Processing Genesys Cloud EventBridge Dead-Letter Queue Events with Python AWS Lambda
This tutorial builds an AWS Lambda function that consumes EventBridge dead-letter queue messages, parses failed Genesys Cloud interaction events, and safely retries the original payload. The implementation uses the Genesys Cloud Interactions API to reconstruct records, applies idempotent retry logic with exponential backoff, updates interaction custom attributes via PATCH requests to track retry state, and streams operational logs to CloudWatch. The code is written in Python 3.9+ using the requests and boto3 libraries.
- OAuth Client Type: Confidential client with
client_credentialsgrant type - Required OAuth Scopes:
interaction:read,interaction:write - API Version: Genesys Cloud Platform API v2
- Runtime: Python 3.9 or higher
- External Dependencies:
requests>=2.31.0,boto3>=1.28.0,pydantic>=2.5.0 - AWS Resources: SQS DLQ subscribed to EventBridge rule, DynamoDB table for idempotency tracking, IAM role with
logs:CreateLogGroup,logs:CreateLogStream,logs:PutLogEvents, anddynamodb:PutItempermissions
Genesys Cloud requires OAuth 2.0 client credentials for server-to-server authentication. The Lambda function must fetch a bearer token before calling the Interactions API. Token caching is critical because Lambda containers persist across invocations, and repeated token requests trigger rate limits.
import os
import requests
from typing import Optional
GENESYS_ORG_ID = os.environ.get("GENESYS_ORG_ID", "your-org-id")
GENESYS_CLIENT_ID = os.environ.get("GENESYS_CLIENT_ID")
GENESYS_CLIENT_SECRET = os.environ.get("GENESYS_CLIENT_SECRET")
TOKEN_URL = f"https://{GENESYS_ORG_ID}.mypurecloud.com/oauth/token"
# In-memory cache shared across Lambda invocations in the same container
_token_cache: dict = {"access_token": None, "expires_at": 0}
def get_genesys_token() -> str:
"""Fetches and caches an OAuth 2.0 bearer token from Genesys Cloud."""
now = time.time()
if _token_cache["access_token"] and now < _token_cache["expires_at"] - 60:
return _token_cache["access_token"]
payload = {
"client_id": GENESYS_CLIENT_ID,
"client_secret": GENESYS_CLIENT_SECRET,
"scope": "interaction:read interaction:write"
response = requests.post(TOKEN_URL, data=payload, headers=headers, timeout=15)
response.raise_for_status()
data = response.json()
_token_cache["access_token"] = data["access_token"]
_token_cache["expires_at"] = now + data["expires_in"]
The token request uses application/x-www-form-urlencoded encoding. The cache stores the token and expiration timestamp, subtracting sixty seconds to prevent boundary failures. The raise_for_status() call ensures immediate failure on 401 or 403 responses.
Step 1: Parse EventBridge Dead-Letter Queue Payloads
EventBridge routes failed events to an SQS dead-letter queue. Each SQS message contains a Message attribute that holds the original EventBridge event, error metadata, and delivery attempt history. The Lambda function must extract the interactionId and reconstruct the original Genesys event.
import json
import logging
from typing import Any
logger = logging.getLogger()
logger.setLevel(logging.INFO)
def parse_dlq_message(event: dict) -> list[dict[str, Any]]:
"""Extracts and parses EventBridge DLQ messages from an SQS trigger event."""
records = event.get("Records", [])
parsed_events = []
for record in records:
message_body = record.get("body", "{}")
event_data = json.loads(message_body)
# EventBridge DLQ wraps the original event in 'detail' or 'source'
original_event = event_data.get("detail", event_data)
interaction_id = original_event.get("interactionId")
if not interaction_id:
logger.warning("Missing interactionId in DLQ message, skipping.")
parsed_events.append({
"interactionId": interaction_id,
"original_event": original_event,
"event_id": record.get("messageId"),
"error_context": event_data.get("errorMessage", "Unknown EventBridge failure")
except json.JSONDecodeError as e:
logger.error("Failed to parse DLQ message body: %s", str(e))
return parsed_events
The parser handles malformed JSON gracefully and filters out messages lacking an interactionId. The messageId from SQS serves as a unique identifier for idempotency tracking.
Step 2: Reconstruct Interaction Records via Interactions API
Once the interactionId is extracted, the function calls GET /api/v2/interactions/{interactionId} to retrieve the full interaction record. This step validates that the interaction exists and provides the baseline data required for retry processing.
import requests
def fetch_interaction(interaction_id: str, token: str) -> dict:
"""Retrieves the full interaction record from Genesys Cloud."""
url = f"https://{GENESYS_ORG_ID}.mypurecloud.com/api/v2/interactions/{interaction_id}"
headers = {
response = requests.get(url, headers=headers, timeout=20)
if response.status_code == 404:
raise ValueError(f"Interaction {interaction_id} not found in Genesys Cloud.")
raise requests.exceptions.RetryError("Rate limit exceeded on Interactions API.")
return response.json()
Expected Response Structure:
"type": "voice",
"state": "completed",
"attributes": {
"system": {
"retryAttempt": 0,
"retryStatus": "none"
"participants": [],
"createdTime": "2024-01-15T10:30:00.000Z",
"updatedTime": "2024-01-15T10:35:00.000Z"
The response includes the interaction state, participant list, and custom attributes. The function raises specific exceptions for 404 and 429 status codes to enable targeted retry handling in the next step.
Step 3: Idempotent Retry Logic with Exponential Backoff and PATCH Updates
Production retry workflows require idempotency checks to prevent duplicate processing, exponential backoff to respect API rate limits, and attribute updates to track retry state. This step combines DynamoDB lookups, a backoff retry loop, and a PATCH request to /api/v2/interactions/{interactionId}.
import boto3
import random
dynamodb = boto3.resource("dynamodb")
IDEMPOTENCY_TABLE = dynamodb.Table(os.environ.get("IDEMPOTENCY_TABLE_NAME", "GenesysRetryIdempotency"))
def is_already_processed(event_id: str) -> bool:
"""Checks DynamoDB to prevent duplicate event processing."""
response = IDEMPOTENCY_TABLE.get_item(Key={"EventId": event_id})
return "Item" in response
logger.error("DynamoDB check failed: %s", str(e))
return False
def mark_as_processed(event_id: str) -> None:
"""Records successful processing in DynamoDB."""
IDEMPOTENCY_TABLE.put_item(Item={"EventId": event_id, "ProcessedAt": time.time()})
def update_interaction_retry_status(interaction_id: str, token: str, attempt: int, status: str) -> None:
"""Patches interaction custom attributes to track retry state."""
headers = {
payload = {
"attributes": {
"system": {
"retryAttempt": attempt,
"retryStatus": status
response = requests.patch(url, json=payload, headers=headers, timeout=20)
raise requests.exceptions.RetryError("Rate limit exceeded during PATCH.")
def exponential_backoff(retry_count: int, base_delay: float = 2.0, max_delay: float = 60.0) -> float:
"""Calculates delay with jitter for exponential backoff."""
delay = min(base_delay * (2 ** retry_count), max_delay)
jitter = random.uniform(0, delay * 0.1)
return delay + jitter
def retry_interaction(interaction_id: str, token: str, max_retries: int = 3) -> bool:
"""Executes idempotent retry logic with exponential backoff."""
for attempt in range(1, max_retries + 1):
update_interaction_retry_status(interaction_id, token, attempt, "retrying")
logger.info("Retry attempt %d/%d for interaction %s", attempt, max_retries, interaction_id)
# Simulate replay logic here (e.g., re-triggering webhook, reprocessing event)
# For this tutorial, we mark success after attribute update
update_interaction_retry_status(interaction_id, token, attempt, "replay_successful")
logger.info("Successfully replayed interaction %s on attempt %d", interaction_id, attempt)
return True
except requests.exceptions.RetryError:
delay = exponential_backoff(attempt - 1)
logger.warning("429 Rate limit hit. Waiting %.2f seconds before retry %d/%d", delay, attempt, max_retries)
time.sleep(delay)
if e.response.status_code == 500:
logger.warning("5xx server error. Waiting %.2f seconds before retry %d/%d", delay, attempt, max_retries)
time.sleep(delay)
else:
update_interaction_retry_status(interaction_id, token, attempt, "replay_failed")
logger.error("Non-retryable HTTP error on interaction %s: %s", interaction_id, str(e))
return False
logger.error("Unexpected error during retry: %s", str(e))
return False
update_interaction_retry_status(interaction_id, token, max_retries, "exhausted_retries")
logger.error("All retry attempts exhausted for interaction %s", interaction_id)
return False
The retry loop updates the system.retryAttempt and system.retryStatus attributes on each iteration. The PATCH request uses JSON merge patch semantics, which Genesys Cloud supports for interaction attributes. Exponential backoff includes jitter to prevent thundering herd scenarios when multiple Lambda instances wake simultaneously. DynamoDB ensures each SQS message ID processes exactly once.
The following module combines authentication, parsing, API reconstruction, idempotency, backoff, and CloudWatch logging into a single deployable Lambda handler.
import json
import os
import random
import logging
import requests
import boto3
# Configuration
IDEMPOTENCY_TABLE_NAME = os.environ.get("IDEMPOTENCY_TABLE_NAME", "GenesysRetryIdempotency")
# Global resources initialized outside handler for container reuse
IDEMPOTENCY_TABLE = dynamodb.Table(IDEMPOTENCY_TABLE_NAME)
now = time.time()
payload = {
raise ValueError(f"Interaction {interaction_id} not found.")
raise requests.exceptions.RetryError("Rate limit exceeded.")
payload = {"attributes": {"system": {"retryAttempt": attempt, "retryStatus": status}}}
def exponential_backoff(retry_count: int) -> float:
delay = min(2.0 * (2 ** retry_count), 60.0)
return delay + random.uniform(0, delay * 0.1)
def process_dlq_event(parsed_event: dict[str, Any], token: str) -> bool:
interaction_id = parsed_event["interactionId"]
event_id = parsed_event["event_id"]
if IDEMPOTENCY_TABLE.get_item(Key={"EventId": event_id}).get("Item"):
logger.info("Event %s already processed. Skipping.", event_id)
return True
interaction = fetch_interaction(interaction_id, token)
logger.info("Retrieved interaction %s. State: %s", interaction_id, interaction.get("state"))
logger.error("Failed to fetch interaction %s: %s", interaction_id, str(e))
return False
max_retries = 3
logger.info("Retry %d/%d for %s", attempt, max_retries, interaction_id)
# Insert actual replay logic here (e.g., re-publishing to target queue, re-triggering webhook)
logger.info("Successfully replayed interaction %s", interaction_id)
return True
logger.warning("429 Rate limit. Backing off %.2fs for %s", delay, interaction_id)
time.sleep(delay)
logger.warning("5xx error. Backing off %.2fs for %s", delay, interaction_id)
time.sleep(delay)
else:
logger.error("Non-retryable error for %s: %s", interaction_id, str(e))
return False
logger.error("Unexpected error for %s: %s", interaction_id, str(e))
return False
logger.error("Retries exhausted for %s", interaction_id)
return False
def lambda_handler(event: dict, context: Any) -> dict:
logger.info("Lambda triggered with %d records", len(event.get("Records", [])))
token = get_genesys_token()
parsed_events = []
for record in event.get("Records", []):
message_body = json.loads(record.get("body", "{}"))
original = message_body.get("detail", message_body)
interaction_id = original.get("interactionId")
if interaction_id:
"original_event": original,
"error_context": message_body.get("errorMessage", "Unknown")
logger.error("Failed to parse record: %s", str(e))
success_count = 0
fail_count = 0
for evt in parsed_events:
if process_dlq_event(evt, token):
success_count += 1
else:
fail_count += 1
logger.info("Processing complete. Success: %d, Failed: %d", success_count, fail_count)
return {"statusCode": 200, "body": json.dumps({"processed": success_count, "failed": fail_count})}
Deploy this code as a Python Lambda function with the environment variables GENESYS_ORG_ID, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, and IDEMPOTENCY_TABLE_NAME configured. Attach an SQS trigger pointing to the EventBridge dead-letter queue.
- Cause: OAuth token expired, invalid client credentials, or missing
scopeparameter. - Fix: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch a confidential client in the Genesys Cloud admin console. Ensure the token cache refreshes before expiration. Addscope: "interaction:read interaction:write"to the token request payload. - Code Fix: The
get_genesys_token()function already validates expiration and re-fetches when necessary. Add explicit logging around token acquisition to trace stale tokens.
Error: 403 Forbidden
- Cause: OAuth client lacks
interaction:readorinteraction:writescopes, or the client is restricted to specific orgs. - Fix: Navigate to the Genesys Cloud developer portal, select the OAuth client, and add the required scopes. Ensure the client is enabled for production use.
- Code Fix: Validate the
scopestring in the token request matches exactly:interaction:read interaction:write.
- Cause: Exceeding Genesys Cloud API rate limits during token requests, interaction fetches, or PATCH operations.
- Fix: Implement exponential backoff with jitter. The
exponential_backoff()function calculates delay based on retry count. Catchrequests.exceptions.RetryErrorand sleep before retrying. - Code Fix: The retry loop already catches 429 responses and applies backoff. Monitor CloudWatch logs for
Rate limitwarnings to tunebase_delayandmax_delay.
Error: 404 Not Found
- Cause: Interaction ID does not exist in the target Genesys Cloud org, or the event references a deleted record.
- Fix: Validate
interactionIdextraction logic. Ensure EventBridge events originate from the same org as the OAuth client. - Code Fix: The
fetch_interaction()function raises aValueErroron 404. The handler logs the failure and skips further retry attempts for that record.
Error: 5xx Internal Server Error
- Cause: Genesys Cloud backend transient failure or payload serialization mismatch.
- Fix: Retry with exponential backoff. Verify JSON payload structure matches the Interactions API PATCH schema.
- Code Fix: The retry loop catches 500 status codes and applies backoff. If failures persist, inspect the PATCH payload structure and ensure
attributes.systemmatches the interaction schema.
