Programmatic Inbound Call Answering with Genesys Cloud Python SDK
  • A Python service that programmatically answers inbound Genesys Cloud calls using the Telephony API, validates SIP constraints, tracks connection latency, and synchronizes events with external CTI systems.
  • This tutorial uses the purecloudplatformclientv2 Python SDK to interact with Genesys Cloud REST endpoints.
  • The implementation covers Python 3.9 with production-grade error handling, retry logic, and structured audit logging.
  • Genesys Cloud OAuth service account with telephony:call:answer, telephony:user:read, and user:read scopes.
  • purecloudplatformclientv2 SDK version 2.0.0 or higher.
  • Python 3.9+ runtime.
  • External dependencies: httpx, pydantic, structlog, uuid.
The Python SDK manages OAuth token acquisition and refresh automatically when configured with client credentials. You must initialize the configuration object before creating API clients.
import purecloudplatformclientv2
from purecloudplatformclientv2 import Configuration
def initialize_genesys_config(client_id: str, client_secret: str, org_url: str = "https://api.mypurecloud.com") -> Configuration:
    config = Configuration()
    config.host = org_url
    config.set_client_credentials(client_id, client_secret)
    config.access_token = None  # SDK will fetch and cache automatically
    return config
The SDK handles token expiration by intercepting 401 responses and re-authenticating transparently. You must ensure the service account possesses the telephony:call:answer scope, otherwise the POST operation will return 403.
Step 1: Line State Verification and Permission Pipeline
Before answering a call, you must verify the target user line state and confirm the caller has telephony permissions. Genesys Cloud rejects answer requests for users in unavailable, busy, or offline states.
from purecloudplatformclientv2 import TelephonyApi, ApiClient
from purecloudplatformclientv2.rest import ApiException
from typing import List
def validate_line_state_and_permissions(
    user_id: str,
    telephony_api: TelephonyApi
) -> bool:
    Verifies the user has an available line and required telephony permissions.
    Returns True if the line is eligible for answering.
        lines_response = telephony_api.get_telephony_user_lines(user_id)
        available_lines: List[str] = []
        for line in lines_response.entity:
            # Check SIP stack constraints: line must be ringing or available
            if line.state in ("ringing", "available"):
                available_lines.append(line.id)
        if not available_lines:
            return False
        # Permission verification pipeline
        # The SDK automatically injects OAuth scopes, but we verify telephony capability
        # by checking if the user has a telephony profile attached
        has_telephony_profile = any(line.telephony_profile_id is not None for line in lines_response.entity)
        return has_telephony_profile and len(available_lines) > 0
    except ApiException as e:
        if e.status == 403:
            raise PermissionError("Service account lacks telephony:user:read scope.") from e
        if e.status == 404:
            raise ValueError(f"User {user_id} not found in Genesys Cloud.") from e
        raise
Step 2: Answer Payload Construction and SIP Constraint Validation
The answer payload must reference the exact call UUID, specify the media type matrix, and include early media directives. SIP stack constraints require the maximum ring timeout to not exceed 60 seconds. We use Pydantic to enforce schema validation before transmission.
from pydantic import BaseModel, Field, ValidationError
from typing import Literal
class CallAnswerPayload(BaseModel):
    call_id: str = Field(..., description="UUID of the inbound call to answer")
    media_type: Literal["audio", "video", "audio+video"] = Field("audio", description="Media type matrix selection")
    early_media: bool = Field(False, description="Enable early media stream before answer")
    max_ring_timeout_ms: int = Field(..., ge=1000, le=60000, description="SIP constraint: max 60000ms")
    def to_sdk_body(self) -> dict:
        """Converts validated payload to SDK-compatible dictionary."""
            "callId": self.call_id,
            "mediaType": self.media_type,
            "earlyMedia": self.early_media,
            "maxRingTimeoutMs": self.max_ring_timeout_ms
def construct_and_validate_answer(
    call_id: str,
    media_type: str = "audio",
    early_media: bool = False,
    ring_timeout_ms: int = 30000
) -> dict:
        payload = CallAnswerPayload(
            call_id=call_id,
            media_type=media_type,
            early_media=early_media,
            max_ring_timeout_ms=ring_timeout_ms
        return payload.to_sdk_body()
    except ValidationError as e:
        raise ValueError(f"Answer payload validation failed: {e.errors()}") from e
Step 3: Atomic POST Execution with Retry and Codec Negotiation
The answer operation uses an atomic POST request. Genesys Cloud triggers automatic codec negotiation when the mediaType is specified. You must implement retry logic for 429 rate limits and transient 5xx errors. The SDK does not include built-in exponential backoff for telephony endpoints, so you must handle it explicitly.
import httpx
def answer_call_with_retry(
    telephony_api: TelephonyApi,
    user_id: str,
    answer_body: dict,
    max_retries: int = 3,
    base_delay: float = 1.0
) -> dict:
    Executes atomic POST to /api/v2/telephony/users/{userId}/calls/{callId}/answer
    with exponential backoff for 429 and 5xx responses.
    retry_count = 0
    last_exception = None
    while retry_count <= max_retries:
            # SDK method maps to POST /api/v2/telephony/users/{userId}/calls/{callId}/answer
            response = telephony_api.post_telephony_user_call_answer(
                user_id=user_id,
                body=answer_body
            # Automatic codec negotiation is triggered server-side upon successful POST
            # The response contains the updated call state and media capabilities
            return response.to_dict()
            last_exception = e
            if e.status == 429:
                # Extract Retry-After header if present, otherwise use exponential backoff
                retry_after = float(e.headers.get("Retry-After", base_delay * (2 ** retry_count)))
                time.sleep(retry_after)
                retry_count += 1
            elif 500 <= e.status < 600:
                time.sleep(base_delay * (2 ** retry_count))
                retry_count += 1
            else:
                # Non-retryable errors (400, 401, 403, 404)
                raise
            raise RuntimeError(f"Unexpected error during call answer: {e}") from e
    raise last_exception if last_exception else RuntimeError("Max retries exceeded")
Step 4: Metrics Tracking, CTI Callback Synchronization, and Audit Logging
Production call answerers require latency tracking, success rate calculation, external CTI synchronization via callbacks, and structured audit logs for governance. This step combines the previous components into a cohesive execution pipeline.
import json
import structlog
from typing import Callable, Optional, Dict, Any
@dataclass
class AnswerMetrics:
    total_attempts: int = 0
    successful_answers: int = 0
    total_latency_ms: float = 0.0
    @property
    def success_rate(self) -> float:
        return (self.successful_answers / self.total_attempts * 100) if self.total_attempts > 0 else 0.0
    @property
    def avg_latency_ms(self) -> float:
        return (self.total_latency_ms / self.total_attempts) if self.total_attempts > 0 else 0.0
class CallAnswerer:
    def __init__(
        self,
        ctI_callback: Optional[Callable[[Dict[str, Any]], None]] = None,
        audit_log_path: str = "call_audit.jsonl"
        self.telephony_api = telephony_api
        self.cti_callback = ctI_callback
        self.audit_log_path = audit_log_path
        self.metrics = AnswerMetrics()
    def execute_answer(
        self,
        user_id: str,
        call_id: str,
    ) -> Dict[str, Any]:
        # Step 1: Validation pipeline
        if not validate_line_state_and_permissions(user_id, self.telephony_api):
            raise RuntimeError(f"User {user_id} line is not eligible for answering.")
        # Step 2: Payload construction
        answer_body = construct_and_validate_answer(
            call_id=call_id,
        self.metrics.total_attempts += 1
            # Step 3: Atomic POST with retry
            response = answer_call_with_retry(
                telephony_api=self.telephony_api,
                user_id=user_id,
                answer_body=answer_body
            self.metrics.successful_answers += 1
            self.metrics.total_latency_ms += latency_ms
            audit_record = {
                "timestamp": time.time(),
                "user_id": user_id,
                "call_id": call_id,
                "status": "success",
                "latency_ms": latency_ms,
                "media_type": media_type,
                "early_media": early_media,
                "response_code": response.get("statusCode", 200)
            self._write_audit_log(audit_record)
            self._sync_cti_callback(audit_record)
            logger.info("Call answered successfully", **audit_record)
            return response
            audit_record = {
                "user_id": user_id,
                "call_id": call_id,
                "status": "failed",
                "error_type": type(e).__name__,
                "error_message": str(e)
            logger.error("Call answer failed", **audit_record)
            raise
    def _write_audit_log(self, record: Dict[str, Any]) -> None:
        with open(self.audit_log_path, "a") as f:
            f.write(json.dumps(record) + "\n")
    def _sync_cti_callback(self, record: Dict[str, Any]) -> None:
        if self.cti_callback:
                self.cti_callback(record)
                logger.warning("CTI callback failed", error=str(e))
The following script combines authentication, validation, payload construction, retry logic, metrics tracking, and audit logging into a single executable module. Replace placeholder credentials with your service account values.
import json
import structlog
from typing import Callable, Optional, Dict, Any, List
from purecloudplatformclientv2 import Configuration, ApiClient, TelephonyApi
# Configure logging
structlog.configure(
    processors=[
        structlog.processors.add_log_level,
        structlog.processors.TimeStamper(fmt="iso"),
        structlog.processors.JSONRenderer()
    context_class=dict,
    logger_factory=structlog.PrintLoggerFactory(),
    wrapper_class=structlog.make_filtering_bound_logger("INFO")
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, org_url: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.org_url = org_url
    def get_config(self) -> Configuration:
        config.host = self.org_url
        config.set_client_credentials(self.client_id, self.client_secret)
        return config
    media_type: str = Field("audio", description="Media type matrix selection")
@dataclass
    @property
def validate_line_state(user_id: str, telephony_api: TelephonyApi) -> bool:
            if line.state in ("ringing", "available") and line.telephony_profile_id is not None:
                return True
        return False
        if e.status == 403:
            raise PermissionError("Missing telephony:user:read scope") from e
        raise
def answer_call_with_retry(telephony_api: TelephonyApi, user_id: str, body: dict) -> dict:
    max_retries = 3
    base_delay = 1.0
    retry_count = 0
            response = telephony_api.post_telephony_user_call_answer(user_id=user_id, body=body)
            if e.status == 429:
                delay = float(e.headers.get("Retry-After", base_delay * (2 ** retry_count)))
                time.sleep(delay)
                retry_count += 1
                retry_count += 1
            raise
class AutomatedCallAnswerer:
    def __init__(self, client_id: str, client_secret: str, org_url: str, cti_callback: Optional[Callable[[Dict[str, Any]], None]] = None):
        self.auth = GenesysAuth(client_id, client_secret, org_url)
        config = self.auth.get_config()
        self.api_client = ApiClient(config)
        self.telephony_api = TelephonyApi(self.api_client)
        self.cti_callback = cti_callback
    def answer_inbound_call(self, user_id: str, call_id: str, media_type: str = "audio", early_media: bool = False, ring_timeout_ms: int = 30000) -> Dict[str, Any]:
        if not validate_line_state(user_id, self.telephony_api):
            raise RuntimeError("Target user line is not ringing or available.")
                call_id=call_id,
            raise ValueError(f"Payload validation failed: {e.errors()}") from e
            response = answer_call_with_retry(self.telephony_api, user_id, payload.to_sdk_body())
            audit = {
                "event": "call_answer",
                "user_id": user_id,
                "call_id": call_id,
                "success_rate": self.metrics.success_rate,
            self._log_audit(audit)
                self.cti_callback(audit)
            return response
            audit = {
                "user_id": user_id,
                "call_id": call_id,
                "status": "failed",
                "error": str(e)
            raise
    def _log_audit(self, record: Dict[str, Any]) -> None:
        with open("genesys_call_audit.jsonl", "a") as f:
# Execution example
    def external_cti_sync(record: Dict[str, Any]) -> None:
        print(f"CTI Sync: {record['status']} | Latency: {record.get('latency_ms', 0):.2f}ms")
    answerer = AutomatedCallAnswerer(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        org_url="https://api.mypurecloud.com",
        cti_callback=external_cti_sync
        result = answerer.answer_inbound_call(
            user_id="YOUR_USER_UUID",
            call_id="YOUR_INBOUND_CALL_UUID",
            media_type="audio",
            early_media=False,
            ring_timeout_ms=45000
        print("Answer payload accepted:", result)
        print(f"Answer operation failed: {e}")
Common Errors and Debugging
  • What causes it: Expired OAuth token or invalid client credentials. The SDK attempts automatic refresh, but network timeouts or misconfigured service accounts block re-authentication.
  • How to fix it: Verify the service account credentials in the Genesys Cloud admin console. Ensure the application uses set_client_credentials before API calls. Check that the token endpoint is reachable.
  • Code showing the fix: The GenesysAuth class handles credential binding. If 401 persists, regenerate the client secret and restart the service to clear cached tokens.
Error: 403 Forbidden
  • What causes it: Missing telephony:call:answer scope on the OAuth token, or the user ID does not belong to the authenticated organization.
  • How to fix it: Update the application’s OAuth scopes in the Genesys Cloud developer portal. Confirm the service account has telephony permissions enabled.
  • Code showing the fix: Add telephony:call:answer to the scope array during OAuth token request. The SDK validates scope presence before sending the POST request.
Error: 400 Bad Request
  • What causes it: Invalid call UUID format, media type mismatch, or ring timeout exceeding 60000ms. SIP stack constraints reject payloads that violate telephony protocol limits.
  • How to fix it: Validate the call UUID against RFC 4122. Ensure maxRingTimeoutMs stays between 1000 and 60000. Use the Pydantic model to catch schema violations before transmission.
  • Code showing the fix: The CallAnswerPayload model enforces le=60000 on max_ring_timeout_ms. Pydantic raises ValidationError with exact field details for immediate correction.
  • What causes it: Exceeding Genesys Cloud telephony API rate limits during high-volume answering scenarios.
  • How to fix it: Implement exponential backoff with jitter. Respect the Retry-After header when present. Throttle answer requests to match your organization’s API tier limits.
  • Code showing the fix: The answer_call_with_retry function implements exponential backoff. It parses Retry-After and sleeps accordingly before retrying the POST operation.
