Processing NICE CXone Data Actions with Apache Flink using Java
  • A Flink streaming job that ingests NICE CXone Data Actions via Kafka, applies tumbling window aggregations to calculate real-time interaction volumes, joins events with static customer data routed through a side output stream, detects complex interaction patterns using the Flink CEP library, and persists results to Apache Cassandra.
  • The implementation uses the Flink 1.17 Java API, the official Flink Kafka Connector, Flink CEP, and the Flink Cassandra Sink.
  • All code is written in Java 17 with Maven dependencies.
  • NICE CXone OAuth 2.0 client credentials with data_actions:read scope
  • Flink 1.17.1 runtime and Java 17 JDK
  • Apache Kafka 3.5+ cluster with a topic named cxone-data-actions
  • Apache Cassandra 4.1+ cluster with keyspace cxone_analytics and table interaction_volumes
  • Maven 3.8+ for dependency management
  • Required Maven dependencies: flink-core, flink-streaming-java, flink-clients, flink-connector-kafka, flink-cep, flink-connector-cassandra, flink-json, jackson-databind, okhttp
NICE CXone Data Actions require OAuth 2.0 client credentials authentication before you can validate the output schema or configure stream routing. The following Java utility fetches an access token and verifies the Data Action configuration using the /api/v2/data-actions endpoint.
import java.io.IOException;
import java.net.URI;
import java.nio.charset.StandardCharsets;
import java.util.Base64;
public class CxoneAuthClient {
    private static final String TOKEN_ENDPOINT = "https://api.nicecxone.com/oauth/token";
    private static final String DATA_ACTIONS_ENDPOINT = "https://api.nicecxone.com/api/v2/data-actions";
    private static final ObjectMapper mapper = new ObjectMapper();
    public static String fetchAccessToken(String clientId, String clientSecret) throws IOException, InterruptedException {
        String credentials = Base64.getEncoder().encodeToString((clientId + ":" + clientSecret).getBytes(StandardCharsets.UTF_8));
        String body = "grant_type=client_credentials";
                .uri(URI.create(TOKEN_ENDPOINT))
                .header("Authorization", "Basic " + credentials)
                .header("Content-Type", "application/x-www-form-urlencoded")
                .POST(HttpRequest.BodyPublishers.ofString(body))
                .build();
        HttpResponse<String> response = HttpClient.newHttpClient().send(request, HttpResponse.BodyHandlers.ofString());
        if (response.statusCode() == 401) {
            throw new RuntimeException("OAuth 401: Invalid client credentials");
        if (response.statusCode() == 429) {
            throw new RuntimeException("OAuth 429: Rate limit exceeded. Implement exponential backoff.");
        JsonNode json = mapper.readTree(response.body());
        return json.get("access_token").asText();
    public static void validateDataAction(String accessToken, String actionId) throws IOException, InterruptedException {
                .uri(URI.create(DATA_ACTIONS_ENDPOINT + "/" + actionId))
                .header("Authorization", "Bearer " + accessToken)
                .GET()
                .build();
        if (response.statusCode() == 403) {
            throw new RuntimeException("OAuth 403: Missing data_actions:read scope");
        if (response.statusCode() == 404) {
            throw new RuntimeException("Data Action not found. Verify actionId matches CXone configuration.");
        System.out.println("Data Action validated successfully. Schema matches Kafka topic: cxone-data-actions");
The required OAuth scope is data_actions:read. Store credentials in environment variables or a secrets manager. The token expires after 3600 seconds. Implement a token refresh wrapper in production by caching the token and checking expires_in before reuse.
Step 1: Kafka Source with Custom Rate Limiter and Backpressure Handling
Flink manages network backpressure natively via credit-based flow control. When downstream operators cannot keep pace with upstream producers, you must throttle the source to prevent heap exhaustion. The following RateLimitedKafkaSource wraps the Kafka consumer with a token bucket algorithm that caps ingestion to a configurable rate per second.
import org.apache.flink.api.common.eventtime.WatermarkStrategy;
import org.apache.flink.api.common.serialization.SimpleStringSchema;
import org.apache.flink.connector.base.source.reader.SourceReader;
import org.apache.flink.connector.kafka.source.KafkaSource;
import org.apache.flink.connector.kafka.source.enumerator.KafkaSourceEnumerator;
import org.apache.flink.connector.kafka.source.reader.KafkaSourceReader;
import org.apache.flink.connector.kafka.source.reader.KafkaSourceReaderContext;
import org.apache.flink.connector.kafka.source.reader.KafkaSourceReaderMetrics;
import org.apache.flink.connector.kafka.source.reader.fan.KafkaPartitionSplitReader;
import org.apache.flink.connector.kafka.source.split.KafkaPartitionSplit;
import org.apache.flink.streaming.api.functions.source.SourceFunction;
import org.apache.flink.streaming.api.watermark.Watermark;
import org.apache.flink.util.Collector;
import org.apache.kafka.clients.consumer.ConsumerConfig;
import org.apache.kafka.clients.consumer.ConsumerRecord;
import org.apache.kafka.clients.consumer.KafkaConsumer;
import org.apache.kafka.common.serialization.StringDeserializer;
import java.time.Duration;
import java.util.Collection;
import java.util.Collections;
import java.util.Properties;
import java.util.concurrent.Semaphore;
public class RateLimitedKafkaSource implements SourceFunction<String> {
    private final String bootstrapServers;
    private final String topic;
    private final int maxEventsPerSecond;
    private volatile boolean isRunning = true;
    private final Semaphore rateLimiter;
    public RateLimitedKafkaSource(String bootstrapServers, String topic, int maxEventsPerSecond) {
        this.bootstrapServers = bootstrapServers;
        this.topic = topic;
        this.maxEventsPerSecond = maxEventsPerSecond;
        // Token bucket approximation using semaphore with periodic refill
        this.rateLimiter = new Semaphore(maxEventsPerSecond);
    @Override
    public void run(SourceContext<String> ctx) throws Exception {
        // Background thread to refill tokens every second
        Thread refillThread = new Thread(() -> {
            while (isRunning) {
                    Thread.sleep(1000);
                    rateLimiter.release(maxEventsPerSecond);
                } catch (InterruptedException e) {
                    Thread.currentThread().interrupt();
                    break;
        refillThread.start();
        Properties props = new Properties();
        props.setProperty(ConsumerConfig.BOOTSTRAP_SERVERS_CONFIG, bootstrapServers);
        props.setProperty(ConsumerConfig.KEY_DESERIALIZER_CLASS_CONFIG, StringDeserializer.class.getName());
        props.setProperty(ConsumerConfig.VALUE_DESERIALIZER_CLASS_CONFIG, StringDeserializer.class.getName());
        props.setProperty(ConsumerConfig.GROUP_ID_CONFIG, "flink-cxone-consumer");
        props.setProperty(ConsumerConfig.AUTO_OFFSET_RESET_CONFIG, "latest");
        try (KafkaConsumer<String, String> consumer = new KafkaConsumer<>(props)) {
            consumer.subscribe(Collections.singletonList(topic));
            while (isRunning) {
                var records = consumer.poll(Duration.ofMillis(100));
                for (ConsumerRecord<String, String> record : records) {
                    if (rateLimiter.tryAcquire()) {
                        ctx.collect(record.value());
                    } else {
                        // Backpressure signal: sleep briefly to yield CPU
                        Thread.sleep(10);
        } finally {
            refillThread.interrupt();
    @Override
    public void cancel() {
        isRunning = false;
This source enforces a hard cap on ingestion velocity. When the semaphore is exhausted, the consumer yields instead of blocking the Flink task manager thread. This prevents OOM errors during CXone campaign spikes.
Step 2: Windowed Aggregations for Real-Time Interaction Volumes
After ingestion, you must aggregate interaction counts per channel within tumbling windows. CXone Data Actions emit JSON payloads containing channel, timestamp, and interactionId. The following pipeline keyes by channel and applies a 10-second tumbling event-time window.
import org.apache.flink.api.common.functions.AggregateFunction;
import org.apache.flink.streaming.api.datastream.DataStream;
import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
import org.apache.flink.streaming.api.windowing.assigners.TumblingEventTimeWindows;
import org.apache.flink.streaming.api.windowing.time.Time;
import org.apache.flink.streaming.api.windowing.triggers.Trigger;
import org.apache.flink.streaming.api.windowing.triggers.TriggerResult;
import org.apache.flink.streaming.api.windowing.windows.TimeWindow;
public class InteractionVolumeAggregator {
    public static DataStream<VolumeRecord> buildAggregationPipeline(DataStream<String> rawStream) {
        return rawStream
                .filter(line -> !line.isEmpty())
                .map(line -> {
                        JsonNode node = mapper.readTree(line);
                        return new InteractionEvent(
                                node.get("channel").asText(),
                                node.get("interactionId").asText(),
                                System.currentTimeMillis()
                    } catch (Exception e) {
                        throw new RuntimeException("Malformed CXone payload", e);
                .keyBy(InteractionEvent::getChannel)
                .window(TumblingEventTimeWindows.of(Time.seconds(10)))
                .aggregate(new VolumeAggregateFunction());
    public static class VolumeAggregateFunction implements AggregateFunction<InteractionEvent, Integer, VolumeRecord> {
        @Override
        public Integer createAccumulator() { return 0; }
        @Override
        public Integer add(InteractionEvent event, Integer acc) { return acc + 1; }
        @Override
        public VolumeRecord getResult(Integer acc) {
            return new VolumeRecord(System.currentTimeMillis(), acc);
        @Override
        public Integer merge(Integer a, Integer b) { return a + b; }
record InteractionEvent(String channel, String interactionId, long timestamp) {}
record VolumeRecord(long windowEnd, int volume) {}
The TumblingEventTimeWindows ensures exactly-once semantics when checkpoints are enabled. The aggregate function maintains minimal state by incrementing a counter instead of collecting full event lists.
Step 3: Side Output Routing and Static Customer Data Join
CXone Data Actions often mix transactional events with static customer profile updates. You must separate these streams using an OutputTag, then join the static data with the aggregated volumes using a KeyedProcessFunction and MapState.
import org.apache.flink.api.common.state.MapState;
import org.apache.flink.api.common.state.MapStateDescriptor;
import org.apache.flink.api.common.typeinfo.Types;
import org.apache.flink.streaming.api.datastream.SingleOutputStreamOperator;
import org.apache.flink.streaming.api.functions.co.KeyedCoProcessFunction;
import org.apache.flink.streaming.api.functions.process.ProcessFunction;
import org.apache.flink.util.OutputTag;
public class CustomerDataJoiner {
    public static final OutputTag<String> CUSTOMER_DATA_TAG = new OutputTag<>("customer-data") {};
    public static SingleOutputStreamOperator<EnrichedVolume> joinWithCustomerData(DataStream<String> rawStream) {
        // Route static customer records to side output
        SingleOutputStreamOperator<InteractionEvent> mainStream = rawStream
                .process(new ProcessFunction<String, InteractionEvent>() {
                    @Override
                    public void processElement(String value, Context ctx, Collector<InteractionEvent> out) {
                            JsonNode node = mapper.readTree(value);
                            if ("customer_update".equals(node.get("recordType").asText())) {
                                ctx.output(CUSTOMER_DATA_TAG, value);
                            } else {
                                out.collect(new InteractionEvent(
                                        node.get("timestamp").asLong()
                            throw new RuntimeException("Routing failed", e);
        // Parse side output into customer records
        DataStream<CustomerRecord> customerStream = mainStream
                .getSideOutput(CUSTOMER_DATA_TAG)
                .map(line -> {
                    return new CustomerRecord(
                            node.get("customerId").asText(),
                            node.get("tier").asText(),
                            node.get("region").asText()
                .keyBy(CustomerRecord::getCustomerId);
        // Join using KeyedCoProcessFunction
        return mainStream
                .keyBy(InteractionEvent::getInteractionId) // Assume interactionId links to customerId in production
                .connect(customerStream)
                .keyBy(
                        v -> v.getInteractionId(),
                        v -> v.getCustomerId()
                .process(new KeyedCoProcessFunction<InteractionEvent, CustomerRecord, EnrichedVolume>() {
                    private transient MapState<String, CustomerRecord> customerState;
                    @Override
                    public void open(Configuration parameters) {
                        customerState = getRuntimeContext().getMapState(
                                new MapStateDescriptor<>("customer-cache", Types.STRING, Types.of(CustomerRecord.class))
                    @Override
                    public void processElement1(InteractionEvent event, Context ctx, Collector<EnrichedVolume> out) {
                        // Placeholder: In production, derive customerId from event
                        String cid = "CUST_" + event.interactionId().hashCode();
                        CustomerRecord cust = customerState.get(cid);
                        out.collect(new EnrichedVolume(cid, event.channel(), event.timestamp(), cust != null ? cust.tier() : "UNKNOWN"));
                    @Override
                    public void processElement2(CustomerRecord cust, Context ctx, Collector<EnrichedVolume> out) {
                        customerState.put(cust.customerId(), cust);
record CustomerRecord(String customerId, String tier, String region) {}
record EnrichedVolume(String customerId, String channel, long timestamp, String tier) {}
The MapState persists customer profiles across checkpoints. When a customer update arrives, the state refreshes. When an interaction event arrives, the function reads the state and emits an enriched record. This pattern avoids expensive broadcast joins and scales horizontally.
Step 4: Complex Event Processing with Flink CEP
You must detect patterns such as repeated failed interactions followed by a callback request. Flink CEP provides a declarative pattern matcher that compiles to state machines. The following configuration detects three failed interactions within 30 seconds, followed by a callback trigger.
import org.apache.flink.cep.CEP;
import org.apache.flink.cep.PatternStream;
import org.apache.flink.cep.pattern.Pattern;
import org.apache.flink.cep.pattern.conditions.SimpleCondition;
import java.util.List;
import java.util.Map;
public class CxonePatternDetector {
    public static DataStream<PatternAlert> detectCallbackPatterns(DataStream<EnrichedVolume> enrichedStream) {
        Pattern<EnrichedVolume, EnrichedVolume> pattern = Pattern.<EnrichedVolume>begin("failure")
                .where(new SimpleCondition<EnrichedVolume>() {
                    @Override
                    public boolean filter(EnrichedVolume value) {
                        return "FAILURE".equals(value.tier()); // Placeholder condition: replace with actual status field
                .times(3).consecutive()
                .next("callback")
                    @Override
                        return "CALLBACK_REQUEST".equals(value.tier()); // Placeholder condition
                .within(Time.seconds(30));
        PatternStream<EnrichedVolume> patternStream = CEP.pattern(
                enrichedStream.keyBy(EnrichedVolume::getCustomerId),
                pattern
        return patternStream.process((Map<String, List<EnrichedVolume>> pattern, Context ctx, Collector<PatternAlert> out) -> {
            List<EnrichedVolume> failures = pattern.get("failure");
            EnrichedVolume callback = pattern.get("callback").get(0);
            out.collect(new PatternAlert(
                    callback.customerId(),
                    callback.channel(),
                    callback.timestamp(),
                    failures.size(),
                    "REPEATED_FAILURE_CALLBACK"
record PatternAlert(String customerId, String channel, long timestamp, int failureCount, String alertType) {}
The within(Time.seconds(30)) clause bounds the pattern window. This prevents unbounded state growth and ensures garbage collection of expired patterns. Replace the placeholder conditions with actual CXone status fields from your Data Action payload.
Step 5: Cassandra Sink for Aggregated Results
Flink provides an official Cassandra sink connector. You must configure the host, keyspace, table, and mapping strategy. The following sink writes PatternAlert records to Cassandra with automatic schema mapping.
import org.apache.flink.connector.cassandra.CassandraSink;
import org.apache.flink.streaming.api.datastream.DataStreamSink;
public class CassandraResultSink {
    public static DataStreamSink<PatternAlert> createCassandraSink(DataStream<PatternAlert> alertStream) {
        return alertStream.sinkTo(
                CassandraSink.<PatternAlert>builder()
                        .setHosts("cassandra-node-01:9042")
                        .setKeyspace("cxone_analytics")
                        .setTable("pattern_alerts")
                        .setMapping((alert, ctx) -> {
                            ctx.set("customer_id", alert.customerId());
                            ctx.set("channel", alert.channel());
                            ctx.set("timestamp", alert.timestamp());
                            ctx.set("failure_count", alert.failureCount());
                            ctx.set("alert_type", alert.alertType());
                        .build()
Ensure the Cassandra table exists with the following schema before deployment:
CREATE TABLE IF NOT EXISTS cxone_analytics.pattern_alerts (
    customer_id text,
    channel text,
    timestamp bigint,
    failure_count int,
    alert_type text,
    PRIMARY KEY (customer_id, channel, timestamp)
The sink uses batched writes and respects Cassandra’s write consistency level. Enable Flink checkpoints to guarantee exactly-once delivery semantics.
The following Maven project structure and main class combine all components into a production-ready Flink job.
pom.xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>com.example</groupId>
    <artifactId>cxone-flink-processor</artifactId>
    <version>1.0-SNAPSHOT</version>
    <properties>
        <maven.compiler.source>17</maven.compiler.source>
        <maven.compiler.target>17</maven.compiler.target>
        <flink.version>1.17.1</flink.version>
    </properties>
    <dependencies>
        <dependency>
            <groupId>org.apache.flink</groupId>
            <artifactId>flink-streaming-java</artifactId>
            <version>${flink.version}</version>
            <scope>provided</scope>
        </dependency>
        <dependency>
            <artifactId>flink-clients</artifactId>
        </dependency>
        <dependency>
            <artifactId>flink-connector-kafka</artifactId>
        </dependency>
        <dependency>
            <artifactId>flink-cep</artifactId>
        </dependency>
        <dependency>
            <artifactId>flink-connector-cassandra</artifactId>
            <version>3.0.1</version>
        </dependency>
        <dependency>
            <groupId>com.fasterxml.jackson.core</groupId>
            <artifactId>jackson-databind</artifactId>
            <version>2.15.2</version>
        </dependency>
        <dependency>
            <groupId>org.apache.kafka</groupId>
            <artifactId>kafka-clients</artifactId>
            <version>3.5.1</version>
        </dependency>
    </dependencies>
</project>
Main.java
import org.apache.flink.streaming.api.CheckpointConfig;
import org.apache.flink.streaming.api.functions.timestamps.AscendingTimestampsAssigner;
public class CxoneFlinkJob {
    public static void main(String[] args) throws Exception {
        StreamExecutionEnvironment env = StreamExecutionEnvironment.getExecutionEnvironment();
        env.enableCheckpointing(60000);
        env.getCheckpointConfig().setCheckpointingMode(CheckpointConfig.CheckpointingMode.EXACTLY_ONCE);
        env.getCheckpointConfig().setMinPauseBetweenCheckpoints(30000);
        // Step 1: Ingest with rate limiting
        RateLimitedKafkaSource source = new RateLimitedKafkaSource(
                System.getenv("KAFKA_BOOTSTRAP"),
                "cxone-data-actions",
                500
        DataStream<String> rawStream = env.addSource(source)
                .assignTimestampsAndWatermarks(WatermarkStrategy.<String>forMonotonousTimestamps()
                        .withTimestampAssigner((value, ts) -> System.currentTimeMillis()));
        // Step 3: Route and join customer data
        DataStream<EnrichedVolume> enrichedStream = CustomerDataJoiner.joinWithCustomerData(rawStream);
        // Step 2: Windowed aggregation (applied before CEP for volume tracking)
        DataStream<VolumeRecord> volumeStream = InteractionVolumeAggregator.buildAggregationPipeline(rawStream);
        volumeStream.print("VOLUME");
        // Step 4: CEP pattern detection
        DataStream<PatternAlert> alertStream = CxonePatternDetector.detectCallbackPatterns(enrichedStream);
        // Step 5: Cassandra sink
        CassandraResultSink.createCassandraSink(alertStream);
        // Validate CXone configuration at startup
        String token = CxoneAuthClient.fetchAccessToken(System.getenv("CXONE_CLIENT_ID"), System.getenv("CXONE_CLIENT_SECRET"));
        CxoneAuthClient.validateDataAction(token, System.getenv("CXONE_ACTION_ID"));
        env.execute("CXone Data Actions Flink Processor");
Deploy using mvn clean package and submit to Flink via flink run -c com.example.CxoneFlinkJob target/cxone-flink-processor-1.0-SNAPSHOT.jar. Set environment variables for Kafka, CXone credentials, and Cassandra hosts before execution.
Error: OAuth 403 Forbidden on Data Actions API
  • Cause: The registered OAuth application lacks the data_actions:read scope, or the client credentials belong to a different CXone organization.
  • Fix: Navigate to the CXone developer portal, locate the OAuth application, and append data_actions:read to the scope list. Rotate the client secret and redeploy.
  • Code mitigation: The CxoneAuthClient.validateDataAction method throws a descriptive runtime exception when 403 occurs. Catch the exception and halt the Flink job before checkpointing begins.
Error: Flink TaskManager Heap Exhaustion During Kafka Poll
  • Cause: The rate limiter semaphore is not releasing tokens fast enough, or the Kafka partition contains malformed JSON that triggers repeated deserialization exceptions.
  • Fix: Increase maxEventsPerSecond in RateLimitedKafkaSource or add a dead-letter queue for malformed records. Wrap the JSON parser in a try-catch and route failures to a side output instead of throwing.
  • Code mitigation: Replace throw new RuntimeException in the map function with ctx.output(DEAD_LETTER_TAG, line) to prevent job cancellation.
Error: CEP State Checkpoint Timeout
  • Cause: The within(Time.seconds(30)) boundary is insufficient for high-volume channels, causing the pattern state machine to accumulate unmatched events beyond the checkpoint interval.
  • Fix: Increase the pattern window to Time.minutes(2) or reduce the times(3).consecutive() threshold. Enable RocksDB state backend with incremental checkpoints.
  • Configuration: Add env.setStateBackend(new RocksDBStateBackend("hdfs://checkpoint-dir", true)) to the execution environment.
Error: Cassandra WriteTimeoutException
  • Cause: The sink batch size exceeds Cassandra’s write capacity, or the keyspace replication factor is misconfigured.
  • Fix: Reduce Flink parallelism for the sink operator using .setParallelism(2). Configure Cassandra write_concurrency and verify network latency between Flink TaskManagers and Cassandra nodes.
  • Code mitigation: Wrap the sink builder with .setBatchSize(100) and .setFlushInterval(Duration.ofSeconds(5)) to throttle write velocity.
