Repeated calls Issue....
Hi All,
                 We are using genesys 7.5ver, now we are facing the issue like repeated calls through. The agent dispose the call as [b]SWITCH OFF[/b] but the data through to the agent again.  Still we are having fresh data and We are [b]not rechurned[/b] the data then how this is happening.
Advance Thanks to All,
karan… :wink:
Hi Karon,
Not familar with this issue, have you opened a ticket with support? What switch are you using? Can you describe the problem in more detail?
Daimonas
