Provisioning NICE CXone Users with Custom SCIM Attributes and Conflict Resolution in Go
- You will build a Go script that provisions NICE CXone users by mapping Active Directory extension attributes to CXone SCIM user extensions.
- The script uses the NICE CXone SCIM 2.0 API to create users and automatically converts 409 Conflict responses into PATCH updates for existing records.
- The implementation covers OAuth 2.0 client credentials authentication, JSON payload construction, and production-ready error handling.
- OAuth 2.0 Client Credentials grant type with
scim:users:writeandscim:users:readscopes - NICE CXone API environment identifier (for example,
us-east-1.api.cxone.com) - Go 1.21 or higher
- Standard library only (
net/http,encoding/json,context,time,fmt,log,os,net/url)
NICE CXone uses a standard OAuth 2.0 Client Credentials flow. The token endpoint lives under the .auth subdomain of your environment. You must cache the token and refresh it before expiration. The CXone API returns an expires_in field in seconds. The following Go implementation fetches the token, stores it in memory, and validates expiration before each API call.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"sync"
"time"
type OAuthResponse struct {
type TokenManager struct {
mu sync.Mutex
token *OAuthResponse
fetchedAt time.Time
clientID string
clientSecret string
authURL string
httpClient *http.Client
func NewTokenManager(clientID, clientSecret, env string) *TokenManager {
return &TokenManager{
clientID: clientID,
clientSecret: clientSecret,
authURL: fmt.Sprintf("https://%s.auth.cxone.com/oauth/token", env),
httpClient: &http.Client{Timeout: 10 * time.Second},
func (tm *TokenManager) GetToken(ctx context.Context) (*OAuthResponse, error) {
tm.mu.Lock()
defer tm.mu.Unlock()
if tm.token != nil && time.Since(tm.fetchedAt) < time.Duration(tm.token.ExpiresIn-60)*time.Second {
return tm.token, nil
body := map[string]string{
"client_id": tm.clientID,
"client_secret": tm.clientSecret,
payload, err := json.Marshal(body)
if err != nil {
return nil, fmt.Errorf("failed to marshal oauth payload: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, tm.authURL, nil)
if err != nil {
return nil, fmt.Errorf("failed to create oauth request: %w", err)
req.SetBasicAuth(tm.clientID, tm.clientSecret)
resp, err := tm.httpClient.Do(req)
if err != nil {
return nil, fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("oauth token fetch returned status %d", resp.StatusCode)
var token OAuthResponse
if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
return nil, fmt.Errorf("failed to decode oauth response: %w", err)
tm.token = &token
tm.fetchedAt = time.Now()
The GetToken method uses a mutex to prevent concurrent duplicate requests. It subtracts sixty seconds from the expires_in value to create a safety buffer. The method returns a 401 error if the client credentials are invalid or the scope is missing.
Step 1: Construct the SCIM Payload and Map AD Attributes
SCIM 2.0 requires a specific schema structure. NICE CXone extends the base user schema with urn:nice:cxone:scim:schemas:extension:user:2.0. You must map your Active Directory extension attributes to CXone extension fields before provisioning. CXone expects the externalId field to remain stable across updates. This field acts as the primary deduplication key.
type ADUser struct {
UserPrincipalName string
GivenName string
Surname string
ExtensionAttr1 string // Maps to CXone extension
ExtensionAttr2 string // Maps to CXone costCenter
ExtensionAttr3 string // Maps to CXone department
type CXoneSCIMUser struct {
Schemas []string `json:"schemas"`
ExternalID string `json:"externalId"`
UserName string `json:"userName"`
Name struct {
GivenName string `json:"givenName"`
FamilyName string `json:"familyName"`
} `json:"name"`
Emails []struct {
Value string `json:"value"`
Primary bool `json:"primary"`
} `json:"emails"`
Active bool `json:"active"`
// CXone specific extension schema
Extension struct {
Extension string `json:"extension"`
CostCenter string `json:"costCenter"`
Department string `json:"department"`
} `json:"urn:nice:cxone:scim:schemas:extension:user:2.0"`
func buildSCIMPayload(adUser ADUser) CXoneSCIMUser {
return CXoneSCIMUser{
Schemas: []string{"urn:ietf:params:scim:schemas:core:2.0:User"},
ExternalID: adUser.UserPrincipalName, // Use UPN as stable externalId
UserName: adUser.UserPrincipalName,
GivenName: adUser.GivenName,
FamilyName: adUser.Surname,
Emails: []struct {
{Value: adUser.UserPrincipalName, Primary: true},
Active: true,
Extension: struct {
Extension: adUser.ExtensionAttr1,
CostCenter: adUser.ExtensionAttr2,
Department: adUser.ExtensionAttr3,
The externalId field prevents duplicate user creation when AD syncs run multiple times. CXone uses this field to locate existing records during conflict resolution. The extension schema object must match the exact URI registered in your CXone tenant configuration.
Step 2: POST User and Handle 409 Conflict with Fallback PATCH
The SCIM specification returns a 409 Conflict status when a user with the same externalId or userName already exists. The response body contains the existing user object. You must extract the id field and issue a PATCH request to update the record instead of failing the sync.
type SCIMResponse struct {
ID string `json:"id"`
type SCIMPatchOperation struct {
Op string `json:"op"`
Path string `json:"path,omitempty"`
Value any `json:"value,omitempty"`
type SCIMPatchPayload struct {
Operations []SCIMPatchOperation `json:"Operations"`
func provisionUser(ctx context.Context, tm *TokenManager, env string, adUser ADUser) error {
payload := buildSCIMPayload(adUser)
jsonBody, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("failed to marshal scim payload: %w", err)
token, err := tm.GetToken(ctx)
if err != nil {
return fmt.Errorf("failed to get oauth token: %w", err)
endpoint := fmt.Sprintf("https://%s.api.cxone.com/scim/v2/Users", env)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, endpoint, nil)
if err != nil {
return fmt.Errorf("failed to create post request: %w", err)
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token.AccessToken))
req.Header.Set("Accept", "application/scim+json")
req.Body = nil // We will set it in the retry wrapper or directly here
// Reassign body properly
req.Body = nil // Reset before assigning
req.Body = nil // Go requires io.ReadCloser. We will use a custom wrapper in the full example.
// For clarity in this step, we assume a helper that wraps []byte into io.ReadCloser.
The previous snippet shows the request construction. The actual HTTP execution requires body handling and status code routing. When the API returns 409, you parse the response body to locate the existing user ID. You then construct a PATCH payload targeting the extension schema path.
func handle409Conflict(ctx context.Context, tm *TokenManager, env string, existingID string, payload CXoneSCIMUser) error {
patchPayload := SCIMPatchPayload{
Operations: []SCIMPatchOperation{
Op: "replace",
Path: "urn:nice:cxone:scim:schemas:extension:user:2.0",
Value: payload.Extension,
Op: "replace",
Path: "active",
Value: payload.Active,
jsonPatch, err := json.Marshal(patchPayload)
if err != nil {
return fmt.Errorf("failed to marshal patch payload: %w", err)
token, _ := tm.GetToken(ctx)
endpoint := fmt.Sprintf("https://%s.api.cxone.com/scim/v2/Users/%s", env, existingID)
req, _ := http.NewRequestWithContext(ctx, http.MethodPatch, endpoint, nil)
// Body assignment handled in full example via bytes.NewReader
The PATCH operation uses replace to overwrite the entire extension block. This approach avoids partial update complications and ensures the CXone record matches the AD source exactly. The active field is explicitly patched because SCIM does not automatically synchronize deactivation states.
Step 3: Implement Retry Logic for 429 Rate Limits and Network Errors
CXone enforces rate limits at the tenant and endpoint level. A 429 response includes a Retry-After header. Your integration must parse this header and wait before retrying. The following wrapper handles exponential backoff for transient errors and strict header compliance for 429s.
func executeWithRetry(ctx context.Context, req *http.Request, maxRetries int) (*http.Response, error) {
var lastErr error
for attempt := 0; attempt <= maxRetries; attempt++ {
if attempt > 0 {
backoff := time.Duration(1<<uint(attempt)) * time.Second
if backoff > 10*time.Second {
backoff = 10 * time.Second
select {
case <-ctx.Done():
return nil, ctx.Err()
case <-time.After(backoff):
// Clone request because body is consumed after first read
reqClone := req.Clone(ctx)
if req.Body != nil {
bodyBytes, _ := io.ReadAll(req.Body)
req.Body = io.NopCloser(bytes.NewReader(bodyBytes))
reqClone.Body = io.NopCloser(bytes.NewReader(bodyBytes))
resp, err := client.Do(reqClone)
if err != nil {
lastErr = fmt.Errorf("http request failed: %w", err)
retryAfter := resp.Header.Get("Retry-After")
if retryAfter != "" {
seconds, _ := strconv.Atoi(retryAfter)
if seconds > 0 {
time.Sleep(time.Duration(seconds) * time.Second)
return nil, fmt.Errorf("rate limited (429), retry-after not parseable")
return resp, nil
return nil, fmt.Errorf("max retries (%d) exceeded: %w", maxRetries, lastErr)
The retry wrapper clones the request to reset the io.ReadCloser body stream. It respects the Retry-After header when present. For non-429 transient errors, it applies exponential backoff capped at ten seconds. This pattern prevents cascading 429 responses across your microservices.
The following script combines authentication, payload construction, conflict resolution, and retry logic into a single executable module. Replace the environment variables with your CXone tenant credentials.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"log"
"net/http"
"os"
"strconv"
"sync"
"time"
// [OAuth and TokenManager structs omitted for brevity, identical to Authentication Setup section]
// [ADUser, CXoneSCIMUser, SCIMResponse, SCIMPatchOperation, SCIMPatchPayload structs omitted]
func main() {
ctx := context.Background()
env := os.Getenv("CXONE_ENV")
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
if env == "" || clientID == "" || clientSecret == "" {
log.Fatal("Missing required environment variables: CXONE_ENV, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET")
tm := NewTokenManager(clientID, clientSecret, env)
adUser := ADUser{
UserPrincipalName: "jdoe@example.com",
GivenName: "Jane",
Surname: "Doe",
ExtensionAttr1: "5402",
ExtensionAttr2: "FIN-OPS",
ExtensionAttr3: "Finance",
if err := provisionAndSync(ctx, tm, env, adUser); err != nil {
log.Fatalf("Provisioning failed: %v", err)
log.Println("User provisioning completed successfully")
func provisionAndSync(ctx context.Context, tm *TokenManager, env string, adUser ADUser) error {
if err != nil {
return fmt.Errorf("marshal failed: %w", err)
if err != nil {
return fmt.Errorf("token fetch failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, endpoint, bytes.NewReader(jsonBody))
if err != nil {
return fmt.Errorf("request creation failed: %w", err)
resp, err := executeWithRetry(ctx, req, 3)
if err != nil {
return fmt.Errorf("post request failed: %w", err)
if resp.StatusCode == http.StatusCreated {
log.Printf("User created successfully: %s", resp.Header.Get("Location"))
return nil
if resp.StatusCode == http.StatusConflict {
var existing SCIMResponse
if err := json.NewDecoder(resp.Body).Decode(&existing); err != nil {
return fmt.Errorf("failed to parse 409 response: %w", err)
log.Printf("User already exists (ID: %s). Triggering update...", existing.ID)
return handle409Conflict(ctx, tm, env, existing.ID, payload)
return fmt.Errorf("unexpected status code: %d", resp.StatusCode)
Op: "replace",
Op: "replace",
Path: "active",
if err != nil {
return fmt.Errorf("patch marshal failed: %w", err)
req, _ := http.NewRequestWithContext(ctx, http.MethodPatch, endpoint, bytes.NewReader(jsonPatch))
if err != nil {
return fmt.Errorf("patch request failed: %w", err)
if resp.StatusCode == http.StatusOK || resp.StatusCode == http.StatusNoContent {
log.Printf("User updated successfully: %s", existingID)
return nil
return fmt.Errorf("patch failed with status: %d", resp.StatusCode)
// [TokenManager and executeWithRetry implementations identical to previous sections]
The script runs as a standalone binary. It fetches the OAuth token, constructs the SCIM payload, attempts creation, catches the 409 conflict, extracts the user ID, and patches the extension attributes. The retry wrapper ensures resilience against transient network failures and API throttling.
- Cause: The OAuth client credentials are invalid, the token has expired, or the
scim:users:writescope is missing. - Fix: Verify the client ID and secret in the CXone Admin Console under API Clients. Ensure the scope list includes
scim:users:write. Check that the token endpoint URL matches your environment subdomain. - Code fix: The
TokenManageralready handles expiration, but you must log the raw response body when status is 401 to identify missing scopes.
Error: 409 Conflict
- Cause: A user with the same
externalIdoruserNamealready exists in CXone. - Fix: This is expected behavior during incremental syncs. The script automatically routes to the PATCH handler. Verify that the
externalIdmapping in AD remains immutable. - Code fix: Ensure the 409 response body is decoded into the
SCIMResponsestruct. If CXone returns an empty body, fall back to querying/scim/v2/Users?filter=userName+eq+"jdoe@example.com".
- Cause: You exceeded the CXone SCIM rate limit. The limit applies per tenant and resets based on the
Retry-Afterheader. - Fix: Implement the retry wrapper shown in Step 3. Do not ignore the
Retry-Afterheader. Spread concurrent provisioning requests across a worker pool with a semaphore. - Code fix: The
executeWithRetryfunction parses the header and sleeps accordingly. Verify your Gostrconv.Atoicall handles integer conversion safely.
- Cause: CXone encountered a backend validation failure, usually due to an invalid extension schema path or malformed JSON.
- Fix: Validate the extension schema URI matches your tenant configuration exactly. Ensure all JSON field names use camelCase as required by SCIM 2.0.
- Code fix: Log the full request payload and response body. Compare the
urn:nice:cxone:scim:schemas:extension:user:2.0path against the CXone SCIM documentation.
