Reporting on multimedia Virtual queue issue
dears i have a problem on reporting on a chat virtual queue the issue is that the virtual queue created has interaction counted on it, but when running queue report on it on Interactive Insights, the report returned no data, and after investigating, i found that those chat interactions have been inserted with “Resource_Key” of the interaction queue that the chat strategy is loaded on, and no records for those interactions with the virtual queue that they are counting on.
So please advise what should i do so that i got the reports on the Virtual queue.
Is the VQ used in any routing logic/strategy?
Yes, it is used in the composer workflow used in Chat routing in “route interaction” block.
Thanks for your fast response.
Try changing the option gim-etl-populate\populate-mm-ixnqueue-facts to “false” (without quotes) for the Script object of this Interaction Queue (not the VQ) which is appearing on the report. Alternatively, to remove all the Interaction Queues keeping only the virtual queues, set the same option on the Info Mart application.
this option is already set with “false” in GIM app. Also my issue is that the VQ is not populated in the GIM, i have no records for MM VQ in the MSF or IRF tables and this causes the VQ to return no data in the Interactive Insights reports. so please advise which options should i set so that i get records for the MM VQ in MSF or IRF.
Yup… if this option was set to true, the expected bebavior would be what is happening to you. Since its false, it might be something else. To be sure that it is a GIM issue and not an ICON/Routing issue, confirm that there are records on the table GIDB_G_VIRTUAL_QUEUE_MM of your GIM schema containing the Virtual Queue that you want reporting on
No there is no records for that VQ in GIDB_G_VIRTUAL_QUEUE, so what is the problem now?
Is your CFG ICON working properly?
what do mean by working properly.
Check if option callconcentrator\vq-write-mode is ser to “1” on the Multimedia ICON too :slight_smile:
