Redacting NICE CXone Speech Analytics Audio Segments with Java
  • This tutorial builds a Java service that programmatically redacts sensitive audio segments in NICE CXone Speech Analytics recordings using atomic PATCH requests.
  • The implementation uses the official NICE CXone Java SDK and the /api/v2/speechanalytics/redactions endpoint.
  • All code is written in Java 17 with explicit error handling, batch validation, and audit logging.
  • OAuth 2.0 Client Credentials flow with scopes: speechanalytics:read, speechanalytics:write, recording:read
  • NICE CXone Java SDK version 2.x or later
  • Java 17 runtime with Maven or Gradle
  • Dependencies: com.nice.cxp:sdk-core, com.nice.cxp:sdk-speechanalytics, com.google.guava:guava, org.slf4j:slf4j-api, jakarta.json:jakarta.json-api
NICE CXone uses a standard OAuth 2.0 Client Credentials flow. The SDK handles token caching and automatic refresh when the ApiClient is configured correctly. You must set the base path to your organization domain and attach the bearer token before invoking any Speech Analytics methods.
import com.nice.cxp.sdk.ApiClient;
import com.nice.cxp.sdk.Configuration;
import java.net.URI;
import java.util.Base64;
public class CxoneAuthManager {
    private static final String TOKEN_ENDPOINT = "https://%s.cxonecloud.com/api/v2/oauth/token";
    private static final ObjectMapper mapper = new ObjectMapper();
    private static final HttpClient httpClient = HttpClient.newHttpClient();
    public static String fetchAccessToken(String orgDomain, String clientId, String clientSecret) throws Exception {
        String url = String.format(TOKEN_ENDPOINT, orgDomain);
        String credentials = Base64.getEncoder().encodeToString((clientId + ":" + clientSecret).getBytes());
        String body = "grant_type=client_credentials&scope=speechanalytics:read+speechanalytics:write+recording:read";
            .uri(URI.create(url))
            .header("Content-Type", "application/x-www-form-urlencoded")
            .header("Authorization", "Basic " + credentials)
            .POST(HttpRequest.BodyPublishers.ofString(body))
            .build();
            throw new RuntimeException("OAuth token fetch failed with status " + response.statusCode());
        JsonNode json = mapper.readTree(response.body());
        return json.get("access_token").asText();
    public static ApiClient initializeApiClient(String orgDomain, String accessToken) {
        ApiClient client = new ApiClient();
        client.setBasePath("https://" + orgDomain + ".cxonecloud.com/api/v2");
        client.setAccessToken(accessToken);
        Configuration.setDefaultApiClient(client);
        return client;
Step 1: Construct and Validate Redaction Payloads
The CXone Speech Analytics API requires redaction requests to contain valid recording UUIDs, precise segment boundaries, and recognized PII category tags. The API enforces a maximum batch size of 50 segments per request to prevent audio processing timeouts. This step validates the input schema, verifies audio format compatibility, and constructs the payload matrix.
import java.util.*;
import java.util.regex.Pattern;
public class RedactionPayloadBuilder {
    private static final int MAX_BATCH_SIZE = 50;
    private static final Pattern UUID_PATTERN = Pattern.compile("^[0-9a-f]{8}-[0-9a-f]{4}-[1-5][0-9a-f]{3}-[89ab][0-9a-f]{3}-[0-9a-f]{12}$", Pattern.CASE_INSENSITIVE);
    private static final Set<String> ALLOWED_FORMATS = Set.of("wav", "mp3", "pcmu", "aac");
    private static final Set<String> VALID_PII_CATEGORIES = Set.of("SSN", "CCN", "DOB", "PHN", "EMAIL", "ADDRESS", "CUSTOM");
    private static final Set<String> VALID_DIRECTIVES = Set.of("silence", "tone", "mask", "voice_clone");
    public record RedactionSegment(long startMs, long endMs, String piiCategory, String replacementDirective) {}
    public record RedactionBatch(String recordingId, String audioFormat, List<RedactionSegment> segments) {}
    public static RedactionBatch validateAndConstruct(String recordingId, String audioFormat, List<RedactionSegment> segments) {
        if (!UUID_PATTERN.matcher(recordingId).matches()) {
            throw new IllegalArgumentException("Invalid recording UUID format: " + recordingId);
        if (!ALLOWED_FORMATS.contains(audioFormat.toLowerCase())) {
            throw new IllegalArgumentException("Unsupported audio format: " + audioFormat);
        if (segments.size() > MAX_BATCH_SIZE) {
            throw new IllegalArgumentException("Batch size exceeds maximum limit of " + MAX_BATCH_SIZE + " segments.");
        List<RedactionSegment> validated = new ArrayList<>();
        for (RedactionSegment seg : segments) {
            if (seg.startMs >= seg.endMs) {
                throw new IllegalArgumentException("Segment start must be less than end. Start: " + seg.startMs + ", End: " + seg.endMs);
            if (!VALID_PII_CATEGORIES.contains(seg.piiCategory.toUpperCase())) {
                throw new IllegalArgumentException("Invalid PII category: " + seg.piiCategory);
            if (!VALID_DIRECTIVES.contains(seg.replacementDirective.toLowerCase())) {
                throw new IllegalArgumentException("Invalid replacement directive: " + seg.replacementDirective);
            validated.add(seg);
        return new RedactionBatch(recordingId, audioFormat.toLowerCase(), validated);
Step 2: Execute Atomic PATCH Operations with Retry Logic
The CXone API processes redactions atomically. If a single segment fails validation on the server, the entire batch is rejected. You must implement exponential backoff for HTTP 429 responses and verify the 200 OK or 201 Created status before committing to secure storage. The SDK method updateRedactions maps to a PATCH /api/v2/speechanalytics/redactions call.
import com.nice.cxp.sdk.speechanalytics.SpeechanalyticsApi;
import com.nice.cxp.sdk.model.RedactionRequest;
import com.nice.cxp.sdk.model.RedactionSegment as SdkSegment;
public class RedactionExecutor {
    private final SpeechanalyticsApi speechApi;
    public RedactionExecutor(SpeechanalyticsApi api) {
        this.speechApi = api;
    public String executeRedaction(RedactionPayloadBuilder.RedactionBatch batch) throws Exception {
        RedactionRequest request = new RedactionRequest();
        request.setRecordingId(batch.recordingId());
        request.setAudioFormat(batch.audioFormat());
        List<SdkSegment> sdkSegments = batch.segments().stream().map(seg -> {
            SdkSegment sdkSeg = new SdkSegment();
            sdkSeg.setStartMs(seg.startMs());
            sdkSeg.setEndMs(seg.endMs());
            sdkSeg.setRedactionType(seg.piiCategory());
            sdkSeg.setReplacementDirective(seg.replacementDirective());
            return sdkSeg;
        }).toList();
        request.setSegments(sdkSegments);
        int maxRetries = 3;
        long delayMs = 1000;
        Exception lastException = null;
        for (int attempt = 0; attempt <= maxRetries; attempt++) {
                // SDK translates to: PATCH /api/v2/speechanalytics/redactions
                // Headers: Authorization: Bearer <token>, Content-Type: application/json
                var response = speechApi.updateRedactions(request);
                if (response.getStatusCode() == 200 || response.getStatusCode() == 201) {
                    return response.getResult().getRedactionId();
                throw new RuntimeException("Unexpected status: " + response.getStatusCode());
            } catch (Exception e) {
                lastException = e;
                if (attempt < maxRetries && isRateLimited(e)) {
                    TimeUnit.MILLISECONDS.sleep(delayMs);
                    delayMs *= 2;
                } else {
                    throw lastException;
    private boolean isRateLimited(Exception e) {
        return e.getMessage() != null && e.getMessage().contains("429");
Step 3: Implement Audio Validation Pipeline
Before submitting redaction directives, you must verify that the replacement audio will not distort voiceprint biometrics or introduce frequency artifacts. This pipeline checks segment boundaries against audio metadata and validates that silence or tone replacements fall within safe frequency ranges.
import java.util.Map;
public class AudioValidationPipeline {
    public record ValidationReport(boolean voiceprintSafe, boolean spectrumSmooth, String artifactRisk) {}
    public static ValidationReport verifySegmentSafety(RedactionPayloadBuilder.RedactionSegment segment, String audioFormat) {
        boolean voiceprintSafe = true;
        boolean spectrumSmooth = true;
        String artifactRisk = "NONE";
        long durationMs = segment.endMs() - segment.startMs();
        // Voiceprint preservation check: segments under 200ms risk biometric disruption
        if (durationMs < 200) {
            voiceprintSafe = false;
            artifactRisk = "BIOMETRIC_DISRUPTION";
        // Frequency spectrum smoothing check: silence replacements on PCMU require padding
        if ("pcmu".equals(audioFormat) && "silence".equals(segment.replacementDirective()) && durationMs > 3000) {
            spectrumSmooth = false;
            artifactRisk = "SPECTRUM_TRUNCATION";
        return new ValidationReport(voiceprintSafe, spectrumSmooth, artifactRisk);
Step 4: Synchronize with DLP Webhooks, Track Metrics, and Generate Audit Logs
NICE CXone triggers webhooks upon redaction completion. You must register a subscriber endpoint and correlate the webhook payload with your internal tracking. This step implements a metrics collector for latency and success rates, and an audit logger for privacy governance.
import java.time.Instant;
import java.util.concurrent.atomic.AtomicLong;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class RedactionGovernanceService {
    private static final Logger logger = LoggerFactory.getLogger(RedactionGovernanceService.class);
    private final AtomicLong successCount = new AtomicLong(0);
    private final AtomicLong failureCount = new AtomicLong(0);
    private final AtomicLong totalLatencyMs = new AtomicLong(0);
    private final Map<String, Long> pendingRedactions = new ConcurrentHashMap<>();
    public void trackStart(String recordingId) {
        pendingRedactions.put(recordingId, Instant.now().toEpochMilli());
        logger.info("AUDIT: Redaction started for recording {}", recordingId);
    public void trackCompletion(String recordingId, boolean success) {
        Long start = pendingRedactions.remove(recordingId);
        if (start == null) return;
        long latency = Instant.now().toEpochMilli() - start;
        totalLatencyMs.addAndGet(latency);
        if (success) {
            successCount.incrementAndGet();
            logger.info("AUDIT: Redaction completed successfully for {}. Latency: {}ms", recordingId, latency);
        } else {
            failureCount.incrementAndGet();
            logger.warn("AUDIT: Redaction failed for {}. Latency: {}ms", recordingId, latency);
    public void handleDlpWebhook(String recordingId, String webhookPayload) {
        logger.info("WEBHOOK_SYNC: DLP system acknowledged redaction for {}. Payload: {}", recordingId, webhookPayload);
        // Forward to external DLP system via HTTP POST if required
    public double getSuccessRate() {
        long total = successCount.get() + failureCount.get();
        return total == 0 ? 0.0 : (double) successCount.get() / total;
    public double getAverageLatencyMs() {
        return total == 0 ? 0.0 : (double) totalLatencyMs.get() / total;
The following class integrates authentication, payload validation, atomic execution, audio safety checks, webhook synchronization, and audit logging into a single runnable service. Replace the placeholder credentials and domain before execution.
import java.util.List;
public class ConeSpeechAnalyticsRedactor {
            // 1. Authentication
            String orgDomain = "your-org";
            String clientId = "YOUR_CLIENT_ID";
            String clientSecret = "YOUR_CLIENT_SECRET";
            String token = CxoneAuthManager.fetchAccessToken(orgDomain, clientId, clientSecret);
            ApiClient apiClient = CxoneAuthManager.initializeApiClient(orgDomain, token);
            SpeechanalyticsApi speechApi = new SpeechanalyticsApi();
            // 2. Governance & Metrics
            RedactionGovernanceService governance = new RedactionGovernanceService();
            RedactionExecutor executor = new RedactionExecutor(speechApi);
            // 3. Define Redaction Segments
            List<RedactionPayloadBuilder.RedactionSegment> segments = List.of(
                new RedactionPayloadBuilder.RedactionSegment(1200, 2800, "SSN", "silence"),
                new RedactionPayloadBuilder.RedactionSegment(4500, 6100, "CCN", "tone"),
                new RedactionPayloadBuilder.RedactionSegment(8000, 9500, "PHN", "mask")
            // 4. Validate Payload
            String recordingId = "a1b2c3d4-e5f6-7890-abcd-ef1234567890";
            RedactionPayloadBuilder.RedactionBatch batch = RedactionPayloadBuilder.validateAndConstruct(
                recordingId, "wav", segments
            // 5. Audio Safety Pipeline
            for (var seg : batch.segments()) {
                var report = AudioValidationPipeline.verifySegmentSafety(seg, batch.audioFormat());
                if (!report.voiceprintSafe() || !report.spectrumSmooth()) {
                    throw new RuntimeException("Audio validation failed: " + report.artifactRisk());
            // 6. Execute Redaction
            governance.trackStart(recordingId);
            String redactionId = executor.executeRedaction(batch);
            // 7. Post-Execution Sync & Metrics
            governance.trackCompletion(recordingId, true);
            governance.handleDlpWebhook(recordingId, "{\"status\":\"compliant\",\"redactionId\":\"" + redactionId + "\"}");
            System.out.println("Redaction ID: " + redactionId);
            System.out.println("Success Rate: " + governance.getSuccessRate());
            System.out.println("Avg Latency: " + governance.getAverageLatencyMs() + "ms");
            System.err.println("Redaction workflow failed: " + e.getMessage());
            e.printStackTrace();
  • Cause: The OAuth token has expired or the client credentials are invalid. The CXone token cache may not have refreshed before the PATCH request.
  • Fix: Implement token expiry checking before API calls. Refresh the token using CxoneAuthManager.fetchAccessToken and update the ApiClient instance via apiClient.setAccessToken(newToken).
  • Code:
    if (System.currentTimeMillis() > tokenExpiryTimestamp) {
        String freshToken = CxoneAuthManager.fetchAccessToken(orgDomain, clientId, clientSecret);
        apiClient.setAccessToken(freshToken);
Error: 403 Forbidden
  • Cause: The OAuth client lacks the speechanalytics:write scope, or the organization has restricted API access to specific IP ranges.
  • Fix: Verify the client credentials in the CXone Admin Console under Platform > OAuth. Ensure the scope string includes speechanalytics:write. Add your server IP to the organization allowlist if network restrictions are enabled.
  • Cause: The CXone Speech Analytics service enforces rate limits per organization. Submitting more than 10 redaction batches per second triggers a cascade rejection.
  • Fix: The retry logic in RedactionExecutor handles this with exponential backoff. Increase the initial delay to 2000ms and cap retries at 4. Implement a request queue with a semaphore if processing high volumes.
  • Code:
    // Inside retry loop
    TimeUnit.MILLISECONDS.sleep(Math.min(delayMs * Math.pow(2, attempt), 8000));
Error: 400 Bad Request
  • Cause: The payload schema violates CXone constraints. Common triggers include overlapping segment boundaries, invalid replacement directives, or batch size exceeding 50 segments.
  • Fix: Validate segments against RedactionPayloadBuilder rules before submission. Ensure startMs is strictly less than endMs and that segments do not overlap. Split batches larger than 50 into multiple sequential requests.
  • Cause: The CXone audio processing engine encountered an unrecoverable state, often due to corrupted recording metadata or unsupported audio encoding.
  • Fix: Verify the recording exists and is accessible via GET /api/v2/speechanalytics/recording/{recordingId}. Download a sample to confirm format integrity. Retry the request after 15 seconds. If the error persists, submit a support ticket with the correlationId from the response headers.
