Rebalancing Genesys Cloud WebSocket Subscription Fan-Out with Node.js
A Node.js middleware service that distributes Genesys Cloud WebSocket notifications across multiple consumer channels, calculates load distribution, validates rebalancing schemas against connection limits, and synchronizes shifts with external load balancers via webhooks. This uses the Genesys Cloud /api/v2/platform/notifservice/websocket endpoint and the ws library. The implementation covers JavaScript/Node.js.
- OAuth2 client credentials with
notification:readandwebsocket:readscopes - Node.js 18+ runtime
npm install ws axios uuid zod pino- Genesys Cloud environment URL (for example,
https://api.mypurecloud.com) - Access to a dedicated OAuth client ID and secret
Genesys Cloud requires a valid Bearer token for WebSocket initialization. The service must acquire the token via the client credentials flow and cache it with automatic refresh logic.
import axios from 'axios';
import { setTimeout } from 'timers/promises';
const GENESYS_BASE_URL = process.env.GENESYS_BASE_URL || 'https://api.mypurecloud.com';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
const OAUTH_SCOPES = ['notification:read', 'websocket:read'].join(' ');
let cachedToken = null;
let tokenExpiry = 0;
async function acquireAccessToken() {
if (cachedToken && Date.now() < tokenExpiry - 60000) {
return cachedToken;
const payload = new URLSearchParams({
client_id: CLIENT_ID,
client_secret: CLIENT_SECRET,
scope: OAUTH_SCOPES
const response = await axios.post(`${GENESYS_BASE_URL}/api/v2/oauth/token`, payload, {
cachedToken = response.data.access_token;
tokenExpiry = Date.now() + (response.data.expires_in * 1000);
return cachedToken;
} catch (error) {
if (error.response && error.response.status === 401) {
throw new Error('OAuth authentication failed. Verify client credentials and scopes.');
throw new Error(`Token acquisition failed: ${error.message}`);
Expected Response:
"token_type": "Bearer",
"expires_in": 3600,
"scope": "notification:read websocket:read"
Step 1: Initialize WebSocket Connections and Subscription Tracking
Genesys Cloud WebSocket connections require the access token in the Authorization header. Each connection maintains a subscription-ref identifier and tracks active channels. The service validates against a maximum WebSocket count to prevent quota exhaustion.
import WebSocket from 'ws';
import { z } from 'zod';
const MAX_WEBSOCKET_COUNT = parseInt(process.env.MAX_WEBSOCKET_COUNT || '50', 10);
const REBALANCE_THRESHOLD = 0.8;
const FanoutMatrixSchema = z.record(z.string(), z.array(z.string()));
const RedistributeDirectiveSchema = z.enum(['shift', 'balance', 'drain']);
const RebalancePayloadSchema = z.object({
subscriptionRef: z.string().uuid(),
fanoutMatrix: FanoutMatrixSchema,
redistribute: RedistributeDirectiveSchema
class GenesysFanoutManager {
constructor() {
this.connections = new Map();
this.messageQueues = new Map();
this.auditLog = [];
this.latencyTracker = { total: 0, count: 0, successes: 0 };
async createConnection(subscriptionRef) {
if (this.connections.size >= MAX_WEBSOCKET_COUNT) {
throw new Error(`Maximum WebSocket count limit reached: ${MAX_WEBSOCKET_COUNT}`);
const token = await acquireAccessToken();
const wsUrl = `${GENESYS_BASE_URL.replace('https', 'wss')}/api/v2/platform/notifservice/websocket`;
const ws = new WebSocket(wsUrl, {
headers: { Authorization: `Bearer ${token}` }
const connectionState = {
ws,
channels: new Set(),
queue: [],
backpressure: false,
createdAt: Date.now()
return new Promise((resolve, reject) => {
ws.on('open', () => {
this.connections.set(subscriptionRef, connectionState);
this.messageQueues.set(subscriptionRef, connectionState.queue);
resolve(connectionState);
ws.on('error', (err) => reject(err));
ws.on('close', () => {
this.connections.delete(subscriptionRef);
this.messageQueues.delete(subscriptionRef);
async subscribeChannel(ref, channel, filterData) {
const conn = this.connections.get(ref);
if (!conn || !conn.ws || conn.ws.readyState !== WebSocket.OPEN) {
throw new Error(`Connection ${ref} is not active`);
const payload = {
type: 'subscribe',
channel,
data: filterData || {}
const start = Date.now();
conn.ws.send(JSON.stringify(payload));
conn.channels.add(channel);
const latency = Date.now() - start;
this.recordLatency(latency, true);
return true;
} catch (error) {
this.recordLatency(Date.now() - start, false);
throw error;
Step 2: Load Distribution Calculation and Backpressure Evaluation
The service evaluates queue depth across all connections. When a connection exceeds the backpressure threshold, the service pauses incoming subscriptions and triggers a redistribution calculation. Stale channels are identified by lack of activity and queue verification.
evaluateBackpressure() {
const activeConnections = Array.from(this.connections.values());
const overloaded = [];
const underloaded = [];
activeConnections.forEach(conn => {
const queueDepth = conn.queue.length;
const isStale = this.isStaleChannel(conn);
if (queueDepth > 500 || conn.backpressure) {
overloaded.push({ id: conn.id, depth: queueDepth, stale: isStale });
} else if (queueDepth < 100) {
underloaded.push({ id: conn.id, depth: queueDepth, stale: isStale });
return { overloaded, underloaded, totalConnections: activeConnections.length };
isStaleChannel(conn) {
const now = Date.now();
const STALE_THRESHOLD_MS = 300000;
return conn.channels.size > 0 && (now - conn.createdAt) > STALE_THRESHOLD_MS && conn.queue.length === 0;
calculateLoadDistribution() {
const { overloaded, underloaded } = this.evaluateBackpressure();
if (overloaded.length === 0) return null;
const totalLoad = overloaded.reduce((sum, c) => sum + c.depth, 0);
const targetDepth = Math.floor(totalLoad / (overloaded.length + underloaded.length));
const shifts = overloaded.map(over => {
const channelsToMove = Array.from(over.stale ? over.channels : over.channels).slice(0, Math.floor(over.depth / 2));
source: over.id,
target: underloaded.length > 0 ? underloaded[0].id : null,
channels: channelsToMove,
estimatedReduction: channelsToMove.length
return { shifts, targetDepth };
Step 3: Rebalancing Payload Construction and Schema Validation
The redistribution directive must pass strict schema validation before execution. The service constructs atomic WebSocket text operations that verify format before sending. Automatic shift triggers execute when the calculated load imbalance exceeds the threshold.
async executeRedistribution(directive) {
const validation = RebalancePayloadSchema.safeParse(directive);
if (!validation.success) {
throw new Error(`Rebalancing schema validation failed: ${validation.error.message}`);
const { subscriptionRef, fanoutMatrix, redistribute } = validation.data;
const distribution = this.calculateLoadDistribution();
if (!distribution) {
this.auditLog.push({ timestamp: Date.now(), event: 'NO_REBALANCE_NEEDED', ref: subscriptionRef });
return { status: 'idle', message: 'Load distribution is within acceptable parameters' };
const operations = [];
for (const shift of distribution.shifts) {
for (const channel of shift.channels) {
operations.push({
type: 'unsubscribe',
channel,
connectionId: shift.source
operations.push({
type: 'subscribe',
channel,
connectionId: shift.target || subscriptionRef
const results = await this.applyAtomicOperations(operations);
this.auditLog.push({ timestamp: Date.now(), event: 'REDISTRIBUTE_EXECUTED', directive: redistribute, operations: operations.length, results });
return { status: 'rebalanced', operations, results };
async applyAtomicOperations(operations) {
const results = [];
for (const op of operations) {
const conn = this.connections.get(op.connectionId);
results.push({ operation: op, status: 'failed', reason: 'connection_inactive' });
continue;
const payload = { type: op.type, channel: op.channel };
results.push({ operation: op, status: 'success' });
} catch (error) {
results.push({ operation: op, status: 'failed', reason: error.message });
return results;
Step 4: Execute Redistribution and Webhook Synchronization
The service tracks latency and success rates, generates audit logs, and synchronizes rebalancing events with an external load balancer via fanout shifted webhooks. The webhook payload contains the updated fanout matrix and shift metadata.
recordLatency(ms, success) {
this.latencyTracker.total += ms;
this.latencyTracker.count++;
if (success) this.latencyTracker.successes++;
getMetrics() {
const avgLatency = this.latencyTracker.count > 0 ? this.latencyTracker.total / this.latencyTracker.count : 0;
const successRate = this.latencyTracker.count > 0 ? this.latencyTracker.successes / this.latencyTracker.count : 0;
averageLatencyMs: Math.round(avgLatency),
successRate: successRate.toFixed(4),
activeConnections: this.connections.size,
auditLogEntries: this.auditLog.length
async syncLoadBalancerWebhook(shiftData) {
const webhookUrl = process.env.LOAD_BALANCER_WEBHOOK_URL;
if (!webhookUrl) return;
const payload = {
event: 'fanout_shifted',
metrics: this.getMetrics(),
shifts: shiftData.shifts,
fanoutMatrix: Array.from(this.connections.entries()).reduce((acc, [id, conn]) => {
acc[id] = Array.from(conn.channels);
return acc;
await axios.post(webhookUrl, payload, {
timeout: 5000
} catch (error) {
console.error(`Webhook sync failed: ${error.message}`);
The following script initializes the fanout manager, establishes connections, runs the rebalancing pipeline, and exposes a management interface. Replace the environment variables with your credentials before execution.
import 'dotenv/config';
import { GenesysFanoutManager } from './fanout-manager.js';
async function main() {
const manager = new GenesysFanoutManager();
const initialRefs = [
require('uuid').v4(),
console.log('Initializing WebSocket connections...');
for (const ref of initialRefs) {
await manager.createConnection(ref);
await manager.subscribeChannel(ref, 'routing:queue:member:status', {});
await manager.subscribeChannel(ref, 'conversation:call', {});
console.log(`Connection ${ref} established and subscribed.`);
} catch (error) {
console.error(`Failed to initialize ${ref}: ${error.message}`);
console.log('Evaluating load distribution...');
const distribution = manager.calculateLoadDistribution();
if (distribution) {
console.log('Load imbalance detected. Triggering redistribution...');
const result = await manager.executeRedistribution({
subscriptionRef: initialRefs[0],
fanoutMatrix: {},
redistribute: 'balance'
console.log('Redistribution result:', result);
await manager.syncLoadBalancerWebhook(distribution);
} else {
console.log('Load is balanced. No redistribution required.');
console.log('Current metrics:', manager.getMetrics());
console.log('Audit log:', manager.auditLog);
main().catch(console.error);
- Cause: The OAuth token is expired, missing, or lacks the required
notification:readandwebsocket:readscopes. - Fix: Verify the client credentials and ensure the token acquisition function refreshes the token before expiration. Check the
Authorizationheader format in the WebSocket constructor. - Code Fix: Add explicit scope validation during token acquisition and log the exact scope string returned by Genesys Cloud.
- Cause: Genesys Cloud enforces rate limits on subscription operations and WebSocket connections. Rapid fan-out initialization triggers throttling.
- Fix: Implement exponential backoff with jitter. The
applyAtomicOperationsmethod should wrap subscription calls in a retry loop. - Code Fix:
async sendWithRetry(ws, payload, retries = 3) {
for (let i = 0; i < retries; i++) {
return true;
} catch (error) {
if (error.response && error.response.status === 429) {
const delay = Math.pow(2, i) * 1000 + Math.random() * 500;
await setTimeout(delay);
} else {
throw error;
return false;
Error: Schema Validation Failed
- Cause: The
subscription-refis not a valid UUID, thefanout-matrixcontains non-string keys, or theredistributedirective is not one of the allowed enum values. - Fix: Validate all incoming rebalancing payloads against the Zod schema before execution. Ensure external systems generate compliant UUIDs.
- Code Fix: Wrap all external ingestion points with
RebalancePayloadSchema.parse()and return structured error responses on failure.
Error: Connection Stale or Inactive
- Cause: The WebSocket connection dropped due to network timeout or Genesys Cloud server reset, but the manager still references the stale object.
- Fix: Listen to the
closeanderrorevents on thewsinstance. Remove the connection from theconnectionsmap immediately and trigger a reconnection routine. - Code Fix: Implement an automatic reconnect scheduler that validates
ws.readyState === WebSocket.CLOSEDbefore attempting to restore subscriptions.
