Resolve Genesys Cloud Routing Queue State Drift and Lock Conflicts in Terraform
- A diagnostic script that identifies the root cause of
genesyscloud_routing_queuestate drift and resolves stale state locks. - A Python utility using the Genesys Cloud Platform Client SDK to verify the actual API state against Terraform state.
- A set of Terraform CLI commands and Python code to clear locks and force state synchronization.
- Terraform Version: 1.5+ (recommended for improved state management).
- Genesys Cloud Provider:
genesyscloud/genesyscloudv1.100+ (ensure you are on a recent version to leverage latest drift detection improvements). - Python: 3.9+ with
pip. - Dependencies:
genesys-cloud-platform-client(Python SDK),requests,json. - Genesys Cloud OAuth: Service account or user credentials with
routing:queue:readandrouting:queue:writescopes. - Environment: Access to the Genesys Cloud organization and the specific workspace where the lock/drift is occurring.
Before running diagnostic code, you must establish a valid authentication context. The Genesys Cloud Python SDK handles token caching automatically if configured correctly, but for debugging state issues, explicit control over the client instance is preferred.
import os
from purecloudplatformclientv2 import PlatformClient
from purecloudplatformclientv2.rest import ApiException
def get_genesys_client():
Initializes the Genesys Cloud Platform Client with environment variables.
client = PlatformClient()
# Use environment variables for security
client.set_environment("mypurecloud.com") # Adjust for your region (e.g., us-gov, eu)
client.set_auth_mode("OAUTH_CLIENT_CREDENTIALS")
client.set_auth_setting("client_id", os.getenv("GENESYS_CLIENT_ID"))
client.set_auth_setting("client_secret", os.getenv("GENESYS_CLIENT_SECRET"))
# Verify connection by fetching the current user info
user_api = client.get_user_api()
user_api.get_users_me()
print("Authentication successful.")
return client
except ApiException as e:
print(f"Authentication failed: {e.status} - {e.reason}")
raise
Required Scopes:
routing:queue:read: To fetch queue details for comparison.routing:queue:write: To update queue settings if manual correction is needed.user:read: To verify authentication.
Step 1: Diagnose the State Lock
Terraform state locks are stored in the remote backend (e.g., S3, Azure Blob, or the Genesys Cloud provider’s internal state if using local backend with remote state). A “lock issue” often manifests as a terraform plan hanging or failing with Error acquiring the state lock. This is frequently caused by a previous apply or plan that terminated unexpectedly (Ctrl+C, network drop, OOM kill).
First, identify the lock ID and info.
# Identify the lock ID from the Terraform error output
# Example error: "Error acquiring the state lock. Lock Info: ID: 1234567890, Path: tfstate/terraform.tfstate, Operation: OperationTypeApply, Who: user@host, Version: 1.5.0, Created: 2023-10-27T10:00:00.000Z, Info: ..."
# Force unlock if you are certain no other process is running
# WARNING: Only use this if you are sure the previous process is dead
terraform force-unlock <LOCK_ID>
If force-unlock fails or the lock persists, the issue may not be a lock but actual data drift that Terraform is struggling to reconcile because of a partial write. The provider may be attempting to read the resource, encountering a conflict, and holding the lock.
Step 2: Verify Actual API State vs. Terraform State
Drift occurs when the Genesys Cloud API state differs from the Terraform state file. For genesyscloud_routing_queue, common drift sources include:
- Default Value Changes: Genesys Cloud updates default values for new fields (e.g.,
wrap_up_timeoutdefaults changing). - Manual UI Changes: An admin changed a setting in the Genesys Cloud Admin console.
- Provider Bug: The provider sent a
PATCHrequest that partially failed, leaving the API in an inconsistent state.
We will write a Python script to fetch the live state of a specific queue and compare it to a snapshot of what Terraform expects.
import json
import sys
from purecloudplatformclientv2 import RoutingApi
def get_queue_live_state(client: PlatformClient, queue_id: str) -> dict:
Fetches the current state of a routing queue from the Genesys Cloud API.
api_instance = RoutingApi(client)
# Real API endpoint: GET /api/v2/routing/queues/{queueId}
response = api_instance.get_routing_queue(queue_id)
# Convert the SDK object to a serializable dictionary
# The SDK objects have a to_dict() method in newer versions,
# otherwise we use json serialization of the model
queue_data = {}
for attr, value in response.__dict__.items():
if not attr.startswith('_'):
queue_data[attr] = value
return queue_data
if e.status == 404:
print(f"Queue {queue_id} not found. Has it been deleted?")
return None
elif e.status == 403:
print(f"Permission denied. Ensure you have routing:queue:read scope.")
return None
else:
print(f"API Error: {e.status} - {e.reason}")
return None
def compare_with_terraform_state(live_data: dict, tf_state_snippet: dict) -> list:
Compares live API data with a provided Terraform state snippet.
Returns a list of discrepancies.
discrepancies = []
# Key fields that commonly drift
fields_to_check = ['name', 'description', 'skill_requirements', 'outbound_email', 'acw_wrap_up_timeout']
for field in fields_to_check:
live_val = live_data.get(field)
tf_val = tf_state_snippet.get(field)
# Normalize None/Null comparisons
if live_val is None and tf_val is None:
if live_val != tf_val:
discrepancies.append({
"field": field,
"terraform_value": tf_val,
"live_api_value": live_val
return discrepancies
if len(sys.argv) < 3:
print("Usage: python diagnose_drift.py <QUEUE_ID> <TF_STATE_JSON_PATH>")
sys.exit(1)
queue_id = sys.argv[1]
tf_state_path = sys.argv[2]
client = get_genesys_client()
# Load Terraform state snippet (usually from terraform state pull | jq .resources[] | jq '.[0].values')
with open(tf_state_path, 'r') as f:
tf_state = json.load(f)
live_data = get_queue_live_state(client, queue_id)
if live_data:
diffs = compare_with_terraform_state(live_data, tf_state)
if diffs:
print("DRIFT DETECTED:")
print(json.dumps(diffs, indent=2))
else:
print("No drift detected between live API and provided Terraform state snippet.")
else:
print("Could not retrieve live state.")
Real API Endpoint: /api/v2/routing/queues/{queueId}
Method: GET
Response Body Sample:
"id": "a1b2c3d4-5678-90ab-cdef-1234567890ab",
"name": "Support Queue",
"description": "Customer support queue",
"skill_requirements": [
"skill": {
"id": "skill123",
"name": "English"
"level": 1
"outbound_email": null,
"acw_wrap_up_timeout": 60
Step 3: Resolve Drift via Terraform Import or Refresh
If the script reveals drift, you have two options:
- Update Terraform State to Match API: If the API state is correct and Terraform is outdated.
- Update API to Match Terraform: If Terraform is the source of truth.
Option A: Refresh State (Recommended for Read-Only Drift)
Use terraform refresh to update the state file with the current API values. This does not change infrastructure but aligns the state file.
# Refresh the state for a specific resource
terraform refresh -target=genesyscloud_routing_queue.support_queue
Option B: Re-import the Resource
If the state is corrupted or the ID has changed, re-importing forces Terraform to read the current API state and update its internal representation.
# Syntax: terraform import <ADDRESS> <ID>
terraform import genesyscloud_routing_queue.support_queue <QUEUE_ID_FROM_API>
Option C: Fix Partial Write via API
If the lock persists because of a partial write (e.g., the queue name updated but the skill requirements did not), you may need to manually correct the API state to match a valid configuration before Terraform can proceed.
def fix_partial_write(client: PlatformClient, queue_id: str, desired_name: str, desired_description: str):
Manually updates a queue to a known good state to resolve partial write issues.
# Construct the body for PATCH /api/v2/routing/queues/{queueId}
# Note: The SDK uses RoutingQueueUpdateRequest or similar depending on version
from purecloudplatformclientv2.models import RoutingQueueUpdateRequest
body = RoutingQueueUpdateRequest(
name=desired_name,
description=desired_description
# Include other required fields if necessary, but PATCH is partial
# Real API endpoint: PATCH /api/v2/routing/queues/{queueId}
api_instance.patch_routing_queue(queue_id, body)
print(f"Queue {queue_id} manually updated to resolve partial write.")
print(f"Failed to update queue: {e.status} - {e.reason}")
# Usage example (call from main if needed)
# fix_partial_write(client, "a1b2c3d4...", "Corrected Name", "Corrected Desc")
This is a consolidated Python script that authenticates, checks for drift, and optionally forces a refresh if significant drift is detected.
#!/usr/bin/env python3
import os
import sys
import json
from purecloudplatformclientv2 import PlatformClient, RoutingApi
return client
print(f"Auth Failed: {e.reason}")
sys.exit(1)
def check_and_report_drift(client, queue_id, tf_state_file):
# Fetch live state
live_response = api_instance.get_routing_queue(queue_id)
# Load TF state
with open(tf_state_file, 'r') as f:
# Extract relevant fields for comparison
live_name = live_response.name
live_desc = live_response.description
live_acw = live_response.acw_wrap_up_timeout
tf_name = tf_state.get('name')
tf_desc = tf_state.get('description')
tf_acw = tf_state.get('acw_wrap_up_timeout')
drift_detected = False
print(f"Checking Queue ID: {queue_id}")
print("-" * 40)
if live_name != tf_name:
print(f"DRIFT: Name -> Live: '{live_name}' vs TF: '{tf_name}'")
drift_detected = True
if live_desc != tf_desc:
print(f"DRIFT: Description -> Live: '{live_desc}' vs TF: '{tf_desc}'")
if live_acw != tf_acw:
print(f"DRIFT: ACW Timeout -> Live: '{live_acw}' vs TF: '{tf_acw}'")
if not drift_detected:
print("No drift detected.")
return drift_detected
return False
if len(sys.argv) != 3:
print("Usage: python check_drift.py <QUEUE_ID> <TF_STATE_JSON_FILE>")
sys.exit(1)
tf_state_file = sys.argv[2]
has_drift = check_and_report_drift(client, queue_id, tf_state_file)
if has_drift:
print("\nRecommendation: Run 'terraform refresh -target=genesyscloud_routing_queue.YOUR_RESOURCE'")
Error: 409 Conflict on terraform apply
What causes it:
The Genesys Cloud API returned a 409 Conflict, often due to a unique constraint violation (e.g., duplicate queue name in the same language pack) or a state lock held by another process.
How to fix it:
- Check for duplicate queue names in the Genesys Cloud Admin console.
- Run
terraform force-unlock <LOCK_ID>if the conflict is due to a stale lock. - If the conflict is data-related, update the Terraform configuration to use a unique name.
What causes it:
Rate limiting. The Genesys Cloud API enforces strict rate limits. If terraform plan or apply triggers many API calls (e.g., updating many queues), you may hit the limit.
How to fix it:
Implement retry logic in your Terraform provider configuration if available, or manually wait and retry. In Python SDKs, use exponential backoff.
def api_call_with_retry(api_function, *args, retries=3, delay=1):
for attempt in range(retries):
return api_function(*args)
if e.status == 429 and attempt < retries - 1:
wait_time = delay * (2 ** attempt)
print(f"Rate limited. Waiting {wait_time} seconds...")
time.sleep(wait_time)
else:
raise
Error: Resource Not Found (404) on terraform plan
What causes it:
The resource exists in the Terraform state file but has been deleted from Genesys Cloud.
How to fix it:
Remove the resource from the Terraform state file.
terraform state rm genesyscloud_routing_queue.deleted_queue
Then run terraform plan to see the recreation plan if needed.
