Purging Genesys Cloud Routing Queue Entries via Python SDK
- A Python module that safely purges waiting contacts from Genesys Cloud routing queues using atomic DELETE operations.
- The implementation uses the Genesys Cloud Routing API (
/api/v2/routing/queues/{queueId}/entries) with explicit schema validation, rate limit handling, and audit logging. - The tutorial covers Python 3.9+ using the
requestslibrary, OAuth 2.0 client credentials flow, and structured callback synchronization for external workforce management systems.
- OAuth 2.0 client credentials grant configured in Genesys Cloud with
routing:queue:readandrouting:queue:writescopes - Genesys Cloud Platform API v2
- Python 3.9 or higher
pip install requests
Genesys Cloud requires an OAuth 2.0 bearer token for all routing operations. The client credentials flow exchanges an application client ID and secret for a short-lived access token. You must cache the token and refresh it before expiration to prevent 401 Unauthorized errors during bulk operations.
import requests
import json
from typing import Optional
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.token_url = f"{self.base_url}/api/v2/oauth/token"
self.expires_at: float = 0.0
if self.access_token and time.time() < self.expires_at - 60:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": "routing:queue:read routing:queue:write"
response = requests.post(self.token_url, data=payload)
response.raise_for_status()
token_data = response.json()
self.expires_at = time.time() + token_data["expires_in"]
Step 1: Entry State Validation and Agent Assignment Verification
Before executing a purge, you must verify that the queue contains valid waiting entries and that no active agent assignments or wrap-up states will cause orphaned contacts. The Routing API only removes entries in the waiting state. You fetch the queue entries with pagination, inspect the state field, and verify agent assignment status.
import requests
class QueueEntryValidator:
def __init__(self, auth_manager: GenesysAuthManager):
self.auth = auth_manager
self.base_url = auth_manager.base_url
def fetch_waiting_entries(self, queue_id: str, max_pages: int = 10) -> List[Dict[str, Any]]:
waiting_entries: List[Dict[str, Any]] = []
page = 1
page_size = 25
while page <= max_pages:
url = f"{self.base_url}/api/v2/routing/queues/{queue_id}/entries"
params = {"pageSize": page_size, "pageNumber": page, "state": "waiting"}
headers = {"Authorization": f"Bearer {self.auth.get_access_token()}"}
response = requests.get(url, params=params, headers=headers)
entities = data.get("entities", [])
if not entities:
break
for entry in entities:
# Filter out entries with active agent assignments or wrap-up states
agent = entry.get("agent", {})
if agent and agent.get("id"):
if entry.get("state") not in ("waiting",):
waiting_entries.append(entry)
if len(entities) < page_size:
break
page += 1
return waiting_entries
HTTP Request/Response Cycle (Step 1)
GET /api/v2/routing/queues/a1b2c3d4-e5f6-7890-abcd-ef1234567890/entries?pageSize=25&pageNumber=1&state=waiting
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Response: 200 OK
"entities": [
"id": "entry-uuid-1",
"queueId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"state": "waiting",
"position": 1,
"waitTime": 120000,
"agent": null
"pageSize": 25,
"pageNumber": 1,
"total": 1
Step 2: Payload Construction and Schema Validation
Genesys Cloud requires a structured PurgeQueueEntryRequest body containing reason codes. You must validate the payload against routing engine constraints before transmission. The reason code matrix maps business categories to standardized codes. Bulk limit directives control how many purge attempts occur per queue to respect platform throughput limits.
import json
from typing import Dict, Any
class PurgePayloadBuilder:
REASON_CODE_MATRIX = {
"operational": {
"code": "MAINTENANCE",
"description": "Scheduled queue maintenance",
"category": "Operational"
"scaling": {
"code": "LOAD_BALANCE",
"description": "Routing capacity optimization",
"category": "Scaling"
"data_cleanup": {
"code": "STALE_CONTACTS",
"description": "Removal of abandoned waiting entries",
"category": "DataCleanup"
@staticmethod
def build(category: str, max_attempts: int = 3) -> Dict[str, Any]:
if category not in PurgePayloadBuilder.REASON_CODE_MATRIX:
raise ValueError(f"Invalid purge category: {category}. Allowed: {list(PurgePayloadBuilder.REASON_CODE_MATRIX.keys())}")
matrix = PurgePayloadBuilder.REASON_CODE_MATRIX[category]
payload = {
"purgeReason": matrix["description"],
"purgeReasonCode": matrix["code"],
"purgeReasonCodeDescription": matrix["description"],
"purgeReasonCodeCategory": matrix["category"],
"_bulk_directive": {
"max_purge_attempts": max_attempts,
"rate_limit_window_seconds": 60,
"max_requests_per_window": 10
return payload
@staticmethod
def validate(payload: Dict[str, Any]) -> bool:
required_fields = ["purgeReason", "purgeReasonCode", "purgeReasonCodeDescription", "purgeReasonCodeCategory"]
for field in required_fields:
if field not in payload or not payload[field]:
return False
return True
Step 3: Atomic DELETE Execution with Rate Limit Handling
The purge operation executes an atomic DELETE against the queue entries endpoint. Genesys Cloud automatically recalculates entry positions after removal. You must implement exponential backoff for 429 Too Many Requests responses and track latency for routing efficiency metrics.
import logging
class QueuePurger:
def __init__(self, auth_manager: GenesysAuthManager, validator: QueueEntryValidator):
self.validator = validator
self.metrics = {"total_purges": 0, "successful_purges": 0, "failed_purges": 0, "total_latency_ms": 0}
def execute_purge(self, queue_id: str, payload: Dict[str, Any], max_retries: int = 3) -> Dict[str, Any]:
headers = {
"Authorization": f"Bearer {self.auth.get_access_token()}",
start_time = time.time()
attempt = 0
while attempt < max_retries:
response = requests.delete(url, json=payload, headers=headers)
if response.status_code == 204:
self.metrics["successful_purges"] += 1
self.metrics["total_latency_ms"] += latency_ms
"status": "success",
"queue_id": queue_id,
"latency_ms": latency_ms,
"attempt": attempt + 1
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
logger.warning(f"Rate limited (429). Retrying in {retry_after}s (attempt {attempt + 1}/{max_retries})")
time.sleep(retry_after)
attempt += 1
self.metrics["failed_purges"] += 1
logger.error(f"Purge failed for queue {queue_id}: {str(e)}")
raise
return {"status": "failed", "queue_id": queue_id, "error": "Max retries exceeded"}
HTTP Request/Response Cycle (Step 3)
DELETE /api/v2/routing/queues/a1b2c3d4-e5f6-7890-abcd-ef1234567890/entries
"purgeReason": "Scheduled queue maintenance",
"purgeReasonCode": "MAINTENANCE",
"purgeReasonCodeDescription": "Scheduled queue maintenance",
"purgeReasonCodeCategory": "Operational"
Response: 204 No Content
(Headers may include Retry-After on 429, or standard rate-limit headers)
Step 4: Callback Synchronization, Metrics, and Audit Logging
External workforce management systems require event synchronization. You register a callback handler that receives purge results and latency data. The audit logger writes structured JSON records for queue governance and compliance tracking.
import json
import os
from typing import Callable, Any, Dict
class PurgeOrchestrator:
def __init__(self, purger: QueuePurger, callback_handler: Callable[[str, Dict[str, Any], float], None] = None):
self.purger = purger
self.callback = callback_handler
self.audit_log_path = "purge_audit.log"
def run_purge_workflow(self, queue_id: str, reason_category: str) -> Dict[str, Any]:
# Step 1: Validate entries
validator = QueueEntryValidator(self.purger.auth)
waiting = validator.fetch_waiting_entries(queue_id)
if not waiting:
logger.info(f"No waiting entries found in queue {queue_id}. Skipping purge.")
return {"status": "skipped", "reason": "no_waiting_entries"}
# Step 2: Build and validate payload
payload_builder = PurgePayloadBuilder()
payload = payload_builder.build(reason_category)
if not payload_builder.validate(payload):
raise ValueError("Purge payload failed schema validation")
# Step 3: Execute purge
result = self.purger.execute_purge(queue_id, payload)
# Step 4: Trigger callback for WFM synchronization
if self.callback:
latency = result.get("latency_ms", 0)
self.callback(queue_id, result, latency)
# Step 5: Write audit log
self._write_audit_log(queue_id, payload, result)
return result
def _write_audit_log(self, queue_id: str, payload: Dict[str, Any], result: Dict[str, Any]):
log_entry = {
"purge_reason_code": payload.get("purgeReasonCode"),
"purge_category": payload.get("purgeReasonCodeCategory"),
"result_status": result.get("status"),
"latency_ms": result.get("latency_ms"),
"metrics_snapshot": self.purger.metrics
with open(self.audit_log_path, "a") as f:
f.write(json.dumps(log_entry) + "\n")
The following script combines all components into a runnable module. Replace the placeholder credentials with your Genesys Cloud application values.
import requests
import json
import logging
from typing import Optional, List, Dict, Any, Callable
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
payload = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret, "scope": "routing:queue:read routing:queue:write"}
page = 1
page_size = 25
if not entities:
break
break
page += 1
"operational": {"code": "MAINTENANCE", "description": "Scheduled queue maintenance", "category": "Operational"},
"scaling": {"code": "LOAD_BALANCE", "description": "Routing capacity optimization", "category": "Scaling"},
"data_cleanup": {"code": "STALE_CONTACTS", "description": "Removal of abandoned waiting entries", "category": "DataCleanup"}
@staticmethod
raise ValueError(f"Invalid purge category: {category}")
return {"purgeReason": matrix["description"], "purgeReasonCode": matrix["code"], "purgeReasonCodeDescription": matrix["description"], "purgeReasonCodeCategory": matrix["category"], "_bulk_directive": {"max_purge_attempts": max_attempts, "rate_limit_window_seconds": 60, "max_requests_per_window": 10}}
@staticmethod
return all(payload.get(f) for f in ["purgeReason", "purgeReasonCode", "purgeReasonCodeDescription", "purgeReasonCodeCategory"])
class QueuePurger:
headers = {"Authorization": f"Bearer {self.auth.get_access_token()}", "Content-Type": "application/json"}
attempt = 0
return {"status": "success", "queue_id": queue_id, "latency_ms": latency_ms, "attempt": attempt + 1}
logger.warning(f"Rate limited (429). Retrying in {retry_after}s")
attempt += 1
raise
if not waiting:
if self.callback:
self.callback(queue_id, result, result.get("latency_ms", 0))
return result
log_entry = {"timestamp": datetime.now(timezone.utc).isoformat(), "queue_id": queue_id, "purge_reason_code": payload.get("purgeReasonCode"), "purge_category": payload.get("purgeReasonCodeCategory"), "result_status": result.get("status"), "latency_ms": result.get("latency_ms"), "metrics_snapshot": self.purger.metrics}
def wfm_callback(queue_id: str, result: Dict[str, Any], latency: float):
print(f"WFM Sync: Queue {queue_id} purge completed with status {result.get('status')} in {latency:.2f}ms")
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
TARGET_QUEUE_ID = "your_queue_uuid"
auth = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET)
validator = QueueEntryValidator(auth)
purger = QueuePurger(auth, validator)
orchestrator = PurgeOrchestrator(purger, wfm_callback)
outcome = orchestrator.run_purge_workflow(TARGET_QUEUE_ID, "operational")
print(f"Final outcome: {json.dumps(outcome, indent=2)}")
print(f"Metrics: {json.dumps(purger.metrics, indent=2)}")
logger.error(f"Workflow terminated: {str(e)}")
- Cause: The OAuth token expired or the client credentials are invalid.
- Fix: Ensure
GenesysAuthManagercaches the token correctly and refreshes it before expiration. Verify the client ID and secret match a Genesys Cloud application withrouting:queue:writescope. - Code fix: The
get_access_tokenmethod already checkstime.time() < self.expires_at - 60to proactively refresh.
Error: 403 Forbidden
- Cause: The application lacks the required OAuth scope or the user associated with the service account does not have routing permissions.
- Fix: Grant
routing:queue:readandrouting:queue:writescopes in the Genesys Cloud admin console under Applications. Assign the service account to a role with Queue Management permissions.
- Cause: You exceeded the routing API rate limit window. Genesys Cloud enforces per-queue and global throughput limits.
- Fix: The
execute_purgemethod implements exponential backoff usingRetry-Afterheaders. Increase the delay multiplier if cascading 429s occur across multiple queue iterations.
Error: 400 Bad Request
- Cause: The purge payload contains invalid reason codes or missing required fields.
- Fix: Validate the payload against
PurgePayloadBuilder.REASON_CODE_MATRIXbefore transmission. EnsurepurgeReasonCodematches the allowed enum values in your Genesys Cloud instance configuration.
Error: 404 Not Found
- Cause: The queue ID does not exist or the queue was archived.
- Fix: Verify the queue UUID against
GET /api/v2/routing/queues. Do not purge archived or deleted queues.
