Registering Genesys Cloud LLM Gateway Model Provider Endpoints with Python
Automate the registration of external LLM model providers to the Genesys Cloud LLM Gateway using a Python registrar that validates payloads, enforces gateway constraints, triggers health checks, syncs secrets, and generates audit logs. This tutorial uses the Genesys Cloud LLM Gateway REST API. The implementation covers Python 3.10+ with httpx and pydantic.
  • OAuth 2.0 confidential client with ai:llm:manage and llm-gateway:write scopes
  • Genesys Cloud LLM Gateway API version 2.0
  • Python 3.10 or higher
  • External dependencies: httpx, pydantic, cryptography, python-dotenv, structlog
Genesys Cloud requires OAuth 2.0 client credentials flow for service-to-service API access. The following code implements token acquisition with caching and automatic refresh logic to avoid repeated authentication calls during batch registration operations.
import os
import httpx
from typing import Optional
load_dotenv()
GENESYS_ENV = os.getenv("GENESYS_ENV", "mypurecloud.com")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
SCOPES = "ai:llm:manage llm-gateway:write"
class GenesysAuthClient:
    def __init__(self, env: str, client_id: str, client_secret: str, scopes: str):
        self.base_url = f"https://{env}/oauth/token"
        self.client_id = client_id
        self.scopes = scopes
        self._expires_at: float = 0.0
    def get_token(self) -> str:
        if self._token and time.time() < self._expires_at:
            return self._token
        payload = {
            "client_id": self.client_id,
            "scope": self.scopes
        with httpx.Client(timeout=15.0) as client:
            response = client.post(self.base_url, data=payload)
            response.raise_for_status()
            data = response.json()
        self._token = data["access_token"]
        self._expires_at = time.time() + (data["expires_in"] - 60)
        return self._token
The token cache subtracts sixty seconds from the actual expiration time to account for clock drift and prevent mid-request 401 errors. The httpx client handles TLS verification automatically using the system certificate store.
The LLM Gateway API enforces strict schema validation to prevent misconfigured providers from degrading routing performance. The registration payload requires a unique provider identifier, a capability matrix defining supported models and features, and an authentication directive specifying credential handling.
from pydantic import BaseModel, Field, field_validator
from typing import List, Dict, Optional
import enum
class AuthType(str, enum.Enum):
    API_KEY = "API_KEY"
    OAUTH2 = "OAUTH2"
    BEARER_TOKEN = "BEARER_TOKEN"
class Capability(BaseModel):
    model_id: str
    max_tokens: int = Field(..., ge=1, le=128000)
    supports_streaming: bool = True
    supports_function_calling: bool = False
    supported_languages: List[str] = Field(default=["en-US"])
class AuthenticationDirective(BaseModel):
    type: AuthType
    encrypted_key: str
    rotation_policy_days: int = Field(default=90, ge=7, le=365)
class ProviderRegistrationPayload(BaseModel):
    provider_id: str = Field(..., pattern=r"^[a-zA-Z0-9_-]{3,64}$")
    endpoint_url: str = Field(..., pattern=r"^https://")
    capabilities: List[Capability]
    auth_directive: AuthenticationDirective
    rate_limit_rpm: int = Field(default=60, ge=1, le=1000)
    timeout_ms: int = Field(default=30000, ge=1000, le=120000)
    @field_validator("endpoint_url")
    @classmethod
    def validate_endpoint_format(cls, v: str) -> str:
        if not v.endswith("/"):
            return v
        return v.rstrip("/")
    @field_validator("capabilities")
    @classmethod
    def validate_capability_matrix(cls, v: List[Capability]) -> List[Capability]:
        if not v:
            raise ValueError("Provider must declare at least one capability")
        model_ids = [c.model_id for c in v]
        if len(model_ids) != len(set(model_ids)):
            raise ValueError("Duplicate model identifiers detected in capability matrix")
        return v
Pydantic enforces structural integrity before the payload reaches the network layer. The regex pattern on provider_id prevents injection characters. The capability matrix validation ensures unique model identifiers and enforces token limits aligned with gateway engine constraints.
Step 2: Gateway Constraint Verification and Atomic POST Registration
The LLM Gateway engine maintains a maximum concurrent provider limit per environment. Attempting to exceed this limit returns a 409 Conflict response. The following code queries the current provider count, validates against the environment limit, and executes an atomic POST registration with exponential backoff for 429 rate limits.
import httpx
import logging
logger = logging.getLogger("llm_gateway_registrar")
class GatewayConstraintValidator:
    def __init__(self, auth: GenesysAuthClient, env: str):
        self.auth = auth
        self.base_url = f"https://{env}/api/v2/ai/llm-gateway"
    def check_provider_limit(self, max_allowed: int = 25) -> bool:
        token = self.auth.get_token()
        with httpx.Client(timeout=10.0) as client:
            response = client.get(f"{self.base_url}/providers", headers=headers)
                time.sleep(float(response.headers.get("retry-after", 2)))
        current_count = len(data.get("entities", []))
        logger.info("Current provider count: %d / %d", current_count, max_allowed)
        return current_count < max_allowed
    def register_provider(self, payload: ProviderRegistrationPayload, max_retries: int = 3) -> Dict:
        headers = {
            "X-Genesys-Request-Id": payload.provider_id
        body = payload.model_dump(mode="json")
        with httpx.Client(timeout=30.0) as client:
            for attempt in range(1, max_retries + 1):
                response = client.post(f"{self.base_url}/providers", headers=headers, json=body)
                    retry_after = float(response.headers.get("retry-after", 2 ** attempt))
                    logger.warning("Rate limited. Retrying in %.1f seconds", retry_after)
                    time.sleep(retry_after)
                if response.status_code == 409:
                    raise RuntimeError("Gateway provider limit exceeded. Cannot register new endpoint.")
                return response.json()
            raise RuntimeError("Max retries exceeded during provider registration")
The X-Genesys-Request-Id header enables idempotent registration retries. The exponential backoff strategy prevents cascading 429 responses during scaling operations. The 409 status code explicitly signals capacity exhaustion.
Step 3: Authentication Directive Encryption and Model Compatibility Pipeline
Before transmission, the provider API key must be encrypted to prevent plaintext exposure in transit or gateway logs. The following pipeline encrypts credentials using Fernet symmetric encryption, validates model compatibility against the gateway routing engine, and triggers an automatic health check upon successful registration.
from cryptography.fernet import Fernet
from typing import Tuple
class SecurityAndCompatibilityPipeline:
    def __init__(self, encryption_key: bytes):
        self.cipher = Fernet(encryption_key)
    def encrypt_api_key(self, raw_key: str) -> str:
        encrypted = self.cipher.encrypt(raw_key.encode("utf-8"))
        return encrypted.decode("utf-8")
    def verify_model_compatibility(self, capabilities: List[Capability], gateway_supported_models: List[str]) -> bool:
        compatible = False
        for cap in capabilities:
            if cap.model_id in gateway_supported_models:
                compatible = True
                logger.info("Model %s verified compatible with gateway routing engine", cap.model_id)
                break
        if not compatible:
            raise ValueError("No declared models match gateway supported model list")
        return compatible
    def trigger_health_check(self, auth: GenesysAuthClient, env: str, provider_id: str) -> Dict:
        token = auth.get_token()
        endpoint = f"https://{env}/api/v2/ai/llm-gateway/providers/{provider_id}/health-check"
            response = client.post(endpoint, headers=headers, json={"check_type": "CONNECTIVITY"})
Fernet encryption ensures the gateway can decrypt the key during routing without exposing it in configuration stores. The compatibility verification prevents routing failures caused by unsupported model architectures. The health check POST initiates a synchronous connectivity validation that returns endpoint latency and TLS certificate status.
Step 4: Vault Synchronization, Metrics Tracking, and Audit Logging
Registration events must synchronize with external secret vaults for credential lifecycle management. The following implementation captures registration latency, tracks connectivity success rates, generates structured audit logs for AI governance, and exposes a webhook handler for provider registration events.
import json
import structlog
from typing import Dict, Any
class RegistrationMetricsCollector:
    def __init__(self):
        self.total_attempts = 0
        self.successful_registrations = 0
        self.total_latency_ms = 0.0
        self.audit_log_path = "llm_gateway_registration_audit.jsonl"
    def record_attempt(self, latency_ms: float, success: bool, provider_id: str, error: Optional[str] = None):
        self.total_attempts += 1
        self.total_latency_ms += latency_ms
        if success:
            self.successful_registrations += 1
        audit_entry = {
            "event": "PROVIDER_REGISTRATION",
            "provider_id": provider_id,
            "latency_ms": latency_ms,
            "success": success,
            "error": error,
            "metrics": {
                "total_attempts": self.total_attempts,
                "success_rate": self.successful_registrations / self.total_attempts if self.total_attempts > 0 else 0.0,
                "avg_latency_ms": self.total_latency_ms / self.total_attempts if self.total_attempts > 0 else 0.0
        with open(self.audit_log_path, "a") as f:
            f.write(json.dumps(audit_entry) + "\n")
        logger.info("Audit log written for %s", provider_id)
def handle_provider_registered_webhook(auth: GenesysAuthClient, env: str, payload: Dict[str, Any]):
    provider_id = payload.get("provider_id")
    vault_sync_endpoint = f"https://{env}/api/v2/ai/llm-gateway/providers/{provider_id}/vault-sync"
    headers = {
        "X-Webhook-Source": "external-vault-integration"
        response = client.post(vault_sync_endpoint, headers=headers, json={"action": "ROTATE_AND_SYNC"})
        logger.info("Vault synchronization triggered for %s", provider_id)
The metrics collector calculates real-time success rates and average latency for capacity planning. The audit log writes newline-delimited JSON entries that integrate with SIEM platforms for AI governance compliance. The webhook handler demonstrates how external systems trigger vault synchronization after registration completes.
The following script combines all components into a production-ready provider registrar. It handles authentication, validation, registration, health checks, metrics collection, and audit logging in a single execution flow.
import os
import httpx
import logging
from typing import Optional, Dict, List
load_dotenv()
ENCRYPTION_KEY = Fernet.generate_key()
            return self._token
        payload = {
        return self._token
    model_id: str
    type: str
    encrypted_key: str
    rotation_policy_days: int = Field(default=90)
    rate_limit_rpm: int = Field(default=60)
class LLMGatewayProviderRegistrar:
    def __init__(self, env: str, client_id: str, client_secret: str):
        self.auth = GenesysAuthClient(env, client_id, client_secret, SCOPES)
        self.env = env
        self.cipher = Fernet(ENCRYPTION_KEY)
        self.metrics = RegistrationMetricsCollector()
    def _encrypt_key(self, raw_key: str) -> str:
        return self.cipher.encrypt(raw_key.encode("utf-8")).decode("utf-8")
    def register(self, provider_id: str, endpoint_url: str, models: List[str], api_key: str) -> Dict:
        start_time = time.time()
            if not self._check_limit():
                raise RuntimeError("Gateway provider limit exceeded")
            capabilities = [Capability(model_id=m, max_tokens=8192) for m in models]
            encrypted_key = self._encrypt_key(api_key)
            payload = ProviderRegistrationPayload(
                provider_id=provider_id,
                endpoint_url=endpoint_url,
                capabilities=capabilities,
                auth_directive=AuthenticationDirective(type="API_KEY", encrypted_key=encrypted_key)
            self._verify_compatibility(capabilities)
            result = self._post_registration(payload)
            self._trigger_health_check(result["id"])
            latency = (time.time() - start_time) * 1000
            self.metrics.record_attempt(latency, True, provider_id)
            logger.info("Successfully registered %s in %.2f ms", provider_id, latency)
            return result
            self.metrics.record_attempt(latency, False, provider_id, str(e))
            raise
    def _check_limit(self) -> bool:
            resp = client.get(f"https://{self.env}/api/v2/ai/llm-gateway/providers", headers=headers)
            resp.raise_for_status()
        return len(resp.json().get("entities", [])) < 25
    def _verify_compatibility(self, capabilities: List[Capability]) -> None:
        supported = ["gpt-4o", "claude-3-5-sonnet", "llama-3-70b"]
        if not any(c.model_id in supported for c in capabilities):
            raise ValueError("No compatible models found")
    def _post_registration(self, payload: ProviderRegistrationPayload) -> Dict:
        headers = {
            for i in range(3):
                resp = client.post(f"https://{self.env}/api/v2/ai/llm-gateway/providers", headers=headers, json=payload.model_dump(mode="json"))
                if resp.status_code == 429:
                    time.sleep(2 ** i)
                return resp.json()
            raise RuntimeError("Registration failed after retries")
    def _trigger_health_check(self, provider_id: str) -> None:
            resp = client.post(f"https://{self.env}/api/v2/ai/llm-gateway/providers/{provider_id}/health-check", headers=headers, json={"check_type": "CONNECTIVITY"})
    def __init__(self):
        if success:
        audit = {
            "timestamp": time.time(),
            "success": success,
            "error": error,
        logger.info("AUDIT: %s", audit)
    registrar = LLMGatewayProviderRegistrar(GENESYS_ENV, CLIENT_ID, CLIENT_SECRET)
    registrar.register(
        provider_id="prod-llm-provider-01",
        endpoint_url="https://api.external-llm-provider.com/v1",
        models=["gpt-4o", "llama-3-70b"],
        api_key=os.getenv("EXTERNAL_LLM_API_KEY", "sk-placeholder-key")
Error: 400 Bad Request (Schema Validation Failure)
  • What causes it: The payload contains invalid field formats, duplicate model identifiers, or missing required capability attributes.
  • How to fix it: Validate the payload locally before transmission using Pydantic. Ensure provider_id matches the ^[a-zA-Z0-9_-]{3,64}$ pattern. Verify max_tokens falls within 1 to 128000.
  • Code showing the fix:
    payload = ProviderRegistrationPayload(**raw_data)
    logger.error("Payload validation failed: %s", str(e))
    raise
Error: 403 Forbidden (Insufficient Scopes)
  • What causes it: The OAuth token lacks ai:llm:manage or llm-gateway:write scopes.
  • How to fix it: Update the confidential client configuration in the Genesys Cloud admin console. Request both scopes during the client credentials exchange.
# Ensure this string matches the exact scope names configured in the OAuth client
Error: 429 Too Many Requests (Rate Limit Cascade)
  • What causes it: Concurrent registration requests exceed the gateway API rate limit.
  • How to fix it: Implement exponential backoff with jitter. Read the retry-after header when present. Limit parallel execution threads to five.
    delay = float(response.headers.get("retry-after", 2 ** attempt))
    time.sleep(delay)
Error: 503 Service Unavailable (Gateway Engine Constraint)
  • What causes it: The LLM Gateway routing engine is undergoing maintenance or has reached maximum concurrent provider capacity.
  • How to fix it: Verify environment status via the Genesys Cloud status dashboard. Wait for maintenance windows to complete. Reduce the max_allowed threshold in the constraint validator if scaling gradually.
if response.status_code == 503:
    logger.warning("Gateway engine unavailable. Deferring registration.")
    raise RuntimeError("Service unavailable. Retry after maintenance window.")
