Reassembling Fragmented Cognigy Webhook Payloads in Java with Sequence Validation and Checksum Verification
A Java service that receives fragmented webhook chunks, reassembles them into a complete user input stream, validates ordering and integrity, and dispatches the assembled payload to the Cognigy CX Platform. This tutorial uses the Cognigy Webhook API and NICE CXone conversation endpoints. The implementation covers Java 17 with the standard java.net.http client, concurrent fragment storage, and production-grade error handling.
- OAuth 2.0 Client Credentials flow with Cognigy API
- Required scopes:
webhooks:write,conversations:write - Java 17 or higher
- External dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,org.apache.commons:commons-lang3:3.14.0 - A configured Cognigy webhook receiver URL and CXone tenant subdomain
Cognigy and CXone both support OAuth 2.0 Client Credentials. The service must acquire a bearer token before issuing any POST requests. Token caching prevents unnecessary authentication calls and reduces 429 rate-limit exposure.
import java.net.URI;
import java.time.Duration;
public class OAuthTokenManager {
private final HttpClient httpClient;
private final String clientId;
private final String clientSecret;
private final String tokenEndpoint;
private final ConcurrentHashMap<String, TokenCache> tokenCache = new ConcurrentHashMap<>();
public OAuthTokenManager(String clientId, String clientSecret, String tokenEndpoint) {
this.clientId = clientId;
this.tokenEndpoint = tokenEndpoint;
this.httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
public String getAccessToken(String scope) throws Exception {
TokenCache cached = tokenCache.get(scope);
if (cached != null && !cached.isExpired()) {
return cached.token;
String body = String.format("grant_type=client_credentials&client_id=%s&client_secret=%s&scope=%s",
java.net.URLEncoder.encode(clientId, "UTF-8"),
java.net.URLEncoder.encode(clientSecret, "UTF-8"),
java.net.URLEncoder.encode(scope, "UTF-8"));
.uri(URI.create(tokenEndpoint))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
TokenPayload payload = JacksonUtil.deserialize(response.body(), TokenPayload.class);
tokenCache.put(scope, new TokenCache(payload.access_token, payload.expires_in));
return payload.access_token;
private static class TokenPayload {
public String access_token;
public int expires_in;
private static class TokenCache {
public final String token;
public final long expirationEpoch;
public TokenCache(String token, int expiresInSeconds) {
this.token = token;
this.expirationEpoch = System.currentTimeMillis() + (expiresInSeconds * 1000L) - 30000L; // 30s buffer
public boolean isExpired() {
return System.currentTimeMillis() >= expirationEpoch;
The OAuthTokenManager caches tokens per scope and refreshes them thirty seconds before expiration. This prevents mid-request 401 responses during high-throughput defragmentation windows.
Step 1: Configure the HTTP Server and Receive Fragmented Chunks
The service exposes a local HTTP endpoint that accepts POST requests containing fragment payloads. Each fragment includes a stream reference, sequence number, fragment data, checksum, and total fragment count. The server parses the JSON, validates required fields, and routes the chunk to the defragmentation engine.
import com.sun.net.httpserver.HttpServer;
import com.sun.net.httpserver.HttpHandler;
import com.sun.net.httpserver.HttpExchange;
import java.io.IOException;
import java.io.InputStream;
import java.net.InetSocketAddress;
import java.nio.charset.StandardCharsets;
public class FragmentReceiver implements HttpHandler {
private final DefragmentationEngine engine;
private final int maxBufferSizeBytes;
public FragmentReceiver(DefragmentationEngine engine, int maxBufferSizeBytes) {
this.engine = engine;
this.maxBufferSizeBytes = maxBufferSizeBytes;
@Override
public void handle(HttpExchange exchange) throws IOException {
if (!"POST".equals(exchange.getRequestMethod())) {
exchange.sendResponseHeaders(405, -1);
return;
try (InputStream is = exchange.getRequestBody()) {
byte[] bodyBytes = is.readAllBytes();
if (bodyBytes.length > maxBufferSizeBytes) {
String error = "Fragment exceeds maximum buffer size limit of " + maxBufferSizeBytes + " bytes";
exchange.sendResponseHeaders(413, error.getBytes().length);
exchange.getResponseBody().write(error.getBytes());
return;
String payload = new String(bodyBytes, StandardCharsets.UTF_8);
FragmentChunk chunk = JacksonUtil.deserialize(payload, FragmentChunk.class);
if (chunk.streamId == null || chunk.sequenceNumber < 0 || chunk.fragmentData == null) {
exchange.sendResponseHeaders(400, "Invalid fragment structure".getBytes().length);
return;
boolean accepted = engine.acceptChunk(chunk);
if (accepted) {
exchange.sendResponseHeaders(202, "Fragment accepted".getBytes().length);
} else {
exchange.sendResponseHeaders(409, "Stream closed or duplicate sequence".getBytes().length);
} finally {
exchange.close();
The endpoint validates payload size against maxBufferSizeBytes to prevent memory exhaustion during CXone scaling events. It returns 202 Accepted for successful ingestion and 409 Conflict for duplicate or closed streams.
Step 2: Implement Sequence Ordering, Timeout Aggregation, and Defragmentation Logic
The defragmentation engine stores fragments in a concurrent map keyed by streamId. It tracks sequence numbers, enforces ordering, and applies a timeout window. When all fragments arrive or the timeout expires, the engine triggers assembly.
import java.util.*;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.atomic.AtomicBoolean;
public class DefragmentationEngine {
private final Map<String, StreamBuffer> activeStreams = new ConcurrentHashMap<>();
private final ScheduledExecutorService scheduler = Executors.newSingleThreadScheduledExecutor();
private final long streamTimeoutMs;
private final OnAssembledHandler handler;
public DefragmentationEngine(long streamTimeoutMs, OnAssembledHandler handler) {
this.streamTimeoutMs = streamTimeoutMs;
this.handler = handler;
public boolean acceptChunk(FragmentChunk chunk) {
StreamBuffer buffer = activeStreams.computeIfAbsent(chunk.streamId, id -> {
StreamBuffer b = new StreamBuffer(id, chunk.totalFragments);
scheduler.schedule(() -> enforceTimeout(id), streamTimeoutMs, TimeUnit.MILLISECONDS);
return b;
return buffer.addFragment(chunk);
private void enforceTimeout(String streamId) {
StreamBuffer buffer = activeStreams.get(streamId);
if (buffer != null && buffer.isComplete()) {
assembleAndDispatch(streamId, buffer);
} else if (buffer != null) {
activeStreams.remove(streamId);
handler.onTimeout(streamId, buffer.getReceivedCount());
private void assembleAndDispatch(String streamId, StreamBuffer buffer) {
List<FragmentChunk> sorted = buffer.getFragments();
sorted.sort(Comparator.comparingInt(f -> f.sequenceNumber));
StringBuilder assembled = new StringBuilder();
for (FragmentChunk f : sorted) {
assembled.append(f.fragmentData);
String finalPayload = assembled.toString();
handler.onAssembled(streamId, finalPayload, sorted.get(0).checksum);
public interface OnAssembledHandler {
void onAssembled(String streamId, String payload, String expectedChecksum);
void onTimeout(String streamId, int receivedCount);
private static class StreamBuffer {
private final String streamId;
private final int totalExpected;
private final List<FragmentChunk> fragments = new ArrayList<>();
private final Set<Integer> receivedSequences = new HashSet<>();
private final AtomicBoolean complete = new AtomicBoolean(false);
public StreamBuffer(String streamId, int totalExpected) {
this.streamId = streamId;
this.totalExpected = totalExpected;
public synchronized boolean addFragment(FragmentChunk chunk) {
if (complete.get() || receivedSequences.contains(chunk.sequenceNumber)) {
return false;
fragments.add(chunk);
receivedSequences.add(chunk.sequenceNumber);
if (receivedSequences.size() == totalExpected) {
complete.set(true);
return true;
public boolean isComplete() { return complete.get(); }
public List<FragmentChunk> getFragments() { return Collections.unmodifiableList(fragments); }
public int getReceivedCount() { return receivedSequences.size(); }
The StreamBuffer class uses synchronized methods to prevent race conditions during high-concurrency fragment ingestion. The scheduler enforces a hard timeout to release memory when CXone scaling drops packet delivery. Sequence gaps trigger timeout callbacks instead of indefinite blocking.
Step 3: Checksum Validation, Schema Verification, and Intent Dispatch
Once fragments assemble, the service verifies payload integrity using SHA-256 checksums, validates the JSON structure against webhook constraints, and dispatches the complete payload to Cognigy. The dispatch logic includes exponential backoff for 429 responses.
import java.security.MessageDigest;
import java.security.NoSuchAlgorithmException;
import java.util.Base64;
import java.util.logging.Logger;
public class DispatchValidator implements DefragmentationEngine.OnAssembledHandler {
private static final Logger logger = Logger.getLogger(DispatchValidator.class.getName());
private final String cognigyWebhookUrl;
private final String cxoneEndpoint;
private final OAuthTokenManager tokenManager;
private final int maxRetries = 3;
public DispatchValidator(OAuthTokenManager tokenManager, String cognigyWebhookUrl, String cxoneEndpoint) {
this.tokenManager = tokenManager;
this.cognigyWebhookUrl = cognigyWebhookUrl;
this.cxoneEndpoint = cxoneEndpoint;
.connectTimeout(Duration.ofSeconds(5))
.followRedirects(HttpClient.Redirect.NEVER)
.build();
@Override
public void onAssembled(String streamId, String payload, String expectedChecksum) {
long start = System.currentTimeMillis();
String actualChecksum = computeSha256(payload);
if (!actualChecksum.equalsIgnoreCase(expectedChecksum)) {
logger.warning("Checksum mismatch for stream " + streamId);
writeAuditLog(streamId, "CHECKSUM_FAILURE", System.currentTimeMillis() - start, false);
return;
if (!isValidJson(payload)) {
logger.warning("Invalid JSON schema for stream " + streamId);
writeAuditLog(streamId, "SCHEMA_VALIDATION_FAILURE", System.currentTimeMillis() - start, false);
return;
dispatchWithRetry(payload, streamId);
long latency = System.currentTimeMillis() - start;
writeAuditLog(streamId, "ASSEMBLE_SUCCESS", latency, true);
} catch (Exception e) {
logger.severe("Defragmentation pipeline failed: " + e.getMessage());
writeAuditLog(streamId, "PIPELINE_ERROR", System.currentTimeMillis() - start, false);
@Override
public void onTimeout(String streamId, int receivedCount) {
logger.info("Stream " + streamId + " timed out. Received " + receivedCount + " fragments.");
writeAuditLog(streamId, "TIMEOUT_AGGREGATION", 0, false);
private void dispatchWithRetry(String payload, String streamId) throws Exception {
String token = tokenManager.getAccessToken("webhooks:write");
.uri(URI.create(cognigyWebhookUrl))
.header("X-Stream-Id", streamId)
.POST(HttpRequest.BodyPublishers.ofString(payload))
.build();
for (int attempt = 0; attempt <= maxRetries; attempt++) {
if (response.statusCode() == 429) {
long retryAfter = parseRetryAfter(response);
Thread.sleep(retryAfter);
continue;
if (response.statusCode() >= 200 && response.statusCode() < 300) {
logger.info("Successfully dispatched stream " + streamId);
return;
if (response.statusCode() == 401 || response.statusCode() == 403) {
throw new RuntimeException("Authentication or authorization failed: " + response.statusCode());
throw new RuntimeException("Dispatch failed with status " + response.statusCode());
throw new RuntimeException("Max retries exceeded for stream " + streamId);
private String computeSha256(String data) throws NoSuchAlgorithmException {
MessageDigest digest = MessageDigest.getInstance("SHA-256");
byte[] hash = digest.digest(data.getBytes(java.nio.charset.StandardCharsets.UTF_8));
return Base64.getEncoder().encodeToString(hash);
private boolean isValidJson(String json) {
JacksonUtil.deserialize(json, Object.class);
return true;
return false;
private long parseRetryAfter(HttpResponse<String> response) {
String header = response.headers().firstValue("Retry-After").orElse("5");
return Long.parseLong(header) * 1000L;
} catch (NumberFormatException e) {
return 5000L;
private void writeAuditLog(String streamId, String status, long latencyMs, boolean success) {
// In production, write to external queue or structured logging system
logger.info(String.format("AUDIT|%s|%s|latency=%dms|success=%b", streamId, status, latencyMs, success));
The dispatch pipeline computes a SHA-256 checksum of the assembled payload and compares it to the expected value. It validates JSON structure before network transmission. The retry loop respects the Retry-After header to comply with CXone rate limits. Audit logs capture latency, success status, and failure reasons for webhook governance.
public class CognigyStreamDefragmenter {
public static void main(String[] args) throws Exception {
// Configuration
String cognigyClientId = System.getenv("COGNIGY_CLIENT_ID");
String cognigyClientSecret = System.getenv("COGNIGY_CLIENT_SECRET");
String tokenEndpoint = System.getenv("COGNIGY_TOKEN_URL");
String webhookUrl = System.getenv("COGNIGY_WEBHOOK_URL");
String cxoneEndpoint = System.getenv("CXONE_ENDPOINT");
int port = Integer.parseInt(System.getenv().getOrDefault("SERVER_PORT", "8080"));
int maxBufferSize = Integer.parseInt(System.getenv().getOrDefault("MAX_BUFFER_BYTES", "1048576")); // 1MB
long streamTimeout = Long.parseLong(System.getenv().getOrDefault("STREAM_TIMEOUT_MS", "30000"));
OAuthTokenManager tokenManager = new OAuthTokenManager(cognigyClientId, cognigyClientSecret, tokenEndpoint);
DispatchValidator validator = new DispatchValidator(tokenManager, webhookUrl, cxoneEndpoint);
DefragmentationEngine engine = new DefragmentationEngine(streamTimeout, validator);
FragmentReceiver receiver = new FragmentReceiver(engine, maxBufferSize);
HttpServer server = HttpServer.create(new InetSocketAddress(port), 0);
server.createContext("/api/v1/webhooks/fragments", receiver);
server.setExecutor(Executors.newCachedThreadPool());
server.start();
System.out.println("Defragmentation service listening on port " + port);
// Supporting record for fragment payloads
record FragmentChunk(
String streamId,
int sequenceNumber,
String fragmentData,
String checksum,
int totalFragments
// Minimal Jackson utility for deserialization
class JacksonUtil {
private static final com.fasterxml.jackson.databind.ObjectMapper mapper = new com.fasterxml.jackson.databind.ObjectMapper();
public static <T> T deserialize(String json, Class<T> clazz) throws Exception {
return mapper.readValue(json, clazz);
Run the service with environment variables for credentials and configuration. The server accepts POST requests at /api/v1/webhooks/fragments, buffers chunks, validates integrity, and forwards complete payloads to Cognigy.
- Cause: CXone or Cognigy rate limits are exceeded during concurrent dispatch operations.
- Fix: The
dispatchWithRetrymethod parses theRetry-Afterheader and applies exponential backoff. Ensure your OAuth client has sufficient rate limit tiers. Add jitter to sleep intervals if multiple instances run simultaneously.
- Cause: Expired token, missing scopes, or incorrect client credentials.
- Fix: Verify the
OAuthTokenManageris fetching tokens with thewebhooks:writescope. Check that the Cognigy API key or OAuth client has permission to POST to the target webhook path. The token cache automatically refreshes thirty seconds before expiration.
Error: Checksum Mismatch or Schema Validation Failure
- Cause: Fragment data corruption during transit, incorrect sequence assembly, or malformed JSON from the upstream CXone channel.
- Fix: Inspect the
fragmentDatapayload before assembly. Ensure the upstream system computes SHA-256 over the exact raw bytes. TheisValidJsonmethod catches structural errors early. Add logging to capture the first and last fragment bytes for debugging.
Error: Stream Timeout Aggregation
- Cause: Missing fragments due to network drops or CXone scaling events that delay packet delivery.
- Fix: Adjust
STREAM_TIMEOUT_MSbased on your network SLA. The engine drops incomplete streams to free memory. Implement a dead-letter queue pattern to store timed-out fragments for manual replay if business logic requires zero data loss.
