Replaying NICE CXone EventBridge Failed Events from Dead Letter Queues with Python
- A Python service that extracts failed events from CXone EventBridge dead letter queues, reconstructs them with retry metadata and destination overrides, and replays them using atomic PUT operations.
- This implementation uses the CXone EventBridge REST API (
/api/v2/eventbridge/dlq/eventsand/api/v2/eventbridge/topics/{topicId}/events) with OAuth2 authentication. - The tutorial covers Python 3.10+ using
httpxfor HTTP transport,pydanticfor schema validation, and standard logging for audit trails.
- OAuth2 client credentials registered in CXone with scopes:
eventbridge:read,eventbridge:write - CXone EventBridge API version
v2 - Python 3.10 or higher
- External dependencies:
pip install httpx pydantic python-dotenv - Network access to your CXone region endpoint (e.g.,
https://api.nicecxone.comor region-specific variant)
CXone uses standard OAuth2 client credentials flow for server-to-server API access. The token endpoint requires your client ID, client secret, and the exact scopes needed for EventBridge operations.
import httpx
import os
from typing import Optional
from dataclasses import dataclass
@dataclass
class CxoneTokenResponse:
access_token: str
token_type: str
expires_in: int
scope: str
def fetch_cxone_token(client_id: str, client_secret: str, region: str = "api.nicecxone.com") -> CxoneTokenResponse:
Retrieves an OAuth2 access token from CXone.
Required scopes: eventbridge:read, eventbridge:write
token_url = f"https://{region}/oauth2/token"
payload = {
"client_id": client_id,
"client_secret": client_secret,
"scope": "eventbridge:read eventbridge:write"
with httpx.Client(timeout=10.0) as client:
response = client.post(token_url, data=payload)
response.raise_for_status()
data = response.json()
return CxoneTokenResponse(
access_token=data["access_token"],
token_type=data["token_type"],
expires_in=data["expires_in"],
scope=data["scope"]
# Example request/response cycle
# POST /oauth2/token
# Headers: Content-Type: application/x-www-form-urlencoded
# Body: grant_type=client_credentials&client_id=YOUR_ID&client_secret=YOUR_SECRET&scope=eventbridge:read%20eventbridge:write
# Response 200 OK:
# "access_token": "eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...",
# "token_type": "Bearer",
# "expires_in": 86400,
# "scope": "eventbridge:read eventbridge:write"
Token caching is required for production systems. Implement a simple TTL cache or use a framework like botocore-style credential providers. The example below assumes tokens are refreshed before expiration.
Step 1: Retrieve Dead Letter Queue Events with Pagination
CXone EventBridge exposes failed events through the DLQ endpoint. The API supports pagination via limit and nextPageToken. You must handle pagination to process all failed events.
import httpx
import logging
from typing import List, Dict, Any, Optional
def fetch_dlq_events(
base_url: str,
token: str,
topic_id: str,
limit: int = 50
) -> List[Dict[str, Any]]:
Retrieves failed events from CXone EventBridge DLQ.
OAuth Scope: eventbridge:read
all_events: List[Dict[str, Any]] = []
next_token: Optional[str] = None
endpoint = f"{base_url}/api/v2/eventbridge/dlq/events"
headers = {
"Accept": "application/json"
while True:
params = {"topicId": topic_id, "limit": limit}
if next_token:
params["nextPageToken"] = next_token
with httpx.Client(timeout=15.0) as client:
response = client.get(endpoint, headers=headers, params=params)
retry_after = int(response.headers.get("Retry-After", 5))
logger.warning("Rate limited (429). Retrying in %d seconds.", retry_after)
logger.error("DLQ fetch failed: %s", e.response.status_code)
raise
events = data.get("events", [])
all_events.extend(events)
next_token = data.get("nextPageToken")
if not next_token or len(events) < limit:
break
return all_events
# Example response structure from /api/v2/eventbridge/dlq/events
# "events": [
# "eventId": "evt_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c",
# "topicId": "topic_pub_conversations",
# "payload": {"conversationId": "conv_123", "type": "conversation:start", "timestamp": "2024-05-10T14:30:00Z"},
# "failureReason": "HTTP 502 Bad Gateway",
# "retryCount": 3,
# "firstFailureTimestamp": "2024-05-10T14:30:05Z",
# "lastFailureTimestamp": "2024-05-10T14:35:00Z"
# "nextPageToken": "eyJwYWdlIjoxfQ=="
Step 2: Construct Replay Payloads with Retry Matrices and Destination Overrides
Failed events must be reconstructed with explicit retry tracking and destination routing directives. CXone EventBridge accepts custom headers and payload extensions for routing.
import uuid
def build_replay_payload(
original_event: Dict[str, Any],
destination_override: Optional[str] = None,
max_retries: int = 5
) -> Dict[str, Any]:
Constructs a replay-ready event payload with idempotency keys,
retry matrices, and destination override directives.
current_retry = original_event.get("retryCount", 0) + 1
if current_retry > max_retries:
raise ValueError(f"Event {original_event['eventId']} exceeded maximum retry window of {max_retries}.")
idempotency_key = f"replay-{original_event['eventId']}-v{current_retry}"
replay_payload = {
"eventId": original_event["eventId"],
"idempotencyKey": idempotency_key,
"originalPayload": original_event["payload"],
"retryMatrix": {
"currentAttempt": current_retry,
"maxAllowed": max_retries,
"firstFailure": original_event.get("firstFailureTimestamp"),
"lastFailure": original_event.get("lastFailureTimestamp"),
"failureReason": original_event.get("failureReason")
"routingDirective": {
"destinationOverride": destination_override,
"preserveOriginalTopic": destination_override is None
"replayMetadata": {
"initiatedAt": datetime.now(timezone.utc).isoformat(),
"clientVersion": "1.0.0"
return replay_payload
# Example constructed payload
# "idempotencyKey": "replay-evt_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c-v4",
# "originalPayload": {"conversationId": "conv_123", "type": "conversation:start", "timestamp": "2024-05-10T14:30:00Z"},
# "retryMatrix": {
# "currentAttempt": 4,
# "maxAllowed": 5,
# "firstFailure": "2024-05-10T14:30:05Z",
# "lastFailure": "2024-05-10T14:35:00Z",
# "routingDirective": {
# "destinationOverride": "https://secure-replay-endpoint.example.com/webhook",
# "preserveOriginalTopic": false
# "replayMetadata": {
# "initiatedAt": "2024-05-11T09:15:22.103Z",
# "clientVersion": "1.0.0"
Step 3: Validate Replay Schemas Against Bus Constraints and Maximum Replay Windows
CXone EventBridge enforces payload size limits (typically 256KB) and schema constraints. You must validate before submission to prevent bus rejection and infinite loop failures.
from pydantic import BaseModel, Field, field_validator
class RetryMatrix(BaseModel):
currentAttempt: int
maxAllowed: int
firstFailure: Optional[str]
lastFailure: Optional[str]
failureReason: Optional[str]
class RoutingDirective(BaseModel):
destinationOverride: Optional[str]
preserveOriginalTopic: bool
class ReplayPayloadSchema(BaseModel):
eventId: str
idempotencyKey: str
originalPayload: dict
retryMatrix: RetryMatrix
routingDirective: RoutingDirective
replayMetadata: dict
@field_validator("retryMatrix")
@classmethod
def validate_retry_window(cls, v: RetryMatrix) -> RetryMatrix:
if v.currentAttempt > v.maxAllowed:
raise ValueError("Replay attempt exceeds maximum allowed retry window.")
return v
@field_validator("originalPayload")
@classmethod
def validate_payload_size(cls, v: dict) -> dict:
import json
size_bytes = len(json.dumps(v).encode("utf-8"))
if size_bytes > 262144: # 256KB limit
raise ValueError("Original payload exceeds EventBridge maximum size of 256KB.")
return v
def validate_replay_payload(payload: Dict[str, Any]) -> ReplayPayloadSchema:
Validates the constructed replay payload against CXone EventBridge constraints.
validated = ReplayPayloadSchema(**payload)
return validated
logger.error("Schema validation failed: %s", str(e))
raise
# Example validation flow
# Input: constructed replay payload
# Output: Validated ReplayPayloadSchema object
# Throws ValueError if retry window exceeded or payload size > 256KB
Step 4: Execute Atomic PUT Operations with Idempotency and Error Classification
Replay submission uses an atomic PUT request to the topic event endpoint. CXone EventBridge supports idempotency via the Idempotency-Key header. You must implement error classification to distinguish between transient failures and permanent corruption.
import json
def classify_error(status_code: int, response_text: str) -> str:
Classifies HTTP errors for replay routing decisions.
if status_code in (400, 422):
return "SCHEMA_VIOLATION"
elif status_code == 409:
return "DUPLICATE_DETECTED"
elif status_code == 413:
return "PAYLOAD_TOO_LARGE"
elif status_code >= 500:
return "SERVER_TRANSIENT"
return "UNKNOWN_FAILURE"
def replay_event_to_topic(
base_url: str,
token: str,
topic_id: str,
payload: Dict[str, Any],
max_backoff_retries: int = 3
Submits the replay payload to CXone EventBridge via atomic PUT.
OAuth Scope: eventbridge:write
endpoint = f"{base_url}/api/v2/eventbridge/topics/{topic_id}/events"
idempotency_key = payload.get("idempotencyKey", str(uuid.uuid4()))
headers = {
"Idempotency-Key": idempotency_key,
with httpx.Client(timeout=20.0) as client:
for attempt in range(1, max_backoff_retries + 1):
response = client.put(endpoint, headers=headers, json=payload)
wait_time = min(2 ** attempt, 30)
logger.warning("Rate limited on replay. Backing off %d seconds.", wait_time)
time.sleep(wait_time)
if response.status_code in (400, 409, 413, 422):
error_class = classify_error(response.status_code, response.text)
logger.error("Fatal replay error [%s]: %s", error_class, response.text)
return {"status": "FAILED", "classification": error_class, "response": response.json()}
return {"status": "SUCCESS", "response": response.json()}
except httpx.HTTPError as e:
logger.error("Network error on attempt %d: %s", attempt, str(e))
if attempt == max_backoff_retries:
raise
return {"status": "EXHAUSTED", "classification": "MAX_RETRIES_EXCEEDED"}
# PUT /api/v2/eventbridge/topics/topic_pub_conversations/events
# Headers: Authorization: Bearer <token>, Content-Type: application/json, Idempotency-Key: replay-evt_...-v4
# Body: {validated replay payload}
# Response 201 Created:
# "status": "queued",
# "routingStatus": "delivered",
# "processedAt": "2024-05-11T09:15:23.450Z"
Step 5: Synchronize Monitoring, Track Latency, and Generate Audit Logs
Production replay systems require latency tracking, success rate calculation, and audit logging for compliance. You will sync replay events to an external monitoring webhook and maintain a structured audit trail.
import json
from dataclasses import dataclass, asdict
from typing import Dict, Any
@dataclass
class ReplayAuditRecord:
event_id: str
action: str
status: str
error_classification: Optional[str]
latency_ms: float
timestamp: str
idempotency_key: str
destination: str
def send_monitoring_alert(webhook_url: str, audit_record: ReplayAuditRecord) -> None:
Synchronizes replay status with external monitoring via webhook callback.
alert_payload = {
"source": "cxone-eventbridge-replayer",
"type": "replay_status_update",
"data": asdict(audit_record)
with httpx.Client(timeout=5.0) as client:
client.post(
webhook_url,
json=alert_payload,
headers={"Content-Type": "application/json"}
logger.warning("Failed to send monitoring alert: %s", str(e))
def process_replay_pipeline(
base_url: str,
token: str,
topic_id: str,
dlq_events: List[Dict[str, Any]],
monitoring_webhook: str,
) -> Dict[str, int]:
Orchestrates the full replay pipeline with latency tracking and audit logging.
stats = {"success": 0, "failed": 0, "skipped": 0}
audit_log: List[ReplayAuditRecord] = []
for event in dlq_events:
start_time = time.time()
event_id = event.get("eventId", "unknown")
# Step 2: Construct payload
replay_payload = build_replay_payload(event, destination_override)
# Step 3: Validate schema
validate_replay_payload(replay_payload)
# Step 4: Execute replay
result = replay_event_to_topic(base_url, token, topic_id, replay_payload)
status = result.get("status", "UNKNOWN")
classification = result.get("classification")
audit_record = ReplayAuditRecord(
event_id=event_id,
action="REPLAY_PUT",
status=status,
error_classification=classification,
latency_ms=round(latency_ms, 2),
timestamp=datetime.now(timezone.utc).isoformat(),
idempotency_key=replay_payload["idempotencyKey"],
destination=destination_override or topic_id
if status == "SUCCESS":
stats["success"] += 1
else:
stats["failed"] += 1
audit_log.append(audit_record)
send_monitoring_alert(monitoring_webhook, audit_record)
logger.error("Pipeline failure for event %s: %s", event_id, str(e))
# Write audit log to file for compliance
with open("replay_audit_log.json", "w") as f:
json.dump([asdict(r) for r in audit_log], f, indent=2)
return stats
# Example audit log entry
# "event_id": "evt_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c",
# "action": "REPLAY_PUT",
# "status": "SUCCESS",
# "error_classification": null,
# "latency_ms": 342.15,
# "timestamp": "2024-05-11T09:15:23.450Z",
# "idempotency_key": "replay-evt_8f3a2b1c-9d4e-5f6a-7b8c-9d0e1f2a3b4c-v4",
# "destination": "topic_pub_conversations"
import os
import json
import logging
import uuid
import httpx
@dataclass
access_token: str
token_type: str
expires_in: int
scope: str
@dataclass
event_id: str
action: str
status: str
latency_ms: float
timestamp: str
destination: str
currentAttempt: int
maxAllowed: int
eventId: str
idempotencyKey: str
@classmethod
return v
@classmethod
return v
payload = {
scope=data["scope"]
def fetch_dlq_events(base_url: str, token: str, topic_id: str, limit: int = 50) -> List[Dict[str, Any]]:
headers = {"Authorization": f"Bearer {token}", "Accept": "application/json"}
while True:
if next_token:
raise
break
return all_events
def build_replay_payload(original_event: Dict[str, Any], destination_override: Optional[str] = None, max_retries: int = 5) -> Dict[str, Any]:
"retryMatrix": {
"replayMetadata": {
return ReplayPayloadSchema(**payload)
if status_code in (400, 422): return "SCHEMA_VIOLATION"
elif status_code == 409: return "DUPLICATE_DETECTED"
elif status_code == 413: return "PAYLOAD_TOO_LARGE"
elif status_code >= 500: return "SERVER_TRANSIENT"
def replay_event_to_topic(base_url: str, token: str, topic_id: str, payload: Dict[str, Any], max_backoff_retries: int = 3) -> Dict[str, Any]:
headers = {
raise
alert_payload = {"source": "cxone-eventbridge-replayer", "type": "replay_status_update", "data": asdict(audit_record)}
client.post(webhook_url, json=alert_payload, headers={"Content-Type": "application/json"})
def run_replay_service(
client_id: str,
client_secret: str,
region: str,
topic_id: str,
base_url = f"https://{region}"
token_resp = fetch_cxone_token(client_id, client_secret, region)
dlq_events = fetch_dlq_events(base_url, token_resp.access_token, topic_id)
result = replay_event_to_topic(base_url, token_resp.access_token, topic_id, replay_payload)
event_id=event_id, action="REPLAY_PUT", status=status,
error_classification=classification, latency_ms=round(latency_ms, 2),
else:
return stats
results = run_replay_service(
client_id=os.getenv("CXONE_CLIENT_ID"),
client_secret=os.getenv("CXONE_CLIENT_SECRET"),
region=os.getenv("CXONE_REGION", "api.nicecxone.com"),
topic_id=os.getenv("CXONE_TOPIC_ID"),
monitoring_webhook=os.getenv("MONITORING_WEBHOOK_URL"),
destination_override=os.getenv("DESTINATION_OVERRIDE_URL")
logger.info("Replay pipeline completed. Stats: %s", results)
- Cause: Expired OAuth token, incorrect client credentials, or missing
eventbridge:read/eventbridge:writescopes. - Fix: Verify token expiration timestamps. Implement automatic token refresh before the
expires_inwindow closes. Ensure the client ID and secret match a CXone application with EventBridge permissions. - Code Fix: Add token TTL tracking in
fetch_cxone_tokenand cache the token untilexpires_in - 60seconds.
Error: 403 Forbidden
- Cause: The OAuth client lacks permission to access the specified topic or DLQ, or the region endpoint is incorrect.
- Fix: Confirm the topic ID exists in your CXone organization. Verify the OAuth client is granted
eventbridge:readandeventbridge:writein the CXone admin console. Check that the region URL matches your deployment.
- Cause: Exceeding CXone EventBridge rate limits during DLQ polling or replay submission.
- Fix: Implement exponential backoff. The provided code includes
Retry-Afterheader parsing and backoff logic infetch_dlq_eventsandreplay_event_to_topic. Increase the initial backoff delay if cascading failures occur.
Error: 400 Bad Request or 422 Unprocessable Entity
- Cause: Payload schema mismatch, missing required fields, or exceeding the 256KB payload limit.
- Fix: Run payloads through
ReplayPayloadSchemavalidation before submission. EnsureoriginalPayloadis a valid JSON object. Check thatretryMatrix.currentAttemptdoes not exceedmaxAllowed.
Error: 409 Conflict
- Cause: Duplicate idempotency key submission. CXone EventBridge rejects replay attempts that reuse an existing idempotency key within the retention window.
- Fix: Increment the version suffix in the idempotency key (
replay-{eventId}-v{N}). The code handles this by appending the retry count to the key.
