Python SDK 422 on Cognigy webhook payload transformation depth limit
cfg = {
“webhookId”: “cognigy-flow-04”,
“transformations”: [{“path”: “$.slots[0].val”, “cast”: “int”}, {“path”: “$.meta.ts”, “cast”: “string”}],
“maxDepth”: 4,
“validate”: True
res = cxone_sdk.post_transform_cfg(cfg)
cxone_sdk returns a 422 when the JSONPath extraction matrix crosses the payload depth limit. The schema mapping directives reject the atomic POST because the automatic type casting triggers fail on unexpected null values. You’ve got to strip the nested objects before the validation pipeline runs. The callback handler expects the reshaped data to match the audit log schema exactly, otherwise the middleware sync drops. Running the transformer locally passes every check, but the live endpoint chokes on the AI orchestration constraints. The maxDepth parameter seems to count array branches twice. Can’t wrap my head around how the depth counter calculates the JSONPath branches.
