual ID
queue_details = fetch_queue_details(queue_id, token, region)
print("Queue Details:")
print(json.dumps(queue_details, indent=2))
members = fetch_queue_members(queue_id, token, region)
print("\nQueue Members:")
print(json.dumps(members, indent=2))
print(f"Error: {e}")
Compare the API response with the Terraform state. Run:
terraform state show module.queue.genesyscloud_routing_queue.my_queue
Look for discrepancies in:
outbound_email_addresswrap_up_policyskillsmembers(if usinggenesyscloud_routing_queue_memberresources)
Step 3: Resolve Drift by Reconciling State
If the API shows a configuration that differs from Terraform, you have two options:
- Update Terraform to match Genesys Cloud: Use
terraform importorterraform applywith-targetto force the state to align. - Update Genesys Cloud to match Terraform: Run
terraform applyto push the desired state to Genesys Cloud.
If the drift is caused by a read-only field or a computed value that changed unexpectedly, you may need to refresh the state.
# Refresh the state from the API
terraform refresh
If terraform refresh fails with a lock error, you must force unlock first:
# Force unlock the state
# Then refresh
terraform refresh
After refreshing, run terraform plan again. If no changes are shown, the drift is resolved. If changes are still shown, review the specific attributes.
Step 4: Handle Member Drift Specifically
Routing queue members are often the source of drift. If you manage members via genesyscloud_routing_queue_member, ensure the member is actually in the queue.
def check_member_in_queue(queue_id: str, user_id: str, token: str, region: str):
else:
endpoint = f"{base_url}/api/v2/routing/queues/{queue_id}/members/{user_id}"
headers = {
return False
return True
load_dotenv()
user_id = "your_user_id_here"
is_member = check_member_in_queue(queue_id, user_id, token, region)
print(f"User {user_id} is a member of queue {queue_id}: {is_member}")
If the user is not a member but Terraform believes they are, import the member resource or recreate it.
This Terraform configuration demonstrates a robust way to define a routing queue with members, minimizing drift risk by using explicit dependencies and ignoring volatile attributes where appropriate.
terraform {
required_providers {
genesyscloud = {
source = "mypurecloud/genesyscloud"
version = ">= 1.30.0"
provider "genesyscloud" {
# Use environment variables for credentials
# GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_REGION
# Define a skill to be used in the queue
resource "genesyscloud_routing_skill" "support_skill" {
name = "Technical Support"
description = "Skill for technical support agents"
# Define the routing queue
resource "genesyscloud_routing_queue" "support_queue" {
name = "Technical Support Queue"
description = "Queue for technical support inquiries"
enabled = true
# Explicitly set wrap_up_policy to avoid drift from default changes
wrap_up_policy {
default_wrap_up_code = "other"
# Associate the skill
skills = [genesyscloud_routing_skill.support_skill.id]
# Ignore attributes that may be updated by other processes
lifecycle {
ignore_changes = [
# Ignore changes to members if managed elsewhere
# members,
# Ignore changes to outbound email if set by admin console
# outbound_email_address
# Define a user to add to the queue (for demonstration)
# In production, use data sources to look up existing users
data "genesyscloud_user" "support_agent" {
name = "John Doe"
# Add the user to the queue
resource "genesyscloud_routing_queue_member" "agent_member" {
queue_id = genesyscloud_routing_queue.support_queue.id
user_id = data.genesyscloud_user.support_agent.id
# Set specific member attributes
member_type = "agent"
# Ignore changes to presence or availability status
lifecycle {
ignore_changes = [
# These may change dynamically
# presence_status,
# availability_status
To apply this configuration:
terraform init
terraform plan
terraform apply
If you encounter a lock error during apply, check for running processes:
ps aux | grep terraform
Kill any stale terraform processes and force unlock the state:
Error: State Lock Held by Another Process
What causes it:
A previous terraform apply or plan command crashed or was interrupted, leaving a lock on the state file.
How to fix it:
- Identify the lock ID:
terraform state pull - Force unlock the state:
terraform force-unlock <LOCK_ID> - Verify the lock is removed:
terraform plan
Error: Queue Not Found (404)
What causes it:
The queue was deleted in Genesys Cloud outside of Terraform, or the ID in the state file is incorrect.
How to fix it:
- Verify the queue exists via API:
curl -X GET "https://api.mypurecloud.com/api/v2/routing/queues/{queue_id}" \ -H "Authorization: Bearer {token}" - If the queue does not exist, remove it from the state file:
terraform state rm genesyscloud_routing_queue.my_queue - Recreate the queue:
terraform apply
Error: Drift in Member List
What causes it:
Members were added or removed in the Genesys Cloud admin console, or via API, without updating Terraform.
How to fix it:
- Import the current state of the queue members:
terraform import genesyscloud_routing_queue_member.agent_member {queue_id}/{user_id} - Run
terraform planto see if any further changes are needed. - If the members are managed elsewhere, add
membersto theignore_changeslifecycle block in thegenesyscloud_routing_queueresource.
Error: Scope Insufficient
What causes it:
The OAuth token does not have the required scopes to read or write queue data.
How to fix it:
Ensure the service account has the following scopes:
Update the .env file and regenerate the token.
