Provision Genesys Cloud Telephony Numbers via Java SDK with Async Jobs and Compliance Validation
- A Java module that validates, provisions, and tracks telephony numbers using asynchronous job processing, enforces location-based compliance, and syncs status to external ITSM platforms via webhooks.
- The implementation uses the Genesys Cloud Java REST SDK to interact with telephony, validation, and platform webhook endpoints.
- The tutorial covers Java 17+ with production-ready error handling, retry logic, and audit tracking.
- OAuth 2.0 client credentials with scopes:
telephony:numbers:write,telephony:numbers:read,telephony:location:read,webhook:write,job:write - Genesys Cloud Java REST SDK v16.0.0 or later
- Java 17+ runtime
- Maven or Gradle dependency management
- External dependency:
com.fasterxml.jackson.core:jackson-databind:2.15.2for JSON serialization
Genesys Cloud API requires OAuth 2.0 client credentials flow. The SDK handles token acquisition and automatic refresh when configured correctly.
import com.genesyscloud.platform.client.Configuration;
import com.genesyscloud.platform.client.auth.OAuth;
public class GenesysAuth {
public static Configuration buildConfiguration(String clientId, String clientSecret, String basePath) {
Configuration config = new Configuration();
config.setBasePath(basePath);
config.setClientId(clientId);
config.setClientSecret(clientSecret);
config.setAuthFlow("client_credentials");
// SDK automatically caches and refreshes tokens
return config;
Step 1: Validate Number Availability and Compliance Matrix
Before provisioning, you must verify number availability and cross-reference location-based routing rules. The validation endpoint returns carrier compatibility and regulatory constraints.
HTTP Request Cycle
POST /api/v2/telephony/providers/edges/numbers/validate HTTP/1.1
Host: api.mypurecloud.com
"countryCode": "US",
"numbers": ["+14155552671"],
"validationType": "full"
Expected Response
"valid": true,
"numbers": [
"number": "+14155552671",
"valid": true,
"carrier": "Bandwidth",
"type": "local",
"locationId": "8f3a1c2d-4e5f-6a7b-8c9d-0e1f2a3b4c5d",
"restrictions": []
Java SDK Implementation
import com.genesyscloud.platform.client.ApiException;
import com.genesyscloud.platform.client.TelephonyProvidersEdgesApi;
import com.genesyscloud.platform.client.model.NumberValidationRequest;
import com.genesyscloud.platform.client.model.NumberValidationResponse;
public class NumberValidator {
private final TelephonyProvidersEdgesApi telephonyEdgesApi;
public NumberValidator(TelephonyProvidersEdgesApi api) {
this.telephonyEdgesApi = api;
public NumberValidationResponse validateNumber(String countryCode, String phoneNumber) throws ApiException {
NumberValidationRequest request = new NumberValidationRequest()
.countryCode(countryCode)
.numbers(List.of(phoneNumber))
.validationType("full");
return telephonyEdgesApi.postTelephonyProvidersEdgesNumbersValidate(request);
} catch (ApiException e) {
if (e.getCode() == 429) {
throw new RuntimeException("Rate limit exceeded. Implement backoff.", e);
if (e.getCode() >= 500) {
throw new RuntimeException("Transient service failure. Retry required.", e);
throw new RuntimeException("Validation failed: " + e.getResponseBody(), e);
Step 2: Construct Provisioning Payload with Location and Routing Targets
The provisioning payload must include the target user or queue, location identifier, and routing configuration. Compliance matrices require explicit location binding to prevent regulatory violations.
import com.genesyscloud.platform.client.model.NumberProvisioningRequest;
public class ProvisioningPayloadBuilder {
public static NumberProvisioningRequest buildPayload(
String userId,
String phoneNumber,
String locationId,
String routingTargetId,
String description) {
return new NumberProvisioningRequest()
.userId(userId)
.number(phoneNumber)
.locationId(locationId)
.routingTargetId(routingTargetId)
.description(description)
.autoProvision(true);
Step 3: Submit Async Provisioning Job with Retry Logic
Genesys Cloud provisioning operations can experience transient delays. You must wrap the call in an async processor with exponential backoff for 429 and 5xx responses.
import com.genesyscloud.platform.client.TelephonyUsersApi;
import com.genesyscloud.platform.client.model.NumberProvisioningResponse;
import java.util.concurrent.*;
public class AsyncProvisioningExecutor {
private final TelephonyUsersApi telephonyUsersApi;
private final ScheduledExecutorService scheduler = Executors.newScheduledThreadPool(2);
public AsyncProvisioningExecutor(TelephonyUsersApi api) {
this.telephonyUsersApi = api;
public NumberProvisioningResponse provisionWithRetry(
NumberProvisioningRequest payload,
int maxRetries,
long initialDelayMs) throws Exception {
long delay = initialDelayMs;
for (int attempt = 1; attempt <= maxRetries; attempt++) {
return telephonyUsersApi.postTelephonyUsersNumbers(payload);
if (e.getCode() == 429 || (e.getCode() >= 500 && e.getCode() < 600)) {
if (attempt == maxRetries) throw e;
System.out.println("Transient failure (HTTP " + e.getCode() + "). Retrying in " + delay + "ms...");
Thread.sleep(delay);
delay *= 2;
} else {
throw e;
throw new IllegalStateException("Provisioning loop exhausted");
Step 4: Synchronize Status with External ITSM via Webhook Callbacks
Register a webhook to notify your IT service management platform when provisioning completes or fails. The webhook must target an HTTPS endpoint capable of verifying Genesys Cloud signatures.
import com.genesyscloud.platform.client.PlatformWebhooksApi;
import com.genesyscloud.platform.client.model.Webhook;
import com.genesyscloud.platform.client.model.WebhookEvent;
import com.genesyscloud.platform.client.model.WebhookDestination;
public class WebhookSyncManager {
private final PlatformWebhooksApi webhookApi;
public WebhookSyncManager(PlatformWebhooksApi api) {
this.webhookApi = api;
public String registerItpsWebhook(String webhookUrl, String orgId) throws ApiException {
WebhookEvent event = new WebhookEvent()
.eventType("telephony.users.numbers.created")
.eventFilter("userId eq '" + orgId + "'");
WebhookDestination destination = new WebhookDestination()
.url(webhookUrl)
.httpMethod("POST")
.contentType("application/json");
Webhook webhook = new Webhook()
.name("ITSM Number Provisioning Sync")
.enabled(true)
.events(List.of(event))
.destinations(List.of(destination));
return webhookApi.postPlatformWebhooksWebhooks(webhook).getId();
Step 5: Track Latency, Audit Logs, and Validation Success Rates
Operational optimization requires deterministic tracking of provisioning duration, validation outcomes, and compliance checks. The audit logger captures timestamps and success metrics for regulatory verification.
import java.time.Instant;
import java.util.ArrayList;
import java.util.List;
import java.util.concurrent.atomic.AtomicInteger;
public record ProvisioningAuditEntry(
String phoneNumber,
String locationId,
Instant startedAt,
Instant completedAt,
long latencyMs,
boolean validated,
boolean provisioned,
String status) {}
public class ProvisioningMetricsTracker {
private final List<ProvisioningAuditEntry> auditLog = new ArrayList<>();
private final AtomicInteger successCount = new AtomicInteger(0);
private final AtomicInteger failureCount = new AtomicInteger(0);
public void recordEntry(ProvisioningAuditEntry entry) {
auditLog.add(entry);
if (entry.provisioned()) {
successCount.incrementAndGet();
} else {
failureCount.incrementAndGet();
public double getSuccessRate() {
int total = successCount.get() + failureCount.get();
return total == 0 ? 0.0 : (double) successCount.get() / total;
public List<ProvisioningAuditEntry> getAuditLog() {
return List.copyOf(auditLog);
The following module integrates validation, compliance checking, async provisioning, webhook registration, and audit tracking into a single executable class. Replace placeholder credentials and identifiers with your environment values.
public class NumberProvisioner {
private final TelephonyUsersApi usersApi;
private final TelephonyProvidersEdgesApi edgesApi;
private final PlatformWebhooksApi webhooksApi;
private final ProvisioningMetricsTracker metrics;
public NumberProvisioner(Configuration config) {
usersApi = new TelephonyUsersApi(config);
edgesApi = new TelephonyProvidersEdgesApi(config);
webhooksApi = new PlatformWebhooksApi(config);
metrics = new ProvisioningMetricsTracker();
public void runProvisioningWorkflow(String phoneNumber, String userId, String locationId, String itsmWebhookUrl) throws Exception {
Instant startedAt = Instant.now();
boolean validated = false;
boolean provisioned = false;
String status = "pending";
// Step 1: Validate availability
NumberValidationResponse validation = new NumberValidator(edgesApi)
.validateNumber("US", phoneNumber);
if (validation.getNumbers() == null || validation.getNumbers().isEmpty()) {
throw new RuntimeException("Number validation returned empty results");
validated = validation.getNumbers().get(0).getValid();
if (!validated) {
throw new RuntimeException("Number failed compliance or availability check");
// Step 2: Build payload
NumberProvisioningRequest payload = ProvisioningPayloadBuilder.buildPayload(
userId, phoneNumber, locationId, userId, "API Provisioned - Compliance Verified");
// Step 3: Async provision with retry
AsyncProvisioningExecutor executor = new AsyncProvisioningExecutor(usersApi);
NumberProvisioningResponse response = executor.provisionWithRetry(payload, 3, 1000);
provisioned = response != null && response.getSuccess();
status = provisioned ? "provisioned" : "failed";
// Step 4: Register webhook for ITSM sync
if (provisioned) {
new WebhookSyncManager(webhooksApi).registerItpsWebhook(itsmWebhookUrl, userId);
} catch (Exception e) {
status = "error: " + e.getMessage();
throw e;
} finally {
Instant completedAt = Instant.now();
long latencyMs = java.time.Duration.between(startedAt, completedAt).toMillis();
metrics.recordEntry(new ProvisioningAuditEntry(
phoneNumber, locationId, startedAt, completedAt, latencyMs, validated, provisioned, status));
System.out.println("Provisioning complete. Success rate: " + metrics.getSuccessRate());
public static void main(String[] args) throws Exception {
Configuration config = GenesysAuth.buildConfiguration(
"YOUR_CLIENT_ID",
"YOUR_CLIENT_SECRET",
"https://api.mypurecloud.com"
NumberProvisioner provisioner = new NumberProvisioner(config);
provisioner.runProvisioningWorkflow(
"+14155552671",
"loc-12345-us-west",
"https://itsm.example.com/webhooks/genesys-numbers"
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify
clientIdandclientSecret. Ensure the SDK configuration usesclient_credentialsflow. The SDK refreshes tokens automatically, but initial authentication must succeed. - Code Fix: Add explicit token validation before API calls.
if (config.getAccessToken() == null || config.getAccessToken().isEmpty()) {
throw new IllegalStateException("OAuth initialization failed. Check credentials.");
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient user permissions.
- Fix: Add
telephony:numbers:writeandtelephony:location:readto the OAuth client. Verify the authenticated user belongs to an organization with telephony entitlements. - Code Fix: Log the exact scope mismatch returned in the response body.
if (e.getCode() == 403) {
System.err.println("Missing scope: " + e.getResponseBody());
Error: 409 Conflict
- Cause: Number already assigned to another routing target or location.
- Fix: Query existing assignments using
GET /api/v2/telephony/users/numbers?userId={userId}before provisioning. Unassign or reuse the existing number. - Code Fix: Implement pre-flight check.
if (usersApi.getTelephonyUsersNumbers(userId, null, null, null, null, null).getEntities().stream()
.anyMatch(n -> n.getNumber().equals(phoneNumber))) {
throw new IllegalStateException("Number already assigned to this user");
- Cause: Exceeded Genesys Cloud rate limits for telephony or webhook endpoints.
- Fix: The
AsyncProvisioningExecutorimplements exponential backoff. IncreaseinitialDelayMsandmaxRetriesfor high-volume deployments. Implement request queuing for batch provisioning. - Code Fix: Adjust retry parameters.
NumberProvisioningResponse response = executor.provisionWithRetry(payload, 5, 2000);
Error: 5xx Service Unavailable
- Cause: Transient provisioning service degradation.
- Fix: Retry with increasing intervals. The SDK does not auto-retry 5xx responses. The provided executor handles this. Monitor Genesys Cloud status page for planned maintenance.
- Code Fix: Log 5xx attempts for capacity planning.
System.out.println("Service degraded. Attempt " + attempt + " of " + maxRetries);
