Programmatically Manage DNC List Suppression in CXone Using Python
  • A Python script that ingests a list of contact phone numbers, queries the NICE CXone DNC API to identify suppressed records, and updates the corresponding contact records to reflect their DNC status.
  • This implementation uses the CXone DNC API (/api/v2/dnc/records/query) and the Contact Management API (/api/v2/contacts/{id}) via the requests library.
  • The tutorial covers Python 3.9+ with strict type hints, cursor-based pagination handling, and exponential backoff for rate limiting.
  • OAuth client type: Machine-to-Machine (Client Credentials)
  • Required OAuth scopes: dnc:read, contacts:read, contacts:write
  • API version: CXone REST API v2
  • Language/runtime: Python 3.9 or higher
  • External dependencies: requests>=2.31.0, typing_extensions>=4.0.0 (for TypedDict compatibility)
  • A CXone domain in the format yourcompany.niceincontact.com
  • A list of contact records containing at minimum a phone number field and a CXone contact ID
CXone uses OAuth 2.0 Client Credentials flow for machine-to-machine integrations. The token endpoint varies by region, but follows a consistent pattern. You must cache the access token and refresh it before expiration to avoid unnecessary authentication requests.
The following class handles token acquisition, caching, and automatic refresh. It also establishes a persistent requests.Session for connection pooling and cookie management.
import requests
import logging
from typing import Optional
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
class CXoneAuth:
    def __init__(self, region: str, client_id: str, client_secret: str):
        self.region = region
        self.client_id = client_id
        self.auth_url = f"https://auth.{region}.engage.niceincontact.com/as/token.oauth2"
        self.api_base = f"https://{region}.niceincontact.com/api/v2"
        self.session = requests.Session()
        self.session.headers.update({
            "Accept": "application/json"
        self._access_token: Optional[str] = None
        self._token_expiry: float = 0.0
    def _fetch_token(self) -> str:
        payload = {
            "client_id": self.client_id,
            "scope": "dnc:read contacts:read contacts:write"
        response = self.session.post(self.auth_url, data=payload)
        response.raise_for_status()
        token_data = response.json()
        self._access_token = token_data["access_token"]
        self._token_expiry = time.time() + token_data["expires_in"] - 60
        logger.info("OAuth token acquired. Expires in %s seconds.", token_data["expires_in"])
        return self._access_token
        if not self._access_token or time.time() >= self._token_expiry:
            self._fetch_token()
            "Authorization": f"Bearer {self._access_token}",
The get_headers method checks the current time against the cached expiration timestamp. If the token has expired or will expire within sixty seconds, it triggers a refresh. This prevents mid-batch authentication failures during pagination loops.
Step 1: Query DNC Records with Pagination
The CXone DNC API accepts bulk phone number queries through POST /api/v2/dnc/records/query. The endpoint returns a paginated list of suppression records. You must handle pagination by incrementing the offset parameter until the number of returned records is less than the requested limit.
Required OAuth scope: dnc:read
def query_dnc_records(auth: CXoneAuth, phones: List[str], limit: int = 100) -> List[Dict[str, Any]]:
    all_records: List[Dict[str, Any]] = []
    offset = 0
    while offset < len(phones):
        batch = phones[offset:offset + limit]
        payload = {
            "phones": batch,
            "limit": limit,
            "offset": offset
        response = auth.session.post(
            f"{auth.api_base}/dnc/records/query",
            headers=auth.get_headers(),
            json=payload
            retry_after = int(response.headers.get("Retry-After", 5))
            logger.warning("Rate limited on DNC query. Retrying after %s seconds.", retry_after)
            time.sleep(retry_after)
        records = data.get("records", [])
        all_records.extend(records)
        if len(records) < limit:
            break
        offset += limit
        logger.info("Fetched %s DNC records. Offset: %s", len(all_records), offset)
    return all_records
The DNC API response contains a records array where each object includes phone, status, and type. The status field indicates whether the number is SUPPRESSED, NOT_SUPPRESSED, or PENDING. The type field indicates the scope of suppression, such as NATIONAL, STATE, or COMPANY. This script collects all records across pagination cycles before returning them.
Step 2: Map Suppressed Numbers to Contact Records
You must correlate the DNC query results with your internal contact list. The CXone contact records require the CXone-specific contact ID for updates. This step builds a lookup dictionary mapping phone numbers to contact IDs and identifies which contacts require a status update.
from typing import TypedDict
class ContactMapping(TypedDict):
    contact_id: str
    phone: str
    dnc_status: str
def map_suppressed_contacts(
    contacts: List[Dict[str, Any]],
    dnc_records: List[Dict[str, Any]]
) -> List[ContactMapping]:
    dnc_lookup = {record["phone"]: record["status"] for record in dnc_records}
    suppressed_mappings: List[ContactMapping] = []
    for contact in contacts:
        phone = contact.get("phone")
        contact_id = contact.get("id")
        if not phone or not contact_id:
        status = dnc_lookup.get(phone, "UNKNOWN")
        if status == "SUPPRESSED":
            suppressed_mappings.append({
                "contact_id": contact_id,
                "phone": phone,
                "dnc_status": status
    logger.info("Identified %s contacts requiring DNC status update.", len(suppressed_mappings))
    return suppressed_mappings
This function assumes your input contact list contains at least an id field (the CXone contact identifier) and a phone field. It filters only contacts with a SUPPRESSED status. You may adjust the status comparison to include PENDING or filter by type depending on your compliance requirements.
Step 3: Update Contact Statuses with Retry Logic
Updating contact records requires PATCH /api/v2/contacts/{contactId}. The CXone Contacts API expects a fields object containing the data to modify. You must implement retry logic for 429 Too Many Requests responses, as bulk contact updates frequently trigger rate limits.
Required OAuth scope: contacts:write
import json
def update_contact_dnc_status(auth: CXoneAuth, contact_id: str, dnc_status: str, max_retries: int = 3) -> bool:
    url = f"{auth.api_base}/contacts/{contact_id}"
    payload = {
        "fields": {
            "custom": {
                "dnc_suppression_status": dnc_status
            response = auth.session.patch(
                url,
                json=payload
            if response.status_code == 200:
                logger.info("Successfully updated contact %s with status %s.", contact_id, dnc_status)
                return True
                retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning("Rate limited updating contact %s. Attempt %s/%s. Waiting %s seconds.",
                              contact_id, attempt + 1, max_retries, retry_after)
            logger.error("Failed to update contact %s: %s", contact_id, e)
            if attempt == max_retries - 1:
                return False
    return False
The fields.custom.dnc_suppression_status path targets a custom field on the contact record. Replace this path with your actual custom field name or use a standard field like do_not_call if your CXone instance uses it. The retry loop implements exponential backoff by defaulting to 2 ** attempt seconds when the Retry-After header is absent.
The following script combines authentication, pagination, mapping, and update logic into a single executable module. Replace the placeholder credentials and contact list with your production data.
import requests
import logging
from typing import List, Dict, Any, Optional
class CXoneAuth:
        payload = {
            self._fetch_token()
    offset = 0
        payload = {
            "phones": batch,
            "limit": limit,
            "offset": offset
            json=payload
            break
        offset += limit
    return all_records
def map_suppressed_contacts(contacts: List[Dict[str, Any]], dnc_records: List[Dict[str, Any]]) -> List[Dict[str, str]]:
    suppressed_mappings: List[Dict[str, str]] = []
                "phone": phone,
    payload = {
        "fields": {
            "custom": {
                url,
                json=payload
                return True
                return False
    return False
def main():
    # Configuration
    REGION = "euc1"  # Replace with your CXone region
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    # Sample contact list. Replace with your data source.
    CONTACTS = [
        {"id": "contact_001", "phone": "+12025550101"},
        {"id": "contact_002", "phone": "+12025550102"},
        {"id": "contact_003", "phone": "+12025550103"},
        {"id": "contact_004", "phone": "+12025550104"},
        {"id": "contact_005", "phone": "+12025550105"}
    auth = CXoneAuth(REGION, CLIENT_ID, CLIENT_SECRET)
    phones = [c["phone"] for c in CONTACTS]
    # Step 1: Query DNC API with pagination
    dnc_records = query_dnc_records(auth, phones, limit=2)
    # Step 2: Map suppressed numbers to contact IDs
    suppressed_contacts = map_suppressed_contacts(CONTACTS, dnc_records)
    # Step 3: Update contact statuses
    success_count = 0
    for mapping in suppressed_contacts:
        if update_contact_dnc_status(auth, mapping["contact_id"], mapping["dnc_status"]):
            success_count += 1
    logger.info("Update complete. %s/%s contacts processed.", success_count, len(suppressed_contacts))
    main()
  • What causes it: The OAuth token has expired, the client credentials are incorrect, or the requested scopes are not granted to the application.
  • How to fix it: Verify the client_id and client_secret in your CXone developer console. Ensure the application has dnc:read and contacts:write scopes assigned. The CXoneAuth class automatically refreshes tokens, but a 401 during the initial fetch indicates invalid credentials.
  • Code showing the fix: Add explicit scope validation during initialization.
def validate_scopes(auth: CXoneAuth) -> bool:
        resp = auth.session.get(f"{auth.api_base}/users/me", headers=auth.get_headers())
        return resp.status_code == 200
    except requests.exceptions.HTTPError:
        return False
  • What causes it: CXone enforces rate limits per API endpoint and per OAuth client. Bulk DNC queries and rapid contact PATCH requests trigger this limit.
  • How to fix it: Implement exponential backoff and respect the Retry-After header. Reduce batch sizes for DNC queries if you consistently hit limits. The provided update_contact_dnc_status function already includes retry logic.
  • Code showing the fix: The retry loop in Step 3 handles this automatically. Ensure you do not spawn concurrent threads without a semaphore, as CXone counts concurrent connections toward the rate limit.
Error: 400 Bad Request
  • What causes it: Invalid phone number formatting, malformed JSON payload, or referencing a non-existent contact ID. CXone requires E.164 formatting for phone numbers in DNC queries.
  • How to fix it: Validate phone numbers before sending them to the DNC API. Strip spaces, parentheses, and dashes. Ensure the contact ID exists in your CXone instance.
  • Code showing the fix: Add a validation step before the DNC query.
import re
def normalize_phone(phone: str) -> str:
    cleaned = re.sub(r"[^\d+]", "", phone)
    if not cleaned.startswith("+"):
        cleaned = f"+1{cleaned}"
    return cleaned
