We’ve got a MuleSoft flow kicking off a Python worker to pull historical wrap-up codes via the Genesys Cloud API. The job runs for about four hours, so the standard access token expires halfway through. I’m trying to wire up automatic token refresh logic in the Python SDK so the worker doesn’t choke on 401s when the background process hits the queue.
Step one: initialize the client with the refresh token stored in the vault. The docs show genesyscloud.auth.AuthMethods.refresh_token but that just returns a new token object without actually swapping it into the active session. Step two: hook into the request interceptor to catch the 401 Unauthorized and trigger a silent rotation. I wrote a wrapper that catches the exception and calls client.auth.refresh(), but the SDK keeps reusing the stale bearer string on the retry.
Here is the current setup:
from genesyscloud import rest
from genesyscloud.auth import AuthMethods
client = rest.rest_client.RestClient()
AuthMethods.refresh_token(client, client_configuration, refresh_token=env["GC_REFRESH_TOKEN"])
def fetch_batch(endpoint):
response = client.get(endpoint)
return response
except rest.api_exception.ApiException as e:
if e.status == 401:
print("Token expired. Triggering silent refresh...")
return client.get(endpoint)
raise
The first call to the analytics interactions queue endpoint works fine. After roughly an hour, the worker hits a 401. The except block fires, prints the refresh message, and calls the auth method again. The next client.get(endpoint) still sends the old Authorization: Bearer <expired_token> header. I checked the network trace and the SDK isn’t updating the header store.
[2024-09-12 14:32:11] INFO: Requesting analytics interactions queue endpoint
[2024-09-12 14:32:15] ERROR: 401 Unauthorized - Access token expired
[2024-09-12 14:32:15] INFO: Token expired. Triggering silent refresh...
[2024-09-12 14:32:16] DEBUG: OAuth exchange successful. New token generated.
[2024-09-12 14:32:16] INFO: Retrying request...
[2024-09-12 14:32:17] ERROR: 401 Unauthorized - Access token expired
Header cache is definitely stuck. Tried clearing it manually. Nothing. Step three: verify if the Python SDK actually supports in-place token mutation or if I need to manually patch the client_configuration.default_headers. I tried overriding client_configuration.default_headers['Authorization'] after the refresh call, but the internal request builder pulls from a cached session object that ignores the dict update. The worker just loops through the retry and eventually times out. MuleSoft expects a clean exit code, so spinning up a fresh RestClient every hour breaks the connection pooling we’ve set up. The refresh_token method definitely exchanges the token with the /oauth/token endpoint, but the payload never sticks to the active HTTP session. I’ve been staring at the genesyscloud.rest.auth module for two hours and the method signatures are pretty sparse.
