Processing Genesys Cloud Routing Events with Python SDK and Webhook Integration
- A Python service that consumes Genesys Cloud routing webhooks, validates queue constraints and agent skills, handles overflow with atomic updates, tracks dispatch metrics, and synchronizes with external monitors.
- This tutorial uses the Genesys Cloud REST API and the
genesys-cloud-sdk-pythonpackage. - The implementation covers Python 3.10+ with
httpx,fastapi, andpydantic.
- OAuth 2.0 confidential client with scopes:
routing:queue:read routing:agent:read analytics:query webhooks:write routing:conversation:write - Genesys Cloud Python SDK v6.0+
- Python 3.10+ runtime
- Dependencies:
pip install httpx fastapi uvicorn genesys-cloud-sdk-python pydantic
Genesys Cloud requires OAuth 2.0 Client Credentials flow for server-to-server API access. The code below fetches an access token, caches it with expiration awareness, and initializes the SDK configuration.
import httpx
from typing import Optional
from genesys.cloud.platform.client.v2 import Configuration, ApiClient
class GenesysAuthManager:
def __init__(self, env: str, client_id: str, client_secret: str):
self.base_url = f"https://{env}.mypurecloud.com"
self.client_id = client_id
self.expires_at: float = 0.0
if self.token and time.time() < self.expires_at - 30:
return self.token
async with httpx.AsyncClient() as client:
response = await client.post(
f"{self.base_url}/oauth/token",
data={
"client_id": self.client_id,
"scope": "routing:queue:read routing:agent:read analytics:query webhooks:write routing:conversation:write"
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
return self.token
def get_sdk_config(self) -> Configuration:
config = Configuration()
config.host = self.base_url
async def token_provider() -> str:
return await self.get_token()
config.access_token = None
config.oauth_access_token = None
config.api_key_prefix = {"Authorization": "Bearer"}
config.api_key = {"Authorization": token_provider}
return config
OAuth Scope Requirement: routing:queue:read routing:agent:read analytics:query webhooks:write routing:conversation:write
Step 1: Construct Processing Payloads with Route References, Priority Matrix, and Dispatch Directive
Define structured models that mirror Genesys Cloud routing concepts. The priority matrix determines fallback routes when the primary queue reaches capacity. The dispatch directive contains the atomic state transition payload.
class RouteReference(BaseModel):
queue_id: str
skill_tag: str
priority_weight: int = Field(ge=1, le=10)
class PriorityMatrix(BaseModel):
routes: List[RouteReference]
class DispatchDirective(BaseModel):
conversation_id: str
target_queue_id: str
wrap_up_code: Optional[str] = None
skill_tag: str
class RoutingEventPayload(BaseModel):
event_type: str
queue_id: str
priority_matrix: PriorityMatrix
dispatch_directive: DispatchDirective
metadata: Dict[str, Any] = {}
Step 2: Validate Processing Schemas Against Routing Engine Constraints and Maximum Queue Depth Limits
Fetch the queue configuration via the SDK. Validate that the incoming payload matches the queue capacity and maximum wait time constraints. Reject payloads that violate engine limits to prevent routing failure.
from genesys.cloud.platform.client.v2 import RoutingApi
from httpx import HTTPStatusError
async def validate_queue_constraints(
api_client: ApiClient,
queue_id: str,
current_depth: int,
max_depth: int
) -> bool:
routing_api = RoutingApi(api_client)
queue = await routing_api.get_routing_queue(queue_id)
except HTTPStatusError as e:
if e.response.status_code == 404:
raise ValueError(f"Queue {queue_id} does not exist.")
raise
if queue.max_wait_time is not None:
# Enforce routing engine constraint: reject if wait time threshold is misconfigured
if queue.max_wait_time < 0:
raise ValueError("Queue max_wait_time cannot be negative.")
if current_depth >= max_depth:
return False
return True
Step 3: Implement Wait Time Calculation Checking and Agent Skill Matching Verification Pipelines
Query queue analytics for real-time wait time and verify that available agents possess the required skill tag. This pipeline prevents caller abandonment by ensuring routing decisions align with actual agent availability.
from genesys.cloud.platform.client.v2 import AnalyticsApi, RoutingApi
async def verify_agent_skills_and_wait_time(
queue_id: str,
required_skill: str
) -> Dict[str, Any]:
analytics_api = AnalyticsApi(api_client)
# Query queue metrics for wait time calculation
analytics_payload = {
"dateFrom": (datetime.utcnow() - timedelta(hours=1)).isoformat(),
"dateTo": datetime.utcnow().isoformat(),
"interval": "PT1H",
"view": "realtime",
"entities": [{"id": queue_id}],
"metrics": ["wait_time_avg", "agents_available_count"]
response = await analytics_api.post_analytics_queues_details_query(body=analytics_payload)
wait_time_avg = 0.0
agents_available = 0
if response.entities and response.entities[0].metrics:
for metric in response.entities[0].metrics:
if metric.id == "wait_time_avg":
wait_time_avg = metric.total or 0.0
elif metric.id == "agents_available_count":
agents_available = metric.total or 0
# Verify agent skill matching pipeline
skill_match = False
if queue.skill_requirement:
skill_match = queue.skill_requirement.tag == required_skill
else:
# Fallback: check if any member has the skill tag
members = await routing_api.get_routing_queue_members(queue_id)
if members.entities:
for member in members.entities:
if member.routing_profile and member.routing_profile.skills:
for skill in member.routing_profile.skills:
if skill.tag == required_skill:
skill_match = True
break
if skill_match:
break
"wait_time_avg_seconds": wait_time_avg,
"agents_available": agents_available,
"skill_match_verified": skill_match
OAuth Scope Requirement: analytics:query routing:queue:read
Step 4: Handle Queue Overflow Detection via Atomic POST Operations with Format Verification and Automatic Spill Over Triggers
When queue depth exceeds limits, execute an atomic routing state update to trigger spill over. The code includes retry logic for 429 rate-limit responses and validates the dispatch payload format before submission.
import logging
logger = logging.getLogger("routing_processor")
async def execute_atomic_dispatch_with_overflow_handling(
conversation_id: str,
directive: DispatchDirective,
max_retries: int = 3
) -> bool:
payload = {
"state": "queued",
"queueId": directive.target_queue_id,
"skillTag": directive.skill_tag,
"wrapUpCode": directive.wrap_up_code
# Atomic POST to update routing state
await routing_api.post_routing_conversations_routing(conversation_id, body=payload)
logger.info("Dispatch directive applied successfully.")
return True
status_code = getattr(e.response, 'status_code', 500)
if status_code == 429:
wait_time = 2 ** attempt
logger.warning(f"Rate limited (429). Retrying in {wait_time}s (attempt {attempt+1})")
elif status_code == 400:
logger.error(f"Format verification failed: {e}")
raise ValueError("Invalid dispatch payload format.") from e
elif status_code == 404:
raise ValueError(f"Conversation {conversation_id} not found.") from e
else:
raise
raise RuntimeError("Maximum retry attempts exceeded for dispatch operation.")
OAuth Scope Requirement: routing:conversation:write
Step 5: Synchronize Processing Events with External ACD Monitors via Route Processed Webhooks for Alignment
Register a webhook that forwards processed routing events to an external ACD monitor. The webhook configuration includes event types, subscription URL, and validation settings.
from genesys.cloud.platform.client.v2 import WebhooksApi
async def register_route_processed_webhook(
webhook_name: str,
target_url: str
) -> str:
webhooks_api = WebhooksApi(api_client)
webhook_body = {
"name": webhook_name,
"description": "Routes processed events to external ACD monitor",
"enabled": True,
"apiVersion": "2.0",
"address": target_url,
"method": "POST",
"contentType": "application/json",
"events": ["routing:queue:member:added", "routing:conversation:wrapup"],
"apiFilter": "routing:queue:member:added,routing:conversation:wrapup"
webhook = await webhooks_api.post_webhooks(body=webhook_body)
return webhook.id
if getattr(e.response, 'status_code', 0) == 409:
raise ValueError("Webhook with this address already exists.")
raise
OAuth Scope Requirement: webhooks:write
The following FastAPI application integrates all components. It exposes a routing processor endpoint, tracks latency and success rates, generates audit logs, and handles the full event lifecycle.
import asyncio
import logging
import json
from fastapi import FastAPI, HTTPException
from httpx import AsyncClient
app = FastAPI(title="Genesys Routing Processor")
logging.basicConfig(level=logging.INFO, format="%(asctime)s %(levelname)s %(message)s")
# Metrics tracking
metrics = {"total_processed": 0, "successful_dispatches": 0, "overflow_spills": 0}
async def process_routing_event(payload: RoutingEventPayload) -> Dict[str, Any]:
audit_log = {
"event_id": payload.conversation_id,
"queue_id": payload.queue_id,
"timestamp": time.time(),
"status": "pending",
"latency_ms": 0,
"overflow_triggered": False
auth = GenesysAuthManager(env="au02", client_id="YOUR_CLIENT_ID", client_secret="YOUR_CLIENT_SECRET")
config = auth.get_sdk_config()
api_client = ApiClient(config)
# Validate constraints
is_valid = await validate_queue_constraints(api_client, payload.queue_id, current_depth=5, max_depth=10)
if not is_valid:
audit_log["status"] = "overflow_detected"
audit_log["overflow_triggered"] = True
metrics["overflow_spills"] += 1
# Verify skills and wait time
verification = await verify_agent_skills_and_wait_time(
api_client,
payload.queue_id,
payload.dispatch_directive.skill_tag
if not verification["skill_match_verified"]:
raise ValueError("Agent skill matching verification failed.")
# Execute dispatch with overflow handling
dispatch_success = await execute_atomic_dispatch_with_overflow_handling(
api_client,
audit_log["status"] = "dispatched" if dispatch_success else "failed"
metrics["total_processed"] += 1
if dispatch_success:
metrics["successful_dispatches"] += 1
audit_log["status"] = "error"
audit_log["error"] = str(e)
logger.error(f"Processing failed for {payload.conversation_id}: {e}")
raise HTTPException(status_code=500, detail=str(e))
finally:
audit_log["latency_ms"] = round(latency_ms, 2)
logger.info(f"AUDIT_LOG:{json.dumps(audit_log)}")
# Sync with external ACD monitor via webhook registration (idempotent)
await register_route_processed_webhook(
api_client,
f"accd-monitor-{payload.queue_id}",
"https://external-acd-monitor.example.com/webhook"
except ValueError:
pass # Webhook already exists
return audit_log
@app.post("/routing/processor")
async def routing_processor_endpoint(payload: RoutingEventPayload):
return await process_routing_event(payload)
@app.get("/metrics")
async def get_metrics():
return metrics
Run the service with uvicorn main:app --host 0.0.0.0 --port 8000. Replace YOUR_CLIENT_ID and YOUR_CLIENT_SECRET with your OAuth credentials.
Error: HTTP 401 Unauthorized
- What causes it: The OAuth token expired or the client credentials are invalid.
- How to fix it: Verify
client_idandclient_secret. Ensure theget_token()method runs before every SDK call. TheGenesysAuthManagerautomatically refreshes tokens 30 seconds before expiration. - Code showing the fix: The
token_providerlambda inget_sdk_configguarantees a fresh token for each request cycle.
Error: HTTP 403 Forbidden
- What causes it: The OAuth client lacks the required scope for the endpoint.
- How to fix it: Add the missing scope to the
scopeparameter in the token request. Verify the client role hasrouting:queue:read,routing:agent:read,analytics:query,webhooks:write, androuting:conversation:writepermissions. - Code showing the fix: Update the
scopestring inGenesysAuthManager.__init__and regenerate the token.
- What causes it: The Genesys Cloud rate limiter blocked the request due to high throughput.
- How to fix it: Implement exponential backoff. The
execute_atomic_dispatch_with_overflow_handlingfunction includes a retry loop withawait asyncio.sleep(2 ** attempt). - Code showing the fix: The retry block in Step 4 catches
429and delays subsequent attempts.
Error: HTTP 400 Bad Request
- What causes it: The dispatch payload contains invalid fields or violates Genesys Cloud schema constraints.
- How to fix it: Validate the
DispatchDirectiveagainst Pydantic models before submission. EnsurequeueIdexists andskillTagmatches the queue configuration. - Code showing the fix: The
validate_queue_constraintsandverify_agent_skills_and_wait_timefunctions reject malformed inputs before the atomic POST.
Error: Skill Matching Verification Failed
- What causes it: No available agent in the queue possesses the required skill tag, or the routing profile is misconfigured.
- How to fix it: Review agent routing profiles in the Genesys Cloud admin console. Ensure the skill tag in
dispatch_directive.skill_tagmatches the queue skill requirement or agent profile skills. - Code showing the fix: The
verify_agent_skills_and_wait_timepipeline explicitly checksqueue.skill_requirement.tagand member routing profiles.
