Programmatically Simulate and Validate Genesys Cloud Presence and Routing States with Python
A Python-based state simulator that programmatically updates user presence, validates routing constraints against capacity and skill availability, executes atomic state transitions, synchronizes with external test harnesses via presence webhooks, and generates audit logs for load testing. This tutorial uses the Genesys Cloud Presence and Routing APIs. The implementation covers Python using the official genesyscloud SDK and httpx.
  • OAuth Client Credentials flow with scopes: presence:write, routing:read, webhook:write, user:read, analytics:read
  • Genesys Cloud Python SDK version 2.0.0 or higher
  • Python 3.9 or higher
  • External dependencies: httpx>=0.24.0, pydantic>=2.0.0, tenacity>=8.2.0, python-dotenv>=1.0.0
  • A Genesys Cloud organization with at least one configured queue, skill, and presence status with capacity greater than zero
The Genesys Cloud Python SDK handles OAuth token acquisition and caching automatically when initialized with client credentials. You must configure the environment variables before running any SDK method.
import os
from genesyscloud import PlatformClient, OAuthClient
load_dotenv()
def initialize_platform_client() -> PlatformClient:
    """Initialize the Genesys Cloud SDK client with OAuth credentials."""
    client = PlatformClient()
    client.set_oauth_client_credentials(
        client_id=os.getenv("GENESYS_CLIENT_ID", ""),
        client_secret=os.getenv("GENESYS_CLIENT_SECRET", ""),
        base_url=os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
    # Verify token acquisition before proceeding
        token = client.oauth_client.get_token()
        if not token or not token.access_token:
            raise RuntimeError("OAuth token acquisition failed. Verify client credentials and scopes.")
        raise RuntimeError(f"Authentication initialization error: {e}")
    return client
The SDK caches the access token and automatically refreshes it when it expires. The presence:write scope is mandatory for state transitions, while routing:read enables constraint validation. The base URL must match your organization region.
Step 1: Validate Routing Constraints and Maximum Concurrent Session Limits
Before applying any presence state change, you must verify that the target user does not exceed routing constraints. The simulator queries the user routing configuration and queue skill requirements to prevent invalid state transitions.
import httpx
from genesyscloud.routing.api import RoutingApi, UsersApi
from genesyscloud.presence.api import PresenceApi
from typing import Dict, Any
def validate_routing_constraints(
    routing_api: RoutingApi,
    users_api: UsersApi,
    user_id: str,
    target_status_id: str,
    presence_api: PresenceApi
) -> Dict[str, Any]:
    Validate routing constraints before state simulation.
    Checks maximum concurrent sessions, skill availability, and capacity limits.
    validation_result = {
        "valid": True,
        "errors": [],
        "user_routing_config": None,
        "target_status_capacity": 0,
        "current_session_count": 0
        # Fetch user routing configuration
        user_routing = users_api.get_routing_user(user_id)
        validation_result["user_routing_config"] = user_routing.to_dict()
        # Fetch current presence status to determine active sessions
        current_status = presence_api.get_presence_user_status(user_id)
        validation_result["current_session_count"] = getattr(current_status, "active_sessions", 0) or 0
        # Fetch target presence status details
        target_status = presence_api.get_presence_status(target_status_id)
        validation_result["target_status_capacity"] = getattr(target_status, "capacity", 0) or 0
        # Constraint check: capacity must be positive for routing availability
        if validation_result["target_status_capacity"] <= 0:
            validation_result["valid"] = False
            validation_result["errors"].append("Target presence status has zero capacity. Routing will ignore this user.")
        # Constraint check: maximum concurrent sessions policy
        max_sessions = getattr(user_routing, "max_concurrent_sessions", None)
        if max_sessions and validation_result["current_session_count"] >= max_sessions:
            validation_result["errors"].append(f"User exceeds maximum concurrent session limit ({max_sessions}).")
        if e.response.status_code == 404:
            validation_result["errors"].append(f"User or presence status not found: {e}")
        else:
            validation_result["errors"].append(f"Routing validation failed with status {e.response.status_code}: {e}")
        validation_result["errors"].append(f"Unexpected validation error: {e}")
    return validation_result
This function returns a structured validation dictionary. The simulator halts the transition if valid is False. The capacity check ensures the user will actually receive routed interactions. The maximum concurrent session check prevents routing policy violations.
Step 2: Construct Atomic Presence State Payload and Execute PUT with Conflict Detection
Genesys Cloud requires atomic updates for presence state changes. You must construct a payload containing the state reference and emulate directive, then apply it using an If-Match header to prevent race conditions during load testing.
from genesyscloud.presence.models import PresenceUpdate
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
@retry(
    stop=stop_after_attempt(3),
    wait=wait_exponential(multiplier=1, min=2, max=10),
    retry=retry_if_exception_type(httpx.HTTPStatusError),
    reraise=True
def apply_atomic_presence_transition(
    presence_api: PresenceApi,
    user_id: str,
    current_etag: str | None = None
    Execute an atomic PUT operation for presence state simulation.
    Implements conflict detection and automatic retry for 429 rate limits.
    # Construct the emulate directive payload
    update_payload = PresenceUpdate(
        status_id=target_status_id,
        state="available" if target_status_id else "offline"
    headers = {}
    if current_etag:
        headers["If-Match"] = current_etag
        response = presence_api.put_presence_user_status(
            user_id=user_id,
            presence_update=update_payload,
            headers=headers
            "success": True,
            "status_code": 200,
            "new_etag": response.etag if hasattr(response, "etag") else None,
            "response_body": response.to_dict()
        if e.response.status_code == 409:
                "success": False,
                "status_code": 409,
                "error": "Conflict detected. Presence state changed concurrently during simulation.",
                "response_body": e.response.json()
        elif e.response.status_code == 429:
            raise  # Triggers tenacity retry
        else:
                "success": False,
                "status_code": e.response.status_code,
                "error": f"Routing API rejected transition: {e}",
            "success": False,
            "status_code": 500,
            "error": f"Unexpected transition failure: {e}",
            "response_body": None
The @retry decorator handles 429 rate limit cascades automatically. The If-Match header enforces optimistic locking. The function returns structured results for audit logging and policy override verification pipelines.
Step 3: Register State Webhook for External Harness Synchronization and Latency Tracking
External test harnesses require real-time alignment with simulated state changes. You will register a presence state change webhook, track latency, and calculate success rates.
from genesyscloud.platform.webhooks.api import WebhooksApi
from genesyscloud.platform.webhooks.models import Webhook
from typing import List
def register_state_simulation_webhook(
    webhooks_api: WebhooksApi,
    webhook_url: str,
    user_id: str
    Register a webhook to synchronize presence state changes with external test harnesses.
    webhook = Webhook(
        name=f"PresenceSimulator_{user_id}",
        enabled=True,
        api_version="v2",
        event_type="presence.userstatus.changed",
        target_url=webhook_url,
        filter=f"user.id eq '{user_id}'",
        auth_scheme="bearer",
        auth_token="sim-harness-token",  # Replace with actual harness token
        retry_count=3,
        retry_delay_seconds=5
        created_webhook = webhooks_api.post_platform_webhook(webhook)
            "success": True,
            "webhook_id": created_webhook.id,
            "event_type": created_webhook.event_type,
            "filter": created_webhook.filter
            "success": False,
            "error": f"Webhook registration failed: {e}",
def calculate_simulation_metrics(
    transitions: List[Dict[str, Any]]
) -> Dict[str, float]:
    Calculate latency and success rates for simulate efficiency tracking.
    if not transitions:
        return {"success_rate": 0.0, "avg_latency_ms": 0.0, "total_requests": 0}
    total = len(transitions)
    successful = sum(1 for t in transitions if t.get("success", False))
    # Simulated latency calculation based on request timestamps
    latencies = []
    for t in transitions:
        if t.get("start_time") and t.get("end_time"):
            latencies.append((t["end_time"] - t["start_time"]).total_seconds() * 1000)
    avg_latency = sum(latencies) / len(latencies) if latencies else 0.0
        "success_rate": successful / total,
        "avg_latency_ms": round(avg_latency, 2),
        "total_requests": total,
        "successful_requests": successful,
        "failed_requests": total - successful
The webhook filter restricts events to the simulated user. The metrics function computes success rates and average latency from transition logs. These values feed into the audit pipeline.
import os
import json
import httpx
load_dotenv()
class PresenceStateSimulator:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client = PlatformClient()
        self.client.set_oauth_client_credentials(
            client_id=client_id,
            client_secret=client_secret,
            base_url=base_url
        self.presence_api = PresenceApi(self.client)
        self.routing_api = RoutingApi(self.client)
        self.users_api = UsersApi(self.client)
        self.webhooks_api = WebhooksApi(self.client)
        self.transition_log: list[dict] = []
    def run_simulation_cycle(
        self,
        user_id: str,
        webhook_url: str,
    ) -> dict:
        start_time = datetime.now(timezone.utc)
        # Step 1: Validate routing constraints
        validation = validate_routing_constraints(
            self.routing_api, self.users_api, user_id, target_status_id, self.presence_api
        if not validation["valid"]:
                "success": False,
                "phase": "validation",
                "errors": validation["errors"],
                "timestamp": start_time.isoformat()
        # Step 2: Apply atomic presence transition
        transition = apply_atomic_presence_transition(
            self.presence_api, user_id, target_status_id, current_etag
        end_time = datetime.now(timezone.utc)
        transition["start_time"] = start_time
        transition["end_time"] = end_time
        transition["user_id"] = user_id
        transition["target_status_id"] = target_status_id
        self.transition_log.append(transition)
        # Step 3: Register webhook if first successful transition
        if transition["success"] and len(self.transition_log) == 1:
            webhook_result = register_state_simulation_webhook(
                self.webhooks_api, webhook_url, user_id
            transition["webhook_registered"] = webhook_result
        # Step 4: Calculate metrics and generate audit log
        metrics = calculate_simulation_metrics(self.transition_log)
        audit_entry = {
            "simulation_cycle": len(self.transition_log),
            "user_id": user_id,
            "target_status_id": target_status_id,
            "validation_passed": validation["valid"],
            "transition_success": transition["success"],
            "metrics": metrics,
            "timestamp": end_time.isoformat(),
            "etag_after_update": transition.get("new_etag")
        with open("presence_simulation_audit.jsonl", "a") as f:
            f.write(json.dumps(audit_entry) + "\n")
            "success": transition["success"],
            "metrics": metrics,
            "audit_entry": audit_entry,
            "new_etag": transition.get("new_etag")
def validate_routing_constraints(routing_api, users_api, user_id, target_status_id, presence_api):
    # Implementation from Step 1
    validation_result = {"valid": True, "errors": [], "user_routing_config": None, "target_status_capacity": 0, "current_session_count": 0}
            validation_result["errors"].append("Target presence status has zero capacity.")
        validation_result["errors"].append(f"HTTP {e.response.status_code}: {e}")
        validation_result["errors"].append(f"Validation error: {e}")
def apply_atomic_presence_transition(presence_api, user_id, target_status_id, current_etag=None):
    # Implementation from Step 2
    @retry(stop=stop_after_attempt(3), wait=wait_exponential(multiplier=1, min=2, max=10), retry=retry_if_exception_type(httpx.HTTPStatusError), reraise=True)
    def _execute():
        update_payload = PresenceUpdate(status_id=target_status_id, state="available" if target_status_id else "offline")
        headers = {"If-Match": current_etag} if current_etag else {}
            response = presence_api.put_presence_user_status(user_id=user_id, presence_update=update_payload, headers=headers)
            return {"success": True, "status_code": 200, "new_etag": getattr(response, "etag", None), "response_body": response.to_dict()}
                return {"success": False, "status_code": 409, "error": "Conflict detected.", "response_body": e.response.json()}
                raise
            else:
                return {"success": False, "status_code": e.response.status_code, "error": str(e), "response_body": e.response.json()}
            return {"success": False, "status_code": 500, "error": str(e), "response_body": None}
    return _execute()
def register_state_simulation_webhook(webhooks_api, webhook_url, user_id):
    # Implementation from Step 3
    webhook = Webhook(name=f"PresenceSimulator_{user_id}", enabled=True, api_version="v2", event_type="presence.userstatus.changed", target_url=webhook_url, filter=f"user.id eq '{user_id}'", auth_scheme="bearer", auth_token="sim-harness-token", retry_count=3, retry_delay_seconds=5)
        created = webhooks_api.post_platform_webhook(webhook)
        return {"success": True, "webhook_id": created.id, "event_type": created.event_type, "filter": created.filter}
def calculate_simulation_metrics(transitions):
    if not transitions:
    latencies = [(t["end_time"] - t["start_time"]).total_seconds() * 1000 for t in transitions if t.get("start_time") and t.get("end_time")]
    return {"success_rate": successful / total, "avg_latency_ms": round(avg_latency, 2), "total_requests": total, "successful_requests": successful, "failed_requests": total - successful}
    simulator = PresenceStateSimulator(
        base_url=os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com"),
    result = simulator.run_simulation_cycle(
        user_id="REPLACE_WITH_USER_ID",
        target_status_id="REPLACE_WITH_STATUS_ID",
        webhook_url="https://your-test-harness.example.com/webhook",
        current_etag=None
    print(json.dumps(result, indent=2, default=str))
This script initializes the SDK, validates constraints, executes the atomic transition, registers the webhook, calculates metrics, and writes JSONL audit logs. Replace the placeholder IDs and webhook URL with your environment values.
  • Cause: Missing or expired OAuth token, or missing presence:write scope on the client.
  • Fix: Verify the GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET values. Ensure the OAuth client in Genesys Cloud has the required scopes attached. The SDK refreshes tokens automatically, but initial credential validation must succeed.
  • Code Fix: Check the initialize_platform_client function output. If token acquisition fails, regenerate the client secret in the Genesys Cloud admin console.
Error: 403 Forbidden
  • Cause: The authenticated user lacks administrative permissions to modify presence states or register webhooks.
  • Fix: Assign the Presence Administrator or Webhook Administrator role to the service account. Verify the OAuth client is not restricted by IP allowlists.
  • Code Fix: Add explicit permission checks before calling put_presence_user_status or post_platform_webhook.
Error: 409 Conflict
  • Cause: Concurrent presence state modification detected via If-Match header mismatch.
  • Fix: Implement optimistic locking by fetching the latest ETag before the next simulation cycle. The retry decorator handles transient 429s, but 409 requires a fresh GET request.
  • Code Fix: Update current_etag in the simulation loop after each successful transition. Query GET /api/v2/presence/users/{userId}/status to retrieve the fresh ETag.
  • Cause: Exceeding Genesys Cloud rate limits during rapid simulation iterations.
  • Fix: The tenacity retry decorator implements exponential backoff. Reduce simulation concurrency or add a manual delay between cycles.
  • Code Fix: Adjust stop_after_attempt and wait_exponential parameters in the @retry decorator. Monitor Retry-After headers in response metadata.
  • Cause: Temporary routing service degradation or malformed payload structure.
  • Fix: Validate the PresenceUpdate model against the OpenAPI schema. Ensure status_id exists and belongs to an active presence configuration.
  • Code Fix: Wrap SDK calls in try-except blocks and log the raw response body. Retry after a fixed delay if the error persists.
