Read Values returned from ConfigServer
Hi guys,
smashing my head for 2 days and can’t see my error…so I connected to ConfigServer, send a request and it returns (yay! xml! values needed!)
And got stuck lol
Trying to capture the 853 from:
<DBID value="853" />
My code:
XDocument resultDocument = objectsRead.ConfObject; //Capture the XML part of the object
var temp = resultDocument.Descendants("DBID").Select(x => "DBID " + x.Attribute("value").Value).ToList();
And I need to catch the DBID to send it to another CfgQuery…BUT the read of this value fails…
I think it has to do something with the UTF8…I tried many ways and same issue.
Anybody has a code to read these values and a little slap to me to understand why am I failing so miserably?
XML is:
<?xml version="1.0" encoding="utf-16"?>
<ConfData xmlns="http://schemas.genesyslab.com/Protocols/Configuration/ConfServer/2005/">
  <CfgPerson>
    <tenantDBID value="101" />
    <lastName value="Rodrigues Geske" />
    <firstName value="Eduardo" />
    <employeeID value="T01039" />
    <userName value="T01039" />
    <password value="81DC9BDB52D04DC20036DBD8313ED055" />
    <isAgent value="2" />
    <CfgAgentInfo>
      <placeDBID value="0" />
      <skillLevels>
        <CfgSkillLevel>
          <skillDBID value="104" />
          <level value="0" />
        </CfgSkillLevel>
      </skillLevels>
      <agentLogins>
        <CfgAgentLoginInfo>
          <agentLoginDBID value="277" />
          <wrapupTime value="0" />
        </CfgAgentLoginInfo>
      </agentLogins>
      <capacityRuleDBID value="0" />
      <siteDBID value="0" />
      <contractDBID value="0" />
    </CfgAgentInfo>
    <isAdmin value="1" />
    <state value="1" />
  </CfgPerson>
</ConfData>
Thanks!
hi,
I had to do something similar but I was looking for the isAgent. I’ve modified it slightly for you so please don’t take this as 100% working but hopefully this helps?
BTW I’m not strong in XML parsing so please don’t laugh if there is a far easier way to do this. I was happy when I got it to work.
Dim varObjectsRead As EventObjectsRead = varMessage
Dim varNavigator As XPathNavigator = varObjectsRead.ConfObject.CreateNavigator()
Dim varNodes As XPathNodeIterator = varNavigator.Select(“//*”)
                Dim xdoc As New XmlDocument
                varNodes.MoveNext()
                varNavigator = varNodes.Current.Clone
                Dim varXML As String = varNavigator.InnerXml
                'load the XML string into an XML document
                xdoc.LoadXml(varXML)
                Dim xNode As XmlNode = xdoc.FirstChild
                'navigate to the attributes
                xNode = xNode.FirstChild
                'cycle through attributes until finding the "DBID"
                Dim varXMLValue As String
                Do Until xNode Is Nothing ' after going to the end the variable will switch to nothing
                If XNode.Name = "DBID" Then
                     varDBIDValue = xNode.Attributes(0).Value.ToString
                     xNode = xNode.NextSibling
                Loop
Nice! Thanks!
Will try it tomorrow! I promised myself no coding this weekend :wink:
Is there any exact reason for using RequestReadObjects? It is possible to use Cfg queries, that returns objects and not XML. So, it is more easily to “parse” retrieved information
Yup, I got it later :wink: I’m now using that method.
