Registering Genesys Cloud Webhook Custom Event Types via C# SDK with Schema Validation and Routing Verification
- A C# module that registers custom event types as Genesys Cloud webhooks with JSON Schema validation, namespace collision detection, and structured audit logging.
- Uses the Genesys Cloud Webhooks API (
/api/v2/webhooks) via the official C# SDKGenesysCloudPlatformClient. - Covers C# 10+ with
GenesysCloudPlatformClient,NJsonSchema, and exponential backoff retry logic.
- OAuth client credentials with scopes:
webhook:write,webhook:read,integration:write - Genesys Cloud C# SDK v1.20+ (
GenesysCloudPlatformClient) - .NET 8.0 runtime
- NuGet packages:
NJsonSchema,Microsoft.Extensions.Logging,System.Text.Json
The Genesys Cloud C# SDK handles token acquisition and automatic refresh when configured with the Client Credentials flow. You must initialize the OAuthClient with your organization URL and required scopes before instantiating the PlatformClient.
using GenesysCloud.Auth;
using GenesysCloud.Platform;
using System.Collections.Generic;
using System.Threading.Tasks;
public class GenesysAuthManager
public static async Task<PlatformClient> InitializePlatformClientAsync(
string clientId,
string clientSecret,
string organizationUrl)
var oauthSettings = new OAuthClientSettings
ClientId = clientId,
ClientSecret = clientSecret,
GrantType = GrantType.ClientCredentials,
Scopes = new List<string> { "webhook:write", "webhook:read", "integration:write" },
BaseUrl = organizationUrl
var oauthClient = new OAuthClient(oauthSettings);
await oauthClient.AuthenticateAsync();
var platformClient = new PlatformClient(oauthClient);
return platformClient;
The SDK caches the access token in memory and automatically requests a new token when the current one expires. You do not need to implement manual token refresh logic. If the token expires during a long-running operation, the SDK retries the request automatically.
Step 1: JSON Schema Draft Validation and Size Constraint Enforcement
Genesys Cloud webhooks enforce a maximum payload size. You must validate the JSON Schema draft 7 definition before submission to prevent registration failure. The validation pipeline checks schema syntax, draft version compliance, and enforces a 64KB character limit.
using NJsonSchema;
using System;
public class SchemaValidator
private const int MaxSchemaSizeBytes = 65536;
public async Task<bool> ValidateAsync(string jsonSchemaString)
if (jsonSchemaString == null) throw new ArgumentNullException(nameof(jsonSchemaString));
var byteCount = System.Text.Encoding.UTF8.GetByteCount(jsonSchemaString);
if (byteCount > MaxSchemaSizeBytes)
throw new InvalidOperationException($"Schema exceeds maximum size limit. Current size: {byteCount} bytes. Limit: {MaxSchemaSizeBytes} bytes.");
var schema = await JsonSchema4.FromJsonAsync(jsonSchemaString);
if (schema == null)
throw new FormatException("Invalid JSON Schema draft 7 structure. Schema matrix parsing failed.");
return true;
This validator throws descriptive exceptions for size violations and malformed schemas. You must catch these exceptions before attempting the API call to avoid 400 Bad Request responses from the Genesys Cloud platform.
Step 2: Namespace Collision Checking and Webhook Routing Verification
Before registering a new event type, you must verify that the namespace does not collide with existing webhooks. You also must verify the target routing endpoint responds correctly to prevent routing ambiguity during scaling. This step uses pagination to scan all existing webhooks.
using GenesysCloud.Platform.APIs.Webhooks;
using GenesysCloud.Platform.Models;
using System;
using System.Net.Http;
public class RoutingAndNamespaceVerifier
private readonly WebhooksApi _webhooksApi;
private readonly HttpClient _httpClient;
private readonly string _targetUrl;
private readonly string _targetNamespace;
public RoutingAndNamespaceVerifier(WebhooksApi webhooksApi, HttpClient httpClient, string targetUrl, string targetNamespace)
_webhooksApi = webhooksApi;
_httpClient = httpClient;
_targetUrl = targetUrl;
_targetNamespace = targetNamespace;
public async Task VerifyAsync()
await CheckNamespaceCollisionAsync();
await VerifyRoutingEndpointAsync();
private async Task CheckNamespaceCollisionAsync()
var request = new WebhooksGetWebhooksRequest { PageSize = 100 };
var page = await _webhooksApi.GetWebhooksAsync(request);
while (page != null)
foreach (var webhook in page.Entities)
if (webhook.Name.Equals(_targetNamespace, StringComparison.OrdinalIgnoreCase))
throw new InvalidOperationException($"Namespace collision detected. Webhook name '{webhook.Name}' already exists with ID {webhook.Id}.");
if (!string.IsNullOrEmpty(page.NextPage))
request = new WebhooksGetWebhooksRequest { PageSize = 100, NextPage = page.NextPage };
else
break;
private async Task VerifyRoutingEndpointAsync()
var response = await _httpClient.SendAsync(new HttpRequestMessage(HttpMethod.Head, _targetUrl));
if (!response.IsSuccessStatusCode)
throw new HttpRequestException($"Routing verification failed. Target endpoint returned {(int)response.StatusCode}.");
The pagination loop continues until NextPage returns null. This ensures you scan the complete webhook registry. The routing verification uses a HEAD request to confirm the target service mesh endpoint is reachable without triggering a full event payload.
Step 3: Atomic POST Registration with Version Increment and Latency Tracking
Registration uses an atomic POST operation to /api/v2/webhooks. You must implement retry logic for 429 rate limit responses. The registration pipeline tracks latency, logs audit events, and automatically increments a version suffix if a collision occurs during concurrent execution.
using Microsoft.Extensions.Logging;
using System;
using System.Diagnostics;
using System.Net;
public class EventRegisterer
private readonly ILogger<EventRegisterer> _logger;
private const int MaxRetryAttempts = 3;
public EventRegisterer(WebhooksApi webhooksApi, ILogger<EventRegisterer> logger)
_logger = logger;
public async Task<Webhook> RegisterAsync(string name, string eventType, string targetUrl, string jsonSchema, int currentVersion)
var stopwatch = Stopwatch.StartNew();
string auditId = Guid.NewGuid().ToString();
int version = currentVersion;
try
var webhook = await RegisterWithRetryAsync(name, eventType, targetUrl, jsonSchema, version);
stopwatch.Stop();
_logger.LogInformation("Registration successful. AuditId: {AuditId}, Latency: {Latency}ms, Version: {Version}",
auditId, stopwatch.ElapsedMilliseconds, webhook.Version);
return webhook;
catch (Exception ex)
stopwatch.Stop();
_logger.LogError(ex, "Registration failed. AuditId: {AuditId}, Latency: {Latency}ms", auditId, stopwatch.ElapsedMilliseconds);
throw;
private async Task<Webhook> RegisterWithRetryAsync(string name, string eventType, string targetUrl, string jsonSchema, int version)
var request = new WebhooksPostWebhookRequest
Body = new Webhook
Name = $"{name}-v{version}",
Enabled = true,
WebhookType = "rest",
Address = targetUrl,
Events = new List<string> { eventType },
RequestType = "json",
HttpBody = jsonSchema,
HttpHeaders = new Dictionary<string, string> { { "X-Genesys-Event-Version", version.ToString() } }
for (int attempt = 1; attempt <= MaxRetryAttempts; attempt++)
try
var response = await _webhooksApi.PostWebhookAsync(request);
return response;
catch (ApiException apiEx) when (apiEx.StatusCode == (int)HttpStatusCode.TooManyRequests)
var delay = TimeSpan.FromSeconds(Math.Pow(2, attempt));
_logger.LogWarning("Rate limit encountered (429). Retrying in {Delay}ms. Attempt {Attempt}/{Max}",
delay.TotalMilliseconds, attempt, MaxRetryAttempts);
await Task.Delay(delay);
catch (ApiException apiEx) when (apiEx.StatusCode == (int)HttpStatusCode.Conflict)
version++;
request.Body.Name = $"{name}-v{version}";
request.Body.HttpHeaders["X-Genesys-Event-Version"] = version.ToString();
_logger.LogWarning("Conflict detected. Incrementing version to {Version} and retrying.", version);
throw new InvalidOperationException("Registration failed after maximum retry attempts.");
The retry logic handles 429 responses with exponential backoff and resolves 409 conflicts by incrementing the version suffix. The HttpHeaders dictionary passes the schema version to the target service mesh for alignment. Latency tracking uses System.Diagnostics.Stopwatch and logs structured audit records for registry governance.
The following console application demonstrates the full registration pipeline. You must replace the placeholder credentials with your OAuth client details.
using System;
namespace GenesysEventRegistration
class Program
static async Task Main(string[] args)
var loggerFactory = LoggerFactory.Create(builder => builder.AddConsole());
var logger = loggerFactory.CreateLogger<Program>();
string clientId = "YOUR_CLIENT_ID";
string clientSecret = "YOUR_CLIENT_SECRET";
string organizationUrl = "https://api.mypurecloud.com";
string targetNamespace = "custom-event-processor";
string targetUrl = "https://your-service-mesh.example.com/events";
string eventType = "integration:custom:order.created";
string jsonSchema = @"{
""$schema"": ""http://json-schema.org/draft-07/schema#"",
""type"": ""object"",
""properties"": {
""orderId"": { ""type"": ""string"" },
""timestamp"": { ""type"": ""string"", ""format"": ""date-time"" },
""metadata"": { ""type"": ""object"" }
""required"": [""orderId"", ""timestamp""]
try
var platformClient = await GenesysAuthManager.InitializePlatformClientAsync(clientId, clientSecret, organizationUrl);
var webhooksApi = platformClient.Webhooks;
var validator = new SchemaValidator();
await validator.ValidateAsync(jsonSchema);
logger.LogInformation("Schema validation passed.");
var httpClient = new HttpClient();
var verifier = new RoutingAndNamespaceVerifier(webhooksApi, httpClient, targetUrl, targetNamespace);
await verifier.VerifyAsync();
logger.LogInformation("Namespace and routing verification passed.");
var registerer = new EventRegisterer(webhooksApi, logger);
var registeredWebhook = await registerer.RegisterAsync(targetNamespace, eventType, targetUrl, jsonSchema, currentVersion: 1);
logger.LogInformation("Successfully registered webhook ID: {Id}", registeredWebhook.Id);
logger.LogError(ex, "Registration pipeline terminated with error.");
This example chains validation, verification, and registration into a single execution flow. You must install the required NuGet packages before compiling. The application logs each stage for audit governance.
- Cause: OAuth client credentials are invalid, or the token has expired without successful refresh.
- Fix: Verify
ClientIdandClientSecretmatch your Genesys Cloud integration settings. Ensure the OAuth client has thewebhook:writescope assigned in the admin console. - Code showing the fix:
catch (ApiException ex) when (ex.StatusCode == 401) { _logger.LogError("Authentication failed. Verify OAuth scopes and credentials."); throw; }
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scope, or the user associated with the client does not have the
webhook:writepermission. - Fix: Assign the
webhook:writescope to the OAuth client. Ensure the client is associated with a user that has the Webhook Admin role. - Code showing the fix:
catch (ApiException ex) when (ex.StatusCode == 403) { _logger.LogError("Insufficient permissions. Grant webhook:write scope and Webhook Admin role."); throw; }
Error: 400 Bad Request
- Cause: JSON Schema exceeds the 64KB limit, contains invalid draft 7 syntax, or the webhook address is malformed.
- Fix: Validate schema size before submission. Use the
SchemaValidatorclass to catch format errors. Verify the target URL uses HTTPS. - Code showing the fix:
if (jsonSchema.Length > 65536) { throw new InvalidOperationException("Schema size exceeds platform constraints."); }
- Cause: The API rate limit has been exceeded. The Webhooks API enforces request limits per tenant and per OAuth client.
- Fix: Implement exponential backoff retry logic. The
RegisterWithRetryAsyncmethod handles this automatically. Reduce concurrent registration threads if you run multiple registerers. - Code showing the fix:
catch (ApiException apiEx) when (apiEx.StatusCode == (int)HttpStatusCode.TooManyRequests) { await Task.Delay(TimeSpan.FromSeconds(Math.Pow(2, attempt))); }
