Processing NICE CXone DTMF Input Streams via WebSocket with Go
  • A persistent WebSocket client that captures real-time DTMF digits from the CXone Voice API, validates sequences against an IVR tree, manages input timeouts, updates interaction variables via REST, logs processing latency, and provides a local simulator endpoint for testing.
  • This implementation uses the CXone Voice WebSocket endpoint (/api/v2/voice/websocket) and the Interaction Variables API (/api/v2/interactions/{id}/variables).
  • The tutorial covers Go 1.21+ with gorilla/websocket and standard net/http libraries.
  • CXone OAuth 2.0 client credentials flow with scopes: voice:read, interactions:read, interactions:write
  • CXone API v2 endpoints (tenant-specific base URL)
  • Go 1.21 or newer
  • External dependencies: github.com/gorilla/websocket, github.com/google/uuid
CXone uses standard OAuth 2.0 client credentials. The token expires after one hour and requires a cache with refresh logic. The following module fetches and caches tokens with automatic expiry handling.
package auth
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"net/http"
	"sync"
	"time"
type TokenResponse struct {
	ExpiresIn   int    `json:"expires_in"`
type OAuthClient struct {
	Tenant      string
	ClientID    string
	ClientSecret string
	httpClient  *http.Client
	token       *TokenResponse
	expiresAt   time.Time
	mu          sync.RWMutex
func NewOAuthClient(tenant, clientID, clientSecret string) *OAuthClient {
	return &OAuthClient{
		Tenant:       tenant,
		ClientID:     clientID,
		ClientSecret: clientSecret,
		httpClient:   &http.Client{Timeout: 10 * time.Second},
func (o *OAuthClient) GetToken(ctx context.Context) (string, error) {
	o.mu.RLock()
	if o.token != nil && time.Now().Before(o.expiresAt.Add(-30 * time.Second)) {
		token := o.token.AccessToken
		o.mu.RUnlock()
		return token, nil
	o.mu.RUnlock()
	o.mu.Lock()
	defer o.mu.Unlock()
	// Double-check after acquiring write lock
		return o.token.AccessToken, nil
	payload := fmt.Sprintf(`{"grant_type":"client_credentials","client_id":"%s","client_secret":"%s"}`, o.ClientID, o.ClientSecret)
	resp, err := o.httpClient.Post(fmt.Sprintf("https://%s.cxone.com/oauth/token", o.Tenant), "application/json", bytes.NewBufferString(payload))
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth returned status %d", resp.StatusCode)
	var tokenResp TokenResponse
		return "", fmt.Errorf("oauth decode failed: %w", err)
	o.token = &tokenResp
	o.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
Step 1: WebSocket Connection & Message Parsing
The CXone Voice WebSocket streams real-time call events. You must establish a persistent connection, handle ping/pong keep-alive signals, and parse JSON payloads for DTMF events. The connection must auto-reconnect on unexpected close codes.
package websocket
import (
	"context"
	"encoding/json"
	"fmt"
	"log"
	"time"
	"github.com/gorilla/websocket"
type DTMFEvent struct {
	Type    string `json:"type"`
	Digit   string `json:"digit"`
	CallID  string `json:"callId"`
	Timestamp int64 `json:"timestamp"`
type Client struct {
	Tenant      string
	TokenGetter func(ctx context.Context) (string, error)
	OnDTMF      func(event DTMFEvent)
	conn        *websocket.Conn
func NewClient(tenant string, tokenGetter func(ctx context.Context) (string, error), onDTMF func(event DTMFEvent)) *Client {
	return &Client{
		Tenant:      tenant,
		TokenGetter: tokenGetter,
		OnDTMF:      onDTMF,
func (c *Client) Connect(ctx context.Context) error {
	token, err := c.TokenGetter(ctx)
	if err != nil {
		return fmt.Errorf("failed to fetch token: %w", err)
	headers := map[string][]string{
		"Authorization": {fmt.Sprintf("Bearer %s", token)},
	dialer := websocket.Dialer{
		HandshakeTimeout: 15 * time.Second,
	u := fmt.Sprintf("wss://%s.cxone.com/api/v2/voice/websocket", c.Tenant)
	conn, _, err := dialer.Dial(u, headers)
	if err != nil {
		return fmt.Errorf("websocket dial failed: %w", err)
	c.conn = conn
	c.startReader(ctx)
	return nil
func (c *Client) startReader(ctx context.Context) {
	defer func() {
		if c.conn != nil {
			c.conn.Close()
	for {
		select {
		case <-ctx.Done():
			return
		default:
			_, message, err := c.conn.ReadMessage()
			if err != nil {
				if websocket.IsUnexpectedCloseError(err, websocket.CloseGoingAway, websocket.CloseNormalClosure) {
					log.Printf("websocket error, reconnecting: %v", err)
					time.Sleep(2 * time.Second)
					_ = c.Connect(ctx)
				return
			var evt DTMFEvent
			if err := json.Unmarshal(message, &evt); err != nil {
			if evt.Type == "dtmf" && c.OnDTMF != nil {
				c.OnDTMF(evt)
Step 2: DTMF State Machine, Timeout & Validation
You must reconstruct menu navigation paths, enforce timeouts for incomplete sequences, validate against IVR definitions, and cache history. The state machine uses a time.Timer that resets on each digit. If the timer fires, the system triggers fallback routing.
package ivr
import (
	"fmt"
	"log"
	"sync"
	"time"
type IVRDefinition struct {
	RootNode string
	Nodes    map[string]Node
type Node struct {
	AllowedDigits []string
	NextNode      string
	IsTerminal    bool
type Session struct {
	CallID        string
	CurrentNode   string
	History       []string
	Timer         *time.Timer
	TimeoutDuration time.Duration
type Engine struct {
	IVR       *IVRDefinition
	Sessions  map[string]*Session
	mu        sync.RWMutex
	OnTimeout func(callID string)
	OnSelect  func(callID string, path []string)
func NewEngine(ivr *IVRDefinition, timeout time.Duration, onTimeout func(string), onSelect func(string, []string)) *Engine {
	return &Engine{
		IVR:         ivr,
		Sessions:    make(map[string]*Session),
		TimeoutDuration: timeout,
		OnTimeout: onTimeout,
		OnSelect: onSelect,
func (e *Engine) ProcessDigit(callID, digit string) {
	e.mu.Lock()
	sess, exists := e.Sessions[callID]
	if !exists {
		sess = &Session{
			CallID:      callID,
			CurrentNode: e.IVR.RootNode,
			History:     []string{},
		e.Sessions[callID] = sess
	if sess.Timer != nil {
		sess.Timer.Reset(e.TimeoutDuration)
	} else {
		sess.Timer = time.AfterFunc(e.TimeoutDuration, func() {
			e.handleTimeout(callID)
	e.mu.Unlock()
	node := e.IVR.Nodes[sess.CurrentNode]
	valid := false
	for _, d := range node.AllowedDigits {
		if d == digit {
			valid = true
			break
	if !valid {
		log.Printf("invalid digit %s for node %s on call %s", digit, sess.CurrentNode, callID)
		return
	e.mu.Lock()
	sess.History = append(sess.History, digit)
	sess.CurrentNode = node.NextNode
	e.mu.Unlock()
	if node.IsTerminal {
		e.mu.Lock()
			sess.Timer.Stop()
		path := make([]string, len(sess.History))
		copy(path, sess.History)
		e.mu.Unlock()
		e.OnSelect(callID, path)
func (e *Engine) handleTimeout(callID string) {
	e.mu.Lock()
	sess := e.Sessions[callID]
	if sess != nil && sess.Timer != nil {
		sess.Timer.Stop()
	e.mu.Unlock()
	if e.OnTimeout != nil {
		e.OnTimeout(callID)
Step 3: Interaction Variable Update & Latency Logging
When a menu selection completes, you must update call state variables via the CXone Interaction API. The request must include retry logic for 429 rate limits and log processing latency for UX optimization.
package interaction
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"net/http"
	"time"
type VariableUpdate struct {
	Name  string `json:"name"`
	Value string `json:"value"`
	Tenant     string
func NewClient(tenant string, tokenGetter func(ctx context.Context) (string, error)) *Client {
	return &Client{
		Tenant:      tenant,
func (c *Client) UpdateVariables(ctx context.Context, interactionID string, variables []VariableUpdate) error {
	start := time.Now()
	if err != nil {
		return fmt.Errorf("token fetch failed: %w", err)
	payload, _ := json.Marshal(variables)
	url := fmt.Sprintf("https://%s.cxone.com/api/v2/interactions/%s/variables", c.Tenant, interactionID)
	// Retry logic for 429
	var resp *http.Response
	for attempt := 0; attempt < 3; attempt++ {
		req, _ := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewBuffer(payload))
		req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
		resp, err = c.httpClient.Do(req)
		if err != nil {
			return fmt.Errorf("request failed: %w", err)
			retryAfter := 2 * time.Duration(attempt+1) * time.Second
			log.Printf("rate limited (429), retrying in %v", retryAfter)
			time.Sleep(retryAfter)
		break
	if resp.StatusCode < 200 || resp.StatusCode >= 300 {
		return fmt.Errorf("interaction API returned %d: %s", resp.StatusCode, string(body))
	latency := time.Since(start)
	log.Printf("interaction variables updated for %s in %v", interactionID, latency)
	return nil
Step 4: DTMF Simulator for IVR Testing
You must expose a local HTTP endpoint that injects synthetic DTMF events. This allows developers to test menu navigation, timeout fallbacks, and variable updates without placing live calls.
package simulator
import (
	"encoding/json"
	"net/http"
	"time"
type SimulatorInput struct {
type Handler struct {
	OnDigit func(callID, digit string)
func (h *Handler) ServeHTTP(w http.ResponseWriter, r *http.Request) {
	if r.Method != http.MethodPost {
		http.Error(w, "method not allowed", http.StatusMethodNotAllowed)
		return
	var input SimulatorInput
	if err := json.NewDecoder(r.Body).Decode(&input); err != nil {
		http.Error(w, "invalid payload", http.StatusBadRequest)
		return
	// Simulate network latency
	time.Sleep(50 * time.Millisecond)
	h.OnDigit(input.CallID, input.Digit)
	w.WriteHeader(http.StatusOK)
	json.NewEncoder(w).Encode(map[string]string{"status": "digit_processed"})
The following module integrates all components into a single executable service. It initializes OAuth, starts the WebSocket listener, configures the IVR engine, wires the simulator, and handles graceful shutdown.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"log"
	"net/http"
	"os"
	"os/signal"
	"syscall"
	"time"
	"dtmfprocessor/auth"
	"dtmfprocessor/interaction"
	"dtmfprocessor/ivr"
	"dtmfprocessor/simulator"
	"dtmfprocessor/websocket"
func main() {
	tenant := os.Getenv("CXONE_TENANT")
	clientID := os.Getenv("CXONE_CLIENT_ID")
	clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
	if tenant == "" || clientID == "" || clientSecret == "" {
		log.Fatal("missing required environment variables: CXONE_TENANT, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET")
	oauth := auth.NewOAuthClient(tenant, clientID, clientSecret)
	interactionClient := interaction.NewClient(tenant, oauth.GetToken)
	// Define IVR tree
	ivrDef := &ivr.IVDefinition{
		RootNode: "main_menu",
		Nodes: map[string]ivr.Node{
			"main_menu": {
				AllowedDigits: []string{"1", "2", "3"},
				NextNode:      "department",
			"department": {
				AllowedDigits: []string{"A", "B"},
				NextNode:      "confirm",
			"confirm": {
				AllowedDigits: []string{"1"},
				NextNode:      "",
				IsTerminal:    true,
	engine := ivr.NewEngine(ivrDef, 10*time.Second, func(callID string) {
		log.Printf("timeout fallback triggered for call %s", callID)
		_ = interactionClient.UpdateVariables(context.Background(), callID, []interaction.VariableUpdate{
			{Name: "ivr_status", Value: "timeout_fallback"},
	}, func(callID string, path []string) {
		log.Printf("menu selection complete for call %s: %v", callID, path)
		pathJSON, _ := json.Marshal(path)
			{Name: "ivr_selection", Value: string(pathJSON)},
			{Name: "ivr_status", Value: "completed"},
	wsClient := websocket.NewClient(tenant, oauth.GetToken, func(evt websocket.DTMFEvent) {
		engine.ProcessDigit(evt.CallID, evt.Digit)
	simHandler := &simulator.Handler{
		OnDigit: func(callID, digit string) {
			engine.ProcessDigit(callID, digit)
	ctx, cancel := context.WithCancel(context.Background())
	defer cancel()
	go func() {
		if err := wsClient.Connect(ctx); err != nil {
			log.Printf("websocket connection failed: %v", err)
	http.Handle("/simulator", simHandler)
	http.HandleFunc("/health", func(w http.ResponseWriter, r *http.Request) {
		fmt.Fprint(w, "ok")
	server := &http.Server{Addr: ":8080"}
	go func() {
		log.Printf("simulator listening on :8080")
		if err := server.ListenAndServe(); err != nil && err != http.ErrServerClosed {
			log.Fatalf("http server failed: %v", err)
	quit := make(chan os.Signal, 1)
	signal.Notify(quit, syscall.SIGINT, syscall.SIGTERM)
	<-quit
	log.Println("shutting down...")
	cancel()
	shutdownCtx, shutdownCancel := context.WithTimeout(context.Background(), 5*time.Second)
	defer shutdownCancel()
	server.Shutdown(shutdownCtx)
Error: 401 Unauthorized on WebSocket or REST calls
  • Cause: Expired OAuth token, incorrect client credentials, or missing voice:read / interactions:write scopes.
  • Fix: Verify the token fetcher returns a fresh token. The auth module caches tokens and refreshes 30 seconds before expiry. Check CXone admin console for scope assignments.
  • Code showing the fix: The GetToken method checks time.Now().Before(o.expiresAt.Add(-30 * time.Second)) and forces a refresh when approaching expiry.
Error: 429 Too Many Requests on Interaction Variables API
  • Cause: Exceeding CXone rate limits during high-volume DTMF processing or rapid variable updates.
  • Fix: Implement exponential backoff. The interaction.UpdateVariables method retries up to three times with increasing delays. Add jitter in production.
  • Code showing the fix: The retry loop checks resp.StatusCode == http.StatusTooManyRequests and sleeps 2 * time.Duration(attempt+1) * time.Second.
Error: WebSocket Close Code 1006 or 1011
  • Cause: Network interruption, CXone server maintenance, or malformed upgrade headers.
  • Fix: The startReader loop detects unexpected close codes and triggers c.Connect(ctx) after a 2-second delay. Ensure the Authorization header uses Bearer format.
  • Code showing the fix: if websocket.IsUnexpectedCloseError(err, websocket.CloseGoingAway, websocket.CloseNormalClosure) triggers reconnection.
Error: Invalid DTMF Transition or Stuck Timeout
  • Cause: Digit does not match AllowedDigits in the current IVR node, or the timer was not reset after a valid input.
  • Fix: Verify the IVR definition matches your actual flow. The ProcessDigit method resets the timer on every valid digit. Invalid digits are logged and ignored, preserving the current node state.
  • Code showing the fix: sess.Timer.Reset(e.TimeoutDuration) executes before validation, ensuring the timeout window extends with each valid press.
