Processing Genesys Cloud Routing Scorecards via Node.js SDK
A Node.js processor that calculates routing scorecards, validates attribute weight matrices against engine constraints, applies configurations via atomic PATCH operations, and synchronizes results with external analytics platforms. This tutorial uses the official Genesys Cloud Node.js SDK and the Routing Queue API. The code is written in modern JavaScript with async/await and production-grade error handling.
- OAuth Client Credentials with scopes:
routing:queue:read,routing:queue:write,routing:agent:read,webhook:write,analytics:conversations:read - Genesys Cloud Node.js SDK v2.10+ (
@genesyscloud/genesyscloud-node-sdk) - Node.js 18 or later
- External dependencies:
axios,ajv,ajv-formats - A Genesys Cloud organization with at least one queue and two agents
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server integrations. The SDK handles token acquisition, caching, and automatic refresh when the access token expires. You must configure the client before making any API calls.
const { PlatformClient, ApiClient } = require('@genesyscloud/genesyscloud-node-sdk');
const CONFIG = {
clientId: process.env.GENESYS_CLIENT_ID,
clientSecret: process.env.GENESYS_CLIENT_SECRET,
environment: process.env.GENESYS_ENVIRONMENT || 'https://api.mypurecloud.com',
scopes: [
'routing:queue:read',
'routing:queue:write',
'routing:agent:read',
'webhook:write',
'analytics:conversations:read'
const initPlatformClient = async () => {
const client = PlatformClient.init({
clientId: CONFIG.clientId,
clientSecret: CONFIG.clientSecret,
environment: CONFIG.environment,
scopes: CONFIG.scopes
await client.login();
console.log('OAuth token acquired successfully.');
return client;
} catch (error) {
console.error('Authentication failed:', error.response?.data || error.message);
process.exit(1);
The login() method performs a POST to /api/v2/oauth/token, caches the JWT, and attaches it to subsequent SDK requests. The SDK automatically handles 401 Unauthorized responses by refreshing the token before retrying the original request.
Routing scorecards in Genesys Cloud are custom business logic applied to queue routing rules. You must construct a payload containing queue ID references, attribute weight matrices, and threshold score directives. The Genesys Cloud scoring engine enforces a maximum attribute count per routing rule and validates normalization factors. This step defines the payload structure and validates it using AJV before submission.
const Ajv = require('ajv');
const addFormats = require('ajv-formats');
const ajv = new Ajv({ allErrors: true });
addFormats(ajv);
const SCORECARD_SCHEMA = {
type: 'object',
required: ['queueId', 'attributes', 'thresholds', 'normalizationFactor'],
properties: {
queueId: { type: 'string', pattern: '^[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}$' },
attributes: {
type: 'array',
maxItems: 10,
items: {
type: 'object',
required: ['skillName', 'weight', 'source'],
properties: {
skillName: { type: 'string' },
weight: { type: 'number', minimum: 0, maximum: 1 },
source: { type: 'string', enum: ['wrapup_code', 'conversation_outcome', 'agent_skill_rating'] }
thresholds: {
type: 'object',
required: ['minimumScore', 'maximumScore'],
properties: {
minimumScore: { type: 'number', minimum: 0 },
maximumScore: { type: 'number', maximum: 100 }
normalizationFactor: { type: 'number', minimum: 0.1, maximum: 1.0 }
const validateScorecardPayload = (payload) => {
const validate = ajv.compile(SCORECARD_SCHEMA);
const valid = validate(payload);
if (!valid) {
const errors = validate.errors.map(e => `${e.instancePath} ${e.message}`);
throw new Error(`Scorecard schema validation failed: ${errors.join(', ')}`);
return true;
The schema enforces a maximum of 10 attributes per scorecard, which aligns with the Genesys Cloud routing rule engine limit. The normalization factor must fall between 0.1 and 1.0 to prevent score inflation. The thresholds object defines the acceptable score range before the routing engine applies the configuration.
Step 2: Score Calculation, Outlier Detection, and Tie-Breaker Logic
Before applying scorecards, you must calculate agent scores, verify normalization factors, and filter outliers. This step implements a z-score outlier detection pipeline and automatic tie-breaker logic to prevent routing skew during scaling events.
const calculateAgentScores = (agents, scorecard) => {
const { attributes, thresholds, normalizationFactor } = scorecard;
const scores = agents.map(agent => {
let rawScore = 0;
attributes.forEach(attr => {
const agentValue = agent.metrics?.[attr.source] || 0;
rawScore += agentValue * attr.weight;
const normalizedScore = rawScore * normalizationFactor * 100;
agentId: agent.id,
rawScore,
normalizedScore: Math.min(Math.max(normalizedScore, thresholds.minimumScore), thresholds.maximumScore)
// Outlier detection using z-score
const mean = scores.reduce((sum, s) => sum + s.normalizedScore, 0) / scores.length;
const stdDev = Math.sqrt(scores.reduce((sum, s) => sum + Math.pow(s.normalizedScore - mean, 2), 0) / scores.length);
const threshold = 2.0; // Standard deviation multiplier
const filteredScores = scores.filter(s => {
if (stdDev === 0) return true;
const zScore = Math.abs((s.normalizedScore - mean) / stdDev);
return zScore <= threshold;
// Tie-breaker logic: fallback to longest tenure when scores match within 0.01
filteredScores.sort((a, b) => {
if (Math.abs(a.normalizedScore - b.normalizedScore) < 0.01) {
return (b.tenureSeconds || 0) - (a.tenureSeconds || 0);
return b.normalizedScore - a.normalizedScore;
return filteredScores;
The normalization factor scales raw metrics into the threshold range. The z-score filter removes agents with extreme metric deviations to prevent routing skew. The tie-breaker logic triggers when two agents share identical normalized scores, falling back to tenureSeconds to ensure deterministic routing decisions.
Step 3: Atomic PATCH Operations with Format Verification and Retry Logic
Genesys Cloud requires atomic updates for queue routing rules. You must verify the payload format matches the Queue model, apply the PATCH operation, and handle rate limits with exponential backoff. This step constructs the routing rule payload and executes the PATCH request.
const buildQueuePatchPayload = (scorecard, processedScores) => {
const topAgentId = processedScores[0]?.agentId || null;
routingRules: [
name: 'Scorecard Routing Rule',
enabled: true,
priority: 1,
expression: `agent.id == "${topAgentId}"`,
routingStrategy: 'longest_available_agent_first',
outboundQueue: null
scorecardMetadata: {
lastProcessedTimestamp: new Date().toISOString(),
agentCount: processedScores.length,
averageScore: processedScores.reduce((sum, s) => sum + s.normalizedScore, 0) / processedScores.length,
normalizationFactor: scorecard.normalizationFactor
const applyScorecardPatch = async (client, queueId, patchPayload, maxRetries = 3) => {
const url = `${client.configuration.basePath}/api/v2/routing/queues/${queueId}`;
const token = await client.authClient.getAccessToken();
for (let attempt = 1; attempt <= maxRetries; attempt++) {
const response = await axios.patch(url, patchPayload, {
headers: {
'Accept': 'application/json',
'Idempotency-Key': `scorecard-patch-${Date.now()}`
if (response.status === 200 || response.status === 204) {
console.log('PATCH successful. Queue routing rules updated.');
return response.data;
} catch (error) {
const retryAfter = error.response.headers['retry-after'] || Math.pow(2, attempt);
console.log(`Rate limited. Retrying in ${retryAfter} seconds...`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
continue;
throw error;
The Idempotency-Key header prevents duplicate processing if the network drops after a successful PATCH. The exponential backoff handles 429 Too Many Requests responses gracefully. The payload includes a scorecardMetadata extension field that Genesys Cloud stores as custom queue metadata for audit purposes.
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
You must synchronize scorecard processing events with external analytics platforms, track latency and accuracy rates, and generate structured audit logs for governance. This step configures a webhook via the Platform API and implements metrics collection.
const configureSyncWebhook = async (client, webhookUrl) => {
const webhookPayload = {
name: 'Routing Scorecard Sync',
enabled: true,
requestUrl: webhookUrl,
method: 'POST',
httpHeaders: { 'Content-Type': 'application/json' },
events: ['routing:queue:updated', 'routing:agent:score:calculated'],
filter: {
type: 'expression',
expression: 'entity.type == "routing"'
contentType: 'application/json',
proxyUri: null,
secret: process.env.WEBHOOK_SECRET || 'default-secret'
const webhook = await client.webhooks.createWebhook(webhookPayload);
console.log('Webhook created:', webhook.id);
return webhook.id;
} catch (error) {
if (error.response?.status === 409) {
console.log('Webhook already exists. Skipping creation.');
return null;
throw error;
const generateAuditLog = (context) => {
event: 'scorecard_processing_cycle',
queueId: context.queueId,
agentCount: context.agentCount,
scoresProcessed: context.scoresProcessed,
outliersFiltered: context.outliersFiltered,
tieBreakersTriggered: context.tieBreakersTriggered,
latencyMs: context.latencyMs,
accuracyRate: context.accuracyRate,
status: context.status,
engineVersion: 'routing-v2',
requestId: context.requestId
The webhook configuration listens to routing:queue:updated events and forwards them to your external analytics platform. The audit log captures latency, accuracy rates, outlier counts, and tie-breaker triggers to support operational governance and routing efficiency analysis.
The following module combines all components into a single executable processor. Replace the environment variables with your Genesys Cloud credentials before running.
const { PlatformClient } = require('@genesyscloud/genesyscloud-node-sdk');
addFormats(ajv);
class RoutingScorecardProcessor {
constructor(config) {
this.config = config;
this.metrics = { latencyMs: 0, accuracyRate: 0, successCount: 0, failureCount: 0 };
async initialize() {
this.client = PlatformClient.init({
clientId: this.config.clientId,
clientSecret: this.config.clientSecret,
environment: this.config.environment,
scopes: this.config.scopes
await this.client.login();
validatePayload(payload) {
const schema = {
type: 'object',
properties: {
attributes: { type: 'array', maxItems: 10, items: { type: 'object', required: ['skillName', 'weight', 'source'], properties: { skillName: { type: 'string' }, weight: { type: 'number', minimum: 0, maximum: 1 }, source: { type: 'string', enum: ['wrapup_code', 'conversation_outcome', 'agent_skill_rating'] } } } },
thresholds: { type: 'object', required: ['minimumScore', 'maximumScore'], properties: { minimumScore: { type: 'number', minimum: 0 }, maximumScore: { type: 'number', maximum: 100 } } },
const validate = ajv.compile(schema);
if (!validate(payload)) {
throw new Error(`Validation failed: ${validate.errors.map(e => `${e.instancePath} ${e.message}`).join(', ')}`);
return true;
processScores(agents, scorecard) {
let rawScore = 0;
attributes.forEach(attr => { rawScore += (agent.metrics?.[attr.source] || 0) * attr.weight; });
return { agentId: agent.id, name: agent.name, rawScore, normalizedScore: Math.min(Math.max(normalizedScore, thresholds.minimumScore), thresholds.maximumScore), tenureSeconds: agent.tenureSeconds || 0 };
const filtered = scores.filter(s => stdDev === 0 || Math.abs((s.normalizedScore - mean) / stdDev) <= 2.0);
const tieBreakersTriggered = filtered.length > 0 ? filtered.slice(1).some((s, i) => Math.abs(s.normalizedScore - filtered[i].normalizedScore) < 0.01) : false;
filtered.sort((a, b) => Math.abs(a.normalizedScore - b.normalizedScore) < 0.01 ? b.tenureSeconds - a.tenureSeconds : b.normalizedScore - a.normalizedScore);
return { scores: filtered, outliersFiltered: scores.length - filtered.length, tieBreakersTriggered };
async applyPatch(queueId, patchPayload) {
const url = `${this.client.configuration.basePath}/api/v2/routing/queues/${queueId}`;
const token = await this.client.authClient.getAccessToken();
for (let attempt = 1; attempt <= 3; attempt++) {
const res = await axios.patch(url, patchPayload, { headers: { Authorization: `Bearer ${token}`, 'Content-Type': 'application/json', 'Idempotency-Key': `scorecard-${Date.now()}` } });
if (res.status === 200 || res.status === 204) return res.data;
} catch (err) {
if (err.response?.status === 429) {
await new Promise(r => setTimeout(r, (err.response.headers['retry-after'] || Math.pow(2, attempt)) * 1000));
continue;
throw err;
async run(scorecard, agents, webhookUrl) {
const startTime = Date.now();
this.validatePayload(scorecard);
const result = this.processScores(agents, scorecard);
const patchPayload = { routingRules: [{ name: 'Scorecard Rule', enabled: true, priority: 1, expression: `agent.id == "${result.scores[0]?.agentId}"`, routingStrategy: 'longest_available_agent_first' }], scorecardMetadata: { lastProcessed: new Date().toISOString(), agentCount: result.scores.length, avgScore: result.scores.reduce((s, v) => s + v.normalizedScore, 0) / result.scores.length } };
await this.applyPatch(scorecard.queueId, patchPayload);
const webhook = await this.client.webhooks.createWebhook({ name: 'Scorecard Sync', enabled: true, requestUrl: webhookUrl, method: 'POST', events: ['routing:queue:updated'], contentType: 'application/json' }).catch(() => null);
const latency = Date.now() - startTime;
this.metrics = { ...this.metrics, latencyMs: latency, accuracyRate: 1.0, successCount: this.metrics.successCount + 1 };
console.log(JSON.stringify({ event: 'scorecard_complete', queueId: scorecard.queueId, agentsProcessed: agents.length, filtered: result.scores.length, outliers: result.outliersFiltered, tieBreakers: result.tieBreakersTriggered, latency, webhookId: webhook?.id }, null, 2));
return result;
} catch (error) {
this.metrics.failureCount++;
console.error('Processing failed:', error.message);
throw error;
module.exports = RoutingScorecardProcessor;
Error: 400 Bad Request
- Cause: The PATCH payload violates the
Queuemodel schema or exceeds the maximum attribute count. - Fix: Verify the
routingRulesarray matches the official schema. Ensureattributescontains 10 or fewer items. Check thatnormalizationFactorfalls between 0.1 and 1.0. - Code Fix: Add schema validation before the PATCH call using AJV, as shown in Step 1.
Error: 403 Forbidden
- Cause: The OAuth token lacks
routing:queue:writeorwebhook:writescopes. - Fix: Regenerate the client credentials with the required scopes. Verify the token claims using
client.authClient.getAccessToken()and decode the JWT to inspect thescopefield.
- Cause: The Routing API enforces per-tenant and per-endpoint rate limits. Bulk scorecard processing triggers cascading limits.
- Fix: Implement exponential backoff with jitter. The
applyPatchmethod includes retry logic that reads theRetry-Afterheader or defaults to2^attemptseconds.
Error: 409 Conflict
- Cause: The webhook already exists or the queue is locked by another concurrent PATCH operation.
- Fix: Catch
409responses and skip creation or wait for the lock to release. Use theIdempotency-Keyheader to guarantee safe retries without duplicate state changes.
Error: Score Skew During Scaling
- Cause: Outlier agents receive disproportionate routing weight when metrics fluctuate during peak volume.
- Fix: The z-score filter removes agents beyond 2 standard deviations from the mean. The tie-breaker logic falls back to
tenureSecondsto distribute load evenly when scores converge.
