Processing Genesys Cloud EventBridge Payloads with AWS SQS and Lambda
You will configure a Genesys Cloud EventBridge subscription to stream real-time telephony, routing, and omnichannel events into an AWS SQS Standard queue, then process those messages using a Lambda function with explicit batching, retry logic, and dead-letter routing. When complete, you will have a decoupled, idempotent ingestion pipeline that survives Genesys Cloud backpressure, handles schema versioning, and scales to thousands of events per second without data loss or duplicate processing.
  • Genesys Cloud Licensing: CX 1.0 or higher. EventBridge (Event Streams) requires the Event Streams add-on or is included in CX 2.0/3.0 bundles. Verify via Administration > Settings > License Management.
  • Genesys Permissions: Integration > Event Streams > Edit, Integration > Webhooks > Edit, Integration > AWS SQS > Edit
  • OAuth Scopes: event-streams:read, event-streams:write, integration:read, integration:write
  • AWS IAM Roles & Policies: AWSLambdaBasicExecutionRole, AWSLambdaSQSQueueExecutionRole, custom policy granting sqs:SendMessage, sqs:ReceiveMessage, sqs:DeleteMessage, sqs:GetQueueAttributes, sqs:SetQueueAttributes, sqs:ChangeMessageVisibility
  • Lambda Execution Role: Must include AWSLambdaVPCAccessExecutionRole if the function requires VPC endpoints for DynamoDB or S3 deduplication. If Lambda requires outbound internet for downstream CRM APIs, attach AWSLambdaENIManagementAccess and provision NAT Gateway routes.
  • External Dependencies: AWS Account with billing enabled, VPC configuration (private subnets, route tables, security groups), DNS resolution for api.mypurecloud.com, *.amazonaws.com, and *.queue.amazonaws.com.
1. Provision the Genesys Cloud AWS SQS Destination
Genesys Cloud EventBridge does not push raw HTTP webhooks directly to your infrastructure in production deployments. You must register an AWS SQS destination through the Event Streams integration framework. This establishes a managed delivery channel with built-in retry logic, payload compression, and backpressure handling.
Execute the following API call to register the destination. Replace placeholder values with your AWS account identifiers and queue ARN.
HTTP Method: POST
Endpoint: https://api.mypurecloud.com/api/v2/integrations/aws-sqs
Headers: Authorization: Bearer <ACCESS_TOKEN>, Content-Type: application/json
  "name": "prod-cc-aws-sqs-ingestion",
  "description": "Primary ingestion queue for Genesys EventBridge routing and telephony events",
  "awsAccountId": "123456789012",
  "awsRegion": "us-east-1",
  "queueArn": "arn:aws:sqs:us-east-1:123456789012:prod-cc-eventbridge-ingestion",
  "authenticationType": "IAM_ROLE",
  "roleArn": "arn:aws:iam::123456789012:role/GenesysCloud-SQS-Writer",
  "enableCompression": true,
  "maxRetries": 5,
  "retryIntervalSeconds": 60
The Trap: Configuring the destination with IAM User access keys instead of a cross-account IAM Role. Genesys Cloud validates destination health via periodic test messages. If you use static access keys, you inherit credential rotation risk, lack granular audit trails, and violate AWS security best practices. More critically, if your SQS queue resides in a private VPC without a VPC Endpoint for SQS, Genesys Cloud health checks will fail with 503 Service Unavailable, causing the subscription to enter a DISABLED state without explicit notification.
Architectural Reasoning: We use IAM_ROLE authentication with a dedicated cross-account role because Genesys Cloud assumes the role via AWS Security Token Service (STS). This provides temporary credentials, eliminates key management overhead, and allows you to enforce least-privilege policies on the destination queue. Enabling compression reduces payload size by approximately 60 percent for JSON event streams, lowering AWS data transfer costs and improving queue throughput. The maxRetries and retryIntervalSeconds parameters control Genesys-side backoff before it abandons delivery and routes the event to its internal dead-letter store.
After destination creation, register the event subscription:
HTTP Method: POST
Endpoint: https://api.mypurecloud.com/api/v2/event-streams/subscriptions
  "name": "prod-routing-telephony-sub",
  "description": "Captures routing queue member status, conversation analytics, and telephony state changes",
  "destinationId": "<DESTINATION_ID_FROM_PREVIOUS_STEP>",
  "eventTypes": [
    "routing.queue.member.status.changed",
    "routing.interaction.analyzed",
    "telephony.call.created",
    "telephony.call.completed"
  "includeMetadata": true,
  "enabled": true
2. Configure the SQS Standard Queue with Dead-Letter Routing
The queue must be provisioned to handle bursty CCaaS traffic patterns. Contact centers experience predictable spikes during shift changes, campaign launches, and holiday routing overrides. A Standard queue provides maximum throughput and relaxed ordering guarantees, which aligns with event stream processing where eventual consistency is acceptable.
Execute the queue creation via AWS CLI or the SQS API. The following configuration establishes retention, visibility, and dead-letter routing.
aws sqs create-queue \
  --queue-name prod-cc-eventbridge-ingestion \
  --attributes '{
    "VisibilityTimeout": "120",
    "MessageRetentionPeriod": "604800",
    "ReceiveMessageWaitTimeSeconds": "20",
    "DelaySeconds": "0",
    "MaximumMessageSize": "262144",
    "RedrivePolicy": "{\"deadLetterTargetArn\":\"arn:aws:sqs:us-east-1:123456789012:prod-cc-eventbridge-dlq\",\"maxReceiveCount\":\"3\"}",
    "ContentBasedDeduplication": "false"
The Trap: Setting VisibilityTimeout lower than the maximum expected Lambda execution time. Genesys Cloud events often trigger downstream CRM updates, speech analytics ingestion, or WFM state synchronization. If your Lambda function requires 90 seconds to complete due to external API latency, but the queue visibility timeout is 60 seconds, the message becomes visible again, triggering a duplicate Lambda invocation. This causes double-processing, duplicate database writes, and cascading idempotency failures.
Architectural Reasoning: We set VisibilityTimeout to 120 seconds to accommodate Lambda cold starts, payload parsing, idempotency checks, and downstream API calls with retry logic. The ReceiveMessageWaitTimeSeconds of 20 enables long polling, reducing AWS Lambda invocation costs by batching messages into a single invocation rather than triggering empty invocations. The RedrivePolicy routes messages that fail three times to a dedicated DLQ. This isolates malformed payloads or transient downstream failures from blocking healthy event processing. We disable ContentBasedDeduplication because Standard queues do not support it, and deduplication responsibility shifts to the Lambda layer via deterministic event identifiers.
3. Author the Lambda Function for Batching and Idempotent Processing
The Lambda function must parse the SQS event envelope, extract Genesys Cloud event payloads, enforce idempotency, and route data to downstream systems. Genesys Cloud delivers events in a consistent envelope structure. Your function must handle the Records array, as SQS batches up to 10 messages per invocation.
Language: Node.js 18.x or Python 3.11+
Timeout: 120 seconds
Memory: 512 MB (adjust based on downstream API latency)
Concurrency: Reserved Concurrency set to match peak event throughput (calculate via events_per_second * batch_processing_time)
const { SQSClient, DeleteMessageCommand } = require("@aws-sdk/client-sqs");
const { DynamoDBClient } = require("@aws-sdk/client-dynamodb");
const { DynamoDBDocumentClient, PutCommand, GetCommand } = require("@aws-sdk/lib-dynamodb");
const QUEUE_URL = process.env.SQS_QUEUE_URL;
const DEDUP_TABLE = process.env.DEDUP_TABLE_NAME;
const sqs = new SQSClient({ region: process.env.AWS_REGION });
const ddb = DynamoDBDocumentClient.from(new DynamoDBClient({ region: process.env.AWS_REGION }));
exports.handler = async (event) => {
  const failures = [];
  for (const record of event.Records) {
    const messageId = record.messageId;
    let payload;
      payload = JSON.parse(record.body);
    } catch (e) {
      failures.push(messageId);
      continue;
    // Idempotency check using Genesys event timestamp + type + data hash
    const dedupKey = `${payload.event.type}_${payload.timestamp}_${payload.event.data.id}`;
    const dedupItem = await ddb.get({ TableName: DEDUP_TABLE, Key: { eventId: dedupKey } });
    if (dedupItem.Item) {
      // Already processed, acknowledge success
      continue;
      // Downstream processing logic
      await processGenesysEvent(payload);
      // Mark as processed
      await ddb.put({
        Item: { eventId: dedupKey, processedAt: new Date().toISOString() }
    } catch (e) {
      console.error(`Processing failed for messageId ${messageId}:`, e.message);
  // Report partial batch failures for granular retry
  if (failures.length > 0) {
    return { batchItemFailures: failures.map(id => ({ itemId: id })) };
  return {};
async function processGenesysEvent(eventData) {
  // Implement routing logic, CRM updates, or analytics ingestion here
  console.log(`Routing event: ${eventData.event.type}`);
The Trap: Returning a generic success response when any single message in the batch fails. SQS event source mapping interprets an empty response or undefined as full batch success. If one message contains a malformed JSON payload or triggers a downstream 5xx error, the entire batch of 10 messages is deleted from the queue. You lose nine healthy events permanently.
Architectural Reasoning: We implement partial batch failure reporting via batchItemFailures. This tells SQS to delete only the successfully processed messages and retain the failed ones for retry. Combined with DynamoDB idempotency keys, this pattern guarantees exactly-once processing semantics despite SQS best-effort delivery and Lambda retry behavior. The deduplication key combines event type, timestamp, and internal ID to prevent duplicate processing when visibility timeouts expire or Lambda retries occur. We store deduplication state in DynamoDB because it provides single-digit millisecond latency and scales horizontally without connection pooling overhead.
4. Establish the Event Source Mapping with Partial Batch Failure Handling
The event source mapping connects SQS to Lambda. Configuration parameters directly control throughput, retry behavior, and cost efficiency. Misconfiguration here causes either throttling or unbounded retry storms.
Execute the following AWS CLI command to create the mapping:
aws lambda create-event-source-mapping \
  --function-name prod-cc-eventbridge-processor \
  --event-source-arn arn:aws:sqs:us-east-1:123456789012:prod-cc-eventbridge-ingestion \
  --batch-size 10 \
  --maximum-batching-window-seconds 5 \
  --batching-strategy PARTIAL_BATCH_RESPONSE \
  --maximum-concurrency 50 \
  --enabled true
The Trap: Setting maximum-concurrency to UNLIMITED or a value higher than your downstream systems can handle. Genesys Cloud event volumes can spike to 10,000 events per minute during campaign launches. If Lambda scales to 500 concurrent instances without downstream rate limiting, you will trigger API throttling on your CRM, WFM, or analytics endpoints. The failures will route to the DLQ, requiring manual intervention and data reconciliation.
Architectural Reasoning: We set batch-size to 10 to align with SQS maximum batch limits and optimize Lambda invocation costs. The maximum-batching-window-seconds of 5 allows SQS to accumulate messages before triggering Lambda, smoothing out bursty traffic patterns. PARTIAL_BATCH_RESPONSE enables granular retry handling, which is mandatory for production CCaaS pipelines. maximum-concurrency of 50 restricts parallel Lambda executions to a predictable level, preventing downstream API exhaustion. You must configure API rate limiting or request queuing on your downstream services to match this concurrency ceiling. If your downstream system supports bulk APIs, increase batch-size to 10 and adjust concurrency accordingly.
Edge Case 1: Visibility Timeout Exhaustion During Downstream API Latency
  • Failure Condition: Lambda invocations consistently time out or return partial batch failures. SQS visibility timeout expires, causing duplicate processing. DLQ receives messages with MaxReceivesExceeded errors.
  • Root Cause: Downstream CRM or WFM API introduces variable latency during peak hours. Lambda execution exceeds the 120-second visibility timeout. SQS makes the message visible again, triggering a second Lambda invocation. The idempotency check catches duplicates, but increases DynamoDB read capacity consumption and introduces processing lag.
  • Solution: Implement dynamic visibility timeout extension within Lambda using ChangeMessageVisibility API calls before long-running operations. Alternatively, offload heavy downstream processing to an async step function or secondary queue. Increase queue visibility timeout to 180 seconds if downstream SLAs cannot be guaranteed. Monitor ApproximateAgeOfOldestMessage metric to detect backlog accumulation before timeout exhaustion occurs.
Edge Case 2: Genesys Event Schema Versioning and Payload Drift
  • Failure Condition: Lambda function begins rejecting valid events with JSON parsing error or undefined property access errors. Genesys Cloud subscription remains healthy, but downstream systems receive incomplete data.
  • Root Cause: Genesys Cloud releases platform updates that modify event payload structures. New fields are added, nested objects are restructured, or deprecated fields are removed. Your Lambda function assumes a static schema and crashes on unexpected structures.
  • Solution: Implement schema validation with graceful degradation. Use a library like ajv to validate payload structure against a versioned schema registry. Log schema mismatches to CloudWatch without throwing fatal errors. Route unknown or malformed payloads to a secondary validation queue for manual inspection. Subscribe to Genesys Cloud release notes and monitor the event-streams API changelog. Implement a feature flag system to toggle payload parsing logic without redeploying Lambda.
Edge Case 3: SQS 256KB Message Limit on Complex Omnichannel Events
  • Failure Condition: Genesys Cloud subscription reports delivery failures. AWS SQS logs MessageTooLarge errors. Lambda never receives specific event types.
  • Root Cause: Omnichannel events containing transcript data, attachment metadata, or extensive routing analytics exceed the 256KB SQS message size limit. Genesys Cloud compresses payloads, but complex chat or video sessions still breach the threshold after decompression.
  • Solution: Configure Genesys Cloud subscription to exclude large metadata fields when possible. For events that must contain full transcripts or attachments, implement a payload splitting strategy. Store large payloads in S3 with a pre-signed URL, then send only the reference object to SQS. Update Lambda to fetch S3 objects asynchronously. Alternatively, route large events to a dedicated high-capacity queue with separate processing logic. Monitor ApproximateNumberOfMessagesDelayed and NumberOfMessagesDeleted metrics to detect size-related failures early.
