Publishing Genesys Cloud Flow Versions via API with Python SDK
This tutorial builds a production-grade Python module that validates, publishes, and monitors Genesys Cloud flow versions asynchronously. The code constructs structured publish payloads with version metadata and dependency hashes, polls the publish job until completion, executes rollback logic on failure, synchronizes exported flow artifacts to an external Git repository, and generates structured audit logs with latency and validation error tracking.
- OAuth2 client credentials grant with scopes:
flow:publish,flow:read,flow:write,flow:version:read,flow:version:write,flow:validate genesyscloudPython SDK version 2.10.0 or later- Python 3.9 runtime
- External dependencies:
pip install genesyscloud gitpython requests - A Genesys Cloud environment with at least one draft flow version ready for promotion
Genesys Cloud uses OAuth2 client credentials flow for server-to-server integrations. The Python SDK handles token acquisition and automatic refresh, but you must configure the client ID, client secret, and environment base URL explicitly.
import os
import json
import logging
from typing import Optional
from genesyscloud import PlatformClientV2, Configuration
from genesyscloud.flows.api import FlowsApi
from genesyscloud.flows.model.publish_flow_version_request import PublishFlowVersionRequest
from genesyscloud.flows.model.validate_flow_version_request import ValidateFlowVersionRequest
from git import Repo, Git
import requests
# Configure structured logging for audit trails
logging.basicConfig(
level=logging.INFO,
format="%(asctime)s | %(levelname)s | %(message)s",
datefmt="%Y-%m-%dT%H:%M:%S%z"
logger = logging.getLogger("flow_publisher")
def init_genesys_client(
client_id: str,
client_secret: str,
environment: str = "mypurecloud.com"
) -> FlowsApi:
Initialize the Genesys Cloud Python SDK with client credentials authentication.
Handles token caching and automatic refresh via the SDK configuration.
config = Configuration()
config.base_url = f"https://{environment}"
config.oauth_client_id = client_id
config.oauth_client_secret = client_secret
config.oauth_access_token_url = f"https://api.{environment}/oauth/token"
# Enable token caching to avoid redundant credential exchanges
config.use_token_cache = True
platform_client = PlatformClientV2(config)
return platform_client.flows_api
Step 1: Validate Flow Graph Against Schema Constraints and Resource Limits
Before publishing, you must validate the flow graph. Genesys Cloud returns a detailed validation report containing schema violations, missing resources, and execution limit warnings. The validation endpoint is synchronous and returns a 200 OK with an array of validation results.
HTTP Equivalent:
POST /api/v2/flows/{flowId}/versions/{versionId}/validate HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer {access_token}
Accept: application/json
Response:
"validationResults": [
"id": "validation-001",
"message": "Flow graph validated successfully.",
"severity": "info"
"validationSummary": {
"totalErrors": 0,
"totalWarnings": 0,
"isSuccessful": true
Python SDK Implementation:
class FlowPublisher:
def __init__(self, flows_api: FlowsApi, repo_path: str):
self.flows_api = flows_api
self.repo_path = repo_path
self.audit_log: list[dict] = []
self.validation_error_rate: float = 0.0
self.total_validations: int = 0
def validate_flow(self, flow_id: str, version_id: str) -> tuple[bool, dict]:
Validates the flow graph. Returns (is_valid, validation_report).
Tracks validation error rates for release management metrics.
self.total_validations += 1
start_time = time.time()
# SDK call maps to POST /api/v2/flows/{flowId}/versions/{versionId}/validate
validate_req = ValidateFlowVersionRequest()
response = self.flows_api.post_flows_flow_id_versions_version_id_validate(
flow_id=flow_id,
version_id=version_id,
body=validate_req
latency = time.time() - start_time
is_valid = response.validation_summary.is_successful
error_count = response.validation_summary.total_errors
if not is_valid:
self.validation_error_rate = (
(self.validation_error_rate * (self.total_validations - 1) + 1) / self.total_validations
logger.warning("Validation failed for version %s. Errors: %d", version_id, error_count)
self._record_audit(
action="validate",
flow_id=flow_id,
status="success" if is_valid else "failed",
latency_ms=round(latency * 1000, 2),
details={
"total_errors": error_count,
"total_warnings": response.validation_summary.total_warnings,
"validation_results": [
{"message": r.message, "severity": r.severity}
for r in response.validation_results
return is_valid, response.to_dict()
self._handle_api_error(e, "validate_flow")
return False, {}
Step 2: Construct Publish Payload and Trigger Async Job
Publishing a flow version is an asynchronous operation. The API accepts a payload containing metadata, dependency hashes, and rollout configuration. Genesys Cloud returns a 202 Accepted response immediately, queuing the publish job.
HTTP Equivalent:
POST /api/v2/flows/{flowId}/versions/{versionId}/publish HTTP/1.1
"publishType": "standard",
"metadata": {
"releaseVersion": "2.4.1",
"deployedBy": "ci-pipeline",
"environment": "production"
"dependencyValidationHash": "sha256:a1b2c3d4e5f67890",
"rolloutConfig": {
"staged": true,
"stages": [
{"percentage": 10, "durationMinutes": 15},
{"percentage": 50, "durationMinutes": 30},
{"percentage": 100, "durationMinutes": 0}
Response:
"status": "queued",
"publishId": "pub-8f7e6d5c-4b3a-2910-8877-665544332211",
"flowId": "fl-12345678-90ab-cdef-1234-567890abcdef",
"versionId": "ver-98765432-10fe-dcba-9876-543210fedcba"
def publish_flow(
self,
flow_id: str,
version_id: str,
release_version: str,
dependency_hash: str,
staged_rollout: bool = True
) -> Optional[str]:
Constructs the publish payload and triggers the async publish job.
Returns the publishId for polling, or None on failure.
# Construct payload matching Genesys Cloud publish contract
payload = {
"metadata": {
"releaseVersion": release_version,
"deployedBy": "api-publisher",
"timestamp": datetime.now(timezone.utc).isoformat()
"dependencyValidationHash": dependency_hash,
"rolloutConfig": {
"staged": staged_rollout,
"stages": [
{"percentage": 10, "durationMinutes": 10},
{"percentage": 50, "durationMinutes": 20},
# SDK call maps to POST /api/v2/flows/{flowId}/versions/{versionId}/publish
publish_req = PublishFlowVersionRequest(**payload)
response = self.flows_api.post_flows_flow_id_versions_version_id_publish(
flow_id=flow_id,
body=publish_req
publish_id = response.publish_id
self._record_audit(
action="publish_triggered",
flow_id=flow_id,
status="queued",
details={"publish_id": publish_id, "payload": payload}
return publish_id
self._handle_api_error(e, "publish_flow")
return None
Step 3: Handle Asynchronous Publish Jobs via Polling with Status Verification and Error Recovery
Large flow deployments require polling. The status endpoint returns queued, publishing, completed, failed, or cancelled. You must implement exponential backoff and handle 429 Too Many Requests to avoid rate-limit cascades.
HTTP Equivalent:
GET /api/v2/flows/{flowId}/versions/{versionId}/publishstatus HTTP/1.1
Response:
"status": "publishing",
"progressPercent": 45,
"currentStage": "validating_dependencies",
"estimatedTimeRemainingSeconds": 120,
"errors": []
def poll_publish_status(
self,
flow_id: str,
version_id: str,
timeout_seconds: int = 600,
poll_interval_base: float = 5.0
) -> bool:
Polls the publish status until completion or failure.
Implements exponential backoff and 429 retry logic.
elapsed = 0
backoff = poll_interval_base
max_retries = 5
while elapsed < timeout_seconds:
# SDK call maps to GET /api/v2/flows/{flowId}/versions/{versionId}/publishstatus
response = self.flows_api.get_flows_flow_id_versions_version_id_publishstatus(
flow_id=flow_id,
status = response.status
if status == "completed":
self._record_audit(
action="publish_completed",
flow_id=flow_id,
status="success",
latency_ms=round((time.time() - start_time) * 1000, 2),
details={"final_progress": response.progress_percent}
return True
if status in ("failed", "cancelled"):
self._record_audit(
action="publish_failed",
flow_id=flow_id,
status="error",
details={"errors": response.errors}
logger.error("Publish job failed for version %s: %s", version_id, response.errors)
return False
logger.info("Publish status: %s | Progress: %d%%", status, response.progress_percent)
if e.response.status_code == 429:
logger.warning("Rate limited (429). Retrying in %.2fs", backoff)
time.sleep(backoff)
backoff = min(backoff * 2, 60)
self._handle_api_error(e, "poll_publish_status")
return False
return False
time.sleep(backoff)
elapsed = time.time() - start_time
logger.error("Publish job timed out after %d seconds", timeout_seconds)
return False
Step 4: Implement Rollback Logic Using Previous Version Restoration and Health Check Triggers
If the publish job fails or a post-deployment health check fails, you must restore the previous stable version. Genesys Cloud allows re-publishing an older version ID to instantly rollback.
def rollback_to_previous_version(self, flow_id: str, previous_version_id: str) -> bool:
Restores a previous flow version by triggering a standard publish.
Used for rollback mitigation after deployment failures.
logger.info("Initiating rollback to version %s for flow %s", previous_version_id, flow_id)
rollback_payload = {
"metadata": {
"releaseVersion": "rollback",
"deployedBy": "automated-rollback",
"reason": "deployment_failure_mitigation"
"dependencyValidationHash": "rollback-bypass-hash",
"rolloutConfig": {
"staged": False,
"stages": [{"percentage": 100, "durationMinutes": 0}]
publish_req = PublishFlowVersionRequest(**rollback_payload)
flow_id=flow_id,
version_id=previous_version_id,
body=publish_req
# Poll rollback completion with shorter timeout
success = self.poll_publish_status(
flow_id=flow_id,
timeout_seconds=300,
poll_interval_base=3.0
self._record_audit(
action="rollback_executed",
flow_id=flow_id,
status="success" if success else "failed",
latency_ms=0,
details={"publish_id": response.publish_id}
return success
self._handle_api_error(e, "rollback_to_previous_version")
return False
def run_health_check(self, flow_id: str) -> bool:
Simulates a health check trigger. In production, this calls your
synthetic monitoring endpoint or checks Genesys analytics for
sudden error rate spikes.
# Placeholder for actual health check logic
logger.info("Running post-deployment health check for flow %s", flow_id)
# Return True if healthy, False if metrics indicate failure
return True
Step 5: Synchronize Flow Artifacts with External Version Control and Generate Audit Logs
After successful deployment, export the exact flow definition that went live and commit it to Git. Generate a structured audit log for compliance tracking.
def export_and_sync_to_vcs(self, flow_id: str, version_id: str, commit_message: str) -> bool:
Exports the published flow definition and commits it to an external Git repository.
response = self.flows_api.get_flows_flow_id_versions_version_id(
flow_id=flow_id,
artifact_path = f"flows/{flow_id}/{version_id}.json"
os.makedirs(os.path.dirname(artifact_path), exist_ok=True)
with open(artifact_path, "w") as f:
json.dump(response.to_dict(), f, indent=2)
repo = Repo(self.repo_path)
repo.index.add([artifact_path])
repo.index.commit(commit_message)
origin = repo.remotes.origin
origin.push()
self._record_audit(
action="vcs_sync",
flow_id=flow_id,
status="success",
latency_ms=0,
details={"artifact_path": artifact_path, "commit": commit_message}
return True
self._handle_api_error(e, "export_and_sync_to_vcs")
return False
def _record_audit(self, action: str, flow_id: str, version_id: str, status: str, latency_ms: float, details: dict):
"""Appends a structured audit entry for compliance tracking."""
entry = {
"action": action,
"flow_id": flow_id,
"version_id": version_id,
"status": status,
"latency_ms": latency_ms,
"validation_error_rate": self.validation_error_rate,
"details": details
self.audit_log.append(entry)
logger.info("AUDIT: %s", json.dumps(entry, default=str))
def _handle_api_error(self, error: Exception, context: str):
"""Centralized error handler for SDK and HTTP exceptions."""
if hasattr(error, "status_code"):
code = error.status_code
if code == 401:
logger.error("Authentication failed in %s. Token expired or invalid.", context)
elif code == 403:
logger.error("Forbidden in %s. Check OAuth scopes: flow:publish, flow:read, flow:write.", context)
elif code == 404:
logger.error("Not found in %s. Flow or version ID may be incorrect.", context)
elif code == 429:
logger.error("Rate limited in %s. Implement backoff.", context)
else:
logger.error("HTTP %d in %s: %s", code, context, str(error))
else:
logger.error("Unexpected error in %s: %s", context, str(error))
def main():
# Configuration
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
ENVIRONMENT = os.getenv("GENESYS_ENVIRONMENT", "mypurecloud.com")
FLOW_ID = os.getenv("FLOW_ID")
VERSION_ID = os.getenv("VERSION_ID")
PREVIOUS_VERSION_ID = os.getenv("PREVIOUS_VERSION_ID")
GIT_REPO_PATH = os.getenv("GIT_REPO_PATH", "./flow-artifacts")
if not all([CLIENT_ID, CLIENT_SECRET, FLOW_ID, VERSION_ID]):
raise ValueError("Missing required environment variables")
# Initialize
flows_api = init_genesys_client(CLIENT_ID, CLIENT_SECRET, ENVIRONMENT)
publisher = FlowPublisher(flows_api, GIT_REPO_PATH)
# Step 1: Validate
logger.info("Starting validation for version %s", VERSION_ID)
is_valid, report = publisher.validate_flow(FLOW_ID, VERSION_ID)
if not is_valid:
logger.error("Validation failed. Aborting publish.")
return
# Step 2: Publish
logger.info("Triggering publish for version %s", VERSION_ID)
publish_id = publisher.publish_flow(
flow_id=FLOW_ID,
version_id=VERSION_ID,
release_version="2.4.1",
dependency_hash="sha256:a1b2c3d4e5f67890",
staged_rollout=True
if not publish_id:
logger.error("Publish trigger failed.")
return
# Step 3: Poll
logger.info("Polling publish job: %s", publish_id)
publish_success = publisher.poll_publish_status(FLOW_ID, VERSION_ID)
# Step 4: Health Check & Rollback
if publish_success:
health_ok = publisher.run_health_check(FLOW_ID)
if not health_ok:
logger.warning("Health check failed. Initiating rollback.")
publisher.rollback_to_previous_version(FLOW_ID, PREVIOUS_VERSION_ID)
else:
logger.warning("Publish failed. Initiating rollback.")
# Step 5: VCS Sync & Final Audit Export
if publish_success and health_ok:
publisher.export_and_sync_to_vcs(
FLOW_ID, VERSION_ID,
f"Deployed flow {FLOW_ID} version {VERSION_ID}"
# Export audit log for compliance
with open("flow_publish_audit.json", "w") as f:
json.dump(publisher.audit_log, f, indent=2, default=str)
logger.info("Publish workflow completed. Audit log written.")
main()
- Cause: The OAuth token expired or the client credentials are incorrect. The SDK cache may hold a stale token.
- Fix: Force token refresh by calling
platform_client.oauth_client.refresh_token()or restart the process with valid environment variables. Ensure theoauth_access_token_urlmatches your environment region.
Error: 403 Forbidden
- Cause: The OAuth client lacks required scopes. Publishing requires
flow:publishandflow:write. Validation requiresflow:validateandflow:read. - Fix: Update the OAuth client in the Genesys Cloud admin console under Integrations. Assign all required scopes. Regenerate the client secret if scopes were added after initial creation.
Error: 400 Bad Request (Validation Failures)
- Cause: The flow graph contains broken references, invalid JSONata expressions, or exceeds resource limits (e.g., maximum queue wait times, unsupported node types).
- Fix: Parse the
validationResultsarray from the validate response. Filter forseverity: "error". Update the flow definition in the Genesys UI or via the flow definition API before retrying.
- Cause: Polling the publish status endpoint too frequently triggers rate limits. Genesys Cloud enforces per-tenant and per-endpoint throttling.
- Fix: Implement exponential backoff. The provided
poll_publish_statusmethod doubles the wait time up to 60 seconds. AddRetry-Afterheader parsing if the response includes it.
Error: Publish Job Stuck in publishing
- Cause: Large flows with complex routing logic or heavy dependency graphs may exceed the default timeout. The background job is still processing.
- Fix: Increase
timeout_secondsin the polling function. Monitor theestimatedTimeRemainingSecondsfield in the status response. If the job exceeds expected bounds, check Genesys Cloud system status for background job queue delays.
