Publishing Genesys Cloud WebSocket Control Messages with Python
  • A Python publisher that constructs, validates, and dispatches real-time WebSocket commands to Genesys Cloud with strict payload serialization, size enforcement, and acknowledgment tracking.
  • This implementation uses the official Genesys Cloud WebSocket API endpoint /api/v2/events/websocket and the standard Python websockets library.
  • The tutorial covers Python 3.10+ using httpx for OAuth token acquisition, pydantic for schema validation, and structured audit logging with latency metrics.
  • OAuth 2.0 Client Credentials grant type with client_id and client_secret
  • Required scopes: analytics:query, routing:conversation:modify, integrations:webhook:manage
  • Python 3.10 or higher
  • External dependencies: pip install websockets httpx pydantic aiofiles
  • Access to a Genesys Cloud organization with WebSocket API enabled
Genesys Cloud requires a valid JWT access token before establishing the WebSocket connection. The token must be passed as a query parameter during the WebSocket handshake. The following code demonstrates a production-grade token acquisition flow with automatic refresh handling.
import httpx
import logging
from typing import Optional
class GenesysOAuthManager:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.token_url = f"{base_url}/oauth/token"
        if self.access_token and time.time() < self.token_expiry:
            return self.access_token
            response = await client.post(
                self.token_url,
                data={
                    "client_id": self.client_id,
            if response.status_code != 200:
                raise httpx.HTTPStatusError(
                    f"OAuth token request failed with status {response.status_code}",
                    request=response.request,
                    response=response
            token_data = response.json()
            self.token_expiry = time.time() + (token_data["expires_in"] - 300)
            logger.info("OAuth token acquired successfully")
Step 1: WebSocket Connection & Handshake Initialization
The Genesys Cloud WebSocket endpoint requires an authenticated connection. You pass the JWT in the query string. After connection, you must send a subscription or command message. The connection handler implements exponential backoff for transient network failures and validates the initial server acknowledgment.
import asyncio
import websockets
import json
from websockets.exceptions import ConnectionClosed, InvalidStatusCode
class GenesysWebSocketConnection:
    def __init__(self, oauth_manager: GenesysOAuthManager, environment: str = "mypurecloud.com"):
        self.oauth = oauth_manager
        self.ws_url = f"wss://api.{environment}/api/v2/events/websocket"
        self.websocket: Optional[websockets.WebSocketClientProtocol] = None
        self.connected: bool = False
    async def connect(self, max_retries: int = 3) -> None:
        token = await self.oauth.get_token()
        ws_url = f"{self.ws_url}?access_token={token}"
        for attempt in range(1, max_retries + 1):
                self.websocket = await websockets.connect(ws_url, ping_interval=20, ping_timeout=10)
                logger.info("WebSocket connection established")
                self.connected = True
                return
            except (ConnectionClosed, InvalidStatusCode) as exc:
                logger.warning(f"Connection attempt {attempt} failed: {exc}")
                if attempt < max_retries:
                    await asyncio.sleep(2 ** attempt)
                else:
                    raise RuntimeError("Failed to establish WebSocket connection after maximum retries")
    async def disconnect(self) -> None:
        if self.websocket and not self.websocket.closed:
            await self.websocket.close()
            self.connected = False
            logger.info("WebSocket connection closed")
Step 2: Payload Construction, Validation Pipeline & Serialization
Genesys Cloud enforces a 64KB maximum frame size and requires strict JSON formatting. The validation pipeline checks topic permissions, verifies payload structure using Pydantic, enforces size limits, and applies serialization matrices before dispatch. QoS-like behavior is simulated through retry directives and acknowledgment tracking.
import pydantic
from enum import Enum
from typing import Any, Dict, List
import hashlib
class QoSLvl(Enum):
    AT_MOST_ONCE = 0
    AT_LEAST_ONCE = 1
    EXACTLY_ONCE = 2
class GenesysMessageSchema(pydantic.BaseModel):
    type: str
    data: Dict[str, Any]
    subscription_id: Optional[str] = None
    qos_level: QoSLvl = QoSLvl.AT_LEAST_ONCE
    @pydantic.field_validator("type")
    @classmethod
    def validate_message_type(cls, value: str) -> str:
        allowed_types = {"subscribe", "unsubscribe", "pause", "resume", "command"}
        if value not in allowed_types:
            raise ValueError(f"Invalid message type: {value}. Must be one of {allowed_types}")
        return value
class PayloadValidator:
    MAX_FRAME_SIZE = 65536  # 64KB limit enforced by Genesys Cloud protocol engine
    @staticmethod
    def validate_and_serialize(message: GenesysMessageSchema) -> bytes:
        payload_bytes = message.model_dump_json().encode("utf-8")
        if len(payload_bytes) > PayloadValidator.MAX_FRAME_SIZE:
            raise ValueError(
                f"Payload size {len(payload_bytes)} exceeds maximum allowed frame size of {PayloadValidator.MAX_FRAME_SIZE} bytes"
        payload_hash = hashlib.sha256(payload_bytes).hexdigest()[:16]
        message.data["internal_checksum"] = payload_hash
        message.data["dispatch_timestamp"] = time.time()
        final_payload = message.model_dump_json().encode("utf-8")
        return final_payload
Step 3: Atomic Dispatch, Acknowledgment Tracking & Latency Metrics
Message dispatch uses atomic WebSocket writes. The publisher tracks latency between dispatch and server acknowledgment, implements retry logic for QoS level 1 and 2, and exposes callback handlers for external broker synchronization. Audit logs record every transaction for governance compliance.
from typing import Callable, Optional, Awaitable
import uuid
@dataclass
class PublishMetrics:
    message_id: str
    topic: str
    dispatch_time: float
    ack_time: Optional[float] = None
    latency_ms: Optional[float] = None
    success: bool = False
    retry_count: int = 0
    error_message: Optional[str] = None
class GenesysMessagePublisher:
    def __init__(
        self,
        connection: GenesysWebSocketConnection,
        broker_sync_callback: Optional[Callable[[PublishMetrics], Awaitable[None]]] = None
        self.connection = connection
        self.broker_callback = broker_sync_callback
        self.audit_log: List[Dict[str, Any]] = []
        self.pending_acks: Dict[str, PublishMetrics] = {}
    async def publish(self, message: GenesysMessageSchema) -> PublishMetrics:
        message_id = str(uuid.uuid4())
        dispatch_time = time.time()
        metrics = PublishMetrics(
            message_id=message_id,
            topic=message.data.get("topic", "unknown"),
            dispatch_time=dispatch_time,
            retry_count=0
            payload_bytes = PayloadValidator.validate_and_serialize(message)
            self.pending_acks[message_id] = metrics
            await self.connection.websocket.send(payload_bytes.decode("utf-8"))
            logger.info(f"Dispatched message {message_id} to Genesys Cloud")
            if message.qos_level == QoSLvl.AT_LEAST_ONCE or message.qos_level == QoSLvl.EXACTLY_ONCE:
                await self._wait_for_ack(message_id, max_retries=3)
            metrics.success = True
            metrics.ack_time = time.time()
            metrics.latency_ms = round((metrics.ack_time - dispatch_time) * 1000, 2)
        except Exception as exc:
            metrics.success = False
            metrics.error_message = str(exc)
            logger.error(f"Publish failed for {message_id}: {exc}")
        finally:
            self._record_audit(metrics)
            if self.broker_callback and metrics.success:
                await self.broker_callback(metrics)
            return metrics
    async def _wait_for_ack(self, message_id: str, max_retries: int) -> None:
                response = await asyncio.wait_for(
                    self.connection.websocket.recv(), timeout=5.0
                resp_data = json.loads(response)
                if resp_data.get("type") == "ack" or resp_data.get("status") == "success":
                    return
                if resp_data.get("type") == "error":
                    raise ValueError(f"Server rejected message: {resp_data.get('message', 'Unknown error')}")
            except asyncio.TimeoutError:
                if attempt < max_retries - 1:
                        json.dumps({"type": "ping", "data": {"message_id": message_id}})
                else:
                    raise TimeoutError("Acknowledgment timeout exceeded")
    def _record_audit(self, metrics: PublishMetrics) -> None:
        audit_entry = {
            "timestamp": time.time(),
            "message_id": metrics.message_id,
            "topic": metrics.topic,
            "latency_ms": metrics.latency_ms,
            "success": metrics.success,
            "error": metrics.error_message
        self.audit_log.append(audit_entry)
        logger.info(f"Audit logged: {audit_entry}")
The following script combines all components into a single executable module. It acquires authentication, establishes the WebSocket connection, constructs a real-time routing command payload, publishes it with QoS directives, and demonstrates external broker synchronization via callback.
import asyncio
import logging
import sys
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
async def external_broker_sync(metrics: PublishMetrics) -> None:
    await asyncio.sleep(0.1)
    logging.info(f"Broker sync triggered for {metrics.message_id} with latency {metrics.latency_ms}ms")
async def main():
    oauth = GenesysOAuthManager(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET"
    connection = GenesysWebSocketConnection(oauth_manager=oauth)
    await connection.connect()
    publisher = GenesysMessagePublisher(
        connection=connection,
        broker_sync_callback=external_broker_sync
    command_message = GenesysMessageSchema(
        type="command",
        data={
            "topic": "routing.conversationEvents",
            "conversation_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
            "action": "hold",
            "metadata": {"reason": "supervisor_review", "queue_id": "default"}
        qos_level=QoSLvl.AT_LEAST_ONCE
        result = await publisher.publish(command_message)
        logging.info(f"Publish result: Success={result.success}, Latency={result.latency_ms}ms")
        delivery_rate = sum(1 for m in publisher.audit_log if m["success"]) / len(publisher.audit_log) * 100
        logging.info(f"Delivery confirmation rate: {delivery_rate:.2f}%")
        logging.error(f"Execution failed: {e}")
        sys.exit(1)
    finally:
        await connection.disconnect()
    asyncio.run(main())
Error: HTTP 401 Unauthorized during WebSocket handshake
  • What causes it: The access token is expired, malformed, or missing from the query string.
  • How to fix it: Ensure the GenesysOAuthManager refreshes the token before connection. Verify the client_id and client_secret match your Genesys Cloud application configuration.
  • Code showing the fix: The get_token method includes a 300-second buffer before expiry to prevent mid-session token expiration.
Error: HTTP 403 Forbidden on message dispatch
  • What causes it: The OAuth token lacks the required scope for the requested command type.
  • How to fix it: Add routing:conversation:modify or analytics:query to your application scopes in the Genesys Cloud admin console.
  • Code showing the fix: Update the OAuth grant request to include the correct scope parameter if using custom grants, or regenerate the token after scope modification.
Error: WebSocket close code 1008 (Policy Violation) or 64KB size limit
  • What causes it: The serialized payload exceeds the Genesys Cloud protocol engine maximum frame size.
  • How to fix it: The PayloadValidator enforces a 64KB limit. If your payload is too large, partition the data into multiple subscription commands or use the REST API for bulk operations.
  • Code showing the fix: PayloadValidator.validate_and_serialize raises a ValueError immediately when len(payload_bytes) > 65536.
Error: TimeoutError on acknowledgment wait
  • What causes it: Network latency, server-side throttling, or missing response handler.
  • How to fix it: Implement exponential backoff in the retry loop. Genesys Cloud may drop WebSocket frames during high load. The _wait_for_ack method includes a ping retry mechanism to re-establish frame synchronization.
  • Code showing the fix: The timeout handler resends a ping frame before failing, and the retry count limits cascading 429-like backpressure.
