Programmatically Updating NICE Cognigy Knowledge Base Articles via REST API with Python Delta Synchronization
- A Python script that reads a local knowledge base dataset, compares it against the remote Cognigy Cloud state, and pushes only modified or new articles to minimize network payload and API calls.
- This tutorial uses the NICE Cognigy Cloud REST API v1 endpoints for knowledge base management.
- All code is written in Python 3.9+ using the
requestslibrary with explicit error handling, pagination, and retry logic.
- Cognigy Cloud tenant with API access enabled and a valid Knowledge Base ID
- Authentication: Bearer token obtained via
/api/v1/auth/loginor OAuth 2.0. Required permissions:knowledge-base:readandknowledge-base:write - API Version: Cognigy Cloud API v1
- Python 3.9 or higher
- External dependencies:
requests>=2.31.0,hashlib(standard library),time(standard library)
Cognigy Cloud uses a Bearer token authentication model. The token expires after a configurable period, typically 24 hours for standard API tokens. Production scripts must implement token caching and refresh logic to avoid repeated login calls. The following example demonstrates a simple in-memory cache with a time-to-live check.
import requests
import json
import os
import hashlib
COGNIGY_BASE_URL = os.getenv("COGNIGY_BASE_URL", "https://your-tenant.cloud.cognigy.com")
COGNIGY_USERNAME = os.getenv("COGNIGY_USERNAME")
COGNIGY_PASSWORD = os.getenv("COGNIGY_PASSWORD")
KNOWLEDGE_BASE_ID = os.getenv("COGNIGY_KB_ID")
class CognigyAuth:
def __init__(self, base_url: str, username: str, password: str):
self.username = username
self.password = password
self.session = requests.Session()
self.session.headers.update({"Content-Type": "application/json"})
def get_token(self) -> str:
if self.token and time.time() < self.token_expiry:
return self.token
login_url = f"{self.base_url}/api/v1/auth/login"
payload = {"username": self.username, "password": self.password}
response = self.session.post(login_url, json=payload)
response.raise_for_status()
data = response.json()
if "token" not in data:
raise ValueError("Authentication successful but no token returned in response.")
self.token = data["token"]
self.token_expiry = time.time() + 86400 # 24 hour cache
self.session.headers.update({"Authorization": f"Bearer {self.token}"})
return self.token
def ensure_auth(self) -> None:
self.get_token()
The ensure_auth method guarantees a valid token before any API call. The requests.Session object persists the Authorization header, reducing repetitive header injection.
Step 1: Fetch Remote Knowledge Base Articles with Pagination
The Cognigy API paginates knowledge base articles using limit and offset parameters. Fetching all articles at once causes memory bloat and increases the risk of timeout errors. The following function implements a pagination loop that collects all remote articles into a dictionary keyed by article ID.
def fetch_remote_articles(auth: CognigyAuth, kb_id: str, limit: int = 100) -> Dict[str, Any]:
articles = {}
offset = 0
while True:
endpoint = f"{auth.base_url}/api/v1/knowledge-bases/{kb_id}/articles"
params = {"limit": limit, "offset": offset}
response = auth.session.get(endpoint, params=params)
retry_after = int(response.headers.get("Retry-After", 5))
time.sleep(retry_after)
page_data = response.json()
if not page_data:
break
for article in page_data:
articles[article["id"]] = article
if len(page_data) < limit:
break
offset += limit
return articles
The function handles 429 rate limits by reading the Retry-After header. It breaks the loop when the returned array is empty or smaller than the requested limit, which indicates the end of the dataset. The resulting dictionary enables O(1) lookups during delta comparison.
Step 2: Compute Delta and Prepare Minimal Payloads
Delta synchronization requires comparing local content against remote content. Cognigy tracks modification timestamps via the updatedAt field. However, relying solely on timestamps can miss concurrent edits or cause redundant updates. A content hash of the core fields (question, answer, tags) provides deterministic change detection. The following function processes a local JSON dataset and returns only the articles that require creation or update.
def compute_content_hash(article: Dict[str, Any]) -> str:
content = f"{article.get('question', '')}|{article.get('answer', '')}|{json.dumps(article.get('tags', []), sort_keys=True)}"
return hashlib.sha256(content.encode("utf-8")).hexdigest()
def compute_delta(local_articles: list[Dict[str, Any]], remote_articles: Dict[str, Any]) -> Dict[str, Any]:
updates = {}
remote_hashes = {aid: compute_content_hash(a) for aid, a in remote_articles.items()}
for local in local_articles:
local_id = local.get("id")
local_hash = compute_content_hash(local)
if local_id and local_id in remote_articles:
remote_hash = remote_hashes[local_id]
if local_hash == remote_hash:
continue # Content matches, skip update
# Build minimal payload: only include fields that Cognigy accepts on PUT
updates[local_id] = {
"title": local["title"],
"question": local["question"],
"answer": local["answer"],
"tags": local.get("tags", [])
else:
# New article
return updates
The delta function excludes unchanged articles entirely. It strips metadata fields like createdAt, updatedAt, and version from the payload, which reduces JSON size and prevents 400 validation errors. Cognigy automatically generates or updates internal timestamps on successful PUT requests.
Step 3: Push Updates with Exponential Backoff
Bulk updates require careful rate limit management. The Cognigy API enforces per-tenant request limits. The following function pushes the delta payloads with exponential backoff and jitter for 429 responses. It also validates HTTP status codes and logs actionable feedback.
def push_updates(auth: CognigyAuth, kb_id: str, updates: Dict[str, Any]) -> Dict[str, str]:
results = {}
base_delay = 1.0
for article_id, payload in updates.items():
delay = base_delay
success = False
while not success:
endpoint = f"{auth.base_url}/api/v1/knowledge-bases/{kb_id}/articles/{article_id}"
# Cognigy uses POST for creation and PUT for updates.
# We detect creation by checking if ID exists in remote state.
# For simplicity, we use PUT which upserts in many Cognigy KB configurations.
# If your tenant uses strict separation, switch to POST when article_id is None or new.
response = auth.session.put(endpoint, json=payload)
retry_after = float(response.headers.get("Retry-After", delay))
print(f"Rate limited on {article_id}. Retrying in {retry_after:.1f}s")
delay = min(delay * 2, 30.0) # Cap at 30 seconds
if response.status_code == 400:
print(f"Bad request for {article_id}: {response.text}")
results[article_id] = "FAILED_400"
success = True
if response.status_code == 404:
print(f"Knowledge base or article not found for {article_id}")
results[article_id] = "FAILED_404"
success = True
results[article_id] = "SUCCESS"
success = True
print(f"Processed {article_id}: {results[article_id]}")
return results
The retry loop doubles the delay on consecutive 429 responses, capped at 30 seconds to prevent indefinite blocking. The function records outcomes per article, enabling downstream reporting or retry queues for failed items.
The following script combines authentication, remote fetching, delta computation, and payload pushing into a single executable module. It reads a local JSON file named local_kb_articles.json containing an array of article objects.
import requests
import json
import os
import hashlib
LOCAL_DATA_FILE = os.getenv("LOCAL_KB_FILE", "local_kb_articles.json")
class CognigyAuth:
return self.token
return self.token
self.get_token()
articles = {}
offset = 0
while True:
if not page_data:
break
break
offset += limit
return articles
updates = {}
else:
return updates
results = {}
base_delay = 1.0
delay = base_delay
success = False
while not success:
success = True
success = True
success = True
return results
def main():
auth = CognigyAuth(COGNIGY_BASE_URL, COGNIGY_USERNAME, COGNIGY_PASSWORD)
auth.ensure_auth()
print(f"Fetching remote articles for KB {KNOWLEDGE_BASE_ID}...")
remote_articles = fetch_remote_articles(auth, KNOWLEDGE_BASE_ID)
print(f"Fetched {len(remote_articles)} remote articles.")
with open(LOCAL_DATA_FILE, "r", encoding="utf-8") as f:
local_articles = json.load(f)
print(f"Computing delta against {len(local_articles)} local articles...")
updates = compute_delta(local_articles, remote_articles)
print(f"Identified {len(updates)} articles to update or create.")
if not updates:
print("No changes detected. Exiting.")
return
print("Pushing updates...")
results = push_updates(auth, KNOWLEDGE_BASE_ID, updates)
success_count = sum(1 for r in results.values() if r == "SUCCESS")
fail_count = len(results) - success_count
print(f"Sync complete. Success: {success_count}, Failed: {fail_count}")
main()
The script requires environment variables for credentials and the knowledge base ID. It executes sequentially: authenticate, fetch, compare, update. The delta computation prevents unnecessary network transfers and reduces API quota consumption.
- What causes it: The Bearer token expired or the login credentials are invalid.
- How to fix it: Verify environment variables. Ensure the
CognigyAuthclass refreshes the token before API calls. Check the Cognigy tenant audit logs for disabled API access. - Code showing the fix: The
ensure_authmethod validates token expiry againsttime.time()and re-authenticates automatically.
Error: 403 Forbidden
- What causes it: The authenticated user lacks
knowledge-base:writepermissions or the Knowledge Base ID belongs to a different tenant. - How to fix it: Assign the required role in the Cognigy admin console. Verify the
KNOWLEDGE_BASE_IDmatches the target tenant URL. - Code showing the fix: Wrap API calls in a try-except block that catches
requests.exceptions.HTTPErrorand checksresponse.status_code == 403to log actionable permission errors.
- What causes it: The tenant exceeded its request rate limit. Bulk operations trigger this frequently.
- How to fix it: Implement exponential backoff with jitter. Reduce the
limitparameter in pagination. Spread updates across multiple hours for large datasets. - Code showing the fix: The
push_updatesfunction readsRetry-Afterheaders and doubles the delay up to 30 seconds.
Error: 400 Bad Request
- What causes it: The payload contains invalid JSON, missing required fields, or unsupported characters in
question/answer. - How to fix it: Validate local data against Cognigy schema requirements. Ensure
tagsis an array of strings. Remove internal Cognigy fields likeversionorcreatedAtfrom the request body. - Code showing the fix: The
compute_deltafunction explicitly constructs minimal payloads containing onlytitle,question,answer, andtags.
