Programmatic Agent Assist Sentiment Alert Triggering with Python SDK
This tutorial builds a Python module that constructs, validates, and deploys Agent Assist sentiment alert policies using the Genesys Cloud CX Python SDK. The code implements emotion matrix evaluation, baseline deviation checking, false alarm suppression, and atomic policy deployment with automatic supervisor notification routing. It also registers a webhook for Workforce Management synchronization, tracks trigger latency and success rates, and generates governance audit logs. The implementation relies on the official genesyscloud-python-sdk and targets Python 3.10+.
- OAuth Client Type: Service Account (Confidential Client) or Web Application
- Required OAuth Scopes:
agentassist:read,agentassist:write,webhook:write,webhook:read,conversation:read - SDK Version:
genesyscloud-python-sdk>= 2.10.0 - Runtime: Python 3.10 or higher
- External Dependencies:
httpx>=0.24.0,pydantic>=2.0.0,tenacity>=8.2.0
Genesys Cloud CX uses OAuth 2.0 client credentials flow for server-to-server integrations. The following code fetches an access token, caches it, and implements automatic refresh before expiration. The httpx library handles the transport layer with timeout and retry configuration.
import httpx
import json
import logging
from typing import Optional
logger = logging.getLogger("genesys_auth")
@dataclass
class TokenCache:
access_token: Optional[str] = None
expires_at: float = 0.0
refresh_token: Optional[str] = None
def is_valid(self, buffer_seconds: int = 60) -> bool:
return self.access_token is not None and time.time() < (self.expires_at - buffer_seconds)
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, environment: str = "mypurecloud.com"):
self.client_id = client_id
self.token_url = f"https://login.{environment}/v2/oauth/token"
self.cache = TokenCache()
self.http_client = httpx.Client(timeout=httpx.Timeout(15.0), follow_redirects=True)
def fetch_token(self) -> str:
if self.cache.is_valid():
return self.cache.access_token
data = {
"client_id": self.client_id,
"scope": "agentassist:read agentassist:write webhook:write webhook:read conversation:read"
response = self.http_client.post(self.token_url, headers=headers, data=data)
response.raise_for_status()
payload = response.json()
self.cache.access_token = payload["access_token"]
self.cache.expires_at = time.time() + payload["expires_in"]
self.cache.refresh_token = payload.get("refresh_token")
logger.info("OAuth token acquired successfully. Expires in %s seconds.", payload["expires_in"])
Step 1: SDK Initialization and Platform Client Configuration
The Genesys Cloud Python SDK requires a platform client configured with the environment and authentication method. The following initialization binds the httpx transport to the SDK and sets up the AgentAssistApi and WebhookApi clients.
from genesyscloud.platform import platform_client_builder
from genesyscloud.platform.AgentAssistApi import AgentAssistApi
from genesyscloud.platform.WebhookApi import WebhookApi
from genesyscloud.platform.conversations_api import ConversationsApi
class GenesysAgentAssistClient:
def __init__(self, auth_manager: GenesysAuthManager, environment: str = "mypurecloud.com"):
self.auth = auth_manager
self.environment = environment
self.base_url = f"https://api.{environment}"
# Initialize SDK platform client
self.platform = platform_client_builder.build(
environment=environment,
oauth_client_id=auth_manager.client_id,
oauth_client_secret=auth_manager.client_secret,
oauth_scopes=["agentassist:read", "agentassist:write", "webhook:write", "webhook:read", "conversation:read"]
self.agent_assist_api = AgentAssistApi(self.platform)
self.webhook_api = WebhookApi(self.platform)
# Tracking metrics
self.trigger_latency_log = []
self.alert_success_count = 0
self.alert_failure_count = 0
self.audit_log = []
Step 2: Construct Sentiment Trigger Payload with Emotion Matrix and Directive
Genesys Cloud Agent Assist policies use condition-action structures. The following code maps the requested sentiment reference, emotion matrix, and alert directive into the official AgentAssistPolicy schema. It also implements baseline deviation checking and false alarm suppression logic before payload generation.
from genesyscloud.platform.models import (
AgentAssistPolicy, AgentAssistCondition, AgentAssistAction,
AgentAssistConditionValue, AgentAssistWebhookAction
class SentimentTriggerBuilder:
BASELINE_THRESHOLD = 0.45
FALSE_ALARM_COOLDOWN_SECONDS = 300
MAX_ALERTS_PER_MINUTE = 12
def __init__(self, platform_client, auth_manager):
self.api = AgentAssistApi(platform_client)
self.alert_timestamps = []
def evaluate_baseline_deviation(self, current_intensity: float) -> bool:
return abs(current_intensity) > self.BASELINE_THRESHOLD
def check_false_alarm_suppression(self) -> bool:
now = time.time()
self.alert_timestamps = [t for t in self.alert_timestamps if now - t < self.FALSE_ALARM_COOLDOWN_SECONDS]
return len(self.alert_timestamps) == 0
def enforce_rate_limit(self) -> bool:
now = time.time()
window_start = now - 60
self.alert_timestamps = [t for t in self.alert_timestamps if t > window_start]
return len(self.alert_timestamps) < self.MAX_ALERTS_PER_MINUTE
def build_payload(self, sentiment_reference: str, emotion_matrix: dict, escalation_threshold: float) -> AgentAssistPolicy:
if not self.evaluate_baseline_deviation(emotion_matrix.get("intensity", 0.0)):
raise ValueError("Emotion intensity does not exceed baseline deviation threshold.")
if not self.check_false_alarm_suppression():
raise RuntimeError("False alarm suppression active. Alert throttled.")
if not self.enforce_rate_limit():
raise RuntimeError("Maximum alert rate limit reached. Trigger blocked.")
condition = AgentAssistCondition(
type="sentiment",
operator="greater_than",
value=AgentAssistConditionValue(value=str(escalation_threshold))
action = AgentAssistAction(
type="webhook",
target_uri="https://your-wfm-system.internal/api/v1/alerts/supervisor",
body=json.dumps({
"sentiment_reference": sentiment_reference,
"emotion_matrix": emotion_matrix,
"alert_directive": "escalate_to_supervisor",
"timestamp": time.time(),
"agent_id": "{{conversation.participants.agent.id}}",
"conversation_id": "{{conversation.id}}"
policy = AgentAssistPolicy(
name="Sentiment Escalation Policy",
description="Automated supervisor notification for high-intensity negative sentiment",
conditions=[condition],
actions=[action],
enabled=True
self.alert_timestamps.append(time.time())
return policy
Step 3: Schema Validation and Rate Limit Enforcement
Before deployment, the payload must pass schema validation against Genesys Cloud constraints. The following method validates field types, checks maximum string lengths, and verifies the emotion matrix structure. It also implements exponential backoff retry logic for 429 rate limit responses.
import re
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
class PolicyValidator:
REQUIRED_FIELDS = ["name", "conditions", "actions"]
MAX_NAME_LENGTH = 256
ALLOWED_EMOTION_KEYS = {"anger", "frustration", "joy", "neutral", "sadness", "fear"}
@staticmethod
def validate_emotion_matrix(matrix: dict) -> bool:
if not isinstance(matrix, dict):
return False
valid_keys = set(matrix.keys()).issubset(PolicyValidator.ALLOWED_EMOTION_KEYS)
for value in matrix.values():
if not isinstance(value, (int, float)) or not (0.0 <= value <= 1.0):
return False
return valid_keys
@staticmethod
def validate_policy_schema(policy: AgentAssistPolicy) -> bool:
if not policy.name or len(policy.name) > PolicyValidator.MAX_NAME_LENGTH:
return False
if not policy.conditions or not policy.actions:
return False
for condition in policy.conditions:
if condition.type not in ["sentiment", "keyword", "intent"]:
return False
return True
@staticmethod
def validate_supervisor_directive(payload_body: str) -> bool:
data = json.loads(payload_body)
return data.get("alert_directive") in ["escalate_to_supervisor", "notify_wfm", "log_only"]
except json.JSONDecodeError:
return False
Step 4: Atomic POST Operation and Supervisor Notification
The following code performs the atomic deployment of the validated policy. It captures the full HTTP cycle, handles SDK exceptions, and logs the transaction for governance. The tenacity decorator manages automatic retries on 429 and 5xx responses.
from genesyscloud.platform.rest import ApiException
class PolicyDeployer:
def __init__(self, api: AgentAssistApi, validator: PolicyValidator):
self.api = api
self.validator = validator
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type(ApiException)
def deploy_policy(self, policy: AgentAssistPolicy) -> dict:
if not self.validator.validate_policy_schema(policy):
raise ValueError("Policy schema validation failed.")
start_time = time.time()
# SDK call maps to: POST /api/v2/agent-assist/policies
# Headers: Authorization: Bearer <token>, Content-Type: application/json
response = self.api.post_agent_assist_policies(body=policy)
latency = time.time() - start_time
"status": "success",
"policy_id": response.id,
"latency_ms": latency * 1000,
"http_status": 201,
"response_body": response.to_dict(),
"audit_entry": {
"action": "policy_deploy",
"policy_name": policy.name,
"timestamp": start_time,
"result": "success"
except ApiException as e:
error_audit = {
"policy_name": policy.name if policy else "unknown",
"result": "failure",
"http_status": e.status,
"reason": e.reason
raise
Step 5: WFM Webhook Synchronization and Audit Tracking
After policy deployment, the system registers a webhook to synchronize triggering events with external Workforce Management systems. The following code constructs the webhook payload, handles the POST request, and updates the tracking metrics.
from genesyscloud.platform.models import Webhook, WebhookCondition, WebhookConditionValue
class WebhookSyncManager:
def __init__(self, api: WebhookApi):
self.api = api
def register_wfm_sync_webhook(self, policy_id: str) -> dict:
webhook = Webhook(
name="WFM Sentiment Alert Sync",
description="Synchronizes agent assist sentiment alerts with external WFM",
enabled=True,
type="webhook",
uri="https://your-wfm-system.internal/api/v1/genesys/sentiment-sync",
conditions=[
WebhookCondition(
type="event",
operator="equal",
value=WebhookConditionValue(value="agentassist.policy.triggered")
headers={"Content-Type": "application/json", "X-Policy-Id": policy_id}
# POST /api/v2/webhooks
response = self.api.post_webhooks(body=webhook)
"webhook_id": response.id,
"sync_target": webhook.uri,
"audit_entry": {
"action": "webhook_register",
"target_system": "wfm",
"result": "success"
"status": "failure",
"webhook_id": None,
"audit_entry": {
"reason": e.reason
The following script integrates all components into a single executable module. It authenticates, builds the sentiment trigger, validates constraints, deploys the policy atomically, registers the WFM webhook, and outputs the audit trail.
import sys
import json
def main():
# Configuration
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
ENVIRONMENT = "mypurecloud.com"
# Sentiment parameters
SENTIMENT_REF = "customer_escalation_v2"
EMOTION_MATRIX = {"anger": 0.82, "frustration": 0.65, "neutral": 0.10}
ESCALATION_THRESHOLD = 0.50
print("Initializing Genesys Cloud Agent Assist Trigger Pipeline...")
# Step 1: Authentication
auth_manager = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET, ENVIRONMENT)
token = auth_manager.fetch_token()
print(f"Authentication successful. Token expires at {time.strftime('%Y-%m-%d %H:%M:%S', time.localtime(auth_manager.cache.expires_at))}")
# Step 2: Platform Client
client = GenesysAgentAssistClient(auth_manager, ENVIRONMENT)
# Step 3: Build Payload
builder = SentimentTriggerBuilder(client.platform, auth_manager)
validator = PolicyValidator()
policy = builder.build_payload(SENTIMENT_REF, EMOTION_MATRIX, ESCALATION_THRESHOLD)
print("Payload constructed successfully. Emotion matrix validated.")
print(f"Payload construction failed: {e}")
sys.exit(1)
# Step 4: Deploy Policy Atomically
deployer = PolicyDeployer(client.agent_assist_api, validator)
deploy_result = deployer.deploy_policy(policy)
print(f"Policy deployed. ID: {deploy_result['policy_id']}. Latency: {deploy_result['latency_ms']:.2f}ms")
client.alert_success_count += 1
client.trigger_latency_log.append(deploy_result['latency_ms'])
client.audit_log.append(deploy_result['audit_entry'])
print(f"Policy deployment failed: {e}")
client.alert_failure_count += 1
sys.exit(1)
# Step 5: WFM Webhook Sync
sync_manager = WebhookSyncManager(client.webhook_api)
webhook_result = sync_manager.register_wfm_sync_webhook(deploy_result['policy_id'])
if webhook_result["status"] == "success":
print(f"WFM webhook registered. ID: {webhook_result['webhook_id']}")
client.audit_log.append(webhook_result['audit_entry'])
else:
print(f"WFM webhook registration failed: {webhook_result.get('reason', 'Unknown error')}")
# Output Audit Log
print("\n--- Governance Audit Log ---")
print(json.dumps(client.audit_log, indent=2))
print(f"\nTrigger Metrics -> Success: {client.alert_success_count}, Failure: {client.alert_failure_count}")
if client.trigger_latency_log:
avg_latency = sum(client.trigger_latency_log) / len(client.trigger_latency_log)
print(f"Average Latency: {avg_latency:.2f}ms")
main()
- Cause: The OAuth token has expired, the client credentials are incorrect, or the
grant_typeparameter is missing. - Fix: Verify
CLIENT_IDandCLIENT_SECRETin the Admin console under Security > OAuth 2.0. Ensure thefetch_tokenmethod runs before every SDK initialization. TheGenesysAuthManagerclass handles automatic refresh, but manual token invalidation requires re-instantiation. - Code Fix: The
is_valid()method includes a 60-second buffer. Reduce this buffer if your environment enforces strict token expiration policies.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scopes (
agentassist:write,webhook:write), or the service account does not have the Agent Assist Administrator role. - Fix: Navigate to Security > OAuth 2.0 > Clients, select your client, and add the missing scopes. Assign the service account the
Agent Assist AdministratororSecurity Administratorrole. - Code Fix: Update the
scopeparameter infetch_token()to include all required permissions. The SDK will raise a clear 403 with areasonfield indicating the missing scope.
- Cause: The request rate exceeds Genesys Cloud API limits (typically 100 requests per minute per client for configuration endpoints).
- Fix: The
tenacitydecorator indeploy_policyimplements exponential backoff. If failures persist, implement a global request queue or increase thewait_exponentialmultiplier. - Code Fix: Adjust the retry configuration:
wait=wait_exponential(multiplier=2, min=4, max=30). Monitor theRetry-Afterheader in the 429 response payload.
Error: 400 Bad Request
- Cause: The payload schema violates Genesys Cloud constraints. Common issues include invalid emotion matrix values outside the 0.0 to 1.0 range, missing required condition fields, or malformed JSON in the webhook body.
- Fix: Run the
PolicyValidator.validate_policy_schema()andvalidate_emotion_matrix()methods before deployment. Ensure all string fields comply with length limits. - Code Fix: The
PolicyValidatorclass catches these violations early. If the SDK still returns 400, parsee.bodyto retrieve the specific field error returned by the Genesys Cloud validation engine.
