Queuing Genesys Cloud Web Messaging Offline Messages via Java SDK
  • A Java service that queues offline Web Messaging guest messages, validates payloads against depth and TTL constraints, posts them atomically via the Conversations API, synchronizes enqueue events with webhooks, tracks latency, and generates audit logs.
  • This tutorial uses the official Genesys Cloud Java SDK (genesyscloud-java) and the Conversations/WebChat API endpoints.
  • The implementation is written in Java 17 with Maven dependency management.
  • OAuth Client Credentials grant type with scopes: webchat:write, conversation:write, webhook:write
  • Genesys Cloud Java SDK version 2.0.0 or higher
  • Java Development Kit 17+
  • Maven or Gradle for dependency resolution
  • Required dependencies: genesyscloud-java, jackson-databind, slf4j-api, java.logging
Add the SDK to your pom.xml:
<dependency>
    <groupId>com.mypurecloud</groupId>
    <artifactId>genesyscloud-java</artifactId>
    <version>2.0.0</version>
</dependency>
<dependency>
    <groupId>com.fasterxml.jackson.core</groupId>
    <artifactId>jackson-databind</artifactId>
    <version>2.15.2</version>
</dependency>
Genesys Cloud requires OAuth 2.0 Client Credentials for server-to-server API access. The Java SDK handles token acquisition and automatic refresh when configured correctly.
import com.mypurecloud.api.client.PureCloudPlatformClientV2;
import com.mypurecloud.api.client.auth.oauth.OAuthClientCredentials;
import com.mypurecloud.api.client.auth.oauth.OAuthConfiguration;
import com.mypurecloud.api.v2.ConversationsWebchatApi;
import com.mypurecloud.api.v2.ConversationsApi;
import com.mypurecloud.api.v2.WebhooksApi;
import java.time.Duration;
public class GenesysAuthManager {
    private static final String ENVIRONMENT = "mypurecloud.com";
    private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
    private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
    public static PureCloudPlatformClientV2 initializeClient() throws Exception {
        if (CLIENT_ID == null || CLIENT_SECRET == null) {
            throw new IllegalStateException("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required.");
        OAuthConfiguration authConfig = OAuthConfiguration.builder()
                .environment(ENVIRONMENT)
                .clientCredentials(new OAuthClientCredentials(CLIENT_ID, CLIENT_SECRET))
                .build();
        PureCloudPlatformClientV2 client = PureCloudPlatformClientV2.builder()
                .oauthConfiguration(authConfig)
                .build();
        return client;
The PureCloudPlatformClientV2 instance caches the access token and automatically requests a new token when expiration approaches. You pass this client instance to all API resource classes.
Step 1: Payload Construction and Constraint Validation
The queuing service receives raw guest data and transforms it into a validated payload. You must check queue-ref, guest-matrix, and store directives against guest-constraints and maximum-queue-depth limits before proceeding.
import java.time.Instant;
import java.util.Map;
import java.util.concurrent.atomic.AtomicInteger;
public record OfflineMessageRequest(
        String queueRef,
        Map<String, Object> guestMatrix,
        String storeDirective,
        long ttlSeconds,
        String messageContent
public class MessageQueueValidator {
    private static final int MAX_QUEUE_DEPTH = 5000;
    private static final int MAX_MESSAGE_BYTES = 65536;
    private final AtomicInteger currentQueueDepth = new AtomicInteger(0);
    private final ObjectMapper mapper = new ObjectMapper();
    public void validateAndIncrement(OfflineMessageRequest request) throws Exception {
        if (currentQueueDepth.get() >= MAX_QUEUE_DEPTH) {
            throw new IllegalStateException("Queue capacity exceeded. Maximum queue depth limit reached.");
        if (request.ttlSeconds <= 0) {
            throw new IllegalArgumentException("TTL evaluation failed. TTL must be greater than zero.");
        String serialized = mapper.writeValueAsString(request);
        if (serialized.getBytes(java.nio.charset.StandardCharsets.UTF_8).length > MAX_MESSAGE_BYTES) {
            throw new IllegalArgumentException("Message serialization failed. Payload exceeds maximum size constraints.");
        if (!request.storeDirective.matches("^(PERSIST|TRANIENT|ARCHIVE)$")) {
            throw new IllegalArgumentException("Invalid store directive. Allowed values: PERSIST, TRANIENT, ARCHIVE.");
        currentQueueDepth.incrementAndGet();
    public void decrementQueueDepth() {
        currentQueueDepth.decrementAndGet();
This validator enforces the maximum-queue-depth limit using thread-safe atomic counters. It calculates serialization size to prevent truncation during scaling events and verifies the store directive against allowed states.
Step 2: Store Validation and TTL Evaluation Logic
Before posting to Genesys Cloud, you must verify session validity and storage quota availability. The SDK returns specific error codes when sessions expire or quotas are breached. You implement a pre-flight check that evaluates TTL expiration and storage readiness.
import com.mypurecloud.api.v2.model.ConversationEvent;
import com.mypurecloud.api.v2.model.ConversationEventAction;
import com.mypurecloud.api.v2.model.WebchatConversationCreateRequest;
import com.mypurecloud.api.v2.model.WebchatMessage;
public class StoreValidationPipeline {
    private final Map<String, Instant> activeSessions = new ConcurrentHashMap<>();
    private static final long MAX_STORAGE_QUOTA_BYTES = 1073741824L; // 1GB example limit
    private long currentStorageUsage = 0;
    public void validateSessionAndQuota(String guestId, OfflineMessageRequest request) throws Exception {
        Instant now = Instant.now();
        Instant sessionExpiry = activeSessions.getOrDefault(guestId, now);
        if (now.isAfter(sessionExpiry)) {
            throw new IllegalStateException("Expired session detected for guest: " + guestId);
        long payloadSize = request.messageContent.getBytes(java.nio.charset.StandardCharsets.UTF_8).length;
        if (currentStorageUsage + payloadSize > MAX_STORAGE_QUOTA_BYTES) {
            throw new IllegalStateException("Storage quota verification failed. Insufficient quota for persistence.");
        Instant ttlExpiry = now.plusSeconds(request.ttlSeconds);
        if (ttlExpiry.isBefore(now)) {
            throw new IllegalArgumentException("TTL evaluation failed. Message already expired.");
        currentStorageUsage += payloadSize;
        activeSessions.put(guestId, ttlExpiry);
    public void releaseStorage(String guestId, long payloadSize) {
        currentStorageUsage -= payloadSize;
        activeSessions.remove(guestId);
The pipeline tracks session lifecycles and storage consumption. It prevents data truncation by rejecting payloads that exceed quota thresholds and blocks expired sessions from consuming queue resources.
Step 3: Atomic HTTP POST Operations and Enqueue Triggers
You post the validated message to Genesys Cloud using the Conversations API. The operation must be atomic, with retry logic for 429 Too Many Requests responses. You construct the WebchatConversationCreateRequest or ConversationEvent payload and execute the POST.
import com.mypurecloud.api.client.ApiException;
import java.util.Collections;
public class MessagePoster {
    private final ConversationsWebchatApi webchatApi;
    private final ConversationsApi conversationsApi;
    private static final int MAX_RETRIES = 3;
    private static final long RETRY_BACKOFF_MS = 1000;
    public MessagePoster(ConversationsWebchatApi webchatApi, ConversationsApi conversationsApi) {
        this.webchatApi = webchatApi;
        this.conversationsApi = conversationsApi;
    public String postOfflineMessage(String guestId, OfflineMessageRequest request) throws Exception {
        WebchatConversationCreateRequest createRequest = new WebchatConversationCreateRequest();
        createRequest.routingQueueId("default-queue-id"); // Replace with actual queue ID
        createRequest.routingSkillGroups(Collections.emptyList());
        createRequest.routingWrapsUp(Collections.emptyList());
        createRequest.routingLanguage("en-US");
        WebchatMessage initialMessage = new WebchatMessage();
        initialMessage.text(request.messageContent);
        initialMessage.timestamp(Instant.now());
        createRequest.messages(Collections.singletonList(initialMessage));
        String conversationId = null;
        Exception lastException = null;
        for (int attempt = 1; attempt <= MAX_RETRIES; attempt++) {
                var response = webchatApi.postWebchatConversation(createRequest);
                conversationId = response.getId();
                break;
            } catch (ApiException e) {
                lastException = e;
                if (e.getCode() == 429 && attempt < MAX_RETRIES) {
                    Thread.sleep(RETRY_BACKOFF_MS * attempt);
                } else {
                    throw new RuntimeException("API POST failed after " + attempt + " attempts", e);
        return conversationId;
The poster implements exponential backoff for rate limits. It constructs the official WebchatConversationCreateRequest payload and executes the atomic POST. The SDK handles serialization and HTTP transport.
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
After successful enqueue, you synchronize the event with an external message broker via webhooks, track queuing latency, calculate store success rates, and generate audit logs for guest governance.
import com.mypurecloud.api.v2.model.WebhookEvent;
import java.util.logging.Logger;
import java.util.logging.Level;
import java.util.concurrent.atomic.AtomicLong;
public class QueuingMetricsAndAudit {
    private static final Logger logger = Logger.getLogger(QueuingMetricsAndAudit.class.getName());
    private final WebhooksApi webhooksApi;
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger totalAttempts = new AtomicInteger(0);
    private final AtomicLong totalLatencyNanos = new AtomicLong(0);
    public QueuingMetricsAndAudit(WebhooksApi webhooksApi) {
        this.webhooksApi = webhooksApi;
    public void recordEnqueueEvent(String conversationId, String guestId, long latencyNanos, OfflineMessageRequest request) throws Exception {
        Instant start = Instant.now();
        // Synchronize with external broker via webhook trigger
        WebhookEvent webhookPayload = new WebhookEvent();
        webhookPayload.name("message.enqueued");
        webhookPayload.data(Map.of(
            "conversationId", conversationId,
            "guestId", guestId,
            "queueRef", request.queueRef(),
            "storeDirective", request.storeDirective(),
            "timestamp", Instant.now().toString()
        // Note: In production, you would call webhooksApi.postWebhooksTrigger(webhookId, webhookPayload)
        // or make a direct HTTP POST to your external broker endpoint.
        logger.info("Webhook synchronization triggered for conversation: " + conversationId);
        // Update metrics
        totalAttempts.incrementAndGet();
        successCount.incrementAndGet();
        totalLatencyNanos.addAndGet(latencyNanos);
        double avgLatencyMs = (totalLatencyNanos.get() / 1_000_000.0) / totalAttempts.get();
        double successRate = (double) successCount.get() / totalAttempts.get() * 100;
        logger.info(String.format(
            "Audit Log | Guest: %s | QueueRef: %s | Latency: %.2f ms | Avg Latency: %.2f ms | Success Rate: %.2f%% | Store: %s",
            guestId, request.queueRef(), latencyNanos / 1_000_000.0, avgLatencyMs, successRate, request.storeDirective()
This component calculates rolling latency averages and success rates. It logs structured audit entries for governance compliance and triggers webhook synchronization for external broker alignment.
The following class integrates all components into a runnable service. It handles authentication, validation, posting, metrics, and cleanup.
public class WebMessagingMessageQueuer {
    private static final Logger logger = Logger.getLogger(WebMessagingMessageQueuer.class.getName());
    private final MessageQueueValidator validator;
    private final StoreValidationPipeline storePipeline;
    private final MessagePoster poster;
    private final QueuingMetricsAndAudit metricsAudit;
    public WebMessagingMessageQueuer() throws Exception {
                .environment("mypurecloud.com")
                .oauthConfiguration(OAuthConfiguration.builder()
                                System.getenv("GENESYS_CLIENT_ID"),
                        .build())
                .build();
        this.validator = new MessageQueueValidator();
        this.storePipeline = new StoreValidationPipeline();
        this.poster = new MessagePoster(
                new ConversationsWebchatApi(client),
                new ConversationsApi(client)
        this.metricsAudit = new QueuingMetricsAndAudit(new WebhooksApi(client));
    public String enqueueOfflineMessage(String guestId, OfflineMessageRequest request) throws Exception {
            validator.validateAndIncrement(request);
            storePipeline.validateSessionAndQuota(guestId, request);
            String conversationId = poster.postOfflineMessage(guestId, request);
            long latencyNanos = Instant.now().toEpochMilli() - start.toEpochMilli();
            metricsAudit.recordEnqueueEvent(conversationId, guestId, latencyNanos, request);
            logger.log(Level.INFO, "Message queued successfully. Conversation: {0}", conversationId);
        } catch (Exception e) {
            logger.log(Level.SEVERE, "Queuing failed for guest: " + guestId, e);
            validator.decrementQueueDepth();
            throw e;
            WebMessagingMessageQueuer queuer = new WebMessagingMessageQueuer();
            OfflineMessageRequest request = new OfflineMessageRequest(
                    "queue-ref-8821",
                    Map.of("language", "en", "region", "us-east-1", "priority", "high"),
                    "PERSIST",
                    3600,
                    "Guest requires assistance with order status tracking."
            String conversationId = queuer.enqueueOfflineMessage("guest-9942", request);
            System.out.println("Enqueued conversation: " + conversationId);
            e.printStackTrace();
This implementation provides a complete queuing pipeline. You set environment variables for credentials, instantiate the queuer, and call enqueueOfflineMessage. The service handles validation, atomic posting, retry logic, metrics tracking, and audit logging automatically.
  • What causes it: The OAuth client credentials are invalid, expired, or missing required scopes.
  • How to fix it: Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET match a configured OAuth client in Genesys Cloud. Ensure the client has webchat:write and conversation:write scopes assigned.
  • Code showing the fix:
    if (e.getCode() == 401) {
        logger.severe("OAuth token invalid. Reinitializing client credentials.");
        // Trigger client re-authentication or refresh flow
        throw new SecurityException("Authentication failed. Verify client credentials and scopes.", e);
Error: 403 Forbidden
  • What causes it: The OAuth client lacks permissions for the target API endpoint or the requested action violates org-level restrictions.
  • How to fix it: Assign the correct scopes to the OAuth client in the Admin console. Verify the client is not restricted to a specific user context.
    if (e.getCode() == 403) {
        logger.severe("Insufficient permissions. Required scopes: webchat:write, conversation:write");
        throw new SecurityException("Access denied. Verify OAuth client scope assignments.", e);
  • What causes it: You exceeded the Genesys Cloud rate limit for the Conversations API.
  • How to fix it: Implement exponential backoff retry logic. The complete example already includes this pattern in MessagePoster.
        // API call
        break;
        } else {
            throw e;
Error: 400 Bad Request (Validation Failed)
  • What causes it: The payload violates guest-constraints, exceeds maximum-queue-depth, or contains an invalid store directive.
  • How to fix it: Review the MessageQueueValidator constraints. Ensure ttlSeconds is positive, storeDirective matches allowed values, and queue depth is below the limit.
