Reg : Not able to create operational parameters in GAX
I have done the “GAX Installation” in our lab. But when i tried to add “Operational Parameters” it throws “Saving Failed” error.
Below listed are the error shown in logs.
[com.genesyslab.gax.opm.entities.Parameter]; nested exception is java.beans.IntrospectionException: type mismatch between read and write methods
Please guide me to fix it.
KM
Did you create an OPM database?
No,We didn’t created any OPM database, instead we set the “write_json” option to true under “opm” section in configuration.
Is OPM database is mandatory? If so, please guide me to do that installation.
KM
What tables are in your database for GAX?
Currently below listed tables are available in GAX
db_upgrades_history
plugin_persistence
asd_deployment
asd_deployment_action
asd_ip
asd_ip_content
asd_ip_owner
asd_sd
asd_privileges
asd_default_roles
asd_default_roles_priv
arm_ar
arm_arf_orig
arm_ar_content
arm_ar_file
arm_encoded_file
arm_personality
opm_custom_value
opm_op_custom_value
opm_op_parameter
opm_parameter
opm_pg
opm_pgt
opm_pgt_app
opm_pgt_element
opm_pgt_section
opm_pg_app
opm_pg_element
opm_pg_section
sequence_table
db_schema_version
~KM
Kubig, Is there any update please..?
? Open an eSR with Genesys if you need a response in a desired time window.
