Reference Existing Genesys Cloud Resources by Name Using Terraform Data Sources
  • A Terraform configuration that dynamically retrieves the IDs of existing Genesys Cloud resources (users, queues, and flow versions) using their display names.
  • This tutorial uses the genesyscloud Terraform provider data sources to resolve names to IDs without hardcoding UUIDs.
  • The programming language is HCL (HashiCorp Configuration Language) for Terraform.
  • OAuth Client Type: Service Account or User Credentials (Username/Password) configured in Genesys Cloud Admin.
  • Required Scopes:
    • user:view (for User data source)
    • queue:view (for Queue data source)
    • flow:view (for Flow data source)
  • Provider Version: genesyscloud provider version 1.10.0 or higher.
  • Runtime Requirements:
    • Terraform CLI version 1.5.0 or higher.
    • A Genesys Cloud organization with at least one User, one Queue, and one Flow created.
  • External Dependencies: None beyond the standard Terraform CLI and the Genesys Cloud provider.
Terraform handles authentication via provider configuration. For this tutorial, we use environment variables to pass credentials securely. This avoids committing secrets to your code repository.
Set the following environment variables in your terminal before running Terraform commands:
export GENESYS_CLOUD_CLIENT_ID="your-client-id"
export GENESYS_CLOUD_CLIENT_SECRET="your-client-secret"
export GENESYS_CLOUD_BASE_URL="https://api.mypurecloud.com"
Alternatively, you can use a credentials.tfvars file (excluded from version control):
# credentials.tfvars
genesys_cloud_client_id     = "your-client-id"
genesys_cloud_client_secret = "your-client-secret"
genesys_cloud_base_url      = "https://api.mypurecloud.com"
Include this in your main.tf:
terraform {
  required_providers {
    genesyscloud = {
      source  = "mycloud/genesyscloud"
      version = ">= 1.10.0"
provider "genesyscloud" {
  # Credentials are automatically picked up from environment variables
  # or can be explicitly set here:
  # client_id     = var.genesys_cloud_client_id
  # client_secret = var.genesys_cloud_client_secret
  # base_url      = var.genesys_cloud_base_url
The provider initializes an OAuth token flow internally. If the credentials are invalid, Terraform will fail immediately during the terraform init or terraform plan phase with a 401 Unauthorized error.
Step 1: Resolve a User ID by Name
User IDs are required for many resources, such as adding users to queues or setting ownership on flows. Hardcoding User IDs is fragile because IDs change if the user is deleted and recreated. Using a data source resolves the ID dynamically.
The genesyscloud_user data source searches for a user by name. If multiple users share the same name, Terraform will fail with an error indicating ambiguity. Ensure the name is unique or use a more specific search strategy if available in newer provider versions (currently, name must be unique).
data "genesyscloud_user" "admin_user" {
  name = "John Doe"
Expected Behavior:
  • Terraform calls the Genesys Cloud API endpoint GET /api/v2/users.
  • It filters the response for a user where name equals "John Doe".
  • It stores the UUID of the first match in data.genesyscloud_user.admin_user.id.
Error Handling:
  • No Match: If no user named “John Doe” exists, terraform plan fails with: Error: No user found with name "John Doe".
  • Multiple Matches: If two users are named “John Doe”, terraform plan fails with: Error: Multiple users found with name "John Doe".
Step 2: Resolve a Queue ID by Name
Queue IDs are essential for routing configurations. Queues are often referenced by name in business logic, but the API requires UUIDs.
data "genesyscloud_queue" "support_queue" {
  name = "Customer Support"
Expected Behavior:
  • Terraform calls GET /api/v2/queues.
  • It filters for a queue where name equals "Customer Support".
  • The resulting ID is available via data.genesyscloud_queue.support_queue.id.
Edge Case:
  • Queue names are case-sensitive. "Customer Support" does not match "customer support". Ensure the name in your data source matches the exact casing in Genesys Cloud Admin.
Step 3: Resolve a Flow Version ID by Name
Flows are versioned resources. Referencing a flow by name alone is insufficient because multiple versions may exist. The genesyscloud_flow data source allows you to specify the flow name and optionally the version name. If no version is specified, it defaults to the latest published version.
data "genesyscloud_flow" "ivr_flow" {
  name = "Main IVR"
  # Optional: specify version name to pin to a specific version
  # version_name = "v1.0"
Expected Behavior:
  • Terraform calls GET /api/v2/flows to find the flow ID by name.
  • It then calls GET /api/v2/flows/{flowId}/versions to list versions.
  • It selects the version matching version_name or the latest published version.
  • The ID is available via data.genesyscloud_flow.ivr_flow.id.
Note: If you do not specify version_name, Terraform returns the ID of the most recently published version. This is dynamic and may change if a new version is published. For stability in production, always pin to a specific version_name.
Step 4: Use Resolved IDs in Resources
Now that you have data sources, you can reference their IDs in other resources. This creates a dependency graph where Terraform ensures the referenced resources exist before creating dependent resources.
Example: Adding the resolved user to the resolved queue.
resource "genesyscloud_queue_member" "admin_in_support" {
  queue_id = data.genesyscloud_queue.support_queue.id
  user_id  = data.genesyscloud_user.admin_user.id
  # Optional: set wrap up code or other queue member settings
Example: Setting the default flow on the queue.
resource "genesyscloud_queue" "support_queue_config" {
  description = "Queue for general support"
  # Use the resolved flow ID
  default_outbound_flow_id = data.genesyscloud_flow.ivr_flow.id
Important: In the example above, genesyscloud_queue is both a data source and a resource. This is allowed, but be cautious. If you modify the queue resource, the data source will reflect the new state after apply. However, it is best practice to separate data sources (read-only references to existing resources) from resources (managed by Terraform).
This example demonstrates a complete Terraform configuration that references existing users, queues, and flows by name and creates a queue member assignment.
File: main.tf
terraform {
    genesyscloud = {
  # Credentials via environment variables
# --- Data Sources: Reference Existing Resources by Name ---
# 1. Resolve User ID
data "genesyscloud_user" "support_agent" {
  name = "Jane Smith"
# 2. Resolve Queue ID
data "genesyscloud_queue" "billing_queue" {
  name = "Billing Inquiries"
# 3. Resolve Flow ID (pin to specific version for stability)
data "genesyscloud_flow" "billing_flow" {
  name         = "Billing Flow"
  version_name = "v2.1"
# --- Resources: Create New Configurations Using Resolved IDs ---
# Add the resolved user to the resolved queue
resource "genesyscloud_queue_member" "jane_in_billing" {
  queue_id = data.genesyscloud_queue.billing_queue.id
  user_id  = data.genesyscloud_user.support_agent.id
  # Optional: Set wrap up code requirements
  wrap_up_required = true
# Create a new queue that references the resolved flow
resource "genesyscloud_queue" "escalation_queue" {
  name        = "Billing Escalations"
  description = "Escalated billing issues"
  # Reference the resolved flow ID
  default_outbound_flow_id = data.genesyscloud_flow.billing_flow.id
  # Reference the resolved user as the queue owner
  owner_id = data.genesyscloud_user.support_agent.id
File: terraform.tfvars (Optional, if not using environment variables)
# Not needed if using environment variables for credentials
Execution Steps:
  1. Initialize Terraform:
    terraform init
  2. Plan the changes:
    terraform plan
    Verify that the plan shows no changes to the data sources (they are read-only) and creates the new resources.
  3. Apply the changes:
    terraform apply
Error: Error: Multiple users found with name "John Doe"
Cause: The Genesys Cloud organization contains more than one user with the exact same name. The data source cannot determine which ID to return.
Fix:
  1. Rename one of the users in Genesys Cloud Admin to make the name unique.
  2. Use a different identifier if available (e.g., email address, if supported by the provider version). Currently, the genesyscloud_user data source only supports name lookup. If uniqueness is not guaranteed, consider managing the user via Terraform instead of referencing it.
Error: Error: No user found with name "Jane Smith"
Cause: No user exists in the Genesys Cloud organization with the specified name.
Fix:
  1. Verify the spelling and casing of the name in Genesys Cloud Admin.
  2. Ensure the user is not deleted or deactivated.
  3. Check that the OAuth client has the user:view scope.
Error: Error: Multiple queues found with name "Support"
Cause: Multiple queues share the same name. Queue names must be unique within an organization for the data source to work.
Fix:
  1. Rename the queues to be unique.
  2. Use a naming convention that includes identifiers, e.g., “Support - US”, “Support - EU”.
Error: Error: No flow found with name "Billing Flow"
Cause: No flow with the specified name exists, or the flow is not published.
Fix:
  1. Verify the flow name in Genesys Cloud Admin.
  2. Ensure the flow is published. Unpublished flows may not be visible to all OAuth clients depending on permissions.
  3. Check that the OAuth client has the flow:view scope.
Error: Error: Multiple flow versions found with name "v1.0"
Cause: Multiple versions of the flow have the same version name. Version names must be unique within a flow.
Fix:
  1. Rename the versions in Genesys Cloud Admin to be unique.
  2. Use a more specific version name, e.g., “v1.0-prod”, “v1.0-staging”.
Cause: The OAuth client lacks the required permissions.
Fix:
  1. Ensure the OAuth client has the correct scopes:
    • user:view for genesyscloud_user
    • queue:view for genesyscloud_queue
    • flow:view for genesyscloud_flow
  2. Verify the client ID and secret are correct.
  3. Check that the OAuth client is not expired or disabled.
