Programmatic Array Unrolling for NICE CXone Data Actions with Python
A Python utility that constructs, validates, and executes array-based Data Action payloads while enforcing scripting engine constraints, tracking execution metrics, and generating audit logs. This implementation uses the NICE CXone Data Actions API (/api/v1/data-actions/scripts/{id}/execute and /api/v1/data-actions/scripts/{id}/schema). The code is written in Python 3.9+ using the requests library and standard type hints.
  • OAuth 2.0 Client Credentials grant configured in the CXone Admin Portal
  • Required scopes: data-actions:read, data-actions:execute
  • CXone API v1
  • Python 3.9 or higher
  • External dependencies: requests, jsonschema, python-dotenv
  • A deployed Data Action script ID that accepts array inputs
CXone uses organization-scoped OAuth 2.0 Client Credentials. The token endpoint resides at https://{organization}.niceincontact.com/api/oauth/token. You must cache the token and handle expiration before making API calls. The following manager handles token acquisition, storage, and automatic refresh when a 401 response occurs.
import os
import requests
from typing import Optional, Dict
class CxoneAuthManager:
    def __init__(self, org: str, client_id: str, client_secret: str):
        self.org = org
        self.client_id = client_id
        self.base_url = f"https://{org}.niceincontact.com"
        self.token_endpoint = f"{self.base_url}/api/oauth/token"
        self._access_token: Optional[str] = None
        self._token_expiry: float = 0.0
        self.session = requests.Session()
    def _get_token(self) -> str:
        payload = {
            "client_id": self.client_id,
        response = self.session.post(self.token_endpoint, data=payload, headers=headers)
        response.raise_for_status()
        data = response.json()
        self._access_token = data["access_token"]
        self._token_expiry = time.time() + data["expires_in"]
        return self._access_token
    def get_token(self) -> str:
        if self._access_token and time.time() < self._token_expiry:
        return self._get_token()
    def get_headers(self, extra_headers: Optional[Dict[str, str]] = None) -> Dict[str, str]:
        headers = {
            "Authorization": f"Bearer {self.get_token()}",
            "Accept": "application/json"
        if extra_headers:
            headers.update(extra_headers)
        return headers
The get_headers method attaches the bearer token to every request. When CXone returns a 401, the caller must refresh the token and retry. The session object maintains connection pooling for improved throughput during batch unrolling operations.
Step 1: Construct Unroll Payloads with Index Matrix and Accumulation Directives
Data Actions scripts process arrays by expanding them into discrete iteration contexts. You must explicitly define the array variable reference, an index matrix to track position, and an accumulation directive to merge iteration results. The scripting engine rejects payloads that omit these structures.
from typing import List, Any, Dict
def build_unroll_payload(
    script_id: str,
    array_data: List[Any],
    array_variable_name: str,
    accumulation_key: str
) -> Dict[str, Any]:
    Constructs a CXone Data Actions unroll payload.
    Includes array reference, index matrix, and accumulation directive.
    index_matrix = {str(i): {"index": i, "batch_group": i % 10} for i in range(len(array_data))}
    payload = {
        "scriptId": script_id,
        "input": {
            array_variable_name: array_data
        "unrollConfig": {
            "arrayVariableReference": array_variable_name,
            "indexMatrix": index_matrix,
            "accumulationDirective": {
                "key": accumulation_key,
                "strategy": "merge_deep",
                "preserveOrder": True
            "scopeIsolation": True
    return payload
The indexMatrix provides deterministic positioning for each iteration. The accumulationDirective tells the scripting engine how to combine partial results. Setting scopeIsolation to True prevents variable leakage between iterations.
Step 2: Validate Schemas Against Scripting Engine Constraints and Max Loop Depth
CXone enforces a maximum loop depth (typically 5) and strict type consistency. You must validate the payload against the script schema before execution. This step injects null checks and verifies type consistency to prevent runtime engine failures.
import jsonschema
from jsonschema import validate, ValidationError
def validate_unroll_schema(payload: Dict[str, Any], schema_url: str, session: requests.Session, headers: Dict[str, str]) -> bool:
    Fetches script schema and validates payload against CXone constraints.
    Enforces max loop depth, null check injection, and type consistency.
    response = session.get(schema_url, headers=headers)
    schema = response.json().get("schema", {})
    # Inject null check rules for array elements
    input_props = schema.get("properties", {}).get("input", {}).get("properties", {})
    for prop_name, prop_schema in input_props.items():
        if prop_schema.get("type") == "array":
            prop_schema["items"]["required"] = prop_schema.get("items", {}).get("required", [])
            prop_schema["items"]["nullAllowed"] = False
        validate(instance=payload, schema=schema)
    except ValidationError as err:
        raise RuntimeError(f"Schema validation failed: {err.message}") from err
    # Enforce maximum loop depth constraint
    array_len = len(payload["input"].get(list(payload["input"].keys())[0], []))
    max_depth = 5
    if array_len > max_depth * 1000:
        raise ValueError(f"Array length {array_len} exceeds safe execution threshold for max depth {max_depth}")
    return True
The validation pipeline fetches the live schema, injects null rejection rules, and checks array length against engine limits. CXone rejects payloads that bypass these constraints with a 400 status code.
Step 3: Execute Atomic GET Operations with Format Verification and Scope Isolation
You must verify the script format before sending the execution payload. An atomic GET request retrieves the current script version and format. The execution POST request then triggers the unrolling process with automatic scope isolation.
from typing import Tuple
def execute_unroll_with_retry(
    auth: CxoneAuthManager,
    max_retries: int = 3,
    backoff_base: float = 1.5
    Executes the unroll payload with retry logic for 429 and 401 responses.
    Returns execution result and latency metrics.
    script_id = payload["scriptId"]
    execute_url = f"{auth.base_url}/api/v1/data-actions/scripts/{script_id}/execute"
    schema_url = f"{auth.base_url}/api/v1/data-actions/scripts/{script_id}/schema"
    # Atomic GET for format verification
    headers = auth.get_headers()
    schema_response = requests.get(schema_url, headers=headers)
    schema_response.raise_for_status()
    script_format = schema_response.json().get("format", "v1")
    if script_format != "v1":
        raise RuntimeError(f"Unsupported script format: {script_format}. Expected v1.")
    # Execution with retry logic
    attempt = 0
    while attempt < max_retries:
            exec_response = requests.post(execute_url, json=payload, headers=headers)
            latency_ms = round((time.perf_counter() - start_time) * 1000, 2)
            if exec_response.status_code == 429:
                retry_after = float(exec_response.headers.get("Retry-After", backoff_base ** attempt))
                time.sleep(retry_after)
                attempt += 1
            if exec_response.status_code == 401:
                auth._access_token = None  # Force refresh
            exec_response.raise_for_status()
                "success": True,
                "data": exec_response.json(),
                "latency_ms": latency_ms,
                "attempt": attempt + 1
            if attempt == max_retries - 1:
                raise RuntimeError(f"Execution failed after {max_retries} attempts: {str(e)}") from e
            attempt += 1
            time.sleep(backoff_base ** attempt)
    raise RuntimeError("Execution loop exhausted")
The GET call verifies the script format before POST execution. The retry loop handles rate limits (429) and token expiration (401). Latency tracking begins before the first request and ends after a successful response.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
External debuggers require synchronization points. You must emit a loop started webhook when unrolling begins. The tracking pipeline records iteration success rates, latency percentiles, and structured audit entries for governance.
import json
class UnrollTracker:
    def __init__(self, webhook_url: str):
        self.audit_log: List[Dict[str, Any]] = []
        self.latencies: List[float] = []
        self.success_count = 0
        self.failure_count = 0
    def trigger_loop_started_webhook(self, script_id: str, iteration_count: int) -> None:
        webhook_payload = {
            "event": "loop_started",
            "iterationCount": iteration_count,
            "source": "cxone_array_unroller"
        requests.post(self.webhook_url, json=webhook_payload, timeout=5.0)
    def record_execution(self, script_id: str, result: Dict[str, Any], payload_hash: str) -> None:
        is_success = result.get("success", False)
        latency = result.get("latency_ms", 0.0)
        self.latencies.append(latency)
        if is_success:
            self.success_count += 1
        else:
            self.failure_count += 1
        audit_entry = {
            "payloadHash": payload_hash,
            "success": is_success,
            "latency_ms": latency,
            "attempt": result.get("attempt", 0),
            "status_code": 200 if is_success else 500
        self.audit_log.append(audit_entry)
    def get_metrics(self) -> Dict[str, Any]:
        avg_latency = sum(self.latencies) / len(self.latencies) if self.latencies else 0.0
            "total_iterations": total,
            "success_rate": round(self.success_count / total, 4) if total > 0 else 0.0,
            "avg_latency_ms": round(avg_latency, 2),
            "audit_entries": len(self.audit_log)
The tracker emits webhook payloads for debugger alignment, calculates success rates, and stores structured audit records. Each execution appends a timestamped entry for compliance reporting.
The following module combines authentication, validation, execution, and tracking into a single runnable script. Replace the environment variables with your CXone credentials and script ID.
import os
import hashlib
import requests
# Import components from previous steps
# CxoneAuthManager, build_unroll_payload, validate_unroll_schema,
# execute_unroll_with_retry, UnrollTracker
def generate_payload_hash(payload: Dict[str, Any]) -> str:
    payload_str = json.dumps(payload, sort_keys=True)
    return hashlib.sha256(payload_str.encode()).hexdigest()
def run_array_unroller(
    org: str,
    client_id: str,
    client_secret: str,
    script_id: str,
    array_var_name: str,
    accumulation_key: str,
    webhook_url: str
    load_dotenv()
    auth = CxoneAuthManager(org, client_id, client_secret)
    tracker = UnrollTracker(webhook_url)
    # Step 1: Construct payload
    payload = build_unroll_payload(script_id, array_data, array_var_name, accumulation_key)
    payload_hash = generate_payload_hash(payload)
    # Step 2: Validate schema
    validate_unroll_schema(payload, schema_url, auth.session, headers)
    # Step 3: Synchronize webhook
    tracker.trigger_loop_started_webhook(script_id, len(array_data))
    # Step 4: Execute with tracking
    result = execute_unroll_with_retry(auth, payload)
    tracker.record_execution(script_id, result, payload_hash)
    return tracker.get_metrics()
    ORG = os.getenv("CXONE_ORG")
    CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
    CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
    SCRIPT_ID = os.getenv("CXONE_SCRIPT_ID")
    WEBHOOK_URL = os.getenv("DEBUG_WEBHOOK_URL", "https://webhook.site/test")
    sample_array = [{"id": 1, "value": "alpha"}, {"id": 2, "value": "beta"}, {"id": 3, "value": "gamma"}]
    metrics = run_array_unroller(
        org=ORG,
        client_id=CLIENT_ID,
        client_secret=CLIENT_SECRET,
        script_id=SCRIPT_ID,
        array_data=sample_array,
        array_var_name="inputRecords",
        accumulation_key="mergedResults",
        webhook_url=WEBHOOK_URL
    print(json.dumps(metrics, indent=2))
This script loads credentials, builds the unroll payload, validates against the live schema, triggers the debugger webhook, executes the payload with retry logic, and returns aggregated metrics. The code requires only environment variable configuration to run in production.
Error: 400 Bad Request (Schema Validation Failure)
  • Cause: The payload structure violates the script schema. Missing array references, invalid accumulation keys, or type mismatches trigger this response.
  • Fix: Verify the unrollConfig matches the script definition. Ensure arrayVariableReference exactly matches the input parameter name in the CXone admin portal. Run the validate_unroll_schema function before execution to catch mismatches early.
  • Code adjustment: Add explicit type casting for array elements before payload construction.
  • Cause: CXone rate limits Data Actions execution endpoints. Rapid unrolling of large arrays exceeds the organization throttle.
  • Fix: Implement exponential backoff. The execute_unroll_with_retry function reads the Retry-After header and sleeps accordingly. Reduce batch size if throttling persists.
  • Code adjustment: Lower max_retries or increase backoff_base to 2.0 for heavy workloads.
  • Cause: Token expiration during long-running unroll operations.
  • Fix: The CxoneAuthManager forces a token refresh when a 401 occurs. Ensure the client_credentials grant has the data-actions:execute scope attached in the CXone developer console.
  • Code adjustment: Verify scope assignment in Admin Portal > Development > API Clients.
Error: 500 Internal Server Error (Script Engine Constraint Violation)
  • Cause: Exceeding maximum loop depth or triggering null pointer exceptions inside the script engine.
  • Fix: Enforce the max_depth check in validate_unroll_schema. Inject null rejection rules before validation. Reduce array length or split into multiple sequential unroll calls.
  • Code adjustment: Add chunking logic to split arrays exceeding 5000 elements into batches of 1000.
