Spent the better part of today trying to pull wrap-up codes via the platform-client-sdk-python and it’s…not going how I thought it would. We’re on Zoom Contact Center, obviously. I’m trying to automate the creation of a report that shows which wrap-up codes are being used most frequently, and the initial step is just getting the list.
The documentation points to using the get_routing_wrapupcodes method within the routing_api module. Seems straightforward enough. The thing is - it’s returning an empty list. Completely empty. Now, I understand the API works with pagination, so the assumption would be that there’s more data available, but the page_size parameter doesn’t seem to affect anything. It just keeps returning an empty wrapup_codes array.
Here’s the relevant snippet:
from platformclient.api.routing import RoutingApi
from platformclient.rest_api import RestApi
api_instance = RoutingApi(RestApi(settings))
organization_id = "YOUR_ORG_ID" # Obviously replaced.
api_response = api_instance.get_routing_wrapupcodes(organization_id)
print(api_response) # Prints an empty list.
print(f"Exception when calling RoutingApi->get_routing_wrapupcodes: {e}")
The organization_id is correct - I’ve validated that against the admin UI. I’m using SDK version40.0.189. I’ve also checked the permissions of the API user - it has the necessary roles to access routing data. We have about 30 wrap-up codes defined in Architect, so this isn’t a case of having no wrap-up codes.
The core of the issue feels like the API isn’t actually fetching the wrap-up codes. I’ve tried different filters - I was hoping maybe there was a default filter being applied - but that didn’t change the output. I’ve verified the endpoint itself is reachable using a simple curl request and it doesn’t throw an error.
I’m starting to suspect that this might be a regional issue. We’re running in us-east-1. Is anyone else having trouble with get_routing_wrapupcodes in that region? Or am I completely missing something obvious? The documentation doesn’t give a lot of detail about any potential limitations or quirks with this endpoint.
The SDK is usually the last place I look - seriously. The Python SDK feels like it’s actively trying to make things harder. The documentation is…optimistic, to say the least.
Tried: hitting the REST API directly. Much cleaner. The endpoint you want is /api/v3/routing/wrapupcodes. It’ll return JSON, so you’ll need to parse it in your script - but at least it returns something consistent.
Here’s a sample using requests - it’s faster to just grab this than to debug the SDK. Don’t bother with authentication headers, assuming you’ve got a valid API token set up in your environment.
import requests
import os
BASE_URL = os.getenv("CXONE_URL") #Set this in your environment
API_TOKEN = os.getenv("CXONE_API_TOKEN") #And this
headers = {
"Authorization": f"Bearer {API_TOKEN}"
response = requests.get(f"{BASE_URL}/api/v3/routing/wrapupcodes", headers=headers)
if response.status_code == 200:
wrapup_codes = response.json()
# Do something with wrapup_codes here
print(wrapup_codes)
else:
print(f"Error: {response.status_code} - {response.text}")
The SDK’s get_routing_wrapupcodes method? I wouldn’t waste another hour on it. It’s bably just a thin wrapper around the API anyway - and a badly implemented one at that. The API is just more predictable.
Don’t use the SDK (404). Seriously. That’s step one. The REST API is simpler, even if parsing JSON feels tedious (it’s not).
The endpoint As noted above is right - /api/v2/routing/wrapupcodes (not v3, pay attention). But you’ll get truncated results. It defaults to page size of 25 (429). You have to specify page_size=100 in the query parameters. Otherwise you’ll be paging forever.
Construct the URL like this - https://<your_instance_url>/api/v2/routing/wrapupcodes?page_size=100.
The requests example in the prior reply is okay. But you’ll need a loop to handle pagination. Pseudo-code:
page = 1
all_wrapup_codes = []
while True:
url = f"https://<your_instance_url>/api/v2/routing/wrapupcodes?page_size=100&page={page}"
response = requests.get(url)
if response.status_code != 200:
print(f"Error {response.status_code} - check your auth token") (500)
break
data = response.json()
all_wrapup_codes.extend(data["entities"])
if data["nextUri"] is None:
break
page += 1
Remember to handle the nextUri field for pagination. If it’s null (400), you’ve got all the wrap-up codes. It’s a string URL if there are more pages.
We’re on Zoom Contact Center, so token management is a pain point, obviously. Ensure your token hasn’t expired. (401)
