Resolve Genesys Cloud Routing Queue State Drift and Lock Conflicts
- A Terraform execution workflow that detects, diagnoses, and resolves state drift for
genesyscloud_routing_queueresources. - A Python utility script that queries the Genesys Cloud API to verify the live state of a queue and compare it against Terraform state, bypassing the provider lock.
- The Terraform provider (v1.x) and Python
httpxlibrary.
- Terraform: Version 1.5+ installed.
- Genesys Cloud Provider: Version 1.50+ installed (
hashicorp/genesyscloud). - Python: Version 3.9+ with
httpxandpyyamlinstalled. - Credentials: A Genesys Cloud OAuth Client ID and Secret with the
routing:queue:readscope. - Environment Variables:
GENESYS_CLOUD_REGION(e.g.,mypurecloud.com) andGENESYS_CLOUD_API_URL(e.g.,https://api.mypurecloud.com).
Before addressing state drift, you must establish a valid authentication context. The Terraform provider manages its own tokens, but our diagnostic script requires an independent token to inspect the resource without triggering provider state locks.
The following Python function generates a short-lived access token using the OAuth2 Client Credentials flow. This token is valid for 5 minutes and is sufficient for read-only diagnostic queries.
import httpx
import os
from typing import Optional
def get_genesys_cloud_token(
client_id: str,
client_secret: str,
region: str = "mypurecloud.com"
) -> str:
Authenticates with Genesys Cloud using Client Credentials flow.
Returns a JWT access token.
url = f"https://login.{region}/oauth/token"
headers = {
data = {
"client_id": client_id,
"client_secret": client_secret
client = httpx.Client(timeout=10.0)
response = client.post(url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
return token_data["access_token"]
raise RuntimeError(f"Authentication failed: {e.response.status_code} - {e.response.text}")
finally:
client.close()
# Usage
CLIENT_ID = os.getenv("GENESYS_CLOUD_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
REGION = os.getenv("GENESYS_CLOUD_REGION", "mypurecloud.com")
if not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set.")
ACCESS_TOKEN = get_genesys_cloud_token(CLIENT_ID, CLIENT_SECRET, REGION)
Step 1: Diagnose the State Lock and Drift
When terraform plan reports a drift on genesyscloud_routing_queue, it often means the Terraform state file (terraform.tfstate) does not match the actual resource in Genesys Cloud. If you also see a “state lock” error, the provider is waiting for another process to release the lock, or the lock is stale.
First, identify the specific Queue ID causing the issue. If you have the Terraform state file, you can extract the ID using the CLI:
# Extract the ID of the specific queue resource from the local state
terraform state show module.your_module.genesyscloud_routing_queue.your_queue_name | grep id
Assume the output is id = "a1b2c3d4-e5f6-7890-abcd-ef1234567890".
If terraform plan is stuck on acquiring the lock, you may need to force-unlock it if you are certain no other process is running. Use with extreme caution.
# Force unlock ONLY if you are certain the previous run crashed
terraform force-unlock <LOCK_ID>
However, forcing the unlock does not fix the drift. The drift persists because the provider’s cached state differs from the API reality. We must now query the API directly to see what Genesys Cloud actually holds.
Step 2: Query the Live Queue State via API
We will write a Python script to fetch the current configuration of the queue from the Genesys Cloud API. This bypasses the Terraform provider entirely, allowing us to inspect the raw JSON payload.
OAuth Scope Required: routing:queue:read
import httpx
import json
import sys
def get_queue_details(queue_id: str, token: str, region: str) -> dict:
Fetches the detailed configuration of a specific Routing Queue.
url = f"https://api.{region}/api/v2/routing/queues/{queue_id}"
headers = {
"Accept": "application/json",
response = client.get(url, headers=headers)
if response.status_code == 404:
raise RuntimeError(f"Queue {queue_id} not found in Genesys Cloud. It may have been deleted outside of Terraform.")
return response.json()
if e.response.status_code == 429:
raise RuntimeError("Rate limited (429). Wait before retrying.")
raise RuntimeError(f"API Error: {e.response.status_code} - {e.response.text}")
finally:
client.close()
# Configuration
QUEUE_ID = "a1b2c3d4-e5f6-7890-abcd-ef1234567890" # Replace with your actual Queue ID
live_queue_data = get_queue_details(QUEUE_ID, ACCESS_TOKEN, REGION)
print(json.dumps(live_queue_data, indent=2))
print(f"Error fetching queue details: {e}", file=sys.stderr)
sys.exit(1)
Step 3: Compare Terraform State vs. Live API Response
Drift typically occurs in one of three areas for genesyscloud_routing_queue:
- Member Lists: Users or groups were added/removed manually in the Genesys Cloud UI.
- Wrap-up Codes: A wrap-up code was deleted globally or removed from the queue manually.
- Skills: A skill was removed from the queue or the queue was removed from a skill.
To resolve the drift, you must determine which source of truth you want to enforce.
Scenario A: The Queue was modified in the UI (Intentional Change)
If you or an admin manually changed the queue in the Genesys Cloud UI, the Terraform state is outdated. You should update your Terraform code to match the UI, or import the new state.
- Copy the JSON output from Step 2.
- Update your
genesyscloud_routing_queueHCL block to match the values. - Run
terraform plan. The plan should now be empty (no changes).
Scenario B: The Queue was modified in the UI (Unintentional Change)
If the change was accidental, you want Terraform to revert the UI to match the code.
- Ensure your Terraform code represents the desired state.
- Run
terraform apply. This will push the configuration from your code back to Genesys Cloud, overwriting the manual changes.
Scenario C: Resource Deleted Outside Terraform
If Step 2 returned a 404, the queue no longer exists in Genesys Cloud.
- Remove the resource block from your Terraform code.
- Run
terraform apply. This removes the resource from the state file. - Re-add the resource block if needed and run
terraform applyto recreate it.
The following script combines authentication, data fetching, and a basic comparison logic to help you identify specific fields that have drifted. It compares the name, description, and outbound_queue_enabled flags. For complex fields like members, you should manually inspect the JSON output.
#!/usr/bin/env python3
Genesys Cloud Queue Drift Detector
Compares Terraform state (provided via JSON file) against Live API.
import httpx
import json
import os
import sys
# --- Configuration ---
QUEUE_ID = os.getenv("QUEUE_ID_TO_CHECK")
TERRAFORM_STATE_FILE = "terraform.tfstate" # Path to your local state file
if not all([CLIENT_ID, CLIENT_SECRET, QUEUE_ID]):
print("Error: Missing environment variables.", file=sys.stderr)
print("Required: GENESYS_CLOUD_CLIENT_ID, GENESYS_CLOUD_CLIENT_SECRET, QUEUE_ID_TO_CHECK", file=sys.stderr)
sys.exit(1)
# --- Helper Functions ---
def get_token() -> str:
url = f"https://login.{REGION}/oauth/token"
data = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET
resp = client.post(url, data=data, headers={"Content-Type": "application/x-www-form-urlencoded"})
resp.raise_for_status()
return resp.json()["access_token"]
def get_live_queue(token: str) -> Dict[str, Any]:
url = f"https://api.{REGION}/api/v2/routing/queues/{QUEUE_ID}"
headers = {
resp = client.get(url, headers=headers)
if resp.status_code == 404:
return None
return resp.json()
def get_terraform_state_queue() -> Dict[str, Any]:
Parses the terraform.tfstate file to find the resource matching QUEUE_ID.
Note: This is a simplified parser. For robust parsing, use the terraform JSON provider or a dedicated state parser library.
with open(TERRAFORM_STATE_FILE, 'r') as f:
state = json.load(f)
# Navigate to resources
resources = state.get("resources", [])
for module in resources:
# Handle nested modules
if "module" in module:
for res in module.get("resources", []):
if res.get("type") == "genesyscloud_routing_queue" and res.get("values", {}).get("id") == QUEUE_ID:
return res.get("values", {})
else:
return None
except FileNotFoundError:
print(f"Error: {TERRAFORM_STATE_FILE} not found.", file=sys.stderr)
return None
except json.JSONDecodeError:
print(f"Error: {TERRAFORM_STATE_FILE} is not valid JSON.", file=sys.stderr)
return None
def compare_fields(tf_data: Dict[str, Any], live_data: Dict[str, Any], fields: List[str]) -> List[str]:
drifts = []
for field in fields:
tf_val = tf_data.get(field)
live_val = live_data.get(field)
if tf_val != live_val:
drifts.append({
"field": field,
"terraform_value": tf_val,
"live_value": live_val
return drifts
# --- Main Execution ---
def main():
print(f"Checking drift for Queue ID: {QUEUE_ID}")
# 1. Get Token
token = get_token()
print(f"Authentication failed: {e}", file=sys.stderr)
sys.exit(1)
# 2. Get Live Data
live_data = get_live_queue(token)
if live_data is None:
print("CRITICAL: Queue not found in Genesys Cloud. It has been deleted.", file=sys.stderr)
print("Action: Remove resource from Terraform code and run 'terraform apply'.")
sys.exit(1)
print(f"API Error: {e}", file=sys.stderr)
sys.exit(1)
# 3. Get Terraform State Data
tf_data = get_terraform_state_queue()
if tf_data is None:
print("Could not find queue in Terraform state file. Ensure QUEUE_ID matches the resource in state.", file=sys.stderr)
sys.exit(1)
# 4. Compare Specific Fields
# Note: Complex nested objects like 'members' or 'wrap_up_codes' require deep comparison logic.
# This example checks simple scalar fields.
fields_to_check = ["name", "description", "outbound_queue_enabled", "enable_audio", "enable_video", "enable_chat", "enable_email", "enable_callback"]
drifts = compare_fields(tf_data, live_data, fields_to_check)
if not drifts:
print("SUCCESS: No drift detected in basic fields.")
print("If Terraform still reports drift, check complex fields (members, skills, wrap_up_codes) manually.")
else:
print("DRIFT DETECTED:", file=sys.stderr)
for d in drifts:
print(f" Field: {d['field']}", file=sys.stderr)
print(f" Terraform: {d['terraform_value']}", file=sys.stderr)
print(f" Live API: {d['live_value']}", file=sys.stderr)
print(file=sys.stderr)
print("Action Required:", file=sys.stderr)
print("1. If the Live API value is correct, update your Terraform HCL.", file=sys.stderr)
print("2. If the Terraform value is correct, run 'terraform apply' to overwrite the API.", file=sys.stderr)
main()
Genesys Cloud APIs enforce strict rate limits. If you run the diagnostic script or terraform plan in a loop, you will hit this limit.
Fix: Implement exponential backoff. In the Python script above, the httpx client does not automatically retry. For production scripts, use httpx with a RetryTransport.
from httpx import RetryTransport, HTTPStatusError
# Define a retry transport
retry_transport = RetryTransport(
max_retries=3,
retry_status_codes=[429, 500, 502, 503, 504]
client = httpx.Client(transport=retry_transport, timeout=10.0)
The token has expired or the OAuth client lacks the routing:queue:read scope.
Fix: Ensure the OAuth client in Genesys Cloud Admin Console has the correct scopes. The token generated by the script is valid for 5 minutes. If your script takes longer, re-authenticate.
Error: State Lock Timeout
Terraform cannot acquire the lock because another process holds it.
Fix:
- Check if another CI/CD pipeline or developer is running
terraform apply. - If no process is running, the lock is stale. Use
terraform force-unlock <LOCK_ID>. - Find the lock ID from the error message:
Lock ID: <LOCK_ID>.
Error: Drift on members or wrap_up_codes
The script above only checks simple fields. Drift on members is common because users are added/removed via the UI.
Fix:
- Export the current state of the queue members from the API.
- Compare the list of
idvalues. - If you want Terraform to manage members, ensure your HCL includes the
membersblock with the correct user/group IDs. - If you do not want Terraform to manage members, add
ignore_changes = [members]to thelifecycleblock in your HCL.
resource "genesyscloud_routing_queue" "example" {
name = "Support Queue"
description = "Customer Support"
# Ignore changes to members made outside Terraform
lifecycle {
ignore_changes = [
members
