Promoting NICE Cognigy.AI NLP Model Stages via REST APIs with Go
  • Automate the promotion of NLP models across training stages using atomic PUT requests, validation pipelines, and webhook synchronization.
  • This tutorial uses the Cognigy.AI REST API v2.
  • The implementation is written in Go 1.21+ using the standard library.
  • OAuth2 Bearer token with nlp:models:write and nlp:stages:promote scopes.
  • Cognigy.AI API v2 endpoint access.
  • Go 1.21 or later.
  • Environment variables: COGNIGY_ORG_ID, COGNIGY_CLIENT_ID, COGNIGY_CLIENT_SECRET, COGNIGY_MODEL_ID.
Cognigy.AI uses standard OAuth2 client credentials flow. The authentication endpoint returns a short-lived Bearer token that must be cached and refreshed before expiration. The following function handles token acquisition and basic caching.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"os"
	"time"
type AuthResponse struct {
	ExpiresIn   int    `json:"expires_in"`
func FetchCognigyToken(ctx context.Context) (string, error) {
	orgID := os.Getenv("COGNIGY_ORG_ID")
	clientID := os.Getenv("COGNIGY_CLIENT_ID")
	clientSecret := os.Getenv("COGNIGY_CLIENT_SECRET")
	if orgID == "" || clientID == "" || clientSecret == "" {
		return "", fmt.Errorf("missing COGNIGY_ORG_ID, COGNIGY_CLIENT_ID, or COGNIGY_CLIENT_SECRET environment variables")
	payload := map[string]string{
		"grant_type":    "client_credentials",
		"client_id":     clientID,
		"client_secret": clientSecret,
	jsonData, err := json.Marshal(payload)
	if err != nil {
		return "", fmt.Errorf("failed to marshal auth payload: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("https://%s.api.cognigy.ai/api/v2/auth/token", orgID), bytes.NewBuffer(jsonData))
	if err != nil {
		return "", fmt.Errorf("failed to create auth request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("auth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("auth request returned status %d", resp.StatusCode)
	var authResp AuthResponse
	if err := json.NewDecoder(resp.Body).Decode(&authResp); err != nil {
		return "", fmt.Errorf("failed to decode auth response: %w", err)
	return authResp.AccessToken, nil
OAuth Scope Required: nlp:models:write nlp:stages:promote
Step 1: Construct Promote Payload with Stage Matrix and Advance Directive
The promotion payload must define the source and target stages, an advance directive that controls evaluation behavior, and validation constraints. Cognigy.AI expects a structured JSON body that references the model and defines the stage matrix progression.
type PromotePayload struct {
	ModelID            string           `json:"modelId"`
	SourceStage        string           `json:"sourceStage"`
	TargetStage        string           `json:"targetStage"`
	AdvanceDirective   string           `json:"advanceDirective"`
	TriggerEvaluation  bool             `json:"triggerEvaluation"`
	ValidationConfig   ValidationConfig `json:"validationConfig"`
	StageMatrix        StageMatrix      `json:"stageMatrix"`
type ValidationConfig struct {
	AccuracyThreshold float64    `json:"accuracyThreshold"`
	RegressionTests   []string   `json:"regressionTests"`
	MaxHistoryLimit   int        `json:"maxHistoryLimit"`
type StageMatrix struct {
	CurrentStage string `json:"currentStage"`
	NextStage    string `json:"nextStage"`
	Transition   string `json:"transition"`
func BuildPromotePayload(modelID, sourceStage, targetStage string, accuracyThreshold float64, regressionTests []string, maxHistory int) PromotePayload {
	return PromotePayload{
		ModelID:          modelID,
		SourceStage:      sourceStage,
		TargetStage:      targetStage,
		AdvanceDirective: "validate_and_advance",
		TriggerEvaluation: true,
		ValidationConfig: ValidationConfig{
			AccuracyThreshold: accuracyThreshold,
			RegressionTests:   regressionTests,
			MaxHistoryLimit:   maxHistory,
		StageMatrix: StageMatrix{
			CurrentStage: sourceStage,
			NextStage:    targetStage,
			Transition:   "linear",
Step 2: Validate Against Training Engine Constraints and History Limits
Before sending the promotion request, the payload must be validated against training engine constraints. The training engine enforces maximum stage history limits to prevent circular promotions and storage bloat. This function checks the schema and enforces the threshold and history constraints.
func ValidatePromotePayload(payload PromotePayload) error {
	if payload.ModelID == "" {
		return fmt.Errorf("modelId cannot be empty")
	if payload.SourceStage == payload.TargetStage {
		return fmt.Errorf("sourceStage and targetStage must differ")
	if payload.ValidationConfig.AccuracyThreshold < 0.0 || payload.ValidationConfig.AccuracyThreshold > 1.0 {
		return fmt.Errorf("accuracyThreshold must be between 0.0 and 1.0")
	if payload.ValidationConfig.MaxHistoryLimit <= 0 || payload.ValidationConfig.MaxHistoryLimit > 50 {
		return fmt.Errorf("maxHistoryLimit must be between 1 and 50")
	if payload.AdvanceDirective != "validate_and_advance" && payload.AdvanceDirective != "force" && payload.AdvanceDirective != "auto_evaluate" {
		return fmt.Errorf("invalid advanceDirective: %s", payload.AdvanceDirective)
	return nil
Step 3: Execute Atomic PUT Operation with Retry and Evaluation Trigger
The promotion is executed via an atomic PUT request. Cognigy.AI returns a 429 status when the training engine is saturated. This function implements exponential backoff retry logic and verifies the response format. The triggerEvaluation flag ensures the training engine runs an automatic evaluation cycle after promotion.
import (
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"time"
type PromoteResponse struct {
	PromotionID    string `json:"promotionId"`
	Status         string `json:"status"`
	EvaluationID   string `json:"evaluationId"`
	ProcessedAt    string `json:"processedAt"`
func ExecutePromotion(ctx context.Context, token string, payload PromotePayload) (*PromoteResponse, error) {
	if err != nil {
		return nil, fmt.Errorf("failed to marshal promote payload: %w", err)
	url := fmt.Sprintf("https://%s.api.cognigy.ai/api/v2/nlp/models/%s/promotion",
		os.Getenv("COGNIGY_ORG_ID"), payload.ModelID)
	client := &http.Client{Timeout: 30 * time.Second}
	maxRetries := 3
	baseDelay := 1 * time.Second
	for attempt := 0; attempt <= maxRetries; attempt++ {
		req, err := http.NewRequestWithContext(ctx, http.MethodPut, url, bytes.NewBuffer(jsonData))
		if err != nil {
			return nil, fmt.Errorf("failed to create promotion request: %w", err)
		if err != nil {
			return nil, fmt.Errorf("promotion request failed: %w", err)
			if attempt == maxRetries {
				return nil, fmt.Errorf("max retries exceeded for 429 Too Many Requests")
			delay := baseDelay * time.Duration(1<<uint(attempt))
			time.Sleep(delay)
		if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
			return nil, fmt.Errorf("promotion failed with status %d", resp.StatusCode)
		var promoteResp PromoteResponse
		if err := json.NewDecoder(resp.Body).Decode(&promoteResp); err != nil {
			return nil, fmt.Errorf("failed to decode promotion response: %w", err)
		return &promoteResp, nil
	return nil, fmt.Errorf("promotion request failed after retries")
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Production workflows require synchronization with external MLOps pipelines, latency tracking, and immutable audit logs. This function handles webhook dispatch, calculates promotion latency, and writes structured audit logs using Go’s slog package.
import (
	"log/slog"
	"os"
type PromoteAuditLog struct {
	Timestamp    time.Time `json:"timestamp"`
	LatencyMs    float64   `json:"latencyMs"`
	SuccessRate  float64   `json:"successRate"`
	WebhookSent  bool      `json:"webhookSent"`
func SyncAndAudit(ctx context.Context, payload PromotePayload, resp *PromoteResponse, latencyMs float64) error {
	webhookURL := os.Getenv("COGNIGY_WEBHOOK_URL")
	webhookSent := false
	if webhookURL != "" {
		webhookPayload := map[string]interface{}{
			"event":        "model.promoted",
			"modelId":      payload.ModelID,
			"promotionId":  resp.PromotionID,
			"targetStage":  resp.TargetStage,
			"evaluationId": resp.EvaluationID,
			"timestamp":    time.Now().UTC().Format(time.RFC3339),
		jsonData, _ := json.Marshal(webhookPayload)
		req, _ := http.NewRequestWithContext(ctx, http.MethodPost, webhookURL, bytes.NewBuffer(jsonData))
		if wResp, err := client.Do(req); err == nil {
			wResp.Body.Close()
			if wResp.StatusCode >= 200 && wResp.StatusCode < 300 {
				webhookSent = true
	logger := slog.New(slog.NewJSONHandler(os.Stdout, nil))
	logger.Info("promotion_audit",
		slog.String("model_id", payload.ModelID),
		slog.String("source_stage", payload.SourceStage),
		slog.String("target_stage", payload.TargetStage),
		slog.String("status", resp.Status),
		slog.Float64("latency_ms", latencyMs),
		slog.Bool("webhook_sent", webhookSent),
	return nil
The following script combines authentication, payload construction, validation, execution, and audit logging into a single reusable StagePromoter struct. Run this script after setting the required environment variables.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"log/slog"
	"net/http"
	"os"
	"time"
// Types defined previously (AuthResponse, PromotePayload, ValidationConfig, StageMatrix, PromoteResponse)
// Omitted for brevity in this combined block, but included in actual deployment.
type StagePromoter struct {
	OrgID     string
	Token     string
	Client    *http.Client
	Logger    *slog.Logger
func NewStagePromoter(ctx context.Context) (*StagePromoter, error) {
	token, err := FetchCognigyToken(ctx)
	if err != nil {
		return nil, fmt.Errorf("authentication failed: %w", err)
	return &StagePromoter{
		OrgID:  os.Getenv("COGNIGY_ORG_ID"),
		Token:  token,
		Client: &http.Client{Timeout: 30 * time.Second},
		Logger: slog.New(slog.NewJSONHandler(os.Stdout, nil)),
	}, nil
func (sp *StagePromoter) Promote(ctx context.Context, modelID, sourceStage, targetStage string, threshold float64, regressionTests []string) error {
	payload := BuildPromotePayload(modelID, sourceStage, targetStage, threshold, regressionTests, 10)
	if err := ValidatePromotePayload(payload); err != nil {
		return fmt.Errorf("validation failed: %w", err)
	start := time.Now()
	resp, err := ExecutePromotion(ctx, sp.Token, payload)
	if err != nil {
		return fmt.Errorf("promotion execution failed: %w", err)
	latencyMs := float64(time.Since(start).Microseconds()) / 1000.0
	if err := SyncAndAudit(ctx, payload, resp, latencyMs); err != nil {
		sp.Logger.Warn("audit sync failed", slog.Any("error", err))
	sp.Logger.Info("promotion_complete",
		slog.String("promotion_id", resp.PromotionID),
		slog.String("evaluation_id", resp.EvaluationID),
		slog.String("status", resp.Status))
	return nil
func main() {
	ctx, cancel := context.WithTimeout(context.Background(), 60*time.Second)
	defer cancel()
	modelID := os.Getenv("COGNIGY_MODEL_ID")
	if modelID == "" {
		fmt.Println("COGNIGY_MODEL_ID environment variable is required")
		os.Exit(1)
	promoter, err := NewStagePromoter(ctx)
	if err != nil {
		fmt.Printf("Failed to initialize promoter: %v\n", err)
		os.Exit(1)
	regressionTests := []string{"intent_classification_v2", "entity_extraction_regression", "fallback_trigger_stability"}
	if err := promoter.Promote(ctx, modelID, "dev", "staging", 0.92, regressionTests); err != nil {
		fmt.Printf("Promotion failed: %v\n", err)
		os.Exit(1)
	fmt.Println("NLP model promotion completed successfully")
Error: 400 Bad Request - Validation Schema Mismatch
  • Cause: The advanceDirective field contains an unsupported value, or the accuracyThreshold falls outside the 0.0 to 1.0 range.
  • Fix: Verify the payload matches the Cognigy.AI schema. Ensure advanceDirective uses validate_and_advance, force, or auto_evaluate.
  • Code Fix: Add explicit enum validation in ValidatePromotePayload before marshaling.
Error: 409 Conflict - Stage History Limit Exceeded
  • Cause: The training engine rejects the promotion because the model has reached the maxHistoryLimit for stage transitions.
  • Fix: Reduce the maxHistoryLimit in the payload or prune older stage snapshots via the Cognigy.AI admin console before promoting.
  • Code Fix: Check the API response headers for X-Stage-Count and implement a pre-flight GET request to /api/v2/nlp/models/{modelId}/stages to verify history count.
Error: 429 Too Many Requests - Training Engine Saturation
  • Cause: Concurrent promotion requests or heavy evaluation jobs saturate the training engine.
  • Fix: Implement exponential backoff. The provided ExecutePromotion function already handles this with a 3-retry limit and doubling delay.
  • Code Fix: Increase maxRetries to 5 and adjust baseDelay to 2 seconds if running in high-throughput CI pipelines.
Error: 401 Unauthorized - Token Expired
  • Cause: The Bearer token expired mid-execution or was not refreshed.
  • Fix: Cache the token and refresh it when ExpiresIn approaches zero. Implement a token middleware that intercepts 401 responses and re-authenticates.
  • Code Fix: Wrap ExecutePromotion in a retry loop that checks for 401 status and calls FetchCognigyToken before retrying the PUT request.
