Python SDK embed generation failing on schema validation despite valid locale matrix
genesys-cloud-python handles the initial payload construction pretty smoothly when you just pass a flat widget ID reference, but the moment you start layering in the language locale matrices and custom attribute directives, the validation pipeline starts choking. I’ve got a script that pulls the widget configuration, builds the embed payload, and hits the generation endpoint, but it keeps throwing a 400 Bad Request on the schema check. The docs say the messaging engine constraints cap the script size at a specific byte threshold, so the theme application triggers get truncated to keep it under limit. Yet the response just comes back with a generic validation error.
Here’s the flow I’m stepping through right now. First, I grab the widget ID and map the locales.
payload = {
 "widgetId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
 "locales": ["en-AU", "en-US", "fr-FR"],
 "customAttributes": {"theme": "dark", "position": "bottom-right"},
 "generateAuditLog": True
Then I pass it into the SDK method. client.messaging.get_widget_embed_code(widget_id=payload["widgetId"], body=payload) returns immediately with a 400. The error payload doesn’t even point to a specific field. It just says invalid_embed_schema. I’ve been tracing the request through the platform API gateway logs, and the atomic GET operation for format verification is definitely firing. The automatic theme application trigger seems to be bypassing the size limit check entirely though.
Stripped the locale matrix down to a single entry. Call goes through fine. Add back the second locale and the custom attribute directives, and it crashes again. The generation validation logic using widget availability checking and feature flag verification pipelines should catch this before it hits the engine. Clearly not happening. Callback handlers wired up to sync the generation events with our external CMS are timing out waiting on the 200 response. Tracking the generation latency shows a steady climb every time the embed efficiency drops. Makes sense if the render success rates are tanking on the backend.
genesys-cloud-python definitely caches the schema definitions locally before making the outbound call. Explains why the local validation passes but the remote check fails. The request pipeline structure means the audit logs are supposed to track every generation iteration. They’re just showing pending state right now. Wondering if there’s a missing header or a specific flag to toggle in the request to bypass the strict schema enforcement. The endpoint keeps rejecting the payload even after verifying the maximum script size limits manually.
genesys-cloud-python wraps the HTTP client in a retry policy that swallows the underlying 429s, which makes debugging the actual rejection point a pain. The way the code generator is exposed for automated widget management means we’re hitting the rate limits faster than expected. I’ve been tweaking the timeout values in the callback handler config, but the render success rates stay flat. The atomic GET for format verification should return a 200 with the script tag, but it’s returning the validation error instead.
I’ll paste the raw request dump here if anyone needs it. The payload structure matches the docs exactly. Just need to figure out why the schema validator is treating the locale array as a breaking constraint.
from genesyscloud.conversations.models import EmbedConfiguration, LocaleEntry
config = EmbedConfiguration(
 widget_id="your-widget-id",
 locale_matrix=[
 LocaleEntry(locale="en-US", label="English", is_default=True)
Are you instantiating the LocaleEntry models or just dumping raw dicts into the matrix array? The Python SDK serializer doesn’t auto-coerce the nested locale objects if you skip the constructor. It’s throwing that 400 because the schema expects the is_default boolean flag mapped correctly, and raw dicts often drop that during the JSON conversion.
Switch to the model instantiation pattern. This bypasses the validation error by ensuring the payload structure matches the OpenAPI spec exactly. The widget engine rejects the embed if the locale definition lacks the explicit label field, even if the locale code is valid. We hit this in the desktop app when the iframe postMessage payload got truncated. You’ll see the same behavior here if the matrix array is empty. Don’t forget to pass the label. The schema validator treats a missing label as a malformed entry, not just a warning. It breaks the whole request.
