Programmatic REST API Integration for NICE Cognigy Bots Using Python
You will build a Python module that programmatically constructs, validates, and registers external REST API integrations for NICE Cognigy bots, executes asynchronous external requests with retry logic, parses responses using JSON path extraction, synchronizes status via webhooks, tracks latency and error rates, and generates audit logs.
This tutorial uses the NICE Cognigy Platform REST API and direct HTTP calls to external services.
The implementation uses Python 3.9+ with httpx, pydantic, jmespath, and tenacity.
- Cognigy tenant URL (e.g.,
https://your-tenant.cognigy.com) - OAuth2 client credentials with scopes:
cognigy:platform:read,cognigy:integrations:write,cognigy:webhooks:manage - Python 3.9 or newer
- External dependencies:
httpx>=0.24.0,pydantic>=2.0.0,jmespath>=1.0.1,tenacity>=8.2.0,pydantic-settings>=2.0.0 - Install dependencies:
pip install httpx pydantic jmespath tenacity pydantic-settings
Cognigy Platform APIs use OAuth2 client credentials flow. You must exchange your client ID and secret for a bearer token before issuing integration commands.
import httpx
import os
from typing import Optional
COGNIGY_BASE_URL = os.getenv("COGNIGY_TENANT_URL", "https://your-tenant.cognigy.com")
CLIENT_ID = os.getenv("COGNIGY_CLIENT_ID")
CLIENT_SECRET = os.getenv("COGNIGY_CLIENT_SECRET")
async def get_cognigy_token() -> str:
"""Authenticate with Cognigy OAuth2 endpoint and return bearer token."""
response = await client.post(
f"{COGNIGY_BASE_URL}/api/v1/auth/oauth/token",
data={
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET,
"scope": "cognigy:platform:read cognigy:integrations:write cognigy:webhooks:manage"
response.raise_for_status()
token_data = response.json()
if "access_token" not in token_data:
raise ValueError("OAuth response missing access_token")
return token_data["access_token"]
Required Scope: cognigy:platform:read cognigy:integrations:write cognigy:webhooks:manage
Endpoint: POST /api/v1/auth/oauth/token
Step 1: Construct and Validate Integration Payloads
You must define the integration structure before registration. The payload must specify the external endpoint, HTTP method, authentication scheme, request mapping, and response mapping. Pydantic enforces schema constraints and validates HTTP method constraints.
from pydantic import BaseModel, Field, validator
from typing import Dict, Any, List, Optional
from enum import Enum
class HttpMethod(str, Enum):
GET = "GET"
POST = "POST"
PUT = "PUT"
PATCH = "PATCH"
DELETE = "DELETE"
class AuthType(str, Enum):
BEARER = "bearer"
API_KEY = "api_key"
BASIC = "basic"
NONE = "none"
class IntegrationConfig(BaseModel):
url: str = Field(..., description="External API endpoint URL")
method: HttpMethod = Field(default=HttpMethod.POST)
auth_type: AuthType = Field(default=AuthType.BEARER)
auth_header_name: Optional[str] = Field(default="Authorization")
headers: Dict[str, str] = Field(default_factory=dict)
request_mapping: Dict[str, Any] = Field(default_factory=dict)
response_mapping: Dict[str, Any] = Field(default_factory=dict)
timeout_seconds: int = Field(default=30, ge=1, le=120)
@validator("url")
def validate_url_scheme(cls, v: str) -> str:
if not v.startswith("https://"):
raise ValueError("External API URLs must use HTTPS for security governance")
return v
@validator("method")
def validate_method_body_constraint(cls, v: HttpMethod, values: Dict[str, Any]) -> HttpMethod:
if v == HttpMethod.GET and "body" in values.get("request_mapping", {}):
raise ValueError("GET requests do not support request body mapping")
return v
class IntegrationDefinition(BaseModel):
name: str = Field(..., min_length=3, max_length=100)
description: str = Field(default="External REST API integration for Cognigy bot")
config: IntegrationConfig
status: str = Field(default="ACTIVE")
bot_id: str = Field(..., description="Cognigy Bot UUID")
def build_integration_payload(bot_id: str, external_url: str, method: str = "POST") -> IntegrationDefinition:
"""Construct a validated integration definition payload."""
return IntegrationDefinition(
name="ExternalServiceConnector",
bot_id=bot_id,
config=IntegrationConfig(
url=external_url,
method=HttpMethod(method.upper()),
auth_type=AuthType.BEARER,
headers={"Content-Type": "application/json", "X-Request-Source": "cognigy-bot"},
request_mapping={"body": {"$input": "bot.payload", "transform": "json_merge"}},
response_mapping={"extract": "data.result", "normalize": "flatten"},
timeout_seconds=15
Required Scope: cognigy:integrations:write
Validation Notes: The schema enforces HTTPS endpoints, restricts request bodies on GET methods, and caps timeout values to prevent resource exhaustion.
Step 2: Register Integration via Cognigy Platform API
After validation, submit the integration definition to the Cognigy Platform API. The response returns the integration identifier and initial status.
async def register_integration(token: str, definition: IntegrationDefinition) -> Dict[str, Any]:
"""POST integration definition to Cognigy Platform API."""
async with httpx.AsyncClient(timeout=15.0) as client:
f"{COGNIGY_BASE_URL}/api/v1/integrations",
headers={
"Accept": "application/json"
json=definition.model_dump(mode="json")
return response.json()
Expected Response:
"id": "int_8f3a2c91-4b7e-4d1a-9c8e-7f2b1a3d5e6f",
"name": "ExternalServiceConnector",
"status": "ACTIVE",
"created_at": "2024-01-15T08:30:00Z",
"config": {
"url": "https://api.external-service.com/v1/data",
"method": "POST",
"timeout_seconds": 15
Step 3: Async Execution with Retry and Error Handling
External services experience transient failures. You must implement asynchronous execution with exponential backoff for 429 and 5xx responses. The tenacity library handles retry logic while httpx manages concurrent external calls.
import asyncio
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type((httpx.HTTPStatusError, httpx.TimeoutException)),
reraise=True
async def execute_external_api(config: IntegrationConfig, payload: Dict[str, Any]) -> Dict[str, Any]:
"""Execute external API call with retry logic and latency tracking."""
external_headers = {**config.headers, "Authorization": f"Bearer {os.getenv('EXTERNAL_API_KEY')}"}
async with httpx.AsyncClient(timeout=config.timeout_seconds) as client:
response = await client.request(
method=config.method.value,
url=config.url,
headers=external_headers,
json=payload
"status_code": response.status_code,
"body": response.json(),
"latency_ms": round(latency_ms, 2)
if e.response.status_code in (429, 500, 502, 503, 504):
raise e
raise ValueError(f"External API returned {e.response.status_code}: {e.response.text}")
Required Scope: cognigy:integrations:write (for execution context)
Error Handling: The decorator retries on 429, 5xx, and timeouts. It raises immediately on 400/401/403 to fail fast on misconfiguration.
Step 4: Response Parsing and Data Transformation
Cognigy bots require normalized JSON structures. You will extract specific fields using JSON path syntax and apply a transformation pipeline.
import jmespath
def parse_and_transform_response(response_data: Dict[str, Any], mapping: Dict[str, Any]) -> Dict[str, Any]:
"""Extract and transform external API response using JSON path."""
extract_path = mapping.get("extract", "*")
normalize_mode = mapping.get("normalize", "none")
extracted = jmespath.search(extract_path, response_data)
if extracted is None:
raise ValueError(f"JSON path '{extract_path}' returned no data")
normalized = {}
if normalize_mode == "flatten":
if isinstance(extracted, list):
normalized["items"] = extracted
normalized["count"] = len(extracted)
elif isinstance(extracted, dict):
normalized = extracted
elif normalize_mode == "map_keys":
normalized = {k.lower().replace(" ", "_"): v for k, v in extracted.items()}
else:
return normalized
Transformation Notes: The pipeline supports flattening arrays, lowercasing keys, and nested object extraction. You must align the extract path with the external API response structure.
Step 5: Webhook Synchronization, Metrics, and Audit Logging
You must synchronize integration status with external API gateways, track performance metrics, and generate immutable audit logs. This step runs after execution completes.
import json
import logging
logger = logging.getLogger("cognigy_integration")
async def sync_webhook_and_log(
integration_id: str,
execution_result: Dict[str, Any],
normalized_data: Dict[str, Any],
webhook_url: str
) -> None:
"""Push status to webhook, track metrics, and write audit log."""
status = "SUCCESS" if execution_result.get("status_code", 500) < 400 else "FAILURE"
latency = execution_result.get("latency_ms", 0)
webhook_payload = {
"integration_id": integration_id,
"status": status,
"latency_ms": latency,
"payload_size": len(json.dumps(normalized_data))
async with httpx.AsyncClient(timeout=5.0) as client:
await client.post(webhook_url, json=webhook_payload)
logger.error("Webhook sync failed: %s", str(e))
# Audit log entry for security governance
audit_entry = {
"event": "INTEGRATION_EXECUTION",
"action": "EXECUTE_EXTERNAL_API",
"status": status,
"error_rate_impact": 1 if status == "FAILURE" else 0,
"logged_at": datetime.now(timezone.utc).isoformat()
logger.info("AUDIT: %s", json.dumps(audit_entry))
return audit_entry
Required Scope: cognigy:webhooks:manage
Metrics Tracking: Latency and error flags are captured per execution. Aggregate these in your observability stack (Prometheus/Grafana or Datadog) using the structured log output.
import asyncio
import os
import logging
logger = logging.getLogger("cognigy_integration_builder")
class CognigyIntegrationBuilder:
def __init__(self, token: str, webhook_url: str):
self.token = token
async def run_integration_workflow(self, bot_id: str, external_url: str, bot_payload: Dict[str, Any]) -> Dict[str, Any]:
# Step 1: Build and validate payload
definition = build_integration_payload(bot_id, external_url, method="POST")
logger.info("Integration payload validated: %s", definition.name)
# Step 2: Register with Cognigy
reg_response = await register_integration(self.token, definition)
integration_id = reg_response["id"]
logger.info("Registered integration: %s", integration_id)
# Step 3: Execute external API asynchronously
execution_result = await execute_external_api(definition.config, bot_payload)
logger.info("External API executed. Status: %s, Latency: %s ms",
execution_result["status_code"], execution_result["latency_ms"])
# Step 4: Parse and transform response
normalized = parse_and_transform_response(
execution_result["body"],
definition.config.response_mapping
logger.info("Response normalized successfully")
# Step 5: Sync webhook, track metrics, audit log
audit = await sync_webhook_and_log(
integration_id, execution_result, normalized, self.webhook_url
"normalized_data": normalized,
"audit_log": audit
async def main():
token = await get_cognigy_token()
builder = CognigyIntegrationBuilder(token, os.getenv("WEBHOOK_URL", "https://hooks.example.com/cognigy-sync"))
result = await builder.run_integration_workflow(
bot_id="bot_123456789",
external_url="https://api.external-service.com/v1/data",
bot_payload={"user_id": "u_998877", "query": "account_balance"}
print("Workflow complete:", result)
asyncio.run(main())
Common Errors and Debugging
Cause: Expired or invalid OAuth token, missing cognigy:integrations:write scope.
Fix: Refresh the token before execution. Verify the client credentials have the required scopes assigned in the Cognigy admin console.
# Token refresh pattern
# Retry request with new token
Error: 403 Forbidden
Cause: Client lacks permission to create integrations for the specified bot_id, or the bot belongs to a different workspace.
Fix: Ensure the OAuth client is linked to the correct Cognigy workspace. Verify the bot_id matches an existing bot in your tenant.
Cause: Cognigy Platform API or external service rate limiting.
Fix: The tenacity retry decorator handles exponential backoff. If failures persist, implement request batching or reduce concurrent bot triggers.
# Tenacity configuration already handles 429 with exponential backoff
# Verify max retries align with your rate limit window
Error: 400 Bad Request (Validation Failure)
Cause: Invalid JSON path in response_mapping, missing HTTPS scheme, or body mapping on GET request.
Fix: Validate the IntegrationConfig before submission. Use definition.model_dump() to inspect the serialized payload.
# Validate before POST
definition.model_validate(definition.model_dump())
Error: 5xx Server Error
Cause: External service outage or Cognigy Platform maintenance.
Fix: Retry logic covers transient 5xx errors. Log the response body for debugging. Implement circuit breaker patterns in production to prevent cascade failures.
