Rerouting NICE CXone Pure Connect Calls via Node.js
  • A Node.js module that programmatically reroutes active Pure Connect calls using CXone Telephony APIs.
  • It validates call states, checks trunk capacity, calculates hunt group overflow, and executes atomic reroute operations.
  • The solution tracks latency, success rates, syncs events via webhooks, and generates audit logs for governance.
  • OAuth 2.0 Client Credentials grant type with scopes: telephony:calls:write, telephony:calls:read, telephony:read, events:write.
  • CXone API version v2.
  • Node.js 18+ runtime with npm.
  • External dependencies: axios, dotenv, uuid.
CXone uses a standard OAuth 2.0 Client Credentials flow. You must cache the access token and refresh it before expiration. The following implementation handles token retrieval, caching, and automatic refresh.
Required Scope: telephony:calls:write
require('dotenv').config();
 * @typedef {Object} TokenCache
 * @property {string} accessToken
 * @property {number} expiresAt
const TOKEN_CACHE = { accessToken: '', expiresAt: 0 };
const CXONE_BASE_URL = process.env.CXONE_BASE_URL || 'https://api.mynice.com';
 * Fetches an OAuth2 token from CXone with caching and refresh logic.
 * @returns {Promise<string>} Valid access token
async function getAuthToken() {
  const now = Date.now();
  if (TOKEN_CACHE.accessToken && now < TOKEN_CACHE.expiresAt - 60000) {
    return TOKEN_CACHE.accessToken;
    const response = await axios.post(`${CXONE_BASE_URL}/api/v2/oauth/token`, {
      client_id: process.env.CXONE_CLIENT_ID,
      client_secret: process.env.CXONE_CLIENT_SECRET,
      scope: 'telephony:calls:write telephony:calls:read telephony:read events:write'
    const data = response.data;
    TOKEN_CACHE.accessToken = data.access_token;
    TOKEN_CACHE.expiresAt = now + (data.expires_in * 1000);
    return data.access_token;
  } catch (error) {
    if (error.response?.status === 401) {
      throw new Error('OAuth authentication failed. Verify client credentials.');
    throw new Error(`Token retrieval failed: ${error.message}`);
Step 1: Call State Verification & Trunk Capacity Pipeline
Before initiating a reroute, you must verify the call state and ensure the target trunk has available capacity. CXone rejects reroute requests if the call is in a terminal state or if the trunk is at maximum concurrency.
Required Scope: telephony:calls:read, telephony:read
 * Validates call state and trunk capacity before rerouting.
 * @param {string} callId - The CXone call identifier
 * @param {string} trunkId - The target trunk identifier
 * @returns {Promise<{isValid: boolean, reason?: string}>}
async function validateCallAndTrunk(callId, trunkId) {
  const token = await getAuthToken();
    const [callResponse, trunkResponse] = await Promise.all([
      axios.get(`${CXONE_BASE_URL}/api/v2/telephony/calls/${callId}`, {
        headers: { Authorization: `Bearer ${token}` }
      axios.get(`${CXONE_BASE_URL}/api/v2/telephony/trunks/${trunkId}/stats`, {
    const callState = callResponse.data.callState;
    const allowedStates = ['connected', 'ringing', 'alerting'];
    if (!allowedStates.includes(callState)) {
      return { isValid: false, reason: `Call state '${callState}' does not permit rerouting.` };
    const trunkStats = trunkResponse.data;
    const currentConcurrent = trunkStats.currentConcurrentSessions || 0;
    const maxConcurrent = trunkStats.maxConcurrentSessions || 0;
    if (currentConcurrent >= maxConcurrent) {
      return { isValid: false, reason: 'Trunk capacity reached. No available sessions.' };
    return { isValid: true };
  } catch (error) {
    if (error.response?.status === 404) {
      return { isValid: false, reason: 'Call or trunk not found.' };
    throw error;
Step 2: Hunt Group Selection & Overflow Calculation
Pure Connect routing relies on destination matrices and overflow thresholds. You must calculate the current load of available hunt groups and select the optimal target based on overflow logic.
Required Scope: telephony:read
 * Calculates overflow and selects the optimal hunt group.
 * @param {string[]} huntGroupIds - Array of candidate hunt group IDs
 * @param {number} overflowThreshold - Maximum allowed concurrent calls before overflow
 * @returns {Promise<{selectedHuntGroupId: string, overflowRate: number}>}
async function selectHuntGroup(huntGroupIds, overflowThreshold) {
  let bestGroup = null;
  let lowestOverflowRate = Infinity;
  for (const groupId of huntGroupIds) {
      const response = await axios.get(`${CXONE_BASE_URL}/api/v2/telephony/huntgroups/${groupId}/stats`, {
      const stats = response.data;
      const currentLoad = stats.currentConcurrentSessions || 0;
      const capacity = stats.maxConcurrentSessions || 1;
      const overflowRate = currentLoad / capacity;
      if (overflowRate < overflowThreshold && overflowRate < lowestOverflowRate) {
        lowestOverflowRate = overflowRate;
        bestGroup = groupId;
    } catch (error) {
      console.warn(`Failed to fetch stats for hunt group ${groupId}: ${error.message}`);
      continue;
  if (!bestGroup) {
    throw new Error('No hunt group available within overflow threshold.');
  return { selectedHuntGroupId: bestGroup, overflowRate: lowestOverflowRate };
Step 3: Construct Reroute Payload & Atomic Execution
The reroute operation requires a strictly formatted payload containing the call reference, destination matrix entry, and redirect directive. CXone enforces a maximum hop count to prevent routing loops. You must validate the schema and execute the atomic POST request with retry logic for rate limiting.
const MAX_HOP_COUNT = 5;
 * Executes the atomic reroute operation with 429 retry logic.
 * @param {string} callId - The call identifier
 * @param {string} destination - Target number, extension, or hunt group ID
 * @param {string} destinationType - 'number', 'extension', or 'huntgroup'
 * @param {number} currentHopCount - Number of previous reroutes
 * @returns {Promise<Object>} API response data
async function executeReroute(callId, destination, destinationType, currentHopCount) {
  if (currentHopCount >= MAX_HOP_COUNT) {
    throw new Error(`Maximum hop count (${MAX_HOP_COUNT}) exceeded. Reroute rejected to prevent routing loop.`);
  const payload = {
    destination: destination,
    type: destinationType,
    transferType: 'blind',
    callReference: {
      callId: callId,
      redirectDirective: 'force',
      hopCount: currentHopCount + 1
    format: 'rfc3966'
  const url = `${CXONE_BASE_URL}/api/v2/telephony/calls/${callId}/transfer`;
  // Retry logic for 429 rate limiting
  let retries = 0;
  const maxRetries = 3;
  const baseDelay = 1000;
  while (retries <= maxRetries) {
      const response = await axios.post(url, payload, {
        headers: {
          Authorization: `Bearer ${token}`,
          'Content-Type': 'application/json'
        timeout: 10000
      return response.data;
    } catch (error) {
      if (error.response?.status === 429 && retries < maxRetries) {
        const delay = baseDelay * Math.pow(2, retries);
        console.warn(`Rate limited (429). Retrying in ${delay}ms...`);
        retries++;
        continue;
      throw error;
Step 4: Synchronize Rerouting Events & Track Metrics
You must synchronize reroute events with external monitoring systems via webhooks. The following pipeline tracks latency, calculates success rates, and emits structured audit logs for telephony governance.
Required Scope: events:write
const { v4: uuidv4 } = require('uuid');
 * Emits reroute event to external webhook and records audit metrics.
 * @param {Object} eventPayload - Reroute execution details
 * @param {string} webhookUrl - External monitoring endpoint
async function syncRerouteEvent(eventPayload, webhookUrl) {
  const auditLog = {
    auditId: uuidv4(),
    callId: eventPayload.callId,
    destination: eventPayload.destination,
    latencyMs: eventPayload.latencyMs,
    success: eventPayload.success,
    hopCount: eventPayload.hopCount,
    overflowRate: eventPayload.overflowRate,
    governanceTag: 'telephony_reroute_audit'
  console.log('AUDIT LOG:', JSON.stringify(auditLog, null, 2));
    await axios.post(webhookUrl, auditLog, {
      timeout: 5000
  } catch (error) {
    console.error(`Webhook sync failed for call ${eventPayload.callId}: ${error.message}`);
    // Non-fatal: logging failure does not abort telephony operation
The following script combines all components into a production-ready rerouter module. Replace the environment variables with your CXone credentials before execution.
// Authentication & Token Management
    }, { headers: { 'Content-Type': 'application/x-www-form-urlencoded' } });
  } catch (error) {
// Validation Pipeline
    const [callRes, trunkRes] = await Promise.all([
      axios.get(`${CXONE_BASE_URL}/api/v2/telephony/calls/${callId}`, { headers: { Authorization: `Bearer ${token}` } }),
      axios.get(`${CXONE_BASE_URL}/api/v2/telephony/trunks/${trunkId}/stats`, { headers: { Authorization: `Bearer ${token}` } })
    const callState = callRes.data.callState;
    if (!['connected', 'ringing', 'alerting'].includes(callState)) {
      return { isValid: false, reason: `Invalid call state: ${callState}` };
    const currentConcurrent = trunkRes.data.currentConcurrentSessions || 0;
    const maxConcurrent = trunkRes.data.maxConcurrentSessions || 0;
      return { isValid: false, reason: 'Trunk at maximum capacity' };
  } catch (error) {
    return { isValid: false, reason: error.response?.status === 404 ? 'Resource not found' : error.message };
// Hunt Group Selection
      const res = await axios.get(`${CXONE_BASE_URL}/api/v2/telephony/huntgroups/${groupId}/stats`, { headers: { Authorization: `Bearer ${token}` } });
      const load = res.data.currentConcurrentSessions || 0;
      const cap = res.data.maxConcurrentSessions || 1;
      const rate = load / cap;
      if (rate < overflowThreshold && rate < lowestOverflowRate) {
        lowestOverflowRate = rate;
    } catch (e) { continue; }
  if (!bestGroup) throw new Error('No hunt group available within threshold');
// Atomic Reroute Execution
  if (currentHopCount >= 5) throw new Error('Maximum hop count exceeded');
  const payload = {
    destination,
    callReference: { callId, redirectDirective: 'force', hopCount: currentHopCount + 1 },
    format: 'rfc3966'
  let retries = 0;
  while (retries <= 3) {
      const res = await axios.post(url, payload, { headers: { Authorization: `Bearer ${token}`, 'Content-Type': 'application/json' }, timeout: 10000 });
      return res.data;
    } catch (error) {
      if (error.response?.status === 429 && retries < 3) {
        await new Promise(r => setTimeout(r, 1000 * Math.pow(2, retries)));
        retries++;
        continue;
      throw error;
// Webhook Sync & Audit
async function syncRerouteEvent(eventData, webhookUrl) {
  const auditLog = {
    auditId: require('uuid').v4(),
    ...eventData,
    await axios.post(webhookUrl, auditLog, { headers: { 'Content-Type': 'application/json' }, timeout: 5000 });
  } catch (e) {
    console.error('Webhook sync failed:', e.message);
// Main Orchestrator
async function rerouteCall(callId, trunkId, candidateHuntGroups, overflowThreshold, webhookUrl) {
  const start = Date.now();
  console.log(`Initiating reroute for call: ${callId}`);
  const validation = await validateCallAndTrunk(callId, trunkId);
  if (!validation.isValid) {
    console.error(`Validation failed: ${validation.reason}`);
    await syncRerouteEvent({ callId, success: false, latencyMs: Date.now() - start, hopCount: 0 }, webhookUrl);
    return;
  const { selectedHuntGroupId, overflowRate } = await selectHuntGroup(candidateHuntGroups, overflowThreshold);
  console.log(`Selected hunt group: ${selectedHuntGroupId} (overflow rate: ${overflowRate.toFixed(2)})`);
    const result = await executeReroute(callId, selectedHuntGroupId, 'huntgroup', 0);
    const latency = Date.now() - start;
    console.log(`Reroute successful: ${JSON.stringify(result)}`);
    await syncRerouteEvent({ callId, destination: selectedHuntGroupId, success: true, latencyMs: latency, hopCount: 1, overflowRate }, webhookUrl);
  } catch (error) {
    console.error(`Reroute failed: ${error.message}`);
    await syncRerouteEvent({ callId, destination: selectedHuntGroupId, success: false, latencyMs: latency, hopCount: 0, overflowRate }, webhookUrl);
// Usage
// rerouteCall('call-12345', 'trunk-67890', ['hg-001', 'hg-002'], 0.85, 'https://monitoring.internal/webhook');
Error: 400 Bad Request
  • What causes it: The payload schema violates telephony constraints, the call state does not permit transfer, or the destination format is invalid.
  • How to fix it: Verify callState matches connected, ringing, or alerting. Ensure destination matches the type field exactly. Use RFC 3966 formatting for numbers.
  • Code showing the fix: Add explicit schema validation before POST execution. Check payload.type against allowed values ['number', 'extension', 'huntgroup'].
  • What causes it: The OAuth token expired during the request pipeline or was never cached correctly.
  • How to fix it: Implement token refresh logic that checks expires_in before each request. The provided getAuthToken function handles this automatically.
  • Code showing the fix: Ensure Authorization: Bearer ${token} header is attached to every request. Never reuse tokens past their expiration window.
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the required scopes, or the target tenant restricts API access.
  • How to fix it: Request telephony:calls:write, telephony:calls:read, and telephony:read scopes during token acquisition. Verify the client ID is whitelisted for telephony operations in the CXone admin console.
  • Code showing the fix: Update the OAuth request body scope parameter to include all required telephony permissions.
  • What causes it: CXone rate limits are enforced per tenant or per endpoint. Bulk reroute operations trigger throttling.
  • How to fix it: Implement exponential backoff. The executeReroute function includes a retry loop that delays execution on 429 responses.
  • Code showing the fix: Use await new Promise(resolve => setTimeout(resolve, baseDelay * Math.pow(2, retryCount))) before retrying.
Error: 409 Conflict
  • What causes it: The call is already being transferred, or another process has locked the call state.
  • How to fix it: Check the callState before initiating the reroute. If the state is transferring or completed, abort the operation and log a governance warning.
  • Code showing the fix: Add a state check in the validation pipeline that returns isValid: false when callState === 'transferring'.
