Purge scripts for statserver tables
Can some help me with the oracle purge scripts for the statservers tables Login,QueueInfo,Voice Extension and status .Iam looking to purge the data which is older than 15days.
tnks…rn
Can any please help me out on this ???
cheers…rn
What version of Oracle database you have?
The oracle version is 10G release 2.
thanks,
Hi RN,
Here are the SQL scripts for purging StatServer’s tables. You can delete records older then specified date using these scripts. Just replace the date ‘2008-07-01’ (July 1st 2008) in the commands below with different date.
Please test these scripts carefully before using them on production system!
— purge table “LOGIN” by date
DELETE LOGIN
WHERE TIME < ((TO_DATE(‘2008-07-01’,‘YYYY-MM-DD’)-TO_DATE(‘1970-01-01 00:01:00’,‘YYYY-MM-DD HH24:MI:SS’))360024);
— purge table “QINFO” by date
DELETE QINFO
WHERE StartTime < ((TO_DATE(‘2008-07-01’,‘YYYY-MM-DD’)-TO_DATE(‘1970-01-01 00:01:00’,‘YYYY-MM-DD HH24:MI:SS’))360024);
— purge table “STATUS” by date
DELETE STATUS
— purge table “VOICE_REASONS” by date
DELETE VOICE_REASONS
WHERE START_TIME < ((TO_DATE(‘2008-07-01’,‘YYYY-MM-DD’)-TO_DATE(‘1970-01-01 00:01:00’,‘YYYY-MM-DD HH24:MI:SS’))360024);
