Programmatically Intercept and Override IVR Voice Prompts in Genesys Cloud Using Node.js
- This code programmatically swaps IVR prompt references inside Genesys Cloud flows by validating media constraints, enforcing DTMF compatibility, applying atomic updates, and tracking intercept metrics.
- This uses the Genesys Cloud Flow API, Media API, and Webhook API via the official Node.js SDK.
- This covers TypeScript/JavaScript with Node.js 18+ and modern async/await patterns.
- OAuth client type:
confidential(Server-to-Server or Client Credentials flow) - Required scopes:
flow:read,flow:write,media:read,media:write,webhook:write,webhook:read - SDK version:
@genesyscloud/purecloud-platform-client-v2v128.0.0+ - Language/runtime requirements: Node.js 18+, TypeScript 5.0+
- External dependencies:
axios,uuid,dotenv,@types/node
Genesys Cloud uses OAuth 2.0 Client Credentials for server-side integrations. The SDK handles token refresh automatically, but you must initialize the platform client with your environment, client ID, and client secret.
import { PureCloudPlatformClientV2 } from '@genesyscloud/purecloud-platform-client-v2';
export function initializeGenesysClient(environment: string, clientId: string, clientSecret: string) {
const client = new PureCloudPlatformClientV2();
client.setEnvironment(environment);
client.loginOAuthClientCredentials(clientId, clientSecret);
return client;
Required OAuth Scope for Authentication: flow:read flow:write media:read media:write webhook:write webhook:read
HTTP Cycle Example:
POST https://api.mypurecloud.com/oauth/token
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=flow:read%20flow:write%20media:read%20media:write%20webhook:write%20webhook:read
Expected Response:
"token_type": "Bearer",
"expires_in": 1800,
"scope": "flow:read flow:write media:read media:write webhook:write webhook:read"
Step 1: Initialize SDK and Define Media Constraints
The media engine enforces strict format and duration limits. You must define these constraints before attempting any prompt override. Genesys Cloud supports MP3, WAV, and OGG formats with specific bitrate and sample rate requirements.
export interface MediaConstraints {
maxDurationSeconds: number;
allowedFormats: string[];
maxBitrateKbps: number;
latencyThresholdMs: number;
maxPromptOverridesPerFlow: number;
export const DEFAULT_MEDIA_CONSTRAINTS: MediaConstraints = {
maxDurationSeconds: 300,
allowedFormats: ['mp3', 'wav', 'ogg'],
maxBitrateKbps: 192,
latencyThresholdMs: 450,
maxPromptOverridesPerFlow: 10
export async function initializeInterceptor(environment: string, clientId: string, clientSecret: string) {
await client.loginOAuthClientCredentials(clientId, clientSecret);
const authData = await client.getAuthData();
if (!authData.accessToken) {
throw new Error('OAuth token acquisition failed');
return { client, constraints: DEFAULT_MEDIA_CONSTRAINTS };
} catch (error: any) {
if (error.response?.status === 401) {
throw new Error('Invalid client credentials or expired token');
if (error.response?.status === 403) {
throw new Error('OAuth application lacks required scopes');
throw error;
OAuth Scope Required: flow:read media:read
Error Handling: The SDK throws axios-style errors. Status 401 indicates credential failure. Status 403 indicates missing scopes. The code catches both and throws descriptive errors.
Step 2: Validate Audio Format and DTMF Compatibility
Before constructing the intercept payload, you must verify the target prompt meets media engine constraints and DTMF compatibility. DTMF detection requires specific audio characteristics to prevent clipping during Media scaling.
import { MediaRecordingApi } from '@genesyscloud/purecloud-platform-client-v2';
export async function validatePromptMedia(
client: PureCloudPlatformClientV2,
promptId: string,
constraints: MediaConstraints
const mediaApi = new MediaRecordingApi(client);
const mediaDetails = await mediaApi.getMediaRecording({ recordingId: promptId });
const format = mediaDetails.mediaFormat?.toLowerCase();
if (!constraints.allowedFormats.includes(format || '')) {
throw new Error(`Unsupported media format: ${format}. Allowed: ${constraints.allowedFormats.join(', ')}`);
if (mediaDetails.duration > constraints.maxDurationSeconds) {
throw new Error(`Prompt exceeds maximum duration limit of ${constraints.maxDurationSeconds} seconds`);
if (mediaDetails.bitrate > constraints.maxBitrateKbps) {
throw new Error(`Prompt bitrate ${mediaDetails.bitrate} kbps exceeds limit of ${constraints.maxBitrateKbps} kbps`);
const isDtmfCompatible = mediaDetails.dtmfDetectionEnabled === true;
if (!isDtmfCompatible && mediaHintsRequiresDtmf(mediaDetails)) {
throw new Error('Prompt lacks DTMF compatibility flags required for interactive IVR steps');
return { valid: true, format, duration: mediaDetails.duration };
console.warn('Rate limit hit during media validation. Implement exponential backoff.');
throw new Error('Media API rate limited');
throw error;
function mediaHintsRequiresDtmf(media: any): boolean {
return media.tags?.includes('interactive') || media.tags?.includes('dtmf-required');
OAuth Scope Required: media:read
Non-Obvious Parameters: The dtmfDetectionEnabled flag determines whether the media engine can safely parse touch-tone inputs without audio clipping. The mediaHintsRequiresDtmf helper checks custom tags that signal interactive steps.
Edge Cases: Prompts tagged as interactive but uploaded without DTMF metadata will fail validation. The code explicitly checks this to prevent runtime audio clipping.
Step 3: Construct Intercept Payload and Apply Atomic Flow Update
You will modify the flow definition by swapping promptId references inside playback steps. Genesys Cloud requires atomic updates with concurrency control. You must fetch the current flow, apply the override directive, and submit via PUT with the If-Match header.
import { FlowApi } from '@genesyscloud/purecloud-platform-client-v2';
export interface InterceptPayload {
flowId: string;
promptIdMap: Record<string, string>;
playbackMatrix: { stepId: string; targetPromptId: string }[];
overrideDirective: 'REPLACE' | 'QUEUE' | 'APPEND';
auditMetadata: Record<string, any>;
export async function applyPromptIntercept(
payload: InterceptPayload,
const flowApi = new FlowApi(client);
const currentFlow = await flowApi.getFlow({ flowId: payload.flowId });
const etag = currentFlow.etag;
if (!etag) {
throw new Error('Flow does not support atomic updates via etag');
const newFlow = { ...currentFlow };
let overrideCount = 0;
for (const step of newFlow.flowSteps || []) {
if (step.type === 'playback' && step.playback?.promptId) {
const currentPrompt = step.playback.promptId;
if (payload.promptIdMap[currentPrompt]) {
if (overrideCount >= constraints.maxPromptOverridesPerFlow) {
throw new Error(`Maximum prompt override limit (${constraints.maxPromptOverridesPerFlow}) reached for this flow`);
step.playback.promptId = payload.promptIdMap[currentPrompt];
step.playback.overrideDirective = payload.overrideDirective;
step.playback.playbackMatrix = payload.playbackMatrix.filter(m => m.stepId === step.id);
overrideCount++;
if (overrideCount === 0) {
throw new Error('No matching prompt references found for intercept');
const updatedFlow = await flowApi.putFlow({
flowId: payload.flowId,
body: newFlow,
headers: { 'If-Match': etag }
success: true,
flowVersion: updatedFlow.version,
overridesApplied: overrideCount,
if (error.response?.status === 409) {
throw new Error('Atomic update conflict. Flow was modified by another process. Retry with fresh etag.');
throw new Error('Flow API rate limited. Implement retry with jitter.');
throw error;
OAuth Scope Required: flow:read flow:write
Non-Obvious Parameters: The If-Match header uses the flow’s etag to guarantee atomicity. The playbackMatrix and overrideDirective fields are attached to the playback step configuration to control how the media engine routes the new prompt.
Edge Cases: Concurrent flow edits will return 409. The code explicitly catches this and instructs retry logic. Exceeding maxPromptOverridesPerFlow prevents media engine overload.
Step 4: Register Webhooks and Synchronize External Telephony Events
Intercept events must synchronize with external telephony providers. You will register a webhook that triggers on flow updates and prompt playback events to maintain alignment.
import { WebhookApi } from '@genesyscloud/purecloud-platform-client-v2';
export async function registerInterceptWebhook(
callbackUrl: string,
flowId: string
const webhookApi = new WebhookApi(client);
const webhookBody = {
description: 'Synchronizes IVR prompt intercept events with external telephony providers',
enabled: true,
targetUrl: callbackUrl,
eventFilters: [
`flow:${flowId}:updated`,
`media:playback:prompt-intercepted`
headers: {
'X-Intercept-Source': 'MediaAPI-NodeJS',
'Content-Type': 'application/json'
method: 'POST',
retryPolicy: {
retryIntervalSeconds: 60,
maxRetries: 5
const createdWebhook = await webhookApi.postWebhook({ body: webhookBody });
success: true,
webhookId: createdWebhook.id,
status: createdWebhook.enabled ? 'active' : 'disabled'
throw new Error('Missing webhook:write scope or invalid callback URL format');
throw error;
OAuth Scope Required: webhook:write
Non-Obvious Parameters: The eventFilters array uses Genesys Cloud event routing syntax. The retryPolicy ensures external telephony providers receive events even during transient network failures.
Edge Cases: Invalid callback URLs return 400. The webhook API validates URL format and requires HTTPS endpoints for production.
Step 5: Track Latency, Success Rates and Generate Audit Logs
You must track intercept latency and override success rates to ensure seamless customer experience. The audit pipeline records every intercept attempt for media governance.
export interface AuditLog {
flowId: string;
promptId: string;
action: 'VALIDATE' | 'INTERCEPT' | 'WEBHOOK_REGISTER';
status: 'SUCCESS' | 'FAILURE' | 'RATE_LIMITED';
latencyMs: number;
timestamp: string;
metadata: Record<string, any>;
export class InterceptAuditTracker {
private logs: AuditLog[] = [];
recordLog(log: AuditLog) {
this.logs.push(log);
console.log(`[AUDIT] ${log.timestamp} | ${log.action} | ${log.status} | Latency: ${log.latencyMs}ms`);
generateMetrics() {
const total = this.logs.length;
if (total === 0) return { total: 0, successRate: 0, avgLatency: 0 };
const successes = this.logs.filter(l => l.status === 'SUCCESS').length;
const avgLatency = this.logs.reduce((acc, l) => acc + l.latencyMs, 0) / total;
total,
successRate: (successes / total) * 100,
avgLatency: Math.round(avgLatency),
rateLimitedCount: this.logs.filter(l => l.status === 'RATE_LIMITED').length
OAuth Scope Required: None (local tracking)
Non-Obvious Parameters: The tracker calculates success rates and average latency across all intercept operations. The metadata field stores prompt IDs, override counts, and etag versions for governance audits.
Edge Cases: High latency spikes indicate media engine scaling pressure. The audit log captures these spikes for capacity planning.
import dotenv from 'dotenv';
import { initializeInterceptor } from './auth';
import { validatePromptMedia } from './media-validation';
import { applyPromptIntercept } from './flow-intercept';
import { registerInterceptWebhook } from './webhook-sync';
import { InterceptAuditTracker } from './audit-tracker';
dotenv.config();
async function runPromptInterceptor() {
const tracker = new InterceptAuditTracker();
console.log('Initializing Genesys Cloud client...');
const { client, constraints } = await initializeInterceptor(
process.env.GENESYS_ENVIRONMENT || 'mypurecloud.com',
process.env.GENESYS_CLIENT_ID!,
process.env.GENESYS_CLIENT_SECRET!
const FLOW_ID = process.env.TARGET_FLOW_ID!;
const NEW_PROMPT_ID = process.env.NEW_PROMPT_ID!;
const CALLBACK_URL = process.env.WEBHOOK_CALLBACK_URL!;
const startTime = Date.now();
console.log('Validating target prompt media...');
const validationResult = await validatePromptMedia(client, NEW_PROMPT_ID, constraints);
tracker.recordLog({
flowId: FLOW_ID,
promptId: NEW_PROMPT_ID,
action: 'VALIDATE',
status: 'SUCCESS',
latencyMs: Date.now() - startTime,
metadata: { format: validationResult.format, duration: validationResult.duration }
console.log('Registering synchronization webhook...');
const webhookResult = await registerInterceptWebhook(client, CALLBACK_URL, FLOW_ID);
tracker.recordLog({
flowId: FLOW_ID,
action: 'WEBHOOK_REGISTER',
status: 'SUCCESS',
metadata: { webhookId: webhookResult.webhookId }
console.log('Applying atomic prompt intercept...');
const interceptPayload = {
flowId: FLOW_ID,
promptIdMap: { [process.env.OLD_PROMPT_ID!]: NEW_PROMPT_ID },
playbackMatrix: [{ stepId: 'step-main-greeting', targetPromptId: NEW_PROMPT_ID }],
overrideDirective: 'REPLACE' as const,
auditMetadata: { initiatedBy: 'automated-interceptor', version: '1.0.0' }
const interceptResult = await applyPromptIntercept(client, interceptPayload, constraints);
tracker.recordLog({
flowId: FLOW_ID,
action: 'INTERCEPT',
status: 'SUCCESS',
metadata: { flowVersion: interceptResult.flowVersion, overridesApplied: interceptResult.overridesApplied }
console.log('Interceptor completed successfully.');
console.log('Metrics:', tracker.generateMetrics());
const status = error.message.includes('rate') ? 'RATE_LIMITED' : 'FAILURE';
tracker.recordLog({
flowId: process.env.TARGET_FLOW_ID || 'unknown',
promptId: process.env.NEW_PROMPT_ID || 'unknown',
status,
latencyMs: 0,
metadata: { error: error.message }
console.error('Interceptor failed:', error.message);
process.exit(1);
runPromptInterceptor();
Dependencies: npm install @genesyscloud/purecloud-platform-client-v2 dotenv uuid axios
Environment Variables: GENESYS_ENVIRONMENT, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, TARGET_FLOW_ID, NEW_PROMPT_ID, OLD_PROMPT_ID, WEBHOOK_CALLBACK_URL
Common Errors and Debugging
Error: 409 Conflict on PUT /api/v2/flows/{flowId}
- What causes it: Another developer or automation updated the flow between your GET and PUT requests. The etag mismatch triggers a conflict.
- How to fix it: Implement a retry loop that fetches the fresh flow, reapplies the intercept payload, and resubmits with the new etag.
- Code showing the fix:
let retries = 0;
const maxRetries = 3;
while (retries < maxRetries) {
return await applyPromptIntercept(client, payload, constraints);
if (error.response?.status === 409 && retries < maxRetries - 1) {
retries++;
await new Promise(r => setTimeout(r, 1000 * retries));
continue;
throw error;
Error: 429 Too Many Requests on Media or Flow APIs
- What causes it: Exceeding Genesys Cloud rate limits (typically 100 requests per minute per API scope).
- How to fix it: Implement exponential backoff with jitter before retrying.
async function retryWithBackoff(fn: () => Promise<any>, maxAttempts = 3) {
for (let i = 0; i < maxAttempts; i++) {
return await fn();
if (error.response?.status === 429 && i < maxAttempts - 1) {
const delay = (Math.pow(2, i) * 1000) + Math.random() * 500;
console.warn(`Rate limited. Retrying in ${Math.round(delay)}ms...`);
await new Promise(r => setTimeout(r, delay));
} else {
throw error;
Error: Prompt lacks DTMF compatibility flags required for interactive IVR steps
- What causes it: The target prompt was uploaded without
dtmfDetectionEnabledmetadata, or the flow step expects touch-tone input. - How to fix it: Re-upload the audio file with DTMF detection enabled via the Media API, or switch the flow step to non-interactive playback.
await mediaApi.postMediaRecording({
body: {
mediaFormat: 'mp3',
dtmfDetectionEnabled: true,
// file upload stream omitted for brevity
