Redacting NICE CXone Call Recordings via Recording API with Python SDK
A Python module that programmatically submits PII redaction jobs for NICE CXone call recordings, validates audio format and quota constraints, polls asynchronous job progress with exponential backoff, verifies redaction accuracy against transcription output, synchronizes status updates to external compliance systems via webhook, and generates immutable audit logs with latency and accuracy metrics.
  • OAuth 2.0 Client Credentials flow configured in CXone Developer Portal
  • Required scopes: recording:redact, recording:read, recording:transcribe
  • CXone site identifier (e.g., mycompany)
  • Python 3.9+ runtime
  • External dependencies: cxoneapi, requests, sqlite3, json, time, http.server
  • CXone Recording API version: v2
NICE CXone uses standard OAuth 2.0 client credentials. You must exchange your client credentials for an access token before initializing the SDK. The following code handles token acquisition, stores it in memory, and implements a simple refresh mechanism when the token expires.
import requests
from typing import Optional
OAUTH_ENDPOINT = "https://{site}.api.cxone.com/oauth/token"
REQUIRED_SCOPES = "recording:redact recording:read recording:transcribe"
class CXoneAuthManager:
    def __init__(self, site: str, client_id: str, client_secret: str):
        self.site = site
        self.client_id = client_id
    def get_token(self) -> str:
        if self.token and time.time() < self.token_expiry - 60:
            return self.token
        url = OAUTH_ENDPOINT.replace("{site}", self.site)
        payload = {
            "client_id": self.client_id,
            "scope": REQUIRED_SCOPES
        response = requests.post(url, data=payload)
        response.raise_for_status()
        data = response.json()
        if "error" in data:
            raise Exception(f"OAuth error: {data['error_description']}")
        self.token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"]
        return self.token
The get_token method checks expiration and fetches a new token when necessary. You must call this method before passing the token to the CXone Python SDK.
Step 1: SDK Initialization and Recording Metadata Validation
Before submitting a redaction job, you must verify that the recording exists, supports redaction, and matches an accepted audio format. CXone redaction only supports MP3, WAV, and PCM formats. The following code initializes the SDK, fetches recording metadata, and validates constraints.
from cxoneapi import CxoneApiClient, RecordingApi
from cxoneapi.exceptions import ApiError
SUPPORTED_FORMATS = {"mp3", "wav", "pcm"}
def validate_recording_constraints(auth: CXoneAuthManager, recording_id: str) -> dict:
    client = CxoneApiClient()
    client.set_access_token(auth.get_token())
    recording_api = RecordingApi(client)
        recording = recording_api.get_recording(recording_id)
    except ApiError as e:
        if e.status == 404:
            raise ValueError(f"Recording {recording_id} not found")
        raise
    audio_format = recording.format.lower() if recording.format else "unknown"
    if audio_format not in SUPPORTED_FORMATS:
        raise ValueError(f"Unsupported audio format: {audio_format}. Supported: {SUPPORTED_FORMATS}")
    if recording.size > 500 * 1024 * 1024:  # 500 MB limit
        raise ValueError("Recording exceeds maximum size for redaction processing")
        "id": recording_id,
        "format": audio_format,
        "size_mb": recording.size / (1024 * 1024),
        "duration_seconds": recording.duration / 1000.0 if recording.duration else 0
The get_recording call uses the recording:read scope. The response includes format, size, and duration. You must reject formats outside the supported list before proceeding.
Step 2: Redaction Payload Construction and Quota Validation
CXone redaction jobs require a structured payload containing the recording identifier, PII patterns, replacement audio behavior, and language configuration. You must also check processing quotas to avoid 429 rate limit cascades. The following function constructs the payload and performs a pre-flight quota check.
import json
def build_redaction_payload(recording_id: str, pii_patterns: list, replacement_type: str = "silence") -> dict:
        "recordingId": recording_id,
        "redactionType": "custom",
        "patterns": pii_patterns,
        "replacementType": replacement_type,
        "language": "en-US",
        "includeTranscript": True,
        "metadata": {
            "workflow": "automated_pii_protection",
            "compliance_standard": "gdpr_hipaa"
def check_redaction_quota(auth: CXoneAuthManager) -> bool:
    url = f"https://{auth.site}.api.cxone.com/api/v2/recording/redaction/limits"
    headers = {"Authorization": f"Bearer {auth.get_token()}"}
    response = requests.get(url, headers=headers)
    if response.status_code == 403:
        return False
        raise Exception("Redaction quota exhausted. Retry after rate limit window closes.")
    return data.get("remainingQuota", 0) > 0
The payload uses recording:redact scope. The patterns array accepts regular expressions or predefined CXone PII identifiers. The replacementType field accepts silence, beep, or customAudioUrl. You must verify quota availability before submission to prevent unnecessary API calls.
Step 3: Asynchronous Job Submission and Polling with Error Recovery
Redaction jobs execute asynchronously. You submit the payload, receive a redactionId, and poll the status endpoint until completion. The following implementation includes exponential backoff, progress tracking, and error recovery for large audio files.
import logging
def submit_and_poll_redaction(auth: CXoneAuthManager, payload: dict) -> dict:
        job = recording_api.post_recording_redaction(payload)
        if e.status == 429:
            retry_after = int(e.headers.get("Retry-After", 30))
            logger.warning(f"Rate limited. Waiting {retry_after} seconds before retry.")
            time.sleep(retry_after)
            return submit_and_poll_redaction(auth, payload)
        raise
    redaction_id = job.id
    start_time = time.time()
    max_retries = 15
    backoff = 5
        time.sleep(backoff)
            status = recording_api.get_recording_redaction(redaction_id)
            if e.status == 503:
                logger.warning("Service unavailable during polling. Retrying.")
                backoff *= 2
            raise
        logger.info(f"Redaction {redaction_id} progress: {status.progress}% | Status: {status.status}")
        if status.status == "completed":
            latency = time.time() - start_time
                "redaction_id": redaction_id,
                "status": status.status,
                "latency_seconds": latency,
                "output_recording_id": status.outputRecordingId,
                "transcript_uri": status.transcriptUri
        if status.status == "failed":
            raise Exception(f"Redaction failed: {status.errors}")
        backoff = min(backoff * 1.5, 60)
    raise TimeoutError(f"Redaction {redaction_id} did not complete within polling window")
The post_recording_redaction call returns a job object with an id. You poll get_recording_redaction using the same recording:redact scope. The polling loop implements exponential backoff capped at 60 seconds. You must handle 503 responses gracefully during long-running jobs.
Step 4: Verification Logic, Webhook Synchronization, and Audit Logging
After redaction completes, you must verify that PII patterns were successfully masked. The following code fetches the redacted transcript, runs pattern matching verification, calculates accuracy scores, logs metrics to SQLite, and exposes a webhook endpoint for external compliance synchronization.
import sqlite3
import re
from http.server import HTTPServer, BaseHTTPRequestHandler
import json
def setup_audit_db(db_path: str) -> sqlite3.Connection:
    conn = sqlite3.connect(db_path)
    conn.execute("""
        CREATE TABLE IF NOT EXISTS redaction_audit (
            id INTEGER PRIMARY KEY AUTOINCREMENT,
            recording_id TEXT NOT NULL,
            redaction_id TEXT NOT NULL,
            status TEXT NOT NULL,
            latency_seconds REAL,
            accuracy_score REAL,
            pii_remaining INTEGER,
            timestamp REAL
    conn.commit()
    return conn
def verify_redaction_accuracy(auth: CXoneAuthManager, transcript_uri: str, pii_patterns: list) -> tuple:
    transcript_response = requests.get(transcript_uri, headers=headers)
    transcript_response.raise_for_status()
    transcript_text = transcript_response.text
    matches = []
    for pattern in pii_patterns:
        found = re.findall(pattern, transcript_text, re.IGNORECASE)
        matches.extend(found)
    total_patterns = len(pii_patterns)
    accuracy = 1.0 - (len(matches) / max(len(transcript_text.split()), 1))
    return accuracy, len(matches), transcript_text
class ComplianceWebhookHandler(BaseHTTPRequestHandler):
    def do_POST(self):
        content_length = int(self.headers.get("Content-Length", 0))
        body = self.rfile.read(content_length)
        payload = json.loads(body)
        print(f"Received compliance webhook: {payload}")
        self.send_response(200)
        self.end_headers()
        self.wfile.write(b"OK")
def run_audit_workflow(auth: CXoneAuthManager, recording_id: str, pii_patterns: list, db_path: str):
    db = setup_audit_db(db_path)
    constraints = validate_recording_constraints(auth, recording_id)
    if not check_redaction_quota(auth):
        raise Exception("Redaction quota unavailable. Deferring job.")
    payload = build_redaction_payload(recording_id, pii_patterns)
    job_result = submit_and_poll_redaction(auth, payload)
    accuracy, remaining_pii, transcript = verify_redaction_accuracy(
        auth, job_result["transcript_uri"], pii_patterns
    db.execute("""
        INSERT INTO redaction_audit
        (recording_id, redaction_id, status, latency_seconds, accuracy_score, pii_remaining, timestamp)
        VALUES (?, ?, ?, ?, ?, ?, ?)
        recording_id,
        job_result["redaction_id"],
        job_result["status"],
        job_result["latency_seconds"],
        accuracy,
        remaining_pii,
        time.time()
    db.commit()
    db.close()
    print(f"Audit logged. Accuracy: {accuracy:.2%} | Remaining PII: {remaining_pii} | Latency: {job_result['latency_seconds']:.2f}s")
    return job_result, accuracy
The verification step uses the recording:read scope to fetch the transcript. You calculate accuracy by comparing remaining PII matches against transcript length. The audit table stores latency, accuracy, and compliance status. The ComplianceWebhookHandler class exposes a local HTTP endpoint that external privacy tools can call to synchronize status.
The following script combines all components into a single runnable module. You must replace the placeholder credentials before execution.
import logging
import sqlite3
import json
import requests
        self.site = site
        self.token = None
        self.token_expiry = 0.0
            return self.token
        payload = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret, "scope": REQUIRED_SCOPES}
        if "error" in data:
        return self.token
        if e.status == 404:
        raise
    return {"id": recording_id, "format": audio_format, "size_mb": recording.size / (1024 * 1024), "duration_seconds": recording.duration / 1000.0 if recording.duration else 0}
    return {"recordingId": recording_id, "redactionType": "custom", "patterns": pii_patterns, "replacementType": replacement_type, "language": "en-US", "includeTranscript": True, "metadata": {"workflow": "automated_pii_protection", "compliance_standard": "gdpr_hipaa"}}
        return False
        if e.status == 429:
            logging.warning(f"Rate limited. Waiting {retry_after} seconds before retry.")
        raise
    max_retries = 15
    backoff = 5
        time.sleep(backoff)
            if e.status == 503:
                logging.warning("Service unavailable during polling. Retrying.")
                backoff *= 2
            raise
        logging.info(f"Redaction {redaction_id} progress: {status.progress}% | Status: {status.status}")
            return {"redaction_id": redaction_id, "status": status.status, "latency_seconds": time.time() - start_time, "output_recording_id": status.outputRecordingId, "transcript_uri": status.transcriptUri}
    conn.execute("CREATE TABLE IF NOT EXISTS redaction_audit (id INTEGER PRIMARY KEY AUTOINCREMENT, recording_id TEXT, redaction_id TEXT, status TEXT, latency_seconds REAL, accuracy_score REAL, pii_remaining INTEGER, timestamp REAL)")
    conn.commit()
    return conn
    def do_POST(self):
        body = self.rfile.read(length)
        logging.info(f"Webhook payload: {body.decode()}")
        self.end_headers()
    auth = CXoneAuthManager(site="your-cxone-site", client_id="YOUR_CLIENT_ID", client_secret="YOUR_CLIENT_SECRET")
    recording_id = "YOUR_RECORDING_ID"
    pii_patterns = [r"\b\d{3}-\d{4}-\d{4}\b", r"\b[A-Z0-9]{2}\d{6}\b", r"\b\d{5}(-\d{4})?\b"]
    logging.info("Starting redaction workflow...")
    logging.info(f"Recording validated: {constraints}")
        logging.error("Quota check failed. Exiting.")
        exit(1)
    logging.info("Submitting redaction job...")
    logging.info("Redaction completed. Fetching transcript for verification...")
    transcript_resp = requests.get(job_result["transcript_uri"], headers=headers)
    transcript_resp.raise_for_status()
    transcript_text = transcript_resp.text
    import re
    matches = []
        matches.extend(re.findall(pattern, transcript_text, re.IGNORECASE))
    db = setup_audit_db("redaction_audit.db")
    db.execute("INSERT INTO redaction_audit (recording_id, redaction_id, status, latency_seconds, accuracy_score, pii_remaining, timestamp) VALUES (?, ?, ?, ?, ?, ?, ?)",
               (recording_id, job_result["redaction_id"], job_result["status"], job_result["latency_seconds"], accuracy, len(matches), time.time()))
    db.commit()
    db.close()
    logging.info(f"Audit logged. Accuracy: {accuracy:.2%} | Remaining PII: {len(matches)} | Latency: {job_result['latency_seconds']:.2f}s")
    server = HTTPServer(("localhost", 8080), ComplianceWebhookHandler)
    logging.info("Compliance webhook listener running on http://localhost:8080")
    server.handle_request()
  • Cause: Expired access token or missing recording:redact scope in OAuth request.
  • Fix: Ensure the CXoneAuthManager refreshes the token before each SDK call. Verify the scope string matches exactly.
  • Code fix: Add explicit scope validation in the OAuth payload and force token refresh by setting self.token_expiry = 0 before retry.
Error: 403 Forbidden
  • Cause: Client lacks permission for redaction operations or quota endpoint access.
  • Fix: Assign the Recording Redactor role to the OAuth client in CXone admin console. Verify the client is enabled for the recording API group.
  • Cause: Polling frequency exceeds CXone rate limits or quota exhaustion.
  • Fix: Implement exponential backoff with jitter. Read the Retry-After header. The provided submit_and_poll_redaction function handles this automatically.
Error: 400 Bad Request - Format Mismatch
  • Cause: Recording format is not MP3, WAV, or PCM, or payload structure violates schema.
  • Fix: Validate recording.format before submission. Ensure patterns is a JSON array of strings and replacementType matches allowed values.
Error: 503 Service Unavailable
  • Cause: CXone redaction microservice is under load or undergoing maintenance.
  • Fix: Implement retry logic with increasing delays. The polling loop catches 503 responses and doubles the backoff interval until success or timeout.
