Replicating NICE CXone Data Actions Cross-Tenant Records with Go
- Build a Go service that constructs and executes cross-tenant data replication payloads using the NICE CXone Data Actions API.
- Use the official CXone Go SDK to manage atomic POST operations, schema validation, and webhook synchronization.
- Implement retry logic, latency tracking, and audit logging for production-grade federation workflows.
- OAuth Client ID and Secret with scopes:
dataactions:write,dataactions:read,federation:read,account:read,integrations:webhooks:write - CXone Go SDK v2.5+ (
github.com/NiceCXone/nice-cxone-go-sdk/v2) - Go 1.21+ runtime
- External dependencies:
go get github.com/NiceCXone/nice-cxone-go-sdk/v2 golang.org/x/oauth2 golang.org/x/oauth2/clientcredentials
CXone uses OAuth 2.0 Client Credentials flow. The token must be cached and refreshed automatically to avoid interrupting replication pipelines.
package auth
import (
"context"
"time"
"golang.org/x/oauth2"
"golang.org/x/oauth2/clientcredentials"
func NewCXoneOAuth2Config(domain, clientID, clientSecret string) *oauth2.Config {
return &clientcredentials.Config{
ClientID: clientID,
ClientSecret: clientSecret,
TokenURL: "https://" + domain + ".api.cxone.com/oauth/token",
Scopes: []string{
"dataactions:write",
"dataactions:read",
"federation:read",
"account:read",
"integrations:webhooks:write",
EndpointParams: []oauth2.EndpointParam{},
func NewTokenSource(ctx context.Context, cfg *oauth2.Config) oauth2.TokenSource {
src := cfg.TokenSource(ctx)
return oauth2.ReuseTokenSource(nil, src)
The oauth2.ReuseTokenSource wrapper prevents redundant token requests. The SDK will attach the bearer token to every outgoing request automatically when passed via http.Client.
Step 1: Construct Replicate Payloads and Validate Against Federation Constraints
Cross-tenant replication requires a structured payload containing source references, a tenant matrix, and transform directives. Before submission, the payload must pass schema validation and federation limit checks. CXone enforces a maximum cross-account limit of 10 target tenants per single data action run.
package replicator
import (
"context"
"encoding/json"
"fmt"
"time"
"github.com/NiceCXone/nice-cxone-go-sdk/v2/client"
"github.com/NiceCXone/nice-cxone-go-sdk/v2/config"
type TenantMatrix struct {
SourceTenantID string `json:"sourceTenantId"`
TargetTenants []string `json:"targetTenants"`
type TransformDirective struct {
SourceField string `json:"sourceField"`
TargetField string `json:"targetField"`
TransformType string `json:"transformType"` // "MAP", "FLATTEN", "HASH"
type ReplicatePayload struct {
DefinitionID string `json:"definitionId"`
TenantMatrix TenantMatrix `json:"tenantMatrix"`
TransformRules []TransformDirective `json:"transformRules"`
SchemaVersion string `json:"schemaVersion"`
type CrossTenantReplicator struct {
client *client.APIClient
oauthSrc oauth2.TokenSource
metrics *ReplicationMetrics
type ReplicationMetrics struct {
TotalAttempts int
SuccessCount int
FailedCount int
TotalLatencyMs int64
func NewCrossTenantReplicator(domain, clientID, clientSecret string) *CrossTenantReplicator {
cfg := config.NewConfig(
domain,
clientID,
clientSecret,
config.WithTokenURL("https://"+domain+".api.cxone.com/oauth/token"),
config.WithScopes("dataactions:write", "dataactions:read", "federation:read", "account:read", "integrations:webhooks:write"),
return &CrossTenantReplicator{
client: client.NewClient(cfg),
oauthSrc: cfg.TokenSource(context.Background()),
metrics: &ReplicationMetrics{},
func (r *CrossTenantReplicator) ValidatePayload(ctx context.Context, payload *ReplicatePayload) error {
if len(payload.TenantMatrix.TargetTenants) > 10 {
return fmt.Errorf("federation constraint violation: maximum cross-account limit is 10 tenants, got %d", len(payload.TenantMatrix.TargetTenants))
if payload.SchemaVersion == "" {
return fmt.Errorf("schema validation failed: schemaVersion is required")
for _, rule := range payload.TransformRules {
if rule.TransformType != "MAP" && rule.TransformType != "FLATTEN" && rule.TransformType != "HASH" {
return fmt.Errorf("transform directive invalid: unsupported type %s", rule.TransformType)
return nil
OAuth Scopes Required: dataactions:write, federation:read
API Endpoint: /api/v2/dataactions/runs (POST)
The validation function enforces platform constraints before network I/O. The CXone federation engine rejects runs exceeding tenant limits or containing malformed transform directives.
Step 2: Execute Atomic POST Operations with Retry and Format Verification
Data action runs are atomic. The payload must be serialized to JSON, verified for format compliance, and submitted with exponential backoff for rate limits.
func (r *CrossTenantReplicator) ExecuteReplication(ctx context.Context, payload *ReplicatePayload) error {
if err := r.ValidatePayload(ctx, payload); err != nil {
return fmt.Errorf("pre-flight validation failed: %w", err)
body, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("serialization failed: %w", err)
startTime := time.Now()
r.metrics.TotalAttempts++
var lastErr error
for attempt := 0; attempt < 5; attempt++ {
runRequest := client.DataActionsRun{
Definition: json.RawMessage(body),
resp, httpResp, err := r.client.DataActionsAPI.RunDefinition(ctx).DataActionsRun(runRequest).Execute()
if err != nil {
lastErr = err
if httpResp != nil && httpResp.StatusCode == 429 {
backoff := time.Duration(1<<attempt) * time.Second
time.Sleep(backoff)
return fmt.Errorf("data action execution failed: %w", err)
if resp.StatusCode == nil || *resp.StatusCode != 202 {
return fmt.Errorf("unexpected response status: %v", resp.StatusCode)
latency := time.Since(startTime).Milliseconds()
r.metrics.TotalLatencyMs += latency
r.metrics.SuccessCount++
return nil
r.metrics.FailedCount++
return fmt.Errorf("replication failed after retries: %w", lastErr)
API Endpoint: POST /api/v2/dataactions/runs
The retry loop handles 429 Too Many Requests responses. CXone enforces rate limits at 100 requests per minute per client ID. The exponential backoff prevents cascade failures. The response returns 202 Accepted with an asynchronous run ID.
Step 3: Register Webhooks, Track Latency, and Generate Audit Logs
External data lakes require event synchronization. CXone webhooks trigger on dataaction.run.completed. The replicator registers the webhook, calculates success rates, and writes structured audit logs for federation governance.
func (r *CrossTenantReplicator) RegisterSyncWebhook(ctx context.Context, targetURL, secret string) error {
webhook := client.Webhook{
Url: targetURL,
Events: []string{"dataaction.run.completed", "dataaction.run.failed"},
Secret: &secret,
ContentType: "application/json",
_, httpResp, err := r.client.IntegrationsAPI.CreateWebhook(ctx).Webhook(webhook).Execute()
if err != nil {
return fmt.Errorf("webhook registration failed: %w", err)
if httpResp.StatusCode != 201 {
return fmt.Errorf("unexpected webhook response: %d", httpResp.StatusCode)
return nil
func (r *CrossTenantReplicator) GenerateAuditLog(runID string, success bool, latencyMs int64) []byte {
logEntry := map[string]interface{}{
"timestamp": time.Now().UTC().Format(time.RFC3339),
"runId": runID,
"status": success,
"latencyMs": latencyMs,
"successRate": float64(r.metrics.SuccessCount) / float64(r.metrics.TotalAttempts),
"totalLatency": r.metrics.TotalLatencyMs,
logBytes, _ := json.MarshalIndent(logEntry, "", " ")
return logBytes
func (r *CrossTenantReplicator) GetSyncSuccessRate() float64 {
if r.metrics.TotalAttempts == 0 {
return 0.0
return float64(r.metrics.SuccessCount) / float64(r.metrics.TotalAttempts)
OAuth Scopes Required: integrations:webhooks:write, dataactions:read
API Endpoint: POST /api/v2/integrations/webhooks
The webhook captures replication completion events. The audit log includes latency, success rate, and run identifiers. Governance pipelines can ingest these logs for compliance reporting.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"os"
metrics ReplicationMetrics
TotalAttempts int
SuccessCount int
FailedCount int
domain,
clientID,
clientSecret,
func (r *CrossTenantReplicator) ValidatePayload(payload *ReplicatePayload) error {
return nil
if err := r.ValidatePayload(payload); err != nil {
if err != nil {
_, httpResp, err := r.client.DataActionsAPI.RunDefinition(ctx).DataActionsRun(runRequest).Execute()
if err != nil {
return fmt.Errorf("rate limited (429): backoff and retry")
if httpResp.StatusCode != 202 {
return fmt.Errorf("unexpected response status: %d", httpResp.StatusCode)
return nil
Url: targetURL,
Secret: &secret,
if err != nil {
return nil
func main() {
ctx := context.Background()
domain := os.Getenv("CXONE_DOMAIN")
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
replicator := NewCrossTenantReplicator(domain, clientID, clientSecret)
payload := &ReplicatePayload{
DefinitionID: "def_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c",
TenantMatrix: TenantMatrix{
SourceTenantID: "tenant_source_001",
TargetTenants: []string{"tenant_target_002", "tenant_target_003"},
TransformRules: []TransformDirective{
{SourceField: "contact_id", TargetField: "ext_contact_id", TransformType: "MAP"},
{SourceField: "interaction_data", TargetField: "payload", TransformType: "FLATTEN"},
SchemaVersion: "v2.1",
if err := replicator.ExecuteReplication(ctx, payload); err != nil {
log.Fatalf("Replication failed: %v", err)
log.Println("Replication run submitted successfully")
if err := replicator.RegisterSyncWebhook(ctx, "https://data-lake.example.com/webhooks/cxone", "whk_secret_abc123"); err != nil {
log.Fatalf("Webhook registration failed: %v", err)
log.Println("Sync webhook registered")
- Cause: Expired OAuth token or missing
Authorization: Bearerheader. The CXone SDK handles token refresh automatically when initialized withconfig.NewConfig(). If using raw HTTP, verify the token endpoint returns a validaccess_token. - Fix: Ensure
clientcredentials.Configmatches the registered OAuth client. Restart the service to force token regeneration if the token cache is corrupted.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or tenant access restrictions. Cross-tenant replication requires
federation:readanddataactions:write. The executing client must have administrator or data action manager roles in both source and target tenants. - Fix: Verify the OAuth client scope list in the CXone admin console. Assign the client to the federation access group.
Error: 400 Bad Request
- Cause: Payload schema mismatch or transform directive violation. CXone rejects runs containing unsupported transform types or missing
schemaVersion. - Fix: Validate the JSON structure against the Data Actions schema. Ensure
transformTypeuses uppercase values (MAP,FLATTEN,HASH). Check thatdefinitionIdreferences an active data action definition.
- Cause: Rate limit exhaustion. CXone enforces 100 requests per minute per client ID for data action endpoints.
- Fix: Implement exponential backoff with jitter. The complete example includes a retry loop. Throttle concurrent replication jobs to stay under the limit.
Error: Federation Constraint Violation
- Cause: Exceeding the maximum cross-account limit of 10 target tenants per run.
- Fix: Split the target tenant list into batches of 10. Execute sequential runs and aggregate results in the external data lake.
