Processing High-Volume Genesys Cloud Interaction Events via EventBridge Without Hitting Lambda Concurrency Limits
- A serverless event processing pipeline that ingests high-volume Genesys Cloud interaction events, buffers them in Amazon SQS, and processes them asynchronously to avoid AWS Lambda concurrency throttling.
- This solution uses the Genesys Cloud API for configuration, AWS EventBridge for event routing, Amazon SQS for buffering, and AWS Lambda for processing.
- The tutorial covers Python (Boto3 for AWS,
requestsfor Genesys) and provides the infrastructure-as-code logic required to deploy the pattern.
- Genesys Cloud: An organization with API access, a valid OAuth Client ID and Secret, and permissions to create Webhooks and manage Integrations.
- AWS Account: Permissions to create EventBridge rules, SQS queues, Lambda functions, and IAM roles.
- SDKs/Libraries:
- Python:
boto3(latest),requests(latest),purecloudplatformclientv2(Genesys Python SDK). - AWS CLI: Configured with appropriate credentials.
- Python:
- Concepts: Understanding of OAuth 2.0 Client Credentials flow, AWS EventBridge bus architecture, and SQS FIFO vs. Standard queues.
Before configuring the integration, you must establish a secure method to authenticate with both Genesys Cloud and AWS. Genesys Cloud uses OAuth 2.0, while AWS uses IAM roles for service-to-service communication.
Genesys Cloud OAuth Token Management
You need a robust way to obtain and refresh access tokens. The Genesys Cloud API requires specific scopes depending on the action. For creating webhooks, you need integration:webhook:write.
import requests
import json
from typing import Optional
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, env_name: str = "mypurecloud.com"):
self.client_id = client_id
self.token_url = f"https://{env_name}/oauth/token"
self.token_expiry: float = 0
def get_token(self) -> str:
Retrieves an OAuth token if expired or not present.
Implements simple caching to avoid unnecessary network calls.
if self.access_token and time.time() < self.token_expiry:
return self.access_token
payload = {
"client_id": self.client_id,
headers = {
response = requests.post(self.token_url, data=payload, headers=headers)
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
# Subtract 60 seconds to provide a buffer before expiry
self.token_expiry = time.time() + data["expires_in"] - 60
Returns headers required for Genesys Cloud API calls.
token = self.get_token()
AWS IAM Role for Lambda
Your Lambda function needs permissions to:
- Receive events from EventBridge.
- Send messages to SQS (if implementing a dead-letter queue or secondary processing).
- Log to CloudWatch.
Create an IAM policy document (lambda-policy.json):
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": [
"logs:CreateLogGroup",
"logs:CreateLogStream",
"logs:PutLogEvents"
"Resource": "arn:aws:logs:*:*:*"
"Effect": "Allow",
"Action": [
"sqs:SendMessage",
"sqs:DeleteMessage",
"sqs:GetQueueAttributes"
"Resource": "arn:aws:sqs:*:*:genesys-interaction-queue"
Step 1: Configure Genesys Cloud Webhook to Target EventBridge
The first step is to configure Genesys Cloud to send interaction events to your AWS EventBridge API destination. You must first create an API Destination in EventBridge, then configure the Webhook in Genesys Cloud.
Note: EventBridge supports custom endpoints via API Destinations. You will create an API Destination in AWS, then use its URL in the Genesys Webhook configuration.
Create AWS EventBridge API Destination
Using Boto3, create the API destination that will receive the Genesys payload.
import boto3
import json
def create_eventbridge_api_destination(region: str, auth_role_arn: str) -> str:
Creates an EventBridge API Destination for Genesys Cloud.
:param region: AWS Region
:param auth_role_arn: IAM Role ARN with permissions to invoke the destination
:return: The ARN of the created API Destination
client = boto3.client('events', region_name=region)
# Define the connection to the API destination
# For HTTPS endpoints, you typically use an API Destination with an ARN of a Lambda or HTTP endpoint
# Here we assume a direct HTTP endpoint configuration or a Lambda-backed endpoint
# Note: For direct HTTP, you often need an API Destination pointing to a Lambda that forwards,
# or use EventBridge's direct HTTP integration if available in your region/plan.
# A more robust pattern is Genesys -> EventBridge Rule -> SQS.
# However, Genesys Webhooks hit an HTTP endpoint.
# Therefore, the standard pattern is: Genesys Webhook -> API Gateway/EventBridge HTTP Endpoint -> SQS.
# Let's assume we are using an EventBridge Custom Bus and an HTTP Endpoint.
# Actually, the most direct way is Genesys Webhook -> AWS API Gateway -> SQS.
# But the prompt asks for EventBridge.
# EventBridge can ingest from HTTP sources via API Destinations.
destination_name = "genesys-interaction-destination"
response = client.create_api_destination(
Name=destination_name,
InvocationEndpoint="https://events.us-east-1.amazonaws.com", # Placeholder, real endpoint depends on setup
HttpMethod="POST",
InvocationRateLimitPerSecond=500, # Genesys can spike high
Description="Destination for Genesys Cloud Interaction Events"
return response['ApiDestinationArn']
except client.exceptions.ResourceAlreadyExistsException:
print("API Destination already exists.")
return f"arn:aws:events:{region}:<account-id>:api-destination/{destination_name}"
Correction: The standard, most reliable pattern for high-volume Genesys events to avoid Lambda concurrency issues is:
Genesys Cloud Webhook → AWS API Gateway (HTTP API) → SQS Queue → Lambda (with limited concurrency).
EventBridge is often used after SQS to route to other services, but for the ingestion point, API Gateway is the standard HTTP receiver. However, if you strictly want EventBridge, you can use EventBridge Pipes or Custom Endpoints. Given the constraint “EventBridge”, we will use the EventBridge Custom Bus with an HTTP Source pattern if available, or more commonly, API Gateway triggering an EventBridge Rule.
Let’s stick to the most robust high-volume pattern: Genesys Webhook → API Gateway → SQS. We will use EventBridge to route the processed data if needed, but the buffering happens in SQS.
Wait, the prompt specifically says “from EventBridge”. This implies the events are already in EventBridge or you are using EventBridge as the ingestion layer. AWS EventBridge now supports Direct HTTP Ingestion via EventBridge API Destinations or Custom Buses with HTTP Connectors.
Let’s use the EventBridge Custom Bus with an HTTP Endpoint pattern.
Configure Genesys Webhook via API
def create_genesys_webhook(auth: GenesysAuth, webhook_url: str, integration_id: str) -> dict:
Creates a Genesys Cloud Webhook that sends interaction events to the provided URL.
:param auth: GenesysAuth instance
:param webhook_url: The URL of the EventBridge HTTP Endpoint or API Gateway
:param integration_id: The ID of the Genesys Integration to attach the webhook to
:return: Webhook creation response
base_url = "https://api.mypurecloud.com"
endpoint = f"/api/v2/integrations/webhooks"
# Define the webhook configuration
webhook_config = {
"name": "HighVolumeInteractionProcessor",
"integration": {
"id": integration_id
"url": webhook_url,
"method": "POST",
"headerContentType": "application/json",
"requestTemplate": "${body}",
"events": [
"routing:conversation:participant:added",
"routing:conversation:participant:removed",
"routing:conversation:wrapup"
"retry": {
"enabled": True,
"retryCount": 3,
"retryDelay": 1000
"auth": {
"type": "basic",
"username": "user",
"password": "pass" # Use API Gateway auth or skip if using EventBridge signed headers
f"{base_url}{endpoint}",
json=webhook_config,
headers=auth.get_headers()
if response.status_code != 201:
raise Exception(f"Failed to create webhook: {response.status_code} - {response.text}")
return response.json()
Required Scope: integration:webhook:write
Step 2: Create SQS Queue for Buffering
To prevent Lambda concurrency limits, you must decouple the ingestion from processing. SQS acts as the buffer.
def create_sqs_queue(region: str, queue_name: str = "genesys-interaction-queue") -> str:
Creates an SQS Standard Queue to buffer Genesys events.
:param queue_name: Name of the queue
:return: Queue URL
sqs = boto3.client('sqs', region_name=region)
# Create queue with high throughput settings
response = sqs.create_queue(
QueueName=queue_name,
Attributes={
'FifoQueue': 'false', # Standard queue for maximum throughput
'ReceiveMessageWaitTimeSeconds': '20', # Long polling
'VisibilityTimeout': '300', # 5 mins for Lambda processing
'MessageRetentionPeriod': '345600', # 4 days
'MaximumMessageSize': '262144' # 256 KB
return response['QueueUrl']
except sqs.exceptions.QueueAlreadyExists:
return sqs.get_queue_url(QueueName=queue_name)['QueueUrl']
Step 3: Configure EventBridge to Route to SQS
If you are using EventBridge as the ingestion point (via HTTP Endpoint), you create a Rule to route to SQS. If you are using API Gateway, you route directly to SQS. Given the “EventBridge” requirement, we assume the events land in an EventBridge Bus.
def create_eventbridge_rule_to_sqs(region: str, bus_name: str, rule_name: str, sqs_queue_arn: str, target_id: str) -> str:
Creates an EventBridge Rule that sends matching events to SQS.
:param bus_name: Name of the EventBridge Bus
:param rule_name: Name of the rule
:param sqs_queue_arn: ARN of the target SQS Queue
:param target_id: ID for the target
:return: Rule ARN
# Define event pattern to match Genesys events
# Genesys events typically have a specific structure.
# If ingested via HTTP, you might need to parse the body.
# For simplicity, we assume a broad match or a specific detail-type.
event_pattern = {
"source": ["genesys.cloud"],
"detail-type": ["InteractionEvent"]
response = client.put_rule(
Name=rule_name,
EventBusName=bus_name,
EventPattern=json.dumps(event_pattern),
State='ENABLED',
Description='Route Genesys interactions to SQS'
# Add SQS as a target
client.put_targets(
Rule=rule_name,
Targets=[
'Id': target_id,
'Arn': sqs_queue_arn
RoleArn='arn:aws:iam::<account-id>:role/EventBridgeToSQSRole' # Needs SQS:SendMessage permission
return response['RuleArn']
raise Exception(f"Failed to create EventBridge rule: {e}")
Step 4: Implement Lambda Processor with Controlled Concurrency
This is the core logic. The Lambda function reads from SQS. By configuring the SQS trigger with a low Batch Size and Reserved Concurrency, you control the load.
Lambda Configuration (via AWS Console or CLI):
- Trigger: SQS
- Batch Size: 10 (Adjust based on payload size and processing time)
- Reserved Concurrency: 100 (Prevents unbounded scaling)
- Visibility Timeout: Must be longer than Lambda timeout + processing time.
Lambda Code (Python):
import json
import boto3
import logging
# Configure logging
logger = logging.getLogger()
logger.setLevel(logging.INFO)
# Initialize clients
sqs_client = boto3.client('sqs')
dynamodb = boto3.resource('dynamodb')
table = dynamodb.Table('genesys-interactions')
def lambda_handler(event: Dict[str, Any], context: Any) -> None:
Processes a batch of Genesys Cloud interaction events from SQS.
:param event: SQS Trigger Event
:param context: Lambda Context
records = event.get('Records', [])
if not records:
logger.info("No records to process.")
return
failed_record_ids = []
for record in records:
# Parse the message body
body_str = record['body']
message = json.loads(body_str)
# Process the Genesys event
process_genesys_event(message)
logger.info(f"Successfully processed event ID: {message.get('id', 'unknown')}")
logger.error(f"Error processing message: {e}", exc_info=True)
# Mark as failed. SQS will retry based on visibility timeout and redrive policy.
failed_record_ids.append(record['messageId'])
# If any records failed, you can handle them here (e.g., send to DLQ)
if failed_record_ids:
logger.warning(f"Failed to process {len(failed_record_ids)} messages: {failed_record_ids}")
def process_genesys_event(event: Dict[str, Any]) -> None:
Core business logic for processing a Genesys event.
event_type = event.get('event', 'unknown')
conversation_id = event.get('conversationId', 'unknown')
participant_id = event.get('participantId', 'unknown')
# Example: Store in DynamoDB
item = {
'eventId': event.get('id', ''),
'timestamp': event.get('timestamp', ''),
'eventType': event_type,
'conversationId': conversation_id,
'participantId': participant_id,
'processedAt': boto3.dynamodb.types.TypeSerializer().serialize(
__import__('datetime').datetime.utcnow()
table.put_item(Item=item)
logger.info(f"Stored event {event_type} for conversation {conversation_id}")
Step 5: Set Up Dead-Letter Queue (DLQ)
High-volume systems will have failed messages. You must configure a DLQ for the main SQS queue.
def setup_dlq(region: str, dlq_name: str = "genesys-interaction-dlq") -> str:
Creates a Dead-Letter Queue for failed messages.
:param dlq_name: Name of the DLQ
:return: DLQ ARN
QueueName=dlq_name,
Attributes={
'MessageRetentionPeriod': '1209600' # 14 days
return sqs.get_queue_url(QueueName=dlq_name)['QueueUrl']
def attach_dlq_to_queue(region: str, main_queue_url: str, dlq_arn: str) -> None:
Attaches a DLQ to the main processing queue.
:param main_queue_url: URL of the main SQS queue
:param dlq_arn: ARN of the DLQ
sqs.set_queue_attributes(
QueueUrl=main_queue_url,
Attributes={
'RedrivePolicy': json.dumps({
'deadLetterTargetArn': dlq_arn,
'maxReceiveCount': '3' # Retry 3 times before sending to DLQ
Below is a consolidated Python script that sets up the infrastructure components. In a production environment, you would use Terraform or CloudFormation, but this demonstrates the API calls.
import boto3
import json
from typing import Dict, Any
class GenesysEventPipeline:
def __init__(self, region: str, account_id: str):
self.region = region
self.account_id = account_id
self.sqs = boto3.client('sqs', region_name=region)
self.events = boto3.client('events', region_name=region)
self.lambda_client = boto3.client('lambda', region_name=region)
def setup_pipeline(self, bus_name: str, queue_name: str, lambda_function_name: str) -> Dict[str, str]:
Sets up the complete event pipeline.
results = {}
# 1. Create DLQ
dlq_url = f"https://sqs.{self.region}.amazonaws.com/{self.account_id}/genesys-interaction-dlq"
self.sqs.create_queue(QueueName="genesys-interaction-dlq")
except:
pass
dlq_arn = self.sqs.get_queue_attributes(
QueueUrl=dlq_url, AttributeNames=['QueueArn']
)['Attributes']['QueueArn']
results['dlq_arn'] = dlq_arn
# 2. Create Main Queue
main_queue_url = f"https://sqs.{self.region}.amazonaws.com/{self.account_id}/{queue_name}"
Attributes={
except:
pass
# Attach DLQ
self.sqs.set_queue_attributes(
Attributes={
results['main_queue_url'] = main_queue_url
main_queue_arn = self.sqs.get_queue_attributes(
QueueUrl=main_queue_url, AttributeNames=['QueueArn']
results['main_queue_arn'] = main_queue_arn
# 3. Create EventBridge Rule (Assuming events are already in the bus)
rule_name = f"RouteGenesysToSQS"
self.events.put_rule(
Name=rule_name,
EventPattern=json.dumps({
State='ENABLED'
except:
pass
self.events.put_targets(
Rule=rule_name,
Targets=[{
'Id': 'SqsTarget',
'Arn': main_queue_arn
RoleArn=f"arn:aws:iam::{self.account_id}:role/EventBridgeToSQSRole"
results['rule_name'] = rule_name
# 4. Create Lambda Event Source Mapping
# This links the SQS queue to the Lambda function
self.lambda_client.create_event_source_mapping(
FunctionName=lambda_function_name,
EventSourceArn=main_queue_arn,
BatchSize=10,
MaximumBatchingWindowInSeconds=5
except self.lambda_client.exceptions.ResourceConflictException:
pass # Already exists
results['lambda_function_name'] = lambda_function_name
return results
pipeline = GenesysEventPipeline(
region="us-east-1",
account_id="123456789012"
setup_results = pipeline.setup_pipeline(
bus_name="custom-bus",
queue_name="genesys-interaction-queue",
lambda_function_name="ProcessGenesysInteractions"
print("Pipeline Setup Results:")
print(json.dumps(setup_results, indent=2))
Error: 429 Too Many Requests from Genesys Cloud
- Cause: Genesys Cloud may rate-limit webhook invocations if the target fails to respond quickly.
- Fix: Ensure your ingestion endpoint (API Gateway/EventBridge HTTP Endpoint) responds with
200 OKimmediately. Do not process the message in the ingestion handler. Offload to SQS instantly. - Code Fix: In your API Gateway Lambda or HTTP handler, return
{'statusCode': 200, 'body': 'OK'}immediately after sending to SQS.
Error: Lambda Concurrency Throttled
- Cause: The number of concurrent Lambda executions exceeds the account or function limit.
- Fix:
- Increase Reserved Concurrency for the Lambda function.
- Reduce the Batch Size in the SQS trigger to allow more parallel consumers.
- Optimize the Lambda code to process faster.
- Code Fix: Update the event source mapping:
self.lambda_client.update_event_source_mapping( UUID='<mapping-uuid>', BatchSize=5, # Lower batch size MaximumConcurrency=100 # Set explicit concurrency limit )
Error: SQS Visibility Timeout Expired
- Cause: The Lambda function takes longer than the SQS Visibility Timeout to process a batch. The message becomes visible again and is re-processed, leading to duplicates.
- Fix: Increase the SQS
VisibilityTimeoutattribute to be greater thanLambda Timeout + Batch Size * Average Processing Time. - Code Fix:
self.sqs.set_queue_attributes( QueueUrl=main_queue_url, Attributes={'VisibilityTimeout': '600'} # 10 minutes )
Error: EventBridge Rule Not Triggering
- Cause: The event pattern does not match the incoming Genesys event structure.
- Fix: Use EventBridge Schema Registry to inspect incoming events. Ensure the
sourceanddetail-typein the rule match the webhook payload. - Debugging: Send a test event via Genesys Cloud’s “Test” button in the Webhook configuration. Check CloudWatch Logs for the Lambda function to see if the message was received.
