Rendering Custom Emoji Sets in Genesys Cloud Web Messaging with TypeScript
  • A TypeScript module that constructs, validates, and renders custom emoji payloads for Genesys Cloud Web Messaging conversations using the Guest SDK.
  • The implementation uses the @genesyscloud/webmessaging-guest-sdk and direct REST calls to the Messaging API.
  • The code is written in TypeScript and targets Node.js 18+ or modern browser environments.
  • OAuth Client Credentials with scopes: webchat:read, webchat:write, analytics:read
  • Genesys Cloud Web Messaging Guest SDK version 2.0+
  • TypeScript 5.0+ with strict mode enabled
  • External dependencies: axios, ajv, ajv-formats, uuid
Genesys Cloud requires a valid OAuth access token before the Guest SDK can initialize or before any REST calls execute. The following function performs a client credentials grant and caches the token for reuse.
import axios, { AxiosError } from 'axios';
interface OAuthConfig {
  orgDomain: string;
  clientId: string;
  clientSecret: string;
export async function fetchOAuthToken(config: OAuthConfig): Promise<string> {
  const url = `https://${config.orgDomain}.mypurecloud.com/api/v2/oauth/token`;
  const payload = new URLSearchParams({
    client_id: config.clientId,
    client_secret: config.clientSecret,
    scope: 'webchat:read webchat:write'
    const response = await axios.post(url, payload, {
    return response.data.access_token;
  } catch (error) {
    if (axios.isAxiosError(error)) {
      const axiosError = error as AxiosError;
      if (axiosError.response?.status === 401) {
        throw new Error('OAuth 401: Invalid client credentials or expired secret.');
      if (axiosError.response?.status === 403) {
        throw new Error('OAuth 403: Client lacks required webchat scopes.');
    throw new Error('Failed to acquire OAuth token.');
The Guest SDK accepts the token directly during initialization. Store the token securely and refresh it before the expires_in window closes.
Step 1: Initialize Guest SDK and Establish Channel Context
The Web Messaging Guest SDK requires an orgDomain and a valid token. After initialization, you must retrieve or create a conversation channel to reference in emoji payloads.
import { WebMessagingGuestSdk, WebMessagingGuestSdkConfig } from '@genesyscloud/webmessaging-guest-sdk';
export async function initGuestSdk(orgDomain: string, oAuthToken: string) {
  const sdkConfig: WebMessagingGuestSdkConfig = {
    orgDomain,
    oAuthToken,
    locale: 'en-US',
    debug: false
  await WebMessagingGuestSdk.init(sdkConfig);
  return WebMessagingGuestSdk;
// Retrieve an active channel UUID (conversation ID)
export async function getActiveChannel(sdk: typeof WebMessagingGuestSdk): Promise<string> {
  const channels = await sdk.channels.list();
  if (channels.length === 0) {
    throw new Error('No active Web Messaging channels found.');
  return channels[0].id;
Step 2: Construct Emoji Mapping Matrix and Fallback Directives
Custom emoji sets require a deterministic mapping from internal codes to Unicode sequences, asset URLs, and fallback text. The matrix enforces maximum glyph size limits to prevent rendering failures in the messaging engine.
export interface EmojiDefinition {
  code: string;
  unicode: string;
  assetUrl: string;
  fallback: string;
  maxGlyphSize: number;
export const EMOJI_MATRIX: Record<string, EmojiDefinition> = {
  'custom_rocket': {
    code: 'custom_rocket',
    unicode: '🚀',
    assetUrl: 'https://assets.example.com/emoji/rocket.png',
    fallback: '[ROCKET]',
    maxGlyphSize: 24
  'custom_check': {
    code: 'custom_check',
    unicode: '✅',
    assetUrl: 'https://assets.example.com/emoji/check.png',
    fallback: '[CHECK]',
    maxGlyphSize: 20
export function resolveEmoji(code: string): EmojiDefinition {
  const definition = EMOJI_MATRIX[code];
  if (!definition) {
    throw new Error(`Emoji code "${code}" not found in mapping matrix.`);
  return definition;
Step 3: Validate Render Schemas Against Messaging Constraints
The messaging engine rejects payloads that exceed character limits or contain malformed Unicode. This step uses AJV to validate the render schema before transmission.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv({ allErrors: true, strict: false });
addFormats(ajv);
const emojiRenderSchema = {
  type: 'object',
  required: ['channelId', 'emojiCode', 'unicode', 'assetUrl', 'fallback'],
  properties: {
    channelId: { type: 'string', format: 'uuid' },
    emojiCode: { type: 'string', minLength: 1, maxLength: 64 },
    unicode: { type: 'string', maxLength: 8 },
    assetUrl: { type: 'string', format: 'uri' },
    fallback: { type: 'string', maxLength: 32 },
    glyphSize: { type: 'integer', minimum: 12, maximum: 32 }
  additionalProperties: false
const validateRenderPayload = ajv.compile(emojiRenderSchema);
export function validateEmojiPayload(payload: Record<string, unknown>): boolean {
  const valid = validateRenderPayload(payload);
  if (!valid) {
    const errors = validateRenderPayload.errors?.map(e => `${e.instancePath}: ${e.message}`).join(', ') || 'Unknown schema error';
    throw new Error(`Render schema validation failed: ${errors}`);
  return true;
Step 4: Execute Atomic PATCH Operations with CDN Cache Triggers
Genesys Cloud Messaging supports atomic updates via PATCH /api/v2/conversations/messaging/messages/{messageId}. This operation updates the message attributes with the validated emoji payload and triggers a CDN cache version bump to force fresh asset delivery.
interface PatchPayload {
  attributes: Record<string, unknown>;
  version: number;
export async function patchMessageWithEmoji(
  orgDomain: string,
  oAuthToken: string,
  messageId: string,
  renderData: Record<string, unknown>
): Promise<void> {
  const url = `https://${orgDomain}.mypurecloud.com/api/v2/conversations/messaging/messages/${messageId}`;
  const cacheVersion = Math.floor(Date.now() / 1000);
  const patchBody: PatchPayload = {
    attributes: {
      ...renderData,
      _renderCacheVersion: cacheVersion,
      _renderTimestamp: new Date().toISOString()
    version: 1
  const maxRetries = 3;
  let attempt = 0;
  while (attempt < maxRetries) {
      await axios.patch(url, patchBody, {
        headers: {
          'Authorization': `Bearer ${oAuthToken}`,
          'Accept': 'application/json'
      return;
    } catch (error) {
        if (axiosError.response?.status === 429) {
          attempt++;
          const delay = Math.pow(2, attempt) * 1000;
          console.warn(`Rate limit 429 hit. Retrying in ${delay}ms...`);
          continue;
        if (axiosError.response?.status === 400) {
          throw new Error('PATCH 400: Invalid payload format or version conflict.');
          throw new Error('PATCH 403: Missing webchat:write scope.');
      throw error;
  throw new Error('Max retries exceeded for PATCH operation.');
Step 5: Cross-Browser Font Verification and Fallback Pipeline
Before rendering, the system checks font availability using the CSS Fonts API. If the primary Unicode glyph cannot be rendered, the pipeline substitutes the fallback directive automatically.
export async function verifyFontAvailability(unicode: string, fontSize: number = 24): Promise<boolean> {
  if (typeof document === 'undefined') {
    return true;
  const fontFace = new FontFace('emoji-test', `local('Apple Color Emoji'), local('Segoe UI Emoji'), local('Noto Color Emoji'), local('Android Emoji')`);
  await fontFace.load();
  document.fonts.add(fontFace);
  const canvas = document.createElement('canvas');
  const context = canvas.getContext('2d');
  if (!context) return false;
  canvas.width = fontSize * 2;
  canvas.height = fontSize * 2;
  context.font = `${fontSize}px ${fontFace.family}`;
  context.fillText(unicode, 0, fontSize);
  const imageData = context.getImageData(0, 0, canvas.width, canvas.height);
  const hasPixels = imageData.data.some(channel => channel !== 0);
  document.fonts.delete(fontFace);
  return hasPixels;
export async function getRenderedGlyph(emojiDef: EmojiDefinition): Promise<string> {
  const isAvailable = await verifyFontAvailability(emojiDef.unicode, emojiDef.maxGlyphSize);
  return isAvailable ? emojiDef.unicode : emojiDef.fallback;
Step 6: Telemetry, Audit Logging, and Webhook Synchronization
Production renderers require latency tracking, success rate monitoring, and external webhook synchronization for asset managers. This module exposes a structured logger and metrics collector.
interface RenderMetrics {
  totalAttempts: number;
  successfulRenders: number;
  averageLatencyMs: number;
  glyphMatchRate: number;
interface AuditLogEntry {
  timestamp: string;
  channelId: string;
  messageId: string;
  emojiCode: string;
  status: 'success' | 'fallback' | 'error';
  latencyMs: number;
class EmojiRendererMetrics {
  private logs: AuditLogEntry[] = [];
  private metrics: RenderMetrics = {
    totalAttempts: 0,
    successfulRenders: 0,
    averageLatencyMs: 0,
    glyphMatchRate: 0
  recordAttempt(entry: AuditLogEntry) {
    this.logs.push(entry);
    this.metrics.totalAttempts++;
    this.metrics.successfulRenders += entry.status !== 'error' ? 1 : 0;
    this.metrics.averageLatencyMs = (
      (this.metrics.averageLatencyMs * (this.metrics.totalAttempts - 1) + entry.latencyMs) /
    this.metrics.glyphMatchRate = this.metrics.successfulRenders / this.metrics.totalAttempts;
  getAuditLogs(): AuditLogEntry[] {
    return [...this.logs];
  getMetrics(): RenderMetrics {
    return { ...this.metrics };
export async function syncEmojiLoadedWebhook(webhookUrl: string, payload: Record<string, unknown>) {
    await axios.post(webhookUrl, payload, {
      timeout: 3000
  } catch (error) {
    console.error('Webhook sync failed, proceeding with local render:', error);
export const renderMetrics = new EmojiRendererMetrics();
The following script combines all components into a single executable module. Replace the placeholder credentials with your Genesys Cloud environment values.
import { fetchOAuthToken, initGuestSdk, getActiveChannel } from './auth';
import { resolveEmoji, validateEmojiPayload, EMOJI_MATRIX } from './matrix';
import { patchMessageWithEmoji } from './patch';
import { getRenderedGlyph } from './font-check';
import { renderMetrics, syncEmojiLoadedWebhook } from './telemetry';
async function main() {
  const ORG_DOMAIN = 'your-org-domain';
  const CLIENT_ID = 'your-client-id';
  const CLIENT_SECRET = 'your-client-secret';
  const WEBHOOK_URL = 'https://your-asset-manager.example.com/api/v1/emoji-sync';
    const oAuthToken = await fetchOAuthToken({ orgDomain: ORG_DOMAIN, clientId: CLIENT_ID, clientSecret: CLIENT_SECRET });
    const sdk = await initGuestSdk(ORG_DOMAIN, oAuthToken);
    const channelId = await getActiveChannel(sdk);
    const targetCode = 'custom_rocket';
    const emojiDef = resolveEmoji(targetCode);
    const renderPayload = {
      channelId,
      emojiCode: targetCode,
      unicode: emojiDef.unicode,
      assetUrl: emojiDef.assetUrl,
      fallback: emojiDef.fallback,
      glyphSize: emojiDef.maxGlyphSize
    validateEmojiPayload(renderPayload);
    const startTime = performance.now();
    const renderedGlyph = await getRenderedGlyph(emojiDef);
    const latencyMs = performance.now() - startTime;
    const status = renderedGlyph === emojiDef.unicode ? 'success' : 'fallback';
    renderMetrics.recordAttempt({
      channelId,
      messageId: 'mock-message-id-123',
      status,
      latencyMs
    await patchMessageWithEmoji(ORG_DOMAIN, oAuthToken, 'mock-message-id-123', renderPayload);
    await syncEmojiLoadedWebhook(WEBHOOK_URL, {
      channelId,
      renderedGlyph,
      latencyMs,
      status
    console.log('Render complete. Metrics:', renderMetrics.getMetrics());
    console.log('Audit Log:', renderMetrics.getAuditLogs());
  } catch (error) {
    console.error('Execution failed:', error);
main();
Error: HTTP 401 Unauthorized
  • Cause: The OAuth token is expired, malformed, or the client credentials are incorrect.
  • Fix: Verify the client_id and client_secret match a configured OAuth client in Genesys Cloud. Implement token refresh logic before the expires_in value elapses.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks the webchat:read or webchat:write scope.
  • Fix: Navigate to the Genesys Cloud admin console, locate the OAuth client, and append the missing scopes to the client configuration. Regenerate the token.
  • Cause: The messaging engine rate limit has been exceeded. Genesys Cloud enforces per-client and per-organization limits.
  • Fix: The provided patchMessageWithEmoji function includes exponential backoff retry logic. Ensure your application does not spawn concurrent PATCH requests for the same message ID.
Error: HTTP 400 Bad Request on PATCH
  • Cause: The payload violates the messaging schema or the version field conflicts with the server state.
  • Fix: Fetch the current message version via GET /api/v2/conversations/messaging/messages/{messageId} before patching. Increment the version value by exactly one. Validate all fields against the AJV schema before transmission.
Error: Font Verification Returns False
  • Cause: The target environment lacks a color emoji font that supports the specific Unicode sequence.
  • Fix: The fallback pipeline automatically substitutes the [CODE] directive. Ensure your CSS stack includes font-family: "Apple Color Emoji", "Segoe UI Emoji", "Noto Color Emoji", sans-serif; to maximize cross-browser compatibility.
