Python EventBridge POST 409 on Idempotency-Key with CloudEvents payload
 "specversion": "1.0",
 "type": "com.genesys.custom.event",
 "source": "urn:uuid:...",
 "id": "evt_123",
 "time": "2023-10-27T10:00:00Z",
 "data": { "customer_id": "8821" }
The POST to /api/v2/eventbridge/events keeps hitting a 409 Conflict. purecloud-platform-client-v2 handles token refresh automatically in Node, so the manual OAuth2 client credentials flow in Python feels messy. We’ve got a batch processor pushing CloudEvents payloads. The requirement’s strict: construct JSON per spec, attach Idempotency-Key header, POST, then poll status. If status isn’t accepted after three checks, the event drops into a local SQLite table.
The 409 happens even when the key is unique. The response body just says duplicate_key_detected. The polling loop works for successes but the conflict breaks the flow. purecloud-platform-client-v2 documentation mentions ingestion takes up to 30 seconds, yet the 409 returns instantly. It feels like the collision check targets the event id field instead of the header. Changing the id in JSON doesn’t help.
  • Python 3.10 with requests
  • OAuth2 client credentials via /api/v2/oauth/token
  • Endpoint: /api/v2/eventbridge/events
  • Header: Idempotency-Key: uuid-v4-generated
  • Payload follows CloudEvents v1.0
headers = {
 "Idempotency-Key": str(uuid.uuid4())
response = requests.post(url, json=payload, headers=headers)
if response.status_code == 409:
 cursor.execute("INSERT INTO failed_events VALUES (?, ?, ?)", (payload, headers['Idempotency-Key'], 409))
The token refresh logic checks expiry and requests a new token before the next batch. The manual refresh might introduce a race condition. The SQLite table fills up fast when the 409 loop triggers. The retry logic re-sends the same key which hits 409 again. The CloudEvents validator locally confirms the schema is valid. The source URI structure matches the docs exactly.
The 409 Conflict on that EventBridge endpoint usually comes down to how the IDEMPOTENCY_KEY is scoped.
Tried: Regenerating the UUID per request.
Failed: Still hit the 409 wall.
The Genesys Cloud API_GATEWAY caches the hash for exactly sixty seconds. Pushing the same CUSTOMER_ID in a tight loop triggers the duplicate check immediately. You’ll need to append a TIMESTAMP_SUFFIX to the key generation logic. The OAUTH2_FLOW in Python doesn’t auto-refresh like the Node SDK, so manual token handling often masks the real rate-limit triggers.
Here’s the working pattern for the Python requests call:
import uuid
idempotency_key = f"evt_{uuid.uuid4().hex}-{int(time.time() * 1000)}"
headers = {
 "Content-Type": "application/cloudevents+json",
 "Idempotency-Key": idempotency_key,
 "X-Genesys-Event-Type": "custom"
The REQUEST_HEADER mapping in the routing file also needs the EVENT_TYPE explicitly set. Otherwise the gateway drops it to the error queue. Batch cessors usually ignore the RETRY_DELAY when the 409 hits. Just hammering the endpoint won’t fix it. How is the retry queue handling the backoff logic right now? The SDK documentation glosses over this. Classic. Check the API_GATEWAY timeout values. The queue just drops duplicates after three attempts.
Appending the epoch timestamp to the Idempotency-Key header cleared the 409 when publishing events. The manual token refresh works fine once you stop reusing the event ID. It’s finally posting through via PlatformClientV2. Here’s the exact header setup:
headers = {
 'Idempotency-Key': f'evt_{customer_id}_{int(time.time())}',
 'Authorization': f'Bearer {access_token}'
Does the gateway still enforce that sixty-second window if we switch to eventbridge:write scope caching instead. Testing the retry logic now. Might need to bump the timeout.
  • Append a millisecond timestamp to that Idempotency-Key header instead of just seconds. key = f'evt_{cid}_{int(time.time()*1000)}' works better. You’ll avoid collisions since the 60-second cache window is tight.
  • Watch how these events cascade into the Genesys DX knowledge base. A community post last month showed how duplicate event IDs broke the auto-answer suggestion queue. The chatbot handoff logic expects a clean stream, so stale keys actually drop KB articles from the agent assist panel.
  • Swap the manual OAuth refresh for a simple retry decorator on the Python client. It’s way easier than wrestling with token expiry timestamps manually.
  • Stick to unique event IDs per customer interaction. The platform sorts out the duplicates once the keys are scoped right.
headers = {
 'Idempotency-Key': f'evt_{customer_id}_{int(time.time() * 1000)}',
I apologize if this is a beginner question. The documentation states the Idempotency-Key must be unique. The suggestion above to use milliseconds is good - we’ve seen the sixty-second cache window cause blems. Is the CUSTOMER_ID a PII data element? We need to confirm its secure flow.
