Realspeak TTS configuration with GVP 8.1.6
I am setting up a Realspeak TTS 4.5 with GVP 8.1.6.
I have configured the MRCP Proxy and Nuance (TTS) Resource Access Point in GVP 8.1.6.
On the Nuance TTS end, I have setup the NSS (Server & Client) and RealSpeak TTS.
Tested RS TTS using the client provided by NSS and it is generating a sample TTS file.
However when I call into a test VXML application on GVP, the MCP is giving an erorr message as shown below.
2010-12-13T11:50:27.296 Int 50041 006F00D0-10002B28 7648 compile_done :file:///C:/Genesys/GVP/MCP1/samples/alaw/TTS.vxml
2010-12-13T11:50:27.296 Int 50028 006F00D0-10002B28 7648 form_enter :Welcome
2010-12-13T11:50:27.296 Int 50029 006F00D0-10002B28 7648 form_select :Hello:BLOCK
2010-12-13T11:50:27.296 Int 50030 006F00D0-10002B28 7648 form_exit normal
2010-12-13T11:50:27.296 Int 50018 006F00D0-10002B28 5980 prompt
2010-12-13T11:50:27.296 Int 50134 006F00D0-10002B28 5980 prompt_play tts|<?xml version="1.0" encoding="UTF-8"?>RealSpeak TTS Test
2010-12-13T11:50:27.296 Std 20003 WARN 006F00D0-10002B28-tts-default-10 3332 06A007E2 Failed to open an MRCP Session using any of the MRCP Clients.
2010-12-13T11:50:27.296 Std 22017 EROR 006F00D0-10002B28-tts-default-10 3332 06A007E1 OpenSession failed with all MRCP Client Instances.
2010-12-13T11:50:27.296 Int 50150 006F00D0-10002B28 3332 tts_open 006F00D0-10002B28-tts-default-10|fail
2010-12-13T11:50:27.296 Int 50039 006F00D0-10002B28 5980 exec_error Could not play audio <?xml version="1.0" encoding="UTF-8"?>RealSpeak TTS Test
2010-12-13T11:50:27.296 Int 50019 006F00D0-10002B28 5980 prompt_end error
2010-12-13T11:50:27.296 Int 50036 006F00D0-10002B28 7720 appl_end
2010-12-13T11:50:27.312 Int 50001 006F00D0-10002B28 3332 incall_end aplend
Any clues what I am doing wrong.
I think that you have to add connection to the Resource Access Point for TTS on MCP object which will use the TTS. Could you check this?
Yup, I was missing the connection on the MCP object.
Thanks a lot.
Do I also need to specify the format for the wave file that is generated and to be played by the MCP (i.e. the VXML application) as the TTS generated could not be heard in the call?
I have not done any wav file format modifications in the NSS or RealSpeak TTS side.
infact I can see the following warning errors in MRCP Proxy logs.
NOTE:- I am able to successfully telnet from GVP Server to RealSpeak TTS Server on port 4900.
2010-12-13T15:30:28.765 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35511408 at port 10062 - ErrorCode 10061
2010-12-13T15:30:38.921 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35466704 at port 10063 - ErrorCode 10061
2010-12-13T15:30:48.875 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35511408 at port 10064 - ErrorCode 10061
2010-12-13T15:30:58.937 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35466704 at port 10065 - ErrorCode 10061
2010-12-13T15:31:08.875 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35511408 at port 10066 - ErrorCode 10061
2010-12-13T15:31:18.937 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35466704 at port 10067 - ErrorCode 10061
2010-12-13T15:31:29.000 Std 20003 WARN 00000000-00000000 6236 08400BB9 RtspStack - Received SocketError(): 35511408 at port 10068 - ErrorCode 10061
The MCP logs though do not show much of an error as shown below.
2010-12-13T15:35:28.890 Int 50134 006F00D0-10002BC7 7324 prompt_play tts|<?xml version="1.0" encoding="UTF-8"?>Welcome to Reliance Communications!!!
2010-12-13T15:35:28.921 Int 50150 006F00D0-10002BC7 5820 tts_open 006F00D0-10002BC7-tts-REALSPEAK-9|success
2010-12-13T15:35:28.921 Int 50132 006F00D0-10002BC7-tts-REALSPEAK-9 5820 mrcp_trace RTSPSESSION: __rtsp_session_809 IP: 10.8.76.235 Vendor: REALSPEAK
2010-12-13T15:35:33.000 Int 50151 006F00D0-10002BC7 5820 tts_close 006F00D0-10002BC7-tts-REALSPEAK-9
2010-12-13T15:35:33.000 Int 50019 006F00D0-10002BC7 7324 prompt_end done
2010-12-13T15:35:33.000 Int 50036 006F00D0-10002BC7 140 appl_end
2010-12-13T15:35:33.015 Int 50001 006F00D0-10002BC7 3252 incall_end aplend
Just for info sake, the NSS Logs shows as TTS Request as success.
TIME=20131213160930547|CHAN=FCKKODOCAAAIBOIBAAAAAAAA|EVNT=SWIfrmt|ENCD=UTF-8|UCPU=0|SCPU=0
TIME=20131213160930547|CHAN=FCKKODOCAAAIBOIBAAAAAAAA|EVNT=SWIclst|VALU=Session FCKKODOCAAAIBOIBAAAAAAAA started|SRC=SWIrec|UCPU=0|SCPU=0
TIME=20131213160930594|CHAN=FCKKODOCAAAIBOIBAAAAAAAA|EVNT=RSsdata|URI=NULL|DATA=<?xml version="1.0" encoding="UTF-8"?>Welcome to Communications!!!|TYPE=NULL|RESULT=TTS_SUCCESS
TIME=20131213160933125|CHAN=FCKKODOCAAAIBOIBAAAAAAAA|EVNT=NUANtnat|TNAT=Nuance|UCPU=0|SCPU=0
TIME=20131213160933125|CHAN=FCKKODOCAAAIBOIBAAAAAAAA|EVNT=SWIclnd|VALU=Session FCKKODOCAAAIBOIBAAAAAAAA ended|SRC=SWIrec|UCPU=0|SCPU=0
